627-W7W-220-012
627-W7W-220-012
    CONND-SUBPLUG7POSVERTSOLDER
627-W7W-220-012 数据手册
ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 48.00±0.25 ORIGINAL 1 33.30±0.25 25.20±0.25 2.84±0.25 2-#4-40UNC Threaded Standoffs 8.30±0.25 2.77 6.00 9.85 Materials and Finish • Insulator: PBT with Glass Fiber, UL94V-0, Black • Shell: Steel, Nickel Plated • Contact: Copper Alloy, with 2-Gold Flash Plating over Nickel • Watertight Frame: PBT with Glass Fiber, UL94V-0, Black • O-Ring: Silicone • Epoxy Sealant: Epoxy • DEGREE OF PROTECTION: IP67 AS PER IEC60529 Electrical Characteristics • • • • • • 21.10±0.25 Current Rating: Signal Contact: 5.0 A High Power Contact: 10.0 A - 14.0 A Dielectric Withstanding Voltage: 1000 V / 1 Min Insulation Resistance: 5000 Megohm Min. Signal Contact Resistance: 10 Milliohms Max. High Power Contact Resistance: 1.0 Milliohms Working Temperature: -55C to +105C Mounting Option 2- #4-40 UNC THREADED HOLE THIS SERIES FULLY CONFORMS TO THE EUROPEAN UNION DIRECTIVES 2002/95/EC COMPLIANT AND 2002/96/EC FOR RoHS COMPLIANCY. Contact Information 20- PC TAIL Power Combo Waterproof D-Sub Connector PLUG PART NUMBER: 627-W7W-220-012 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. 627-W7W Assembly DRAWN: R.STA.MONICA DATE: June.4/13 CHECKED: DATE: SCALE: NTS SHEET 1 OF DRAWING NUMBER 627-W7W Assembly 1 ISSUE 1 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: EDAC: 627-W7W-220-012
627-W7W-220-012 价格&库存
很抱歉,暂时无法提供与“627-W7W-220-012”相匹配的价格&库存,您可以联系我们找货
