DESCRIPTION: FEMALE // SOLDER CUP // STAMPED
D
0.109 [2.77]
0.236±0.006 [6.00]
(50 PIN DIMENSION)
0.240±0.006 [6.10]
SPECIFICATIONS:
MATERIALS:
SHELL: NICKEL OR TIN PLATED STEEL
INSULATOR: PBT +30% GF, UL 94V-0, BLACK
CONTACTS: COPPER ALLOY, GOLD PLATED
ELECTRICALS:
CURRENT RATING: 5 AMPS
CONTACT RESISTANCE: 15 mOHMS MAX
INSULTOR RESISTANCE: 1000 MOHMS MIN
VOLTAGE: 500V AC FOR 1 MINUTE
WORKING VOLTAGE: 250 VAC
TEMPERATURE: -50°C TO +100°C
[0.90±0.3]
A±0.014
B±0.004
0.166 [4.21]
±0.010
C±0.006
171-YYY-20YLYY1
F±0.010
E±0.010
Ø0.120 [3.05]
PIN #1
SERIES
POSITIONS
009
015
025
037
050
GENDER
2 = FEMALE
TERMINATION
0 = SOLDER CUP
SHELL PLATING
2 = TIN (NOT AVAILABLE FOR HW OPTIONS)
3 = NICKEL
HARDWARE OPTIONS
00 = NO HARDWARE
01 = .098" 4-40 CN (SOLDER SIDE)
02 = .236" 4-40 CN (SOLDER SIDE)
03 = .236" 4-40 CN (MATING SIDE)
05 = .237" 4-40 BOARD LOCK (.063" PCB)
91 = .237" 4-40 JACK SCREW / BOARD LOCK (.063" PCB)
PLATING OPTIONS
1 = GOLD FLASH
2 = 30u" GOLD MATING AREA // GF TAILS
0.429 ±0.010
[10.90]
0.161±0.010
[4.10]
DIMENSIONS (in/mm)
POS.
9
15
25
37
50
A
B
1.213
0.984
30.80
24.99
C
D
E
0.642
0.756
0.311
0.496
16.30
19.20
7.90
12.60
1.541
1.312
0.971
1.091
0.311
0.496
39.15
33.32
24.65
27.70
7.90
12.60
2.087
1.853
1.512
1.618
0.311
0.496
53.00
47.04
38.40
41.10
7.90
12.60
2.728
2.500
2.157
2.256
0.311
0.496
69.30
63.50
54.80
57.30
7.90
12.60
2.638
2.406
2.055
2.169
0.429
0.602
67.00
61.00
52.20
55.10
10.90
15.30
RoHS COMPLIANT
N
C
F
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
WILL ACCEPT 28-20 AWG CONDUCTORS
UNITS = INCHES [MM]
DRAWN:
J. KADEL
DATE:
07/24/2018
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
171-YYY-20YLYY1
15
DESCRIPTION: CLINCH NUT HARDWARE
TOLERANCE:
ALL DIMENSIONS ARE ±0.010
ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS
01X ..... 0.098" (SOLDER SIDE)
02X ..... 0.236" (SOLDER SIDE)
03X..... 0.236" (MATING SIDE)
0.279
0.141
0.279
0.098
0.236
0.236
05X ..... 0.237" (SOLDER SIDE)
91X ..... 0.237" (SOLDER SIDE)
0.234
0.280
0.506
0.063
0.237
RoHS COMPLIANT
N
C
NOTE: 4-40 FEMALE SCREW LOCK IS REMOVABLE
0.063
0.237
UNITS = INCHES
DRAWN:
J. KADEL
DATE:
07/24/2018
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
171-YYY-20YLYY1
15
很抱歉,暂时无法提供与“171-009-203L911”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 560+14.82842560+1.92205
