198-026-213L001
198-026-213L001
    NORCOMP
198-026-213L001 数据手册
DIMENSIONS: mm DESCRIPTION: VERTICAL - HIGH PROFILE - STAMPED ELECTRICAL: INSULATOR RESISTANCE: WORKING VOLTAGE: OPERATING TEMPERATURE: CONTACT RESISTANCE: CONTACT AMPERAGE: MATERIALS: CONTACTS: A ± 0.30 B ± 0.10 C ± 0.15 7.90 ± 0.15 SHELL INSULATOR 12.6 ± 0.3 1000 MΩ MIN. 250V -50°C TO +100°C 15 mΩ MAX. 5 AMPS BRASS GOLD FLASH IN MATING AREA TIN PLATING ON TAIL ENDS STEEL, NICKEL PLATED PBT, UL94-V0 5.8 ± 0.2 0.9 4.10 198-YYY-213LYY1 9.4 ± 0.3 SERIES POSITIONS 015 026 GENDER 2 = FEMALE TERMINATION 1 = VERTICAL SOLDER SHELL PLATING 3 = NICKEL HARDWARE OPTIONS 00 = NO HARDWARE 03 = .197" 4-40 HEX STANDOFF 55 = .161" 4-40 CLINCH NUT (BOARD SIDE) PLATING OPTIONS 1 = GOLD FLASH 3.6 ± 0.25 Ø0.7 ± 0.05 D ± 0.25 RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DO NOT SCALE FROM DRAWING DRAWN: P. JENKINS DATE: 09/15/2005 NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 198-YYY-213LYY1 2 DESCRIPTION: VERTICAL - HIGH PROFILE - STAMPED .984 CL .492 .656 .215 .145 .125 .055 .035 Ø 0.126 *MINIMUM 1.312 CL .385 .295 .205 .115 .335 .245 .155 .065 HOLE PATTERN SHOWN ARE FOR FEMALE .025 .156 .078 CL Ø 0.043 .010 .080 .100 .170 .190 * .020 .110 .200 .290 .380 15 POSITION N C .160 .250 .340 * UNITS = inch TYP. SUGGESTED SIZE MAY NOT BE SUITABLE FOR ALL APPLICATIONS 26 POSITION RoHS COMPLIANT THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. .070 UNITS = inches DO NOT SCALE FROM DRAWING DRAWN: P. JENKINS DATE: 09/15/2005 NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 198-YYY-213LYY1 2 DESCRIPTION: VERTICAL - HIGH PROFILE - STAMPED HARDWARE OPTIONS: 55 = #4-40 CLINCH NUT (BOARD SIDE) 03 = #4-40 HEX STANDOFF 5.00 4.0 4.0 RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DO NOT SCALE FROM DRAWING DRAWN: P. JENKINS DATE: 09/15/2005 NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 198-YYY-213LYY1 2
198-026-213L001 价格&库存
很抱歉,暂时无法提供与“198-026-213L001”相匹配的价格&库存,您可以联系我们找货
198-026-213L001
  • 50+56.7567650+7.36415
