DIMENSIONS: mm
DESCRIPTION: VERTICAL - HIGH PROFILE - STAMPED
ELECTRICAL:
INSULATOR RESISTANCE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
CONTACT RESISTANCE:
CONTACT AMPERAGE:
MATERIALS:
CONTACTS:
A ± 0.30
B ± 0.10
C ± 0.15
7.90 ± 0.15
SHELL
INSULATOR
12.6 ± 0.3
1000 MΩ MIN.
250V
-50°C TO +100°C
15 mΩ MAX.
5 AMPS
BRASS
GOLD FLASH IN MATING AREA
TIN PLATING ON TAIL ENDS
STEEL, NICKEL PLATED
PBT, UL94-V0
5.8 ± 0.2
0.9
4.10
198-YYY-213LYY1
9.4 ± 0.3
SERIES
POSITIONS
015
026
GENDER
2 = FEMALE
TERMINATION
1 = VERTICAL SOLDER
SHELL PLATING
3 = NICKEL
HARDWARE OPTIONS
00 = NO HARDWARE
03 = .197" 4-40 HEX STANDOFF
55 = .161" 4-40 CLINCH NUT (BOARD SIDE)
PLATING OPTIONS
1 = GOLD FLASH
3.6 ± 0.25
Ø0.7 ± 0.05
D ± 0.25
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = mm
DO NOT SCALE FROM DRAWING
DRAWN:
P. JENKINS
DATE:
09/15/2005
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
3
198-YYY-213LYY1
2
.984
CL
.492
.656
.215
.145
.125
.055
.035
Ø 0.126
*MINIMUM
1.312
CL
.385
.295
.205
.115
.335
.245
.155
.065
HOLE PATTERN SHOWN
ARE FOR FEMALE
.025
.156
.078
CL
Ø 0.043
.010
.080
.100
.170
.190
.020
.110
.200
.290
.380
15 POSITION
N
C
.160
.250
.340
UNITS = inch
TYP.
SUGGESTED SIZE
MAY NOT BE SUITABLE FOR ALL APPLICATIONS
26 POSITION
RoHS COMPLIANT
.070
UNITS = inches
DRAWN:
P. JENKINS
DATE:
09/15/2005
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
3
198-YYY-213LYY1
2
HARDWARE OPTIONS:
55 = #4-40 CLINCH NUT (BOARD SIDE)
03 = #4-40 HEX STANDOFF
5.00
4.0
4.0
RoHS COMPLIANT
N
C
UNITS = mm
DRAWN:
P. JENKINS
DATE:
09/15/2005
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
3
198-YYY-213LYY1
2
很抱歉,暂时无法提供与“198-026-213L551”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+40.2765950+5.22717
