09663525612
09663525612
    HARTING(浩亭)
    CONND-SUBRCPT25POSR/ASOLDER
09663525612 数据手册
Ergebnisseite der Teileliste Partlist 09 66 352 6611 D-Sub - S PCB connector gender Termination shell Number of contacts Row pitch Board fixing flange Performance level Material < > Other applications female connector, right angled Stamped solder pins tinned metal shell 25 way Row separation 2.54 mm with grounding board locks M3 Performance level 2 PBTP Note: Obligatory information about HARTING products can be obtained exclusively from the data sheets. The data sheet is up to date 2D files © Copyright 1999-2003 Harting KGaA and its licencors - Any suggestions and bug reports are welcome at: HARKIS@harting.com file:///F|/imaging/BITTING/CF_PROCESS/MANUAL/08262003/HART/TB_09663526611_BL05_R27960.html [October-07-2003 11:36:31 AM] Ergebnisseite der Teileliste Partlist 09 66 352 5612 D-Sub - S PCB connector gender Termination shell Number of contacts Row pitch Board fixing flange Performance level Material < > Other applications female connector, right angled Stamped solder pins tinned metal shell 25 way Row separation 2.54 mm with grounding board locks UNC4-40 Performance level S4 PBTP Note: Obligatory information about HARTING products can be obtained exclusively from the data sheets. The data sheet is up to date 2D files © Copyright 1999-2003 Harting KGaA and its licencors - Any suggestions and bug reports are welcome at: HARKIS@harting.com file:///F|/imaging/BITTING/CF_PROCESS/MANUAL/08262003/HART/TB_09663525612_BL05_R27960.html [October-07-2003 11:36:32 AM] Ergebnisseite der Teileliste Partlist 09 66 352 5611 D-Sub - S PCB connector < gender Termination shell Number of contacts Row pitch Board fixing flange Performance level Material > Other applications female connector, right angled Stamped solder pins tinned metal shell 25 way Row separation 2.54 mm with grounding board locks M3 Performance level S4 PBTP Note: Obligatory information about HARTING products can be obtained exclusively from the data sheets. Data sheets are available in following formats 2D files Typenblatt im PDF Typenblatt im DXF © Copyright 1999-2003 Harting KGaA and its licencors - Any suggestions and bug reports are welcome at: HARKIS@harting.com file:///F|/imaging/BITTING/CF_PROCESS/MANUA...262003/HART/TB_0966352x61x_BL05_R27960.HTML [October-07-2003 11:36:33 AM] Ergebnisseite der Teileliste Partlist 09 66 352 6612 D-Sub - S PCB connector gender Termination shell Number of contacts Row pitch Board fixing flange Performance level Material < > Other applications female connector, right angled Stamped solder pins tinned metal shell 25 way Row separation 2.54 mm with grounding board locks UNC4-40 Performance level 2 PBTP Note: Obligatory information about HARTING products can be obtained exclusively from the data sheets. The data sheet is up to date 2D files © Copyright 1999-2003 Harting KGaA and its licencors - Any suggestions and bug reports are welcome at: HARKIS@harting.com file:///F|/imaging/BITTING/CF_PROCESS/MANUAL/08262003/HART/TB_09663526612_BL05_R27960.html [October-07-2003 11:36:35 AM] Ergebnisseite der Teileliste Partlist 09 66 352 7611 D-Sub - S PCB connector gender Termination shell Number of contacts Row pitch Board fixing flange Performance level Material < > Other applications female connector, right angled Stamped solder pins tinned metal shell 25 way Row separation 2.54 mm with grounding board locks M3 Performance level 3 PBTP Note: Obligatory information about HARTING products can be obtained exclusively from the data sheets. The data sheet is up to date 2D files © Copyright 1999-2003 Harting KGaA and its licencors - Any suggestions and bug reports are welcome at: HARKIS@harting.com file:///F|/imaging/BITTING/CF_PROCESS/MANUAL/08262003/HART/TB_09663527611_BL05_R27960.html [October-07-2003 11:36:36 AM] Ergebnisseite der Teileliste Partlist 09 66 352 7612 D-Sub - S PCB connector gender Termination shell Number of contacts Row pitch Board fixing flange Performance level Material < > Other applications female connector, right angled Stamped solder pins tinned metal shell 25 way Row separation 2.54 mm with grounding board locks UNC4-40 Performance level 3 PBTP Note: Obligatory information about HARTING products can be obtained exclusively from the data sheets. The data sheet is up to date 2D files © Copyright 1999-2003 Harting KGaA and its licencors - Any suggestions and bug reports are welcome at: HARKIS@harting.com file:///F|/imaging/BITTING/CF_PROCESS/MANUAL/08262003/HART/TB_09663527612_BL05_R27960.html [October-07-2003 11:36:37 AM] Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: HARTING: 09663525611 09663525612
09663525612 价格&库存
很抱歉,暂时无法提供与“09663525612”相匹配的价格&库存,您可以联系我们找货
