684M11W1103L461
684M11W1103L461
    NORCOMP
    弯插
    11(10 + 1 电源) 位 D-Sub,组合式 插头,公引脚 连接器, 通孔,直角 焊接
684M11W1103L461 数据手册
DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED 5 GΩ MIN. 250V -55°C TO +125°C 1.543 [39.20] 1.0 mΩ MAX. 10 mΩ MAX. 1.311 [33.30] SEE P/N KEY 5 AMPS 0.994 [25.25] 1 2 3 7 A1 8 4 5 4.5 Kg MAX. 0.3 Kg MIN. 6 9 10 COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED 0.112 [2.84] 230°C PROCESS TEMP. 0.327 [8.30] NICKEL PLATED STEEL NICKEL PLATED STEEL NICKEL PLATED BRASS 0.492 [12.50] 10° 0.031 [0.80] 0.240 [6.10] 684M11W1103LYYY 46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS 62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS SEE SHEET 2 FOR CONTACT & BRACKET DIMENSION DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 1 = GOLD FLASH UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 04/19/2013 NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 684M11W1103L461 3 DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED RIGHT ANGLE BRACKET DIMENSIONS(in/mm) 1.311 OPTION #4-40 INSERT S P 0.146 0.185 3.70 4.70 0.087 0.087 2.22 2.22 46 0.218 62 0.164 Ø 0.165 1-PLACE 0.420 [10.67] Ø 0.043 10-PLACES 0.520 Ø 0.130 2-PLACES 0.420 0.470 0.370 SIGNAL CONTACTS 0.109 POWER CONTACTS PCB EDGE Ø 0.026 [Ø 0.65] S Ø 0.148 [Ø 3.75] P 0.370 [9.40] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 04/19/2013 0.520 [13.20] NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 684M11W1103L461 3
684M11W1103L461 价格&库存
很抱歉,暂时无法提供与“684M11W1103L461”相匹配的价格&库存,您可以联系我们找货
684M11W1103L461
