989-050-130L121
989-050-130L121
    NORCOMP
    CONND-TYPEPLUG50POSSTR
989-050-130L121 数据手册
SCSI 2 & 3 DIE CAST WITH THUMBSCREWS SPECIFICATIONS: MATERIALS: C D BACK SHELL: ZINC PLATED NICKEL OVER COPPER JACKSCREWS: STEEL, NICKEL PLATED OVER COPPER SCREWS: CLAMP: STEEL, NICKEL PLATED OVER COPPER STEEL, NICKEL PLATED DIMENSIONS A No. OF PINS A B C D E 50 1.252 [31.80] 2.98 [53.30] 0.461 [11.70] 0.535 [13.60] 1.520 [38.60] 68 1.673 [42.50] 2.516 [63.90] 0.465 [11.80] 0.543 [13.80] 1.508 [38.30] ALL TOLERANCES = 0.012 [0.30] KIT INCLUDES: E 19.80mm (1) (2) (2) (1) (2) (2) MALE CONNECTOR - SOLDER CUP METAL SHELL HALVES THUMBSCREWS (2-56 THREADS) STRAIN RELIEF CLAMP STRAIN RELIEF SCREWS HOUSING SCREWS BACK SHELL KIT PART NUMBER 989-YYY-130L121 SERIES POSITIONS 050 068 CONTACTS SOLDER MATERIAL 30 = DIE CAST (NICKEL) RoHS COMPLIANT L = LOW TEMP. PROCESS COLOR 12 = METAL(IZED) PUT-UP 1 = KIT 1.331 [33.80] B STRAIN RELIEF CLAMP RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: N. KOVALSKY DATE: 04/18/2008 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 989-YYY-130L121 4 DESCRIPTION: CONNECTOR FOR 988 SERIES BACK SHELL KIT SPECIFICATIONS: MATERIALS: PIN 1 HOUSING: THERMOPLASTIC, BLACK PBT UL94V-0 CONTACTS: PHOSPHOR BRONZE A ±0.012 FRONT SHELL: 5u'' GOLD MATING AREA 100u'' MIN TIN SOLDER AREA STEEL, NICKEL PLATED OVER COPPER B ±0.009 ELECTRICAL: RATED CURRENT: DIELECTRIC WITHSTANDING: INSULATION RESISTANCE: CONTACT RESISTANCE: 500 MOhms MIN. 35 mOhms MAX. ENVIRONMENT: OPERATING TEMPERATURE: -40°C TO +85°C MAX RECOMMEND WIRE AWG: 22 AWG 0.050 [1.27] C ±0.012 0.5A 500VAC DIMENSIONS 0.225 [5.70] No. OF PINS A B C 50 1.545 [39.30] 1.372 [34.85] 0.366 [9.30] 68 1.996 [50.70] 1.825 [46.35] 0.366 [9.30] 0.197±0.006 [5.00] 0.650±0.012 [16.50] 0.0354 [0.9] REF ONLY RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: N. KOVALSKY DATE: 04/18/2008 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 989-YYY-130L121 4 DESCRIPTION: PIN CONFIGURATION FOR 988 SERIES BACK SHELL KIT 50 POSITION 68 POSITION PIN 25 PIN 1 PIN 50 PIN 26 PIN 26 PIN 27 PIN 50 PIN 49 PIN 24 PIN 2 PIN 1 PIN 25 RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. PIN 34 PIN 1 PIN 36 N. KOVALSKY DATE: 04/18/2008 PIN 68 PIN 67 PIN 35 PIN 34 PIN 2 PIN 1 PIN 33 UNITS = inches [mm] DRAWN: PIN 68 PIN 35 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 989-YYY-130L121 4
989-050-130L121 价格&库存
很抱歉,暂时无法提供与“989-050-130L121”相匹配的价格&库存,您可以联系我们找货
