684M21W1103L461
684M21W1103L461
    NORCOMP
    弯插
    CONN D-SUB PLUG 21POS R/A SOLDER
684M21W1103L461 数据手册
DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED 2.088 [53.05] 5 GΩ MIN. 250V -55°C TO +125°C 1.852 [47.05] 1.0 mΩ MAX. 10 mΩ MAX. SEE P/N KEY 5 AMPS 1.533 [38.95] 4.5 Kg MAX. 0.3 Kg MIN. 1 2 3 4 5 A1 6 7 8 9 10 0.327 [8.30] 11 12 13 14 15 0.492 [12.50] COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED 16 17 18 19 20 230°C PROCESS TEMP. NICKEL PLATED STEEL NICKEL PLATED STEEL NICKEL PLATED BRASS 10° 0.240 [6.10] 0.031 [0.80] 684M21W1103LYYY 46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS 62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS SEE SHEET 2 FOR CONTACT & BRACKET DIMENSION DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 1 = GOLD FLASH UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 07/22/2013 NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 684M21W1103L461 4 DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED 1.852 RIGHT ANGLE BRACKET 0.652 0.598 DIMENSIONS(in/mm) 0.544 OPTION #4-40 INSERT 0.489 0.435 S P 0.146 0.185 46 0.381 3.70 4.70 0.087 0.087 2.22 2.22 62 0.326 Ø0.165 1-PLACE 0.272 0.420 [10.67] 0.218 Ø0.130 2-PLACES 0.370 0.420 SIGNAL CONTACTS 0.470 0.520 0.163 POWER CONTACTS Ø0.043 20-PLACES PCB EDGE Ø 0.026 [Ø 0.65] S Ø 0.148 [Ø 3.75] P 0.370 [9.40] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 07/22/2013 0.520 [13.20] NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 684M21W1103L461 4
684M21W1103L461 价格&库存
很抱歉,暂时无法提供与“684M21W1103L461”相匹配的价格&库存,您可以联系我们找货
