DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED
5 GΩ MIN.
250V
-55°C TO +125°C
1.0 mΩ MAX.
10 mΩ MAX.
SEE P/N KEY
5 AMPS
4.5 Kg MAX.
0.3 Kg MIN.
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
230°C PROCESS TEMP.
NICKEL PLATED STEEL
NICKEL PLATED STEEL
NICKEL PLATED BRASS
684M9W4103LYYY
46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS
62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS
SEE SHEET 2
FOR CONTACT & BRACKET DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
1 = GOLD FLASH
UNITS = inches [mm]
DO NOT SCALE FROM DRAWING
DRAWN:
M. SIGMON
DATE:
08/20/2012
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
684M9W4103L461
3
RIGHT ANGLE BRACKET
1.852
DIMENSIONS(in/mm)
0.571
0.571
OPTION
#4-40 INSERT
0.265
S
P
0.146
0.185
3.70
4.70
0.087
0.087
2.22
2.22
46
0.307
62
0.218
0.420 [10.67]
SIGNAL CONTACTS
POWER CONTACTS
0.109
TYP
0.164
Ø 0.026 [Ø 0.65]
S
Ø 0.148 [Ø 3.75]
P
0.370 [9.40]
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
08/20/2012
0.520 [13.20]
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
684M9W4103L461
3
很抱歉,暂时无法提供与“684M9W4103L461”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+181.867101+23.44618
