681S9W4203L001
681S9W4203L001
    NORCOMP
    9(5 + 4 电源) 位 D-Sub,组合式 插座,母形插口 连接器, 面板安装,通孔 焊接
681S9W4203L001 数据手册
DESCRIPTION: POWER / SIGNAL - VERTICAL BOARD - FEMALE - IP67 SPECIFICATIONS: ELECTRICAL: INSULATION RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: SIGNAL CONTACT RESISTANCE: POWER PINS: SIGNAL PINS: 2.088 [53.05] ±0.010 [±0.25] 1.852 [47.05] ±0.010 [±0.25] Ø 0.120 [Ø 3.05] 2-PLACES 1.512 [38.40] ±0.010 [±0.25] A4 2 A3 1 A2 A1 5 GΩ MIN. 1000 VAC FOR 1 MIN 250V -55°C TO +125°C 1.0 mΩ MAX. 10 mΩ MAX. 40 AMPS 5 AMPS MECHANICAL: CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 4.5 Kg MAX. 0.3 Kg MIN. MATERIALS: CONTACTS: INSULATOR: COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED SEAL: SHELL: HARDWARE: F08 FLEXIBLE ADHESIVE NICKEL PLATED STEEL NICKEL PLATED BRASS 230°C PROCESS TEMP. 5 4 3 10° 0.311 [7.90] ±0.010 [±0.25] 681S9W4203LYYY 0.492 [12.50] ±0.010 [±0.25] 0 = 40 AMP 0.228 [5.80] 0 = NO HARDWARE 4 = 0.237" BOARDLOCK PCB SIDE 0.421 [10.70] 1 = GOLD FLASH 0.031 [0.80] ±0.010 [±0.25] MEETS IP67 STANDARDS (SEE PAGE 2 FOR SEALING DETAILS) SEE SHEET 2 FOR DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES [MM] DRAWN: M. SIGMON DATE: 06/11/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 4 681S9W4203LYYY 2 DESCRIPTION: 681 SERIES CONTACTS NOTE: SIGNAL AND POWER CONTACTS COME PRE-LOADED INTO INSULATORS Ø 0.026 [0.65] 0.112 [2.84] A 0.22 ± .012 [5.60 ± 0.30] SIGNAL CONTACTS A FRONT SEAL APPLIED BETWEEN FRONT INSULATOR AND FRONT METAL SHELL MIDDLE SEAL APPLIED BETWEEN FRONT INSULATOR AND BACK INSULATOR 0.209 ± 0.012 [5.30 ± 0.30] 0.031 ± 0.012 [0.80 ± 0.30] DETAIL A-A SHOWN FOR REFERENCE ONLY Ø 0.148 [3.75] 0.059 ± 0.012 [1.50 ± 0.30] POWER CONTACTS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES [MM] DRAWN: M. SIGMON DATE: 06/11/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 4 681S9W4203LYYY 2 DESCRIPTION: PCB LAYOUT 1.852 0.571 0.571 0.307 0.326 0.218 Ø 0.130 2-PLACES 0.112 Ø 0.043 10-PLACES Ø 0.165 3-PLACES 0.163 0.272 0.381 RECOMMENDED PCB LAYOUT RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES DRAWN: M. SIGMON DATE: 06/11/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 3 4 681S9W4203LYYY 2 DESCRIPTION: CLINCH NUT HARDWARE TOLERANCE: ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS 0 ..... NO HARDWARE RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 4 ..... 0.237" PCB SIDE UNITS = INCHES [MM] DRAWN: M. SIGMON DATE: 06/11/2013 ALL DIMENSIONS ARE ±0.010 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 4 4 681S9W4203LYYY 2
681S9W4203L001 价格&库存
很抱歉,暂时无法提供与“681S9W4203L001”相匹配的价格&库存,您可以联系我们找货
