09693009176
09693009176
    HARTING(浩亭)
09693009176 数据手册
Extract from the online catalog     UKH 95-PE/N Order No.: 3009176 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=3009176   Ground modular terminal block, Screw connection, Cross section:  25 mm² - 95 mm², AWG: 4 - 3/0, Width: 50 mm, Color: green-yellow, Mounting type: NS 35/15, NS 32   Product notes WEEE/RoHS-compliant since: 09/01/2005 Commercial data GTIN (EAN) 4 017918 091705 sales group A020 Pack 5 pcs. Customs tariff 85369010 Catalog page information Page 231 (CL-2005) http:// www.download.phoenixcontact.com Please note that the data given here has been taken from the online catalog. For comprehensive information and data, please refer to the user documentation. The General Terms and Conditions of Use apply to Internet downloads. Technical data General Note Screws with hexagonal socket Number of levels 1 Number of connections 2 PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 1 / 5 Feb 25, 2011 UKH 95-PE/N Order No.: 3009176 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=3009176 Color green-yellow Insulating material PA Inflammability class acc. to UL 94 V0 Dimensions Width 50 mm Length 83 mm Height NS 35/7.5 99 mm Height NS 35/15 96.5 mm Technical data Maximum load current 232 A (with 95 mm conductor cross section) Rated surge voltage 8 kV Pollution degree 3 Surge voltage category III Insulating material group I Nominal current IN 232 A Nominal voltage UN 1000 V 2 Connection data Conductor cross section solid min. 25 mm² Conductor cross section solid max. 95 mm² Conductor cross section stranded min. 35 mm² Conductor cross section stranded max. 95 mm² Conductor cross section AWG/kcmil min. 4 Conductor cross section AWG/kcmil max 3/0 Conductor cross section stranded, with ferrule without plastic sleeve min. 35 mm² Conductor cross section stranded, with ferrule without plastic sleeve max. 95 mm² 2 conductors with same cross section, solid min. 25 mm² 2 conductors with same cross section, solid max. 35 mm² 2 conductors with same cross section, stranded min. 25 mm² 2 conductors with same cross section, stranded max. 35 mm² 2 conductors with same cross section, stranded, ferrules without plastic sleeve, min. 16 mm² PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 2 / 5 Feb 25, 2011 UKH 95-PE/N Order No.: 3009176 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=3009176 2 conductors with same cross section, stranded, ferrules without plastic sleeve, max. 35 mm² 2 conductors with same cross section, stranded, TWIN ferrules with plastic sleeve, min. 35 mm² 2 conductors with same cross section, stranded, TWIN ferrules with plastic sleeve, max. 95 mm² Type of connection Screw connection Stripping length 33 mm Screw thread M8 Tightening torque, min 15 Nm Tightening torque max 20 Nm Accessories Item Designation Description 1201028 NS 32 AL UNPERF 2000MM G rail 32 mm (NS 32) 1201280 NS 32 CU/120QMM UNPERF 2000MM G-profile DIN rail, deep-drawn, material: Copper, unperforated, height 15 mm, width 32 mm, length 2 m 1201358 NS 32 CU/35QMM UNPERF 2000MM G-profile DIN rail, material: Copper, unperforated, height 15 mm, width 32 mm, length 2 m 1201002 NS 32 PERF 2000MM G-profile DIN rail, material: Steel, perforated, height 15 mm, width 32 mm, length 2 m 1201015 NS 32 UNPERF 2000MM G-profile DIN rail, material: Steel, unperforated, height 15 mm, width 32 mm, length 2 m 1201895 NS 35/15 CU UNPERF 2000MM DIN rail, material: Copper, unperforated, 1.5 mm thick, height 15 mm, width 35 mm, length: 2 m 1201730 NS 35/15 PERF 2000MM DIN rail, material: Steel, perforated, height 15 mm, width 35 mm, length: 2 m 1201714 NS 35/15 UNPERF 2000MM DIN rail, material: Steel, unperforated, height 15 mm, width 35 mm, length: 2 m ZB10:SO/CMS Zack strip, 10-section, divisible, special printing, marking according to customer requirements Assembly Marking 1050525 PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 3 / 5 Feb 25, 2011 UKH 95-PE/N Order No.: 3009176 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=3009176 Diagrams/Drawings Dimensioned drawing PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 4 / 5 Feb 25, 2011 UKH 95-PE/N Order No.: 3009176 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=3009176 Address PHOENIX CONTACT Deutschland GmbH Flachsmarktstr. 8 32825 Blomberg,Germany Phone +49 5235 3 12000 Fax +49 5235 3 41200 http://www.phoenixcontact.de © 2011 Phoenix Contact Technical modifications reserved; PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 5 / 5 Feb 25, 2011
09693009176 价格&库存
很抱歉,暂时无法提供与“09693009176”相匹配的价格&库存,您可以联系我们找货
