684S13W6103L461
684S13W6103L461
    NORCOMP
    弯插
    13(7 + 6 电源) 位 D-Sub,组合式 插头,公引脚 连接器, 自由悬挂 焊接
684S13W6103L461 数据手册
DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67 ELECTRICAL: INSULATOR RESISTANCE: WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: POWER CONTACT AMPERAGE: 5 GΩ MIN. 250V -55°C TO +125°C 1.0 mΩ MAX. SEE P/N KEY MECHANICAL: 4.5 Kg MAX. CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 0.3 Kg MIN. MATERIALS: CONTACTS: INSULATOR: COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED SHELL: BRACKET: BOARD LOCK: SEAL: NICKEL PLATED STEEL NICKEL PLATED STEEL NICKEL PLATED BRASS F08 FLEXIBLE ADHESIVE 230°C PROCESS TEMP. MEETS IP67 STANDARDS (SEE PAGE 3 FOR SEALING DETAILS) 684S13W6103LYYY 00 = 40 AMP POWER // NO BRACKET // STANDARD PCB TAILS 46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS 62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS SEE SHEET 2 FOR CONTACT & BRACKET DIMENSION DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 1 = GOLD FLASH UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 09/07/2012 NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 684S13W6103L461 2 DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67 RIGHT ANGLE BRACKET DIMENSIONS(in/mm) OPTION #4-40 INSERT S P 0.146 0.185 46 3.70 4.70 0.087 0.087 2.22 2.22 62 0.420 [10.67] SIGNAL CONTACTS POWER CONTACTS P.C.B. EDGE Ø 0.026 [Ø 0.65] PCB LAYOUT S Ø 0.148 [Ø 3.75] P 0.370 [9.40] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 09/07/2012 0.520 [13.20] NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 684S13W6103L461 2 DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67 A A FRONT SEAL APPLIED OVER INSULATOR AND BETWEEN FRONT & REAR SHELLS DETAIL A-A SHOWN FOR REFERENCE ONLY RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 09/07/2012 NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 684S13W6103L461 2
684S13W6103L461 价格&库存
很抱歉,暂时无法提供与“684S13W6103L461”相匹配的价格&库存,您可以联系我们找货
