DEMA9S
DEMA9S
    CINCH
    DSUB9FCRIMPG30ZINC
DEMA9S 数据手册
Catalog No. C-865 CIN::APSE ® High Speed Interconnect Technology CIN::APSE ® FEATURES High-Speed Interconnect Technology ■ High signal speed capability enabling frequencies greater than 20 GHz. ■ Z-Axis, solderless, compression mount interconnect system. ■ Applications include production Land Grid Array (LGA) integrated circuit sockets, flex circuit to PCB, and parallel PCB to PCB interconnections. ■ Provides solutions to many of the problems associated with through hole and surface mount soldered technology. ■ Enables upgrade and system maintenance strategies. ■ Available in custom I/O configurations and I/O counts from 1 to over 5,000. ■ Offers low profile capabilities with compressed signal path length as short as 0.8 mm. ■ Contact centerline spacing of 1mm or greater. ■ Excellent reliability in commercial, military, and aerospace applications. ■ Application can result in lower installed and system maintenance costs. MATERIALS Contact Material: Molybdenum CIN::APSE Contact Plating: Gold Plunger Material: Copper alloy Plunger Plating: Gold Insulator Material: Liquid crystal polymer ENVIRONMENTAL Packaging Tray Material: Anti-static ABS Button-Only Configuration with 0.020" (0.5 mm) Diameter Temperature Life Testing: 1000 Hours @ 200°C Thermal Shock: 2,000 Cycles @ 20°C to 110°C Humidity: 5,000 Hours @ 30°C to 80°C, 80% RH IC Component to Board Socket (LGA) Salt Spray: 96 Hours Low Temperature: Operates in liquid nitrogen (77°K) Bellcore TR-NWT-001217: Passed with plungers ELECTRICAL Button-Only Configuration with 0.020" (0.5 mm) Diameter DC Resistance: 15mΩ average Inductance: Less than 1 nH Current-Carrying Capability: Insulation Resistance: MECHANICAL Dielectric Withstanding Voltage: Up to 3 Amps. 25,000 MegΩ @ 500 VDC 900 VAC at sea level Button-Only Configuration with 0.020" (0.5 mm) diameter Durability: 25,000 Z-axis actuations (CIN::APSE contact only) Shock: 100 Gs; 6 milliseconds, no discontinuity greater than 2 nanoseconds Vibration: 20 Gs; 10-20,000 Hz; no discontinuity greater than 2 nanoseconds Call Toll Free: 1 (800) 323-9612 1-1 Flex Circuit to PCB CIN::APSE ® High-Speed Interconnect Technology THE BUTTON CONTACT The unique construction of the CIN::APSE contact provides superior mechanical and electrical performance. It is constructed of randomly wound molybdenum wire that is formed into a cyclindrical shape. Standard CIN::APSE contact diameters are 0.020" and 0.040". Mechanical • • • • • • Small form factor (0.020" diameter by 0.32" min. high) Low compression force (approx. 2.5 oz. min. per contact) Multiple beam structures Several points of contact per button Extremely lightweight Natural wiping action Electrical • Short signal path • Very low inductance and resistance • Signal integrity tested in the GHz range Typical CIN::APSE Applications • LGA package I/O to PC board (IC packages, multi-chip modules) • PC board to PC board (parallel processors, enhancement/mezzanine cards) • Flex circuit to PC board (rigid flex, harnessing) • Flex circuit to ceramic (chip to harness) CIN::APSE APPLIED The basic button contact configuration consists of a single button installed in our patented “hourglass” design. The hourglass cavity retains the CIN::APSE contact securely. Typically 0.003" protrudes from the top and the bottom of the insulator. Step 1: Using alignment features, position the CIN::APSE connector between a LGA chip package and PCB or two PCBs that have matching footprints. 1-2 Step 2: Add Z-Axis compression and secure. Call Toll Free: 1 (800) 323-9612 CIN::APSE ® High-Speed Interconnect Technology 1 TYPICAL CONFIGURATION 1. Button-Only This is the basic CIN::APSE contact configuration. It is ideally suited for z-axis applications requiring minimum height, high density, and signal integrity. This configuration is used in LGA and IC sockets, PCB to PCB, and flex print circuit to PCB applications. 2. Plunger-Button The addition of a gold-plated brass plunger increases the durability of the CIN::APSE contact system while also achieving additional height. This configuration suits itself especially well for PCB to PCB interconnect and those that require excessive handling. Other custom configurations are available. Contact Cinch for details. CIN::APSE Applications Due to its breakthrough nature, it is impossible to illustrate all of the applications CIN::APSE technology can address. The following applications illustrate only a portion of the types of interconnect problems that CIN::APSE can solve. Call Toll Free: 1 (800) 323-9612 1-3 CIN::APSE ® High-Speed Interconnect Technology 1 VARIOUS CIN::APSE APPLICATIONS IC Component to Board Socket (LGA) PCB to PCB Hybrid Circuit to Flex to PCB LCD to Flex to PCB Cable to PCB/Flex Flex Circuit to PCB 1-4 Call Toll Free: 1 (800) 323-9612 COMMERCIAL Barrier Blocks Circular Mini DIN BNC Jones Plugs Edge Connectors Commercial [.050” (1.27mm) Density Solder Introduction Cup/Wire D-Microminiature] Cinch Commercial Products, consisting of Jones Plugs and Sockets, Barrier Blocks, Edge Cards, Two-Piece Commercial Dins, Mini Din Plugs, and their newest addition the 75Ω Press-Fit BNC Receptacle, provide a wide variety of connectors for the purchaser and designer to chose from. The Jones Plugs and Sockets have been utilized for decades and provide a quick, reliable, and economical means of solving your higher current-carrying capacity needs. Available in two series (300 and 2,400), these connectors can be found in data processing controls; amusement and vending machines; medical, communication, and test equipment; as well as industrial controls and heavy-duty, battery-powered equipment. Both series are available in a variety of cable and panel mounting options. Cinch Barrier Blocks are designed to simplify wiring work by reducing splicing, preventing current leaks and short circuits, and increasing insulation. Available in a variety of densities, these barrier blocks can be found in applications ranging from industrial controls to switching systems. Designed specially for applications where space is at a premium, the Cinch Mini Din family is ideal for personal computers, keyboard-mouse interface, hand-held electronic equipment, office-automation equipment, and audio and video equipment. Available in sizes 3 through 8 contact, the Cinch Mini Din family includes a fully shielded cable mounted plug in various cable lengths or cable mounted plug components for customers with high-volume assembly and overmold capabilities. Cinch Edge Card Connectors are available in a variety of styles on both .100 or .156 center spacing. The newest addition to the commercial family, the 75Ω Press-Fit BNC Receptacle is designed around a unique patented press-fit design that allows for multiple insertion into a backplane without loss of mechanical retention or electrical performance. When looking for time reliability to solve your commercial interconnect needs, look no further than Cinch Connectors. Whether it's a Jones Plug and Socket, Barrier Block, Edge Card, Mini Din plug, or our newest addition, the 75Ω BNC Press-Fit connector, you will always know years of customer satisfaction stand behind the product you chose. 2-1 Call Toll Free: 1 (800) 323-9612 2 Barrier Blocks ■ A wide variety of barrier blocks makes it possible to select the combination of mechanical and electrical characteristics that best meet the exact requirements of your application. MATERIALS ■ A wide selection of optional terminals and fanning strips permits the equipment designer to choose the method of termination most suitable for his environmental specifications and manufacturing requirements. Insulation Material: Molded monoblock, general purpose phenolic, black, UL Rated 94V-1 Eyelets: Material - Brass Plating - Nickel Screws: Material - Steel Plating - Nickel over copper flash Solder Terminals: Material - Brass Plating - Electro-Tin Marker Strip Material: Nema Grade XPC, UL Rated 94V-O ENVIRONMENTAL FEATURES ■ Interposing barriers between terminals yield higher electrical ratings and provide additional protection against frayed wire shorting. Operating Temperature: -55° to +300°F Certifications: UL Recognized - File E61245 CSA - LR 31996 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-2 Barrier Blocks TERMINAL BLOCK QUICK REFERENCE Center-to- Number Single or Center of Double Screw Series Spacing Terminals Row Size Operating Voltage Current Rating Max. Wire Size Max. Watts/ Terminal Voltage Voltage Rating Rating w/Marker w/o Marker Marker Strip Mounting 140 .375 1-25 Double 5-40 250 Volts 15 Amps #16 3750 2000 1100 Bottom 141 .438 1-20 Double 6-32 250 Volts 20 Amps #14 5000 2400 1100 Bottom 142 .563 1-17 Double 8-32 250 Volts 30 Amps #10 7500 2600 1600 Bottom 150 .688 1-10 Double 10-32 250 Volts 40 Amps #10 10,000 2400 1500 Bottom 151 .875 1-8 Double 12-32 250 Volts 50 Amps #8 12,500 3400 1800 Bottom 152 1.125 1-6 Double 1/4-28 250 Volts 70 Amps #6 54,000 3800 2100 Bottom 164 .375 1-21 Double 6-32 250 Volts 15 Amps #14 3750 2000 1100 Bottom 540 .375 2-31 Double 5-40 600 Volts 15 Amps #16 3750 2300 2300 Top 541 .438 2-30 Double 6-32 600 Volts 20 Amps #14 5000 2800 2800 Top 542 .563 2-26 Double 8-32 600 Volts 30 Amps #10 7500 4000 4000 Top 176 .375 2-10 Single 5-40 250 Volts 15 Amps #16 3750 N/A 1100 N/A Marketed exclusively through distribution. 2-3 Call Toll Free: 1 (800) 323-9612 .375 Density, 5-40 x 3/16" BH Screw, Open Bottom, Double Row Barrier Blocks Series 140 Electrical Characteristics Voltage Rating: 250 VAC RMS maximum Current Rating: 15 Amps maximum Maximum Watts Per Terminal: 3750 Mechanical Characteristics Maximum Wire Size: #16 AWG Recommended Tightening Torque: 9 lb.-in. Dimensions Ordering Information No. of Standard Screw Terminals Catalog No. 1 1-140 2 2-140 3 3-140 4 4-140 5 5-140 6 6-140 7 7-140 8 8-140 9 9-140 10 10-140 11 11-140 12 12-140 13 13-140 14 14-140 15 15-140 16 16-140 17 17-140 18 18-140 19 19-140 20 20-140 21 21-140 22 22-140 23 23-140 24 24-140 25 25-140 Call Toll Free: 1 (800) 323-9612 2-4 “M” Dim. .750 1.125 1.500 1.875 2.250 2.625 3.000 3.375 3.750 4.125 4.500 4.875 5.250 5.625 6.000 6.375 6.750 7.125 7.500 7.875 8.250 8.625 9.000 9.375 9.750 “L” Dim. 1.032 1.407 1.782 2.157 2.532 2.907 3.282 3.657 4.032 4.407 4.782 5.157 5.532 5.907 6.282 6.657 7.032 7.407 7.782 8.157 8.532 8.907 9.282 9.657 10.032 Marketed exclusively through distribution. Barrier Blocks Series 140 .375 Density, 5-40 x 3/16" BH Screw, Open Bottom, Double Row Solder Terminal Options Dimensions “Y” Terminals “3/4W” Terminals “W” Terminals Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 Catalog No. 1-140-Y 2-140-Y 3-140-Y 4-140-Y 5-140-Y 6-140-Y 7-140-Y 8-140-Y 9-140-Y 10-140-Y 11-140-Y 12-140-Y 13-140-Y 14-140-Y 15-140-Y 16-140-Y 17-140-Y 18-140-Y 19-140-Y 20-140-Y 21-140-Y 22-140-Y 23-140-Y 24-140-Y 25-140-Y Catalog No. 1-140-3/4W 2-140-3/4W 3-140-3/4W 4-140-3/4W 5-140-3/4W 6-140-3/4W 7-140-3/4W 8-140-3/4W 9-140-3/4W 10-140-3/4W 11-140-3/4W 12-140-3/4W 13-140-3/4W 14-140-3/4W 15-140-3/4W 16-140-3/4W 17-140-3/4W 18-140-3/4W 19-140-3/4W 20-140-3/4W 21-140-3/4W 22-140-3/4W 23-140-3/4W 24-140-3/4W 25-140-3/4W Catalog No. 1-140-W 2-140-W 3-140-W 4-140-W 5-140-W 6-140-W 7-140-W 8-140-W 9-140-W 10-140-W 11-140-W 12-140-W 13-140-W 14-140-W 15-140-W 16-140-W 17-140-W 18-140-W 19-140-W 20-140-W 21-140-W 22-140-W 23-140-W 24-140-W 25-140-W Solder Terminals can be ordered separately. Terminal Type “Y” “3/4W” “W” Catalog No. Y-140 3/4W-140 W-140 Marketed exclusively through distribution. 2-5 Call Toll Free: 1 (800) 323-9612 .375 Density, 5-40 x 3/16" BH Screw, Open Bottom, Double Row Barrier Blocks Series 140 Marker Strips Dimensions Standard “Y” Terminal 2 Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 Catalog No. MS-1-140 MS-2-140 MS-3-140 MS-4-140 MS-5-140 MS-6-140 MS-7-140 MS-8-140 MS-9-140 MS-10-140 MS-11-140 MS-12-140 MS-13-140 MS-14-140 MS-15-140 MS-16-140 MS-17-140 MS-18-140 MS-19-140 MS-20-140 MS-21-140 MS-22-140 MS-23-140 MS-24-140 MS-25-140 Catalog No. MS-1-140-Y MS-2-140-Y MS-3-140-Y MS-4-140-Y MS-5-140-Y MS-6-140-Y MS-7-140-Y MS-8-140-Y MS-9-140-Y MS-10-140-Y MS-11-140-Y MS-12-140-Y MS-13-140-Y MS-14-140-Y MS-15-140-Y MS-16-140-Y MS-17-140-Y MS-18-140-Y MS-19-140-Y MS-20-140-Y MS-21-140-Y MS-22-140-Y MS-23-140-Y MS-24-140-Y MS-25-140-Y Use Standard Marker Strips for “3/4W” and “W” Solder Terminals. Accessories • Jumpers • Fanning Strips Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-6 .438 Density, 6-32 x 1/4" BH Screw, Open Bottom, Double Row Barrier Blocks Series 141 Electrical Characteristics Voltage Rating: 250 VAC RMS maximum Current Rating: 20 Amps maximum Maximum Watts Per Terminal: 5000 Mechanical Characteristics Maximum Wire Size: #14 AWG Recommended Tightening Torque: 12 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Standard Screw Catalog No. 1-141 2-141 3-141 4-141 5-141 6-141 7-141 8-141 9-141 10-141 11-141 12-141 13-141 14-141 15-141 16-141 17-141 18-141 19-141 20-141 “M” Dim. .875 1.312 1.750 2.187 2.625 3.062 3.500 3.938 4.375 4.813 5.250 5.687 6.125 6.562 7.000 7.437 7.875 8.312 8.750 9.187 “L” Dim. 1.187 1.625 2.062 2.500 2.938 3.375 3.812 4.250 4.687 5.125 5.562 6.000 6.437 6.875 7.312 7.750 8.187 8.625 9.062 9.500 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-8 .438 Density, 6-32 x 1/4" BH Screw, Open Bottom, Double Row Barrier Blocks Series 141 Solder Terminal Options Dimensions “Y” Terminals “3/4W” Terminals “W” Terminals Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Catalog No. 1-141-Y 2-141-Y 3-141-Y 4-141-Y 5-141-Y 6-141-Y 7-141-Y 8-141-Y 9-141-Y 10-141-Y 11-141-Y 12-141-Y 13-141-Y 14-141-Y 15-141-Y 16-141-Y 17-141-Y 18-141-Y 19-141-Y 20-141-Y Catalog No. 1-141-3/4W 2-141-3/4W 3-141-3/4W 4-141-3/4W 5-141-3/4W 6-141-3/4W 7-141-3/4W 8-141-3/4W 9-141-3/4W 10-141-3/4W 11-141-3/4W 12-141-3/4W 13-141-3/4W 14-141-3/4W 15-141-3/4W 16-141-3/4W 17-141-3/4W 18-141-3/4W 19-141-3/4W 20-141-3/4W Catalog No. 1-141-W 2-141-W 3-141-W 4-141-W 5-141-W 6-141-W 7-141-W 8-141-W 9-141-W 10-141-W 11-141-W 12-141-W 13-141-W 14-141-W 15-141-W 16-141-W 17-141-W 18-141-W 19-141-W 20-141-W Solder Terminals can be ordered separately. Terminal Type “Y” “3/4W” “W” Catalog No. Y-141 3/4W-141 W-141 Marketed exclusively through distribution. 2-9 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Blocks High Reliability Series 141 All-Plastic .438 Density, 6-32 x 1/4" BH Screw, Open Bottom, Double Row Marker Strips Dimensions Standard “Y” Terminal 2 Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Catalog No. MS-1-141 MS-2-141 MS-3-141 MS-4-141 MS-5-141 MS-6-141 MS-7-141 MS-8-141 MS-9-141 MS-10-141 MS-11-141 MS-12-141 MS-13-141 MS-14-141 MS-15-141 MS-16-141 MS-17-141 MS-18-141 MS-19-141 MS-20-141 Catalog No. MS-1-141-Y MS-2-141-Y MS-3-141-Y MS-4-141-Y MS-5-141-Y MS-6-141-Y MS-7-141-Y MS-8-141-Y MS-9-141-Y MS-10-141-Y MS-11-141-Y MS-12-141-Y MS-13-141-Y MS-14-141-Y MS-15-141-Y MS-16-141-Y MS-17-141-Y MS-18-141-Y MS-19-141-Y MS-20-141-Y Use Standard Marker Strip for “3/4W” and “W” Solder Terminals. Accessories • Jumpers • Fanning Strips Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-10 Barrier Blocks Series 142 .563 Density, 8-32 x 5/16" BH Screw, Open Bottom, Double Row Electrical Characteristics Voltage Rating: 250 VAC RMS maximum Current Rating: 30 Amps maximum Maximum Watts Per Terminal: 7500 Mechanical Characteristics Maximum Wire Size: #10 AWG Recommended Tightening Torque: 16 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Standard Screw Catalog No. 1-142 2-142 3-142 4-142 5-142 6-142 7-142 8-142 9-142 10-142 11-142 12-142 13-142 14-142 15-142 16-142 17-142 “M” Dim. 1.125 1.687 2.250 2.812 3.375 3.937 4.500 5.062 5.625 6.187 6.750 7.312 7.875 8.437 9.000 9.562 10.125 “L” Dim. 1.531 2.094 2.656 3.219 3.781 4.344 4.906 5.468 6.031 6.594 7.156 7.719 8.281 8.844 9.406 9.969 10.531 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-12 Barrier Blocks Series 142 .563 Density, 8-32 x 5/16" BH Screw, Open Bottom, Double Row Solder Terminal Options Dimensions “Y” Terminals “3/4W” Terminals “W” Terminals Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Catalog No. 1-142-Y 2-142-Y 3-142-Y 4-142-Y 5-142-Y 6-142-Y 7-142-Y 8-142-Y 9-142-Y 10-142-Y 11-142-Y 12-142-Y 13-142-Y 14-142-Y 15-142-Y 16-142-Y 17-142-Y Catalog No. 1-142-3/4W 2-142-3/4W 3-142-3/4W 4-142-3/4W 5-142-3/4W 6-142-3/4W 7-142-3/4W 8-142-3/4W 9-142-3/4W 10-142-3/4W 11-142-3/4W 12-142-3/4W 13-142-3/4W 14-142-3/4W 15-142-3/4W 16-142-3/4W 17-142-3/4W Catalog No. 1-142-W 2-142-W 3-142-W 4-142-W 5-142-W 6-142-W 7-142-W 8-142-W 9-142-W 10-142-W 11-142-W 12-142-W 13-142-W 14-142-W 15-142-W 16-142-W 17-142-W Solder Terminals can be ordered separately. Terminal Type “Y” “3/4W” “W” Catalog No. Y-142 3/4W-142 W-142 Marketed exclusively through distribution. 2-13 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Blocks High Reliability Series 142 All-Plastic .563 Density, 8-32 x 5/16" BH Screw, Open Bottom, Double Row Marker Strips Dimensions Standard “Y” Terminal 2 Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Catalog No. MS-1-142 MS-2-142 MS-3-142 MS-4-142 MS-5-142 MS-6-142 MS-7-142 MS-8-142 MS-9-142 MS-10-142 MS-11-142 MS-12-142 MS-13-142 MS-14-142 MS-15-142 MS-16-142 MS-17-142 Catalog No. MS-1-142-Y MS-2-142-Y MS-3-142-Y MS-4-142-Y MS-5-142-Y MS-6-142-Y MS-7-142-Y MS-8-142-Y MS-9-142-Y MS-10-142-Y MS-11-142-Y MS-12-142-Y MS-13-142-Y MS-14-142-Y MS-15-142-Y MS-16-142-Y MS-17-142-Y Use Standard Marker Strips for “3/4W” and “W” Solder Terminals. Accessories • • Jumpers Fanning Strips Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-14 .688 Density, 10-32 x 5/16" BH Screw, Open Bottom, Double Row Barrier Blocks Series 150 Electrical Characteristics Voltage Rating: 250 VAC RMS maximum Current Rating: 40 Amps maximum Maximum Watts Per Terminal: 10,000 Mechanical Characteristics Maximum Wire Size: #10 AWG Recommended Tightening Torque: 20 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 Standard Screw Catalog No. 1-150 2-150 3-150 4-150 5-150 6-150 7-150 8-150 9-150 10-150 Y-Terminals Catalog No. 1-150-Y 2-150-Y 3-150-Y 4-150-Y 5-150-Y 6-150-Y 7-150-Y 8-150-Y 9-150-Y 10-150-Y “M” Dim. 1.375 2.062 2.750 3.437 4.125 4.812 5.500 6.187 6.875 7.562 “L” Dim. 1.812 2.500 3.187 3.875 4.562 5.250 5.938 6.625 7.312 8.000 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-16 Barrier Blocks Series 150 .688 Density, 10-32 x 5/16" BH Screw, Open Bottom, Double Row Marker Strips Dimensions Standard “Y” Terminal .688 TYP (17.46) Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 Catalog No. MS-1-150 MS-2-150 MS-3-150 MS-4-150 MS-5-150 MS-6-150 MS-7-150 MS-8-150 MS-9-150 MS-10-150 Catalog No. MS-1-150-Y MS-2-150-Y MS-3-150-Y MS-4-150-Y MS-5-150-Y MS-6-150-Y MS-7-150-Y MS-8-150-Y MS-9-150-Y MS-10-150-Y Accessories None Available for 150 Series. Marketed exclusively through distribution. 2-17 Call Toll Free: 1 (800) 323-9612 .875 Density, 12-32 x 3/8" BH Screw, Open Bottom, Double Row Barrier Blocks Series 151 Electrical Characteristics Voltage Rating: 250 Volts maximum Current Rating: 50 Amps maximum Maximum Watts Per Terminal: 12,500 Mechanical Characteristics Maximum Wire Size: #8 Recommended Tightening Torque: 40 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 Catalog No. 1-151 2-151 3-151 4-151 5-151 6-151 7-151 8-151 “M” Dim. (in) 1.750 2.625 3.500 4.375 5.250 6.125 7.000 7.875 “L” Dim. (in) 2.282 3.157 4.032 4.907 5.782 6.657 7.532 8.407 Marker Strip Catalog No. N/A MS-2-151 MS-3-151 MS-4-151 MS-5-151 MS-6-151 MS-7-151 MS-8-151 Solder Terminals can be ordered separately. Terminal Type “W” Catalog No. W-151 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-18 1.25 Density, 1/4-28 x 1/2" BH Screw, Open Bottom, Double Row Barrier Blocks Series 152 Electrical Characteristics Voltage Rating: 250 Volts maximum Current Rating: 70 Amps maximum Maximum Watts Per Terminal: 54,000 Mechanical Characteristics Maximum Wire Size: #6 Recommended Tightening Torque: 75 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 Catalog No. 1-152 2-152 3-152 4-152 5-152 6-152 “M” Dim. (in) 2.250 3.375 4.500 5.625 6.750 7.875 “L” Dim. (in) 2.876 4.001 5.126 6.251 7.376 8.501 Marker Strip Catalog No. N/A MS-2-152 MS-3-152 MS-4-152 MS-5-152 MS-6-152 Accessories None Available for 152 Series. Marketed exclusively through distribution. 2-19 Call Toll Free: 1 (800) 323-9612 Barrier Blocks Series 164 .375 Density, 6-32 x 5/16" BH Screw, Open Bottom, Double Row Electrical Characteristics Voltage Rating: 250 Volts maximum Current Rating: 15 Amps maximum Maximum Watts Per Terminal: 3750 Mechanical Characteristics Maximum Wire Size: #14 Recommended Tightening Torque: 12 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 “M” Dim. (in) 0.750 1.125 1.500 1.875 2.250 2.625 3.000 3.375 3.750 4.125 4.500 4.875 5.250 5.625 6.000 6.375 6.750 7.125 7.500 7.875 8.250 Catalog No. 1-164 2-164 3-164 4-164 5-164 6-164 7-164 8-164 9-164 10-164 11-164 12-164 13-164 14-164 15-164 16-164 17-164 18-164 19-164 20-164 21-164 “L” Dim. (in) 1.032 1.407 1.782 2.157 2.532 2.907 3.282 3.657 4.032 4.407 4.782 5.157 5.532 5.907 6.282 6.657 7.032 7.407 7.782 8.157 8.532 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-20 Barrier Blocks Series 164 .375 Density, 6-32 x 1/4" BH Screw, Open Bottom, Double Row Solder Terminal Options Dimensions “Y” Terminals “3/4W” Terminals “W” Terminals Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Catalog No. 1-164-Y 2-164-Y 3-164-Y 4-164-Y 5-164-Y 6-164-Y 7-164-Y 8-164-Y 9-164-Y 10-164-Y 11-164-Y 12-164-Y 13-164-Y 14-164-Y 15-164-Y 16-164-Y 17-164-Y 18-164-Y 19-164-Y 20-164-Y 21-164-Y Catalog No. 1-164-3/4W 2-164-3/4W 3-164-3/4W 4-164-3/4W 5-164-3/4W 6-164-3/4W 7-164-3/4W 8-164-3/4W 9-164-3/4W 10-164-3/4W 11-164-3/4W 12-164-3/4W 13-164-3/4W 14-164-3/4W 15-164-3/4W 16-164-3/4W 17-164-3/4W 18-164-3/4W 19-164-3/4W 20-164-3/4W 21-164-3/4W Catalog No. 1-164-W 2-164-W 3-164-W 4-164-W 5-164-W 6-164-W 7-164-W 8-164-W 9-164-W 10-164-W 11-164-W 12-164-W 13-164-W 14-164-W 15-164-W 16-164-W 17-164-W 18-164-W 19-164-W 20-164-W 21-164-W Marketed exclusively through distribution. 2-21 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Blocks High Reliability Series 164 All-Plastic [.050” .375 (1.27mm) Density, 6-32 Density x 1/4" Solder BH Screw, Cup/Wire Open Bottom, D-Microminiature] Double Row Marker Strips Dimensions Standard “Y” Terminal 2 Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Catalog No. N/A MS-2-140 MS-3-140 MS-4-140 MS-5-140 MS-6-140 MS-7-140 MS-8-140 MS-9-140 MS-10-140 MS-11-140 MS-12-140 MS-13-140 MS-14-140 MS-15-140 MS-16-140 MS-17-140 MS-18-140 MS-19-140 MS-20-140 MS-21-140 Catalog No. N/A MS-2-140-Y MS-3-140-Y MS-4-140-Y MS-5-140-Y MS-6-140-Y MS-7-140-Y MS-8-140-Y MS-9-140-Y MS-10-140-Y MS-11-140-Y MS-12-140-Y MS-13-140-Y MS-14-140-Y MS-15-140-Y MS-16-140-Y MS-17-140-Y MS-18-140-Y MS-19-140-Y MS-20-140-Y MS-21-140-Y Use Standard Marker Strips for “3/4W” and “W” Solder Terminals. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-22 .375 Density, 5-40 x 1/4" BH Screw, Closed Bottom, Double Row Barrier Blocks Series 540 Electrical Characteristics Voltage Rating: 600 Volts maximum Current Rating: 15 Amps Maximum Watts Per Terminal: 3750 Mechanical Characteristics Maximum Wire Size: #16 Recommended Tightening Torque: 9 lb.-in. Dimensions Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 Catalog No. 2-540 3-540 4-540 5-540 6-540 7-540 8-540 9-540 10-540 11-540 12-540 13-540 14-540 15-540 16-540 17-540 18-540 19-540 20-540 21-540 22-540 23-540 24-540 25-540 26-540 27-540 28-540 29-540 30-540 31-540 “M” Dim. (in) 1.125 1.500 1.875 2.250 2.625 3.000 3.375 3.750 4.125 4.500 4.875 5.250 5.625 6.000 6.375 6.750 7.125 7.500 7.875 8.250 8.625 9.000 9.375 9.750 10.125 10.500 10.875 11.250 11.625 12.000 “L” Dim. (in) 1.407 1.782 2.157 2.532 2.907 3.282 3.657 4.032 4.407 4.782 5.157 5.532 5.907 6.282 6.657 7.032 7.407 7.782 8.157 8.532 8.907 9.282 9.657 10.032 10.407 10.782 11.157 11.532 11.907 12.282 Marker Strip Catalog No. MSX-2-540 MSX-3-540 MSX-4-540 MSX-5-540 MSX-6-540 MSX-7-540 MSX-8-540 MSX-9-540 MSX-10-540 MSX-11-540 MSX-12-540 MSX-13-540 MSX-14-540 MSX-15-540 MSX-16-540 MSX-17-540 MSX-18-540 MSX-19-540 MSX-20-540 MSX-21-540 MSX-22-540 MSX-23-540 MSX-24-540 MSX-25-540 MSX-26-540 MSX-27-540 MSX-28-540 MSX-29-540 MSX-30-540 MSX-31-540 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-24 .438 Density, 6-32 x 1/4" BH Screw, Closed Bottom, Double Row Barrier Blocks Series 541 Electrical Characteristics Voltage Rating: 600 Volts maximum Current Rating: 20 Amps Maximum Watts Per Terminal: 5000 Mechanical Characteristics Maximum Wire Size: #14 Recommended Tightening Torque: 12 lb.-in. Dimensions Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 Catalog No. 2-541 3-541 4-541 5-541 6-541 7-541 8-541 9-541 10-541 11-541 12-541 13-541 14-541 15-541 16-541 17-541 18-541 19-541 20-541 21-541 22-541 23-541 24-541 25-541 26-541 27-541 28-541 29-541 30-541 “M” Dim. (in) 1.314 1.752 2.190 2.628 3.066 3.504 3.942 4.380 4.818 5.256 5.694 6.132 6.570 7.008 7.446 7.884 8.322 8.760 9.198 9.636 10.074 10.512 10.950 11.388 11.826 12.264 12.702 13.140 13.578 “L” Dim. (in) 1.626 2.064 2.502 2.940 3.378 3.816 4.254 4.692 5.130 5.568 6.006 6.444 6.882 7.320 7.758 8.196 8.634 9.072 9.510 9.948 10.386 10.824 11.262 11.700 12.138 12.576 13.014 13.452 13.890 Marker Strip Catalog No. MSX-2-541 MSX-3-541 MSX-4-541 MSX-5-541 MSX-6-541 MSX-7-541 MSX-8-541 MSX-9-541 MSX-10-541 MSX-11-541 MSX-12-541 MSX-13-541 MSX-14-541 MSX-15-541 MSX-16-541 MSX-17-541 MSX-18-541 MSX-19-541 MSX-20-541 MSX-21-541 MSX-22-541 MSX-23-541 MSX-24-541 MSX-25-541 MSX-26-541 MSX-27-541 MSX-28-541 MSX-29-541 MSX-30-541 Marketed exclusively through distribution. 2-25 Call Toll Free: 1 (800) 323-9612 .563 Density, 8-32 x 5/16" BH Screw, Closed Bottom, Double Row Barrier Blocks Series 542 Electrical Characteristics Voltage Rating: 600 Volts maximum Current Rating: 30 Amps Maximum Watts Per Terminal: 7500 Mechanical Characteristics Maximum Wire Size: #10 Recommended Tightening Torque: 16 lb.-in. Dimensions Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 Catalog No. 2-542 3-542 4-542 5-542 6-542 7-542 8-542 9-542 10-542 11-542 12-542 13-542 14-542 15-542 16-542 17-542 18-542 19-542 20-542 21-542 22-542 23-542 24-542 25-542 26-542 “M” Dim. (in) 1.689 2.252 2.815 3.378 3.941 4.504 5.067 5.630 6.193 6.756 7.319 7.882 8.445 9.008 9.571 10.134 10.697 11.260 11.823 12.386 12.949 13.512 14.075 14.638 15.201 “L” Dim. (in) 2.095 2.658 3.221 3.784 4.347 4.910 5.473 6.036 6.599 7.162 7.725 8.288 8.851 9.414 9.977 10.540 11.103 11.666 12.229 12.792 13.355 13.918 14.481 15.044 15.607 Marker Strip Catalog No. MSX-2-542 MSX-3-542 MSX-4-542 MSX-5-542 MSX-6-542 MSX-7-542 MSX-8-542 MSX-9-542 MSX-10-542 MSX-11-542 MSX-12-542 MSX-13-542 MSX-14-542 MSX-15-542 MSX-16-542 MSX-17-542 MSX-18-542 MSX-19-542 MSX-20-542 MSX-21-542 MSX-22-542 MSX-23-542 MSX-24-542 MSX-25-542 MSX-26-542 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-26 .375 Density, 5-40 x 3/16" BH Screw, Dip Solder, Single Row Barrier Blocks Series 176 Electrical Characteristics Voltage Rating: 250 Volts maximum Current Rating: 15 Amps maximum Maximum Watts Per Terminal: 3750 Mechanical Characteristics Maximum Wire Size: 16 AWG Recommended Tightening Torque: 16 lb.-in. Dimensions L M Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 With Mounting Ears Catalog No. Catalog No. .125 Tail Lgth .184 Tail Lgth 2-176-2 2-176-3 3-176-2 3-176-3 4-176-2 4-176-3 5-176-2 5-176-3 6-176-2 6-176-3 7-176-2 7-176-3 8-176-2 8-176-3 9-176-2 9-176-3 10-176-2 10-176-3 “M” Dimension 1.125 1.500 1.875 2.250 2.625 3.000 3.375 3.375 4.125 Without Mounting Ears Catalog No. Catalog No. .125 Tail Lgth .184 Tail Lgth 2-176-2A 2-176-3A 3-176-2A 3-176-3A 4-176-2A 4-176-3A 5-176-2A 5-176-3A 6-176-2A 6-176-3A 7-176-2A 7-176-3A 8-176-2A 8-176-3A 9-176-2A 9-176-3A 10-176-2A 10-176-3A 11-176-2A 11-176-3A 12-176-2A 12-176-3A “L” Dimension 1.469 1.844 2.219 2.594 2.969 3.344 3.719 4.094 4.469 “L” Dimension .719 1.094 1.469 1.844 2.219 2.594 2.969 3.344 3.719 4.094 4.469 Marketed exclusively through distribution. 2-27 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Blocks High Reliability Accessories All-Plastic Solder Terminals 3/4W, Y, and W Optional Terminals for use with Cinch terminal blocks. See chart for type and dimensions. (Below) 2 Ordering Information "3/4 W" Terminals - Dimensions Catalog A Number in mm 3/4W-140 .953 24.21 3/4W-141 1.156 29.36 3/4W-142 1.422 36.11 B in .719 .680 .797 C mm 18.20 17.27 20.24 in .312 .422 .500 mm 12.70 15.88 18.64 in .136 .152 .177 mm 19.05 23.83 27.79 in .312 .422 .500 D mm 7.92 10.72 12.70 in .062 .078 .094 E mm 1.57 1.98 2.39 in .146 .152 .177 D in mm .593 15.06 .781 19.83 .906 23.01 in .093 .125 .125 F mm 3.71 3.86 4.50 in .094 .125 .125 mm 2.36 3.18 3.18 in .091 .103 .126 mm 3.71 3.86 4.50 in .094 .125 .125 mm 2.39 3.18 3.18 "Y" Terminals - Dimensions Catalog Number Y-140 Y-141 Y-142 A in .281 .312 .421 B mm 7.14 7.92 10.69 in .500 .625 .734 C mm 3.45 3.86 4.50 E F mm 2.31 2.62 3.20 "W" Terminals - Dimensions Catalog Number W-140 W-141 W-142 A in 1.219 1.563 1.875 B mm 30.96 39.70 47.63 in .750 .938 1.094 C D mm 7.92 10.72 12.70 in .063 .078 .094 E mm 1.60 1.98 2.39 in .146 .152 .177 F mm 2.39 3.18 3.18 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-28 Barrier Blocks Accessories Quick Clamp Terminals Simplifies engaging of wires to barrier blocks. Wire is inserted into flared opening and screw is tightened. Screws are brass binder head type with nickel plating. Terminals are brass with tin plating. Includes two mating clamps and one screw. QC-1 Shown Ordering Information Barrier Block Series 141, 541 142, 542 Catalog No. QC-1 QC-2 Screw Size 6-32x5/16" 8-32x3/8" Wire Gauge Range AWG 12 thru 22 10 thru 16 Jumpers For connecting between adjacent terminals or alternate terminals. All jumpers are brass with nickel plating. Ordering Information Barrier Block Series 140 141 141 142 142, 542 142, 542 540 541 542 Type A B F F D E C C C Catalog No. 140J-1 141J-1 141J 95B 142J-1* 142J-2 540J 541J 542J Type A Type B Type C Type E Type F * Connects two alternate terminals Type D Marketed exclusively through distribution. 2-29 Call Toll Free: 1 (800) 323-9612 2 Barrier Block Accessories Fanning Strips MATERIALS FEATURES ■ Minimize wiring errors. ■ Available in straight and right-angle styles. ■ Available with cable clamp hole on right or left side, designated by “L” or “R” at end of catalog number. ■ Cable clamp hole for securing cable/wires with lacing twine or ty-wrap. Insulation Material: UL 94HB rated XPC, chocolate Contact Material: Brass Contact Plating: Cadmium Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-30 Barrier Block Accessories Fanning Strips Catalog Numbers and Dimensions for Fanning Strips for 140 Series Terminal Blocks Straight Type Dimensions Catalog No. 6-160B-R Catalog No. 6-160-R Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Catalog No. 2-160-R 3-160-R 4-160-R 5-160-R 6-160-R 7-160-R 8-160-R 9-160-R 10-160-R 11-160-R 12-160-R 13-160-R 14-160-R 15-160-R 16-160-R 17-160-R 18-160-R 19-160-R 20-160-R 21-160-R Catalog No. 2-160-L 3-160-L 4-160-L 5-160-L 6-160-L 7-160-L 8-160-L 9-160-L 10-160-L 11-160-L 12-160-L 13-160-L 14-160-L 15-160-L 16-160-L 17-160-L 18-160-L 19-160-L 20-160-L 21-160-L Catalog No. 2-160B-R 3-160B-R 4-160B-R 5-160B-R 6-160B-R 7-160B-R 8-160B-R 9-160B-R 10-160B-R 11-160B-R 12-160B-R 13-160B-R 14-160B-R 15-160B-R 16-160B-R 17-160B-R 18-160B-R 19-160B-R 20-160B-R 21-160B-R Catalog No. 2-160B-L 3-160B-L 4-160B-L 5-160B-L 6-160B-L 7-160B-L 8-160B-L 9-160B-L 10-160B-L 11-160B-L 12-160B-L 13-160B-L 14-160B-L 15-160B-L 16-160B-L 17-160B-L 18-160B-L 19-160B-L 20-160B-L 21-160B-L Marketed exclusively through distribution. 2-31 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Block High Reliability Accessories All-Plastic Fanning Fanning Strips Strips Catalog Numbers and Dimensions for Fanning Strips for 140 Series Terminal Blocks, Continued Right-Angle Type Dimensions 2 Catalog No. 6-160A-R Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Catalog No. 2-160A-R 3-160A-R 4-160A-R 5-160A-R 6-160A-R 7-160A-R 8-160A-R 9-160A-R 10-160A-R 11-160A-R 12-160A-R 13-160A-R 14-160A-R 15-160A-R 16-160A-R 17-160A-R 18-160A-R 19-160A-R 20-160A-R 21-160A-R Catalog No. 2-160A-L 3-160A-L 4-160A-L 5-160A-L 6-160A-L 7-160A-L 8-160A-L 9-160A-L 10-160A-L 11-160A-L 12-160A-L 13-160A-L 14-160A-L 15-160A-L 16-160A-L 17-160A-L 18-160A-L 19-160A-L 20-160A-L 21-160A-L Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-32 Barrier Block Accessories Fanning Strips Catalog Numbers and Dimensions for Fanning Strips for 141 Series Terminal Blocks Straight Type Dimensions No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Catalog No. 2-161-R 3-161-R 4-161-R 5-161-R 6-161-R 7-161-R 8-161-R 9-161-R 10-161-R 11-161-R 12-161-R 13-161-R 14-161-R 15-161-R 16-161-R 17-161-R 18-161-R 19-161-R 20-161-R Catalog No. 2-161-L 3-161-L 4-161-L 5-161-L 6-161-L 7-161-L 8-161-L 9-161-L 10-161-L 11-161-L 12-161-L 13-161-L 14-161-L 15-161-L 16-161-L 17-161-L 18-161-L 19-161-L 20-161-L 2 Catalog No. 5-161-R Right-Angle Type Dimensions No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Catalog No. 2-161A-R 3-161A-R 4-161A-R 5-161A-R 6-161A-R 7-161A-R 8-161A-R 9-161A-R 10-161A-R 11-161A-R 12-161A-R 13-161A-R 14-161A-R 15-161A-R 16-161A-R 17-161A-R 18-161A-R 19-161A-R 20-161A-R Catalog No. 2-161A-L 3-161A-L 4-161A-L 5-161A-L 6-161A-L 7-161A-L 8-161A-L 9-161A-L 10-161A-L 11-161A-L 12-161A-L 13-161A-L 14-161A-L 15-161A-L 16-161A-L 17-161A-L 18-161A-L 19-161A-L 20-161A-L Catalog No. 5-161A-R Marketed exclusively through distribution. 2-33 Call Toll Free: 1 (800) 323-9612 Barrier Block Accessories Fanning Strips Catalog Numbers and Dimensions for Fanning Strips for 142 Series Barrier Blocks Straight Type Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Catalog No. 2-162-R 3-162-R 4-162-R 5-162-R 6-162-R 7-162-R 8-162-R 9-162-R 10-162-R 11-162-R 12-162-R 13-162-R 14-162-R 15-162-R 16-162-R 17-162-R Dimensions Catalog No. 2-162-L 3-162-L 4-162-L 5-162-L 6-162-L 7-162-L 8-162-L 9-162-L 10-162-L 11-162-L 12-162-L 13-162-L 14-162-L 15-162-L 16-162-L 17-162-L Catalog No. 5-162-R Right-Angle Type Dimensions Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Catalog No. 2-162A-R 3-162A-R 4-162A-R 5-162A-R 6-162A-R 7-162A-R 8-162A-R 9-162A-R 10-162A-R 11-162A-R 12-162A-R 13-162A-R 14-162A-R 15-162A-R 16-162A-R 17-162A-R Catalog No. 2-162A-L 3-162A-L 4-162A-L 5-162A-L 6-162A-L 7-162A-L 8-162A-L 9-162A-L 10-162A-L 11-162A-L 12-162A-L 13-162A-L 14-162A-L 15-162A-L 16-162A-L 17-162A-L Catalog No. 5-162A-R Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-34 Barrier Block Accessories Lug-Type Terminal Strips Materials Insulation Material: UL 94 HB rated XPC, chocolate Contact Material: Steel Contact Plating: Cadmium Mechanical Characteristics Mounting Hole: .140" (3.56mm) diameter Strip Dimension: .0625" (1.59mm) thick x .375" (9.53mm) wide Lug Density: .375" (9.53mm) Ordering Information Mounting Catalog No. Centers 51 51A 51B 51C 51F 51L 51R 52 52A 52B 52C 52R 53 1.500 (38.10) 53A 1.500 (38.10) 53B .750 (19.05) 53C .750 (19.05) 53E 53F 54 1.875 (47.63) 54A 1.875 (47.63) 54B 54C 55 2.250 (57.15) 55A 2.250 (57.15) 55B 1.500 (38.10) 55C 1.500 (38.10) 56 2.625 (66.68) 56A 2.625 (66.68) 56B 1.875 (47.63) 56C 1.875 (47.63) 1 1 1 2 4 1/2 3 1 1 1 2 4 1 2 4 1 1 1 1 2 4 1 1 2 4 1 1 2 4 1 1 Lug Type Used In Position 2 3 4 5 6 7 8 2 4 1 1 1 3 2 4 1 1 1 1 1 2 4 2 4 1 1 1 1 1 1 2 4 1 1 2 4 1 1 1 1 3 1 1 1 1 1 1 1 1 2 4 1 1 1 1 1 1 1 1 1 1 2 4 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 4 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 4 1 1 2 4 1 1 1 1 2 4 1 1 1 1 2 4 2 4 1 1 Dimensions Marketed exclusively through distribution. 2-35 Call Toll Free: 1 (800) 323-9612 Jones Plugs/Sockets Series 300 Multiple Density Solder Eyelet ■ Solder lug terminals with .093" x .062" (2.36mm x 1.57mm) wiring holes. ■ Two-contact "Jones" connector is round, all others are rectangular. ■ For use in cable-to-panel and cable-to-cable applications. FEATURES ■ Designed for light and medium duty. ■ Plug prongs are .156" (3.96mm) wide and .047" (1.19mm) thick. ■ Polarized to prevent wrong-way insertion. ■ Plugs have projecting flat blades, sockets have recessed twin bellows. ■ Cable clamps of zinc and clear irridite-plated steel used for strain relief. ■ UL Recognized-file E170218 (UL 1977), E130965 (UL1863). ■ CSA-LR31996. ■ See Panel Cutout dimension on page (2-38). MATERIALS Insulation Material: Molded monoblock, general purpose phenolic, black UL94V-1 Contact Material: Plug: Brass Socket: Phosphor bronze Contact Plating: Cadmium Operating Temperature: Up to +105°C ELECTRICAL Hood Material: UL 94V-0 rated thermoplastic Operating Voltage: Current Rating: Contact Resistance: 250 VAC RMS maximum 10 Amps 16 Milliohms maximum Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-36 Jones Plugs/Sockets Series 300 Multiple Density Solder Eyelet Polarizing Patterns - 300 Series Marketed exclusively through distribution. 2-37 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series All-Plastic 300 Multiple Density Solder Eyelet Mounting Dimensions A Reference 2 in B mm in 1.016 C mm D in mm in mm 25.81 .750 19.05 - - 303 .453 11.51 304 .719 18.26 .781 19.84 1.000 25.40 - - 306 .719 18.26 1.031 26.19 1.000 25.40 - - 308 .719 18.26 1.281 32.54 1.000 25.40 - - 310 .719 18.26 1.578 40.08 1.000 25.40 - - 312 .953 24.21 1.266 32.16 1.250 31.75 - - 315-12 .953 24.21 1.516 38.51 1.250 31.75 - - 315 1.016 25.81 1.641 41.68 1.375 34.93 - - 318 1.016 25.81 1.953 49.61 1.375 34.93 .625 15.88 321 1.016 25.81 2.266 57.56 1.375 34.93 .469 11.91 324 1.016 25.81 2.578 65.48 1.375 34.93 .625 15.88 327 1.016 25.81 2.891 73.43 1.375 34.93 .781 19.84 330 1.016 25.81 3.203 81.36 1.375 34.93 .938 23.83 333 1.016 25.81 3.516 89.31 1.375 34.93 1.094 27.79 NOTE: For 300 Series 2 through 33 contact angle bracket connectors. All mounting holes are .156" (3.96mm) dia. Maximum chassis thickness is .063" (1.59mm) for bottom mounting. Mounting holes are located on center line unless otherwise shown. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-38 Jones Plugs/Sockets Series 300 No. of Contacts 2 3 4 6 8 10 12 15* 15 18 21 24 27 30 33 [.050” Multiple (1.27mm) Density Density Solder SolderCup/Wire Eyelet With Angle D-Microminiature] Bracket/Less Angle Bracket With Angle Bracket Catalog No. Catalog No. Plug Socket P-302-AB S-302-AB P-303-AB S-303-AB P-304-AB S-304-AB P-306-AB S-306-AB N/A N/A P-310-AB N/A P-312-AB N/A N/A S-315-12-AB P-315-AB S-315-AB P-318-AB S-318-AB P-321-AB S-321-AB P-324-AB S-324-AB P-327-AB S-327-AB P-330-AB S-330-AB P-333-AB S-333-AB Less Angle Bracket Catalog No. Catalog No. Plug Socket P-302-LAB S-302-LAB P-303-LAB S-303-LAB P-304-LAB S-304-LAB P-306-LAB S-306-LAB N/A N/A P-310-LAB N/A P-312-LAB N/A N/A S-315-12-LAB P-315-LAB S-315-LAB P-318-LAB S-318-LAB P-321-LAB S-321-LAB P-324-LAB S-324-LAB P-327-LAB S-327-LAB P-330-LAB S-330-LAB P-333-LAB S-333-LAB No. of Contacts 2 3 4 6 8 10 12 15 15 18 21 24 27 30 33 X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. No. of Contacts 2 3 4 6 8 10 12 15* A in .656 1.000 .750 1.000 -1.562 1.250 1.500 B mm in 16.67 25.40 19.05 25.40 -39.69 31.75 38.10 .438 .688 .688 -.688 .938 .938 C mm 11.11 17.46 17.46 -17.46 23.81 23.81 D in mm in mm .969 .750 1.000 1.000 -1.000 1.250 1.250 24.61 19.05 25.40 25.40 -25.40 31.75 31.75 1.219 1.062 1.312 1.312 -1.312 1.562 1.562 30.96 26.99 33.34 33.34 -33.34 39.69 39.69 *Special 15 contact arrangement to allow 12-position mating. L Reference 15 18 21 24 27 30 33 M in mm 1.625 1.938 2.250 2.563 2.875 3.188 3.500 41.28 49.23 57.15 65.10 73.03 80.98 88.90 in See note 1.250 .938 1.250 1.562 1.875 2.188 Polarizing Pin mm 31.75 23.81 31.75 39.69 47.63 55.58 NO NO NO 14 14 14 17 NOTE: 15-position plug and socket require only two mounting brackets, mounted on center of connector. Marketed exclusively through distribution. 2-39 Call Toll Free: 1 (800) 323-9612 2 Jones DURA-CON® Plugs/Sockets High Reliability Series All-Plastic 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Flush Plate 300 Series with Flush Plate (FP) 2 No. of Catalog No. Catalog No. Contacts Plug Socket 2 P-302-FP S-302-FP 3 P-303-FP S-303-FP 4 P-304-FP S-304-FP 6 P-306-FP S-306-FP 8 N/A N/A 10 P-310-FP N/A 12 P-312-FP N/A NOTE: Not available in contact sizes 15-33. X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. Dimensions - Plug or Socket No. of Contacts 2 3 4 6 8 10 12 A in 2.063 2.063 2.063 2.063 -2.563 2.563 B mm 52.40 52.40 52.40 52.40 -65.10 65.10 in 1.250 1.250 1.250 1.250 -1.750 1.750 C mm 31.75 31.75 31.75 31.75 -44.45 44.45 in 1.750 1.750 1.750 1.750 -2.250 2.250 D mm 44.45 44.45 44.45 44.45 -57.15 57.15 in .938 .688 .938 -1.500 1.188 mm 23.81 17.46 23.81 -38.10 30.16 E Max. in mm .719 18.26 .500 12.70 .750 19.05 .750 19.05 --.750 19.05 1.000 25.40 Panel Cutout Dimensions A Reference 303-FP 304-FP 306-FP 308-FP 310-FP 312-FP in .953 .703 .953 -1.516 1.203 B mm 24.21 17.86 24.21 -38.51 30.56 in .516 .766 .766 -.766 1.016 C mm 13.11 19.46 19.46 -19.46 25.81 in 1.750 1.750 1.750 -2.250 2.250 mm 44.45 44.45 44.45 -57.15 57.15 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-40 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] End Brackets 300 Series with End Brackets (EB) No. of Contacts 15 18 21 24 28 30 33 Catalog No. Plug P-315-EB P-318-EB P-321-EB P-324-EB P-328-EB P-330-EB P-333-EB Catalog No. Socket S-315-EB S-318-EB S-321-EB S-324-EB S-328-EB S-330-EB S-333-EB 2 NOTE: Not available in contact sizes 2-12. X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. Dimensions No. of Contacts 15 18 21 24 27 30 33 L ±.031 (.79mm) 2.313 58.75 2.625 66.68 2.938 74.63 3.250 82.55 3.563 90.50 3.875 98.43 4.188 106.38 M ±.031 (.79mm) 2.000 50.80 2.313 58.75 2.625 66.68 2.938 74.63 3.250 82.55 3.563 90.50 3.875 98.43 P ±.063 (1.59mm) 1.625 41.28 1.938 49.23 2.250 57.15 2.563 65.10 2.875 73.03 3.188 80.98 3.500 88.90 Polarizing Pin NO NO NO 14 14 14 17 Panel Cutout Dimensions A Reference 315-EB 318-EB 321-EB 324-EB 327-EB 330-EB 333-EB in 1.641 1.953 2.266 2.578 2.891 3.203 3.516 B mm 41.68 49.61 57.56 65.48 73.43 81.36 89.31 in 1.016 1.016 1.016 1.016 1.016 1.016 1.016 C mm 25.81 25.81 25.81 25.81 25.81 25.81 25.81 in 2.000 2.313 2.625 2.938 3.250 3.563 3.875 mm 50.80 58.75 66.68 74.63 82.55 90.50 98.43 Marketed exclusively through distribution. 2-41 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series All-Plastic 300 Multiple Density Solder Eyelet Recessed Plate 300 Series with Recessed Plate (RP) 2 No. of Contacts 2 3 4 6 8 10 12 Catalog No. Plug P-302-RP P-303-RP P-304-RP P-306-RP N/A P-310-RP P-312-RP Catalog No. Socket S-302-RP S-303-RP S-304-RP S-306-RP N/A N/A N/A NOTE: Not available in contact sizes 15-33. Y = length of plug or socket tails. Dimensions No. of Contacts 2 3 4 6 8 10 12 A in 2.063 2.063 2.063 2.063 -2.563 2.563 B mm 52.40 52.40 52.40 52.40 -65.10 65.10 in 1.500 1.500 1.500 1.500 -2.000 2.000 C mm 38.10 38.10 38.10 38.10 -50.80 50.80 in 1.750 1.750 1.750 1.750 -2.250 2.250 mm 44.45 44.45 44.45 44.45 -57.15 57.15 D Max. in mm 1.350 34.29 1.350 34.29 1.350 34.29 1.350 34.29 --1.850 46.99 1.850 46.99 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-42 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Shallow Bracket 300 Series with Shallow Bracket (SB) No. of Contacts 15 18 21 24 27 30 33 Catalog No. Plug P-315-SB P-318-SB P-321-SB P-324-SB P-327-SB P-330-SB P-333-SB Catalog No. Socket S-315-SB S-318-SB S-321-SB S-324-SB S-327-SB S-330-SB S-333-SB 2 NOTE: Not available in contact sizes 2-12. X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. Dimensions No. of Polarizing Contacts 15 18 21 24 27 30 33 A ±.031 (.79mm) in mm 1.688 42.86 2.000 50.80 2.313 58.75 2.625 66.68 2.938 74.63 3.250 82.55 3.563 90.50 M ±.031 (.79mm) in mm 2.125 53.98 2.438 61.93 2.750 69.85 2.063 52.40 3.375 85.73 3.688 93.68 4.000 101.60 L ±.063 (1.59mm) in mm 2.547 64.69 2.859 72.62 3.172 80.57 3.484 88.49 3.797 96.44 4.109 104.38 4.422 112.32 Polarizing Pin NO NO NO 14 14 14 17 Panel Cutout Dimensions A Reference 315-SB 318-SB 321-SB 324-SB 327-SB 330-SB 333-SB in 1.750 2.063 2.375 2.688 3.000 3.313 3.625 B mm 44.45 52.40 60.33 68.28 76.20 84.15 92.08 in 1.156 1.156 1.156 1.156 1.156 1.156 1.156 C mm 29.36 29.36 29.36 29.36 29.36 29.36 29.36 in 2.125 2.438 2.750 3.062 3.376 3.688 4.000 mm 53.98 61.93 69.85 77.77 85.75 93.68 101.60 Marketed exclusively through distribution. 2-43 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series All-Plastic 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Deep Bracket 300 Series Deep Bracket (DB) 2 No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Plug P-302-DB P-303-DB P-304-DB P-306-DB N/A N/A P-312-DB P-315-DB P-318-DB P-321-DB P-324-DB P-327-DB P-330-DB P-333-DB Catalog No. Socket S-302-DB S-303-DB S-304-DB S-306-DB N/A N/A N/A S-315-DB S-318-DB S-321-DB S-324-DB S-327-DB S-330-DB S-333-DB Dimensions Y = length of plug or socket tails. L ±.063 (1.60mm) in mm 2.813 71.44 3.125 79.38 3.437 87.31 3.750 95.25 4.063 103.19 4.375 111.13 4.688 119.06 No. of Contacts 15 18 21 24 27 30 33 M ±.031 (.79mm) in mm 2.375 60.33 2.688 68.28 3.000 76.20 3.313 84.15 3.625 92.08 3.938 100.03 4.250 107.95 Polarizing Pin NO NO NO 14 14 14 17 Panel Cutout Dimensions A Reference 302-DB thru 312-DB 315-DB 318-DB 321-DB 324-DB 327-DB 330-DB 333-DB B C in mm in mm in mm 1.453 2.000 2.313 2.625 2.938 3.250 3.562 3.875 36.91 50.80 58.75 66.68 74.63 82.55 90.47 98.43 1.125 1.438 1.438 1.438 1.438 1.438 1.438 1.438 28.58 36.53 36.53 36.53 36.53 36.53 36.53 36.53 1.750 2.376 2.688 3.000 3.312 3.626 3.938 4.250 38.10 60.35 68.28 76.20 84.12 92.10 100.03 107.95 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-44 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet With Hood & 90° Clamp D-Microminiature] 300 Series with Hood and 90° Cable Clamp (CCE) No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Plug P-302-CCE P-303-CCE P-304-CCE P-306-CCE N/A P-310-CCE P-312-CCE P-315-CCE P-318-CCE P-321-CCE P-324-CCE P-327-CCE P-330-CCE P-333-CCE Catalog No. Socket S-302-CCE S-303-CCE S-304-CCE S-306-CCE N/A N/A N/A S-315-CCE S-318-CCE S-321-CCE S-324-CCE S-327-CCE S-330-CCE S-333-CCE 2 Dimensions No. of Contacts 2 3 4 6 8 10 12 A +.016 (.41mm) in mm .691 17.55 1.034 26.26 .786 19.96 1.036 26.31 --1.592 40.44 1.286 32.66 No. of Contacts 15 18 21 24 27 30 33 B +.016 (.41mm) in mm .472 11.99 .724 18.39 .724 18.39 --.720 18.29 .974 24.74 C +.031 (.79mm) in mm .953 24.21 .953 24.21 .953 24.21 .078 27.38 --1.203 30.56 1.203 30.56 E in 2.514 2.826 3.139 3.451 3.764 4.076 4.389 L mm 63.85 71.78 79.73 87.66 95.61 103.53 111.48 in 1.795 2.107 2.420 2.732 3.045 3.357 3.670 mm 45.59 53.52 61.47 69.39 77.34 85.27 93.22 G in .313 .344 .453 .469 -.359 .422 mm 7.95 8.74 11.51 11.91 -9.12 10.72 Cable Opening in mm .563 14.30 .563 14.30 .625 15.88 .625 15.88 .625 15.88 .750 19.05 .750 19.05 Cable "D" Opening in mm .313 7.95 .250 6.35 .375 9.53 .438 11.13 --.500 12.70 .563 14.30 Polarizing Pin NO NO NO 14 14 14 17 Marketed exclusively through distribution. 2-45 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series All-Plastic 300 [.050” (1.27mm) Density Multiple Density Solder Eyelet Solder Cup/Wire With Hood & 180° Clamp D-Microminiature] 300 Series with Hood and 180° Cable Clamp (CCT) 2 No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Plug P-302-CCT P-303-CCT P-304-CCT P-306-CCT N/A P-310-CCT P-312-CCT P-315-CCT P-318-CCT P-321-CCT P-324-CCT P-327-CCT P-330-CCT P-333-CCT Catalog No. Socket S-302-CCT S-303-CCT S-304-CCT S-306-CCT N/A N/A N/A S-315-CCT S-318-CCT S-321-CCT S-324-CCT S-327-CCT S-330-CCT S-333-CCT Dimensions No. of Contacts 2 3 4 6 8 10 12 A ± .016 (.41mm) in mm .691 17.55 1.034 26.26 .786 19.96 1.036 26.31 --1.592 40.44 1.286 32.66 No. of Contacts 15 18 21 24 27 30 33 B ± .016 (.41mm) in mm .472 11.99 .724 18.39 .724 18.39 --.720 18.29 .974 24.74 L in 1.795 2.107 2.420 2.732 3.045 3.357 3.670 mm 45.59 53.52 61.47 69.39 77.34 85.27 93.22 C ± .031 (.79mm) in mm .953 24.21 .953 24.21 .953 24.21 1.078 27.38 --1.203 30.56 1.203 30.56 Cable Opening in mm .563 14.30 .563 14.30 .625 15.88 .625 15.88 .625 15.88 .750 19.05 .750 19.05 “D” Cable Opening in mm .375 9.53 .313 7.95 .375 9.53 .438 11.13 --.500 12.70 .563 14.30 E ± .031 (.79mm) in mm .359 9.12 .359 9.12 .469 11.91 .484 12.29 --.500 12.70 .469 11.91 Polarizing Pin NO NO NO 14 14 14 17 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-46 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] 180° Clamp w/Locks 300 Series Plug with Hood and Lock (CCT-L) and Socket with Hood and Keeper (CCT-K) No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Catalog No. Plug w/ Lock Socket w/ Keeper P-302-CCT-L S-302-CCT-K P-303-CCT-L S-303-CCT-K P-304-CCT-L S-304-CCT-K P-306-CCT-L S-306-CCT-K N/A N/A P-310-CCT-L N/A P-312-CCT-L N/A P-315-CCT-L S-315-CCT-K P-318-CCT-L S-318-CCT-K P-321-CCT-L S-321-CCT-K P-324-CCT-L S-324-CCT-K P-327-CCT-L S-327-CCT-K P-330-CCT-L S-330-CCT-K P-333-CCT-L S-333-CCT-K Socket 2 Plug Dimensions No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 A ± .016 (.41mm) in mm .691 17.5 1.034 26.26 .786 19.96 1.036 26.31 --1.592 40.44 1.286 32.66 1.795 45.59 2.107 53.52 2.420 61.47 2.732 69.39 3.045 77.34 3.357 85.27 3.670 93.22 B ± .016 (.41mm) in mm .472 11.99 .724 18.39 .724 18.39 --.720 18.29 .974 24.74 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 C ± .031 (.79mm) in mm .953 24.21 .953 24.21 .953 24.21 1.078 27.38 --1.203 30.56 1.203 30.56 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 F in .359 .359 .469 .484 -.500 .469 .712 .712 .712 .712 .712 .712 .712 mm 9.12 9.12 11.91 12.29 -12.70 11.91 18.08 18.08 18.08 18.08 18.08 18.08 18.08 “D” Cable Opening Polarizing in mm Pin .375 9.53 -.313 7.94 -.375 9.53 -.438 11.13 ----.500 12.70 -.563 14.30 -.563 14.30 NO .563 14.30 NO .625 15.88 NO .625 15.88 14 .625 15.88 14 .750 19.05 14 .750 19.05 17 Marketed exclusively through distribution. 2-47 Call Toll Free: 1 (800) 323-9612 DURA-CON® High Reliability Miscellaneous All-Plastic [.050” (1.27mm) Density Multiple Density Solder Cup/Wire Solder Eyelet D-Microminiature] JONES PLUGS AND SOCKETS 300 SERIES MATING CHART PLUGS MOUNTING CONFIG. AB 2 AB DB FP RP EB SB CCE CCT •* • •* • • • • • • • • • • • • • • • • •* •* •* •* •* •* •* •* • • •* •* •* • • DB FP SOCKETS RP EB SB CCE CCT • • • • • CCT-L CCT-K LAB • • • • • • • • • CCT-L • • CCT-K • LAB • • • • • • • • • • These are recommended configurations. •* These are possible configurations, but not normally recommended. NOTE: Cinch layout S315-12 is available only in “AB” or “LAB”. Replacement Drive Pins for Series 300 Plugs and Sockets with Cable Caps and Clamps Dimensions No. of Contacts 2 3 4,6,8,10* 12 15-33* Ordering Information Dim. L +.005 (.13mm) in mm .687 17.45 .468 11.89 .718 18.24 .953 28.58 1.125 28.58 No. of Contacts 2 3 4,6,8,10* 12 15-33* Catalog No. 302R 303R 304R 312R 333R *10 contact size and 15 through 33 contact sizes require two pins per unit; all other sizes require only one. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-48 Jones Plugs/Sockets Series 2400 Multiple Density Solder Eyelet ■ For use in cable-to-cable and cable-to-panel applications. ■ Designed for medium duty. ■ Plug prongs are .250" (6.35mm) wide and .055" (1.40mm) thick. ■ Socket contacts have solder eyelet contacts of .093" diameters. ■ Polarized to prevent wrong-way insertion. FEATURES ■ Plugs have projecting flat blades, sockets have recessed twin bellows. ■ Cable clamps of zinc and clear irridite-plated steel are used for strain relief. ■ Bifurcated bellows socket contact provides four individual flexing surfaces for maximum contact with the blade. ■ Plugs and sockets have recessed pockets with barriers around the contacts. ■ A shoulder extends around the face (mating) side of both plug and socket presenting a finished appearance when mounted in bracket or cap. ■ Intermates with existing 400 Series Products on the market. ■ UL Recognized - file - E17021B (UL1977) E130965 (1863). ■ CSA - LR31996-2. ELECTRICAL MATERIALS ■ Panel cutout dimensions (See page 2-57). Insulation Material: Molded monoblock, general purpose phenolic, black Contact Material: Plug: Brass Socket: Phosphor bronze Contact Plating: Cadmium Operating Temperature: Up to +105°C Hood Material: Formed metal with dielectric liner in hood to prevent shorting Operating Voltage: Current Rating: Current Resistance: 250 VAC RMS 15 Amps 1.0 Milliohms maximum Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-50 Jones Plugs/Sockets Series 2400 Multiple Density Solder Eyelet Less Angle Bracket 2400 Series Less Angle Bracket No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-LAB P-2406-LAB P-2408-LAB P-2410-LAB P-2412-LAB Catalog No. Socket S-2402-LAB S-2404-LAB S-2406-LAB S-2408-LAB S-2410-LAB S-2412-LAB Plug Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 M in .563 1.000 1.438 1.875 2.313 2.750 L mm 14.29 25.40 36.51 47.63 58.74 69.85 in .656 1.094 1.531 1.969 2.406 1.844 mm 16.67 27.78 38.89 50.01 61.12 46.83 Marketed exclusively through distribution. 2-51 Call Toll Free: 1 (800) 323-9612 ® Jones DURA-CON High Reliability Plugs/Sockets All-Plastic Series 2400 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] With Angle Bracket 2400 Series with Angle Bracket 2 No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-AB P-2406-AB P-2408-AB P-2410-AB P-2412-AB Catalog No. Socket S-2402-AB S-2404-AB S-2406-AB S-2408-AB S-2410-AB S-2412-AB Plug Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 M in .563 1.000 1.438 1.875 2.313 2.750 L mm 14.29 25.40 36.51 47.63 58.74 69.85 in .656 1.094 1.531 1.969 2.406 2.844 mm 16.67 27.78 38.89 50.01 61.12 72.24 Panel Cutout dimensions are on page 2-61. Call Toll Free: 1 (800) 323-9612 Marketed exclusively through distribution. 2-52 Jones Plugs/Sockets Series 2400 [.050” Multiple (1.27mm) DensityDensity Solder Solder Cup/Wire Eyelet D-Microminiature] Shallow Bracket 2400 Series with Shallow Bracket No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-SB P-2406-SB P-2408-SB P-2410-SB P-2412-SB Catalog No. Socket S-2402-SB S-2404-SB S-2406-SB S-2408-SB S-2410-SB S-2412-SB 2 Plug Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 L in 1.500 1.937 2.375 2.813 3.250 3.688 M mm 38.10 49.21 60.33 71.45 82.55 93.68 in 1.062 1.500 1.938 2.375 2.813 3.250 mm 26.99 38.10 49.23 60.33 71.45 82.55 Panel Cutout dimensions are on page 2-61. R. Max. in mm 1.766 19.45 1.234 31.34 1.672 42.47 2.109 53.57 2.547 64.69 2.984 75.80 Marketed exclusively through distribution. 2-53 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series All-Plastic 2400 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Deep Bracket 2400 Series with Deep Bracket 2 No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-DB P-2406-DB P-2408-DB P-2410-DB P-2412-DB Catalog No. Socket S-2402-DB S-2404-DB S-2406-DB S-2408-DB S-2410-DB S-2412-DB Plug Socket Plug or Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 B in .922 1.359 1.797 2.234 2.672 3.109 L mm 23.42 34.53 45.64 56.74 67.87 78.97 in 1.750 2.188 2.625 3.063 3.500 3.938 M mm 44.45 55.58 57.53 77.79 88.90 100.03 in 1.313 1.750 2.188 2.625 3.063 3.500 mm 33.35 44.45 55.58 66.68 77.80 88.90 Panel Cutout dimensions are on page 2-61. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-54 Jones Plugs/Sockets Series 2400 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] With Hood & 90° Clamp 2400 Series with Hood and 90° Clamp No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-CCE P-2406-CCE P-2408-CCE P-2410-CCE P-2412-CCE Catalog No. Socket S-2402-CCE S-2404-CCE S-2406-CCE S-2408-CCE S-2410-CCE S-2412-CCE 2 Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 L in .625 1.062 1.500 1.937 2.375 2.813 C mm 15.88 26.99 38.10 49.21 60.33 71.45 in 1.375 1.375 1.375 1.344 1.344 1.312 mm 34.93 34.93 34.93 34.13 34.13 33.34 Cable Opening in mm .375 9.53 .438 11.11 .438 11.11 .563 14.29 .563 14.29 .625 15.88 Marketed exclusively through distribution. 2-55 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series All-Plastic 2400 Multiple Density Solder Eyelet With Hood & 180° Clamp 2400 Series with Hood and 180° Clamp 2 No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-CCT P-2406-CCT P-2408-CCT P-2410-CCT P-2412-CCT Catalog No. Socket S-2402-CCT S-2404-CCT S-2406-CCT S-2408-CCT S-2410-CCT S-2412-CCT Plug Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 L in .625 1.062 1.500 1.937 2.375 2.813 Cable Opening in mm .313 7.94 .438 11.11 .438 11.11 .563 14.29 .563 14.29 .625 15.88 mm 15.88 26.99 38.10 49.21 60.33 71.45 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-56 Jones Plugs/Sockets Series 2400 Panel Cutout Dimensions Angle Bracket A Reference in mm P-2402-AB --S-2402-AB 1.188 30.16 P-2404-AB S-2404-AB 1.625 41.28 P-2406-AB S-2406-AB 2.063 52.40 P-2408-AB S-2408-AB 2.500 63.50 P-2410-AB S-2410-AB 2.938 74.63 P-2412-AB S-2412-AB 3.375 85.73 Panel Cutout Dimensions Shallow Bracket A Reference in mm P-2402-SB S-2402-SB 1.062 27.00 P-2404-SB S-2404-SB 1.500 38.10 P-2406-SB S-2406-SB 1.938 49.22 P-2408-SB S-2408-SB 2.376 60.34 P-2410-SB S-2410-SB 2.812 71.44 P-2412-SB S-2412-SB 3.250 82.56 Panel Cutout Dimensions Deep Bracket A Reference in mm P-2402-DB S-2402-DB 1.312 33.34 P-2404-DB S-2404-DB 1.750 44.46 P-2406-DB S-2406-DB 2.188 55.56 P-2408-DB S-2408-DB 2.624 66.68 P-2410-DB P-2410-DB 3.062 77.80 P-2412-DB S-2412-DB 3.500 88.90 [.050” (1.27mm) Density Solder Panel Cup/Wire Cutout Dimensions D-Microminiature] B C in -1.008 mm -25.60 in -1.015 mm -25.78 1.445 36.70 1.015 25.78 1.886 47.83 1.015 25.78 2.320 58.93 1.015 25.78 2.758 70.05 1.015 25.78 3.195 81.15 1.015 25.78 in mm in mm .813 20.64 1.156 29.37 1.250 31.75 1.156 29.37 1.688 42.86 1.156 29.37 2.125 53.98 1.156 29.37 2.563 65.10 1.156 29.37 3.000 76.20 1.156 29.37 in mm in mm .938 23.81 1.438 36.51 1.375 34.93 1.438 36.51 1.813 46.04 1.438 36.51 2.250 57.15 1.438 36.51 2.688 68.28 1.438 36.51 3.125 79.38 1.438 36.51 B 2 C B C Marketed exclusively through distribution. 2-57 Call Toll Free: 1 (800) 323-9612 Contact positions 3, 4, 5, 6, 7, and 8. Pre-assembled with standard shielded cable lengths; consult factory for other lengths. Molded-in strain relief. Cable and overmold available in standard colors: black or beige. Contacts available with gold over nickel. Shielding system designed to meet FCC requirements for EMI/RFI suppression. UL Recognized - file E170218 (UL1977). CSA Certified - file LR31996-6. Insulation Material: Plug Insulator: UL 94V-0 rated nylon Plug Overmold: PVC (black or beige) Cable Jacket: PVC (black or beige) Contact Material: Plug: Phosphor bronze Contact Plating: Option 1: Gold Flash over nickel underplate overall Option 2: Option 1 plus additional gold in mating area for total thickness of 30µin. Shield Material: Steel Shield Plating: Nickel Standard Cable Shielded cable with 0.197 inch OD Composition: jacket over 28 AWG stranded wire conductors. Contact factory for custom cable requirements. Shock: MIL-STD-202, Method 213, Condition C Operating Temperature: -40°C to +70°C Heat Resistance: 196 hrs. at 100°C Salt Spray: MIL-STD-202, Method 101D, Condition D Vibration: MIL-STD-202, Method 204, Condition B Humidity: MIL-STD-202, Method 103, 48 hrs. at 90-95% RH at 40°C MECHANICAL ELECTRICAL MATERIALS ■ ■ ■ ■ ■ ■ ■ ■ Single-Ended Cable Assembly ENVIRONMENTAL FEATURES Circular Mini DIN Plugs Voltage Rating: Current Rating: Contact Resistance: Insulation Resistance: 500 VAC RMS, 707 VDC 1 Amp at 100 VAC 2 Amps at 12 VDC Contact to contact: 30 milliohms maximum Shield to shield: 50 milliohms maximum 500 megohms minimum at 500 VDC 100 megohms minimum after humidity Durability: Withstands 500 mating/unmating cycles Mating Force: 10 lb. (4.5 kg) maximum Unmating Force: 1 lb. (0.9 kg) minimum Contact Retention: 3 lb. minimum Call Toll Free: 1 (800) 323-9612 PIN NO 1 2 3 4 5 6 7 8 COLOR BLACK GREEN RED BROWN BLUE WHITE YELLOW GRAY Marketed exclusively through distribution. 2-58 Circular Mini DIN Plugs Single-Ended Cable Assembly Dimensions 3-Contact 4-Contact 5-Contact 7-Contact 6-Contact 8-Contact Ordering Information: (NOTE: One meter = 39.62 inches.) For cable assemblies with plug on one end. Plug features contacts with Option 1 plating (gold flash over nickel). No. of Contacts 3 4 4 4 5 6 6 6 7 7 7 8 8 8 Cable Length Meter Black Color Cable & Overmold Catalog No. Beige Color Cable & Overmold Catalog No. 1 1 2 3 1 1 2 3 1 2 3 1 2 3 MDC-3P05 MDC-4P05 MDC-4P13 MDC-4P15 MDC-5P05 MDC-6P05 MDC-6P13 MDC-6P15 MDC-7P05 MDC-7P13 MDC-7P15 MDC-8P05 MDC-8P13 MDC-8P15 MDC-3P08 MDC-4P08 MDC-4P53 MDC-4P55 MDC-5P08 MDC-6P08 MDC-6P53 MDC-6P55 MDC-7P08 MDC-7P53 MDC-7P55 MDC-8P08 MDC-8P53 MDC-8P55 The above cable assemblies are highly recommended for general commercial applications. Contact factory for other lengths or colors. For cable assemblies with plug on one end. Plug features contacts with Option 2 plating (Option 1 with additional gold in mating area). NOTE: Total gold thickness in mating area is 30 microinches. No. of Contacts 3 4 5 6 7 8 Cable Length Meter Black Color Cable & Overmold Catalog No. Beige Color Cable & Overmold Catalog No. 1 1 1 1 1 1 MDC-3P06 MDC-4P06 MDC-5P06 MDC-6P06 MDC-7P06 MDC-8P06 MDC-3P09 MDC-4P09 MDC-5P09 MDC-6P09 MDC-7P09 MDC-8P09 The above cable assemblies are recommended where greater contact durability is required. Additional Capabilities • Additional lengths or colors of the above cable assemblies can be produced. Consult factory for custom orders. • Custom-plated contacts can be provided. Consult factory for information. Marketed exclusively through distribution. 2-59 Call Toll Free: 1 (800) 323-9612 FEATURES Circular Mini DIN Plugs Plug Components for Cable Termination ■ Individual components available for cable assembly with overmolding. ■ Plug insulator available with contact positions 3, 4, 5, 6, 7, and 8. ■ Seamless shield case is crimped to cable shield; designed to meet FCC requirements for EMI/RFI suppression. ■ One-piece shield case - no extra ferrules or shields required with Cinch Shield Crimp Tools. ■ Contacts are crimp style and supplied on reels. ■ Contacts available with gold over nickel in several options. ■ Tools available to facilitate reliable, efficient termination. ■ Terminates 24 to 30 AWG wire. ■ UL Recognized - file E170218 (UL1977). Insulation Material: Plug Insulator: 94 V-0 rated nylon Contact Material: Plug: Phosphor bronze MATERIALS Contact Plating: Option 1: Gold flash over nickel underplate overall Option 2: Option 1 plus additional gold in mating area for total thickness of 30µin. Option 3: Option 1 plus additional gold in mating area for total thickness of 50µin. Shield Case Material: Steel Shield Case Plating: Nickel Dimensions 3-Contact 6-Contact 4-Contact 5-Contact 7-Contact 8-Contact Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-60 Circular Mini DIN Plugs Plug Components for Cable Termination Ordering Information For each Plug Assembly, the following components are needed: one plug insulator, one shield, and adequate contacts. Component Type Insulator Shield Case Contact Description 3 Position Insulator 4 Position Insulator 5 Position Insulator 6 Position Insulator 7 Position Insulator 8 Position Insulator Metal Shield Case Option 1 Plating Option 1 Plating Option 2 Plating Option 2 Plating Option 3 Plating Quantity 1 1 1 1 1 1 1 300 on Reel 15,000 on Reel 300 on Reel 15,000 on Reel 15,000 on Reel Catalog No. MDX-3PI MDX-4PI MDX-5PI MDX-6PI MDX-7PI MDX-8PI MDX-PZ MDX-P-3A MDX-P-15A MDX-P-3B MDX-P-15B MDX-P-15D Tool Ordering Information The following tools are recommended for Mini Din Cable Plug Assembly. One tool of each type is required. Tool Type Contact Crimp Contact Insertion Insulator Insertion Shield Crimp Description Stripper-Crimper Machine Complete, Includes Dies Contact Crimp Hand Tool Crimps using 300 Contact Reels Combination Contact Insertion and Insulator Insertion Tool Contact Insertion Hand Tool Fixture used with MDT-P28 Insulator Insertion Bench Mounted Tool Insulator Insertion Hand Tool Pneumatic Crimp Tool Catalog No. MDT-P25 MDT-P35 MDT-P41 MDT-P28 MDT-P29 MDT-P34 MDT-P30 MDT-P81 Overview of Assembly Steps • Prepare multi-conductor cable. • Crimp contacts onto individual conductors using tool MDT-P25 or tool MDT-P35. • Insert contact with conductor into insulator using tool MDT-P41 or have insertion tool MDT-P28 with insulator locating vice MDT-P29. • Insert insulator into the shield case using tool MDT-P34 or MDT-P30. • Crimp the shield case onto the cable shield using tool MDT-P81. • Overmold plastic to complete the assembly. Marketed exclusively through distribution. 2-61 Call Toll Free: 1 (800) 323-9612 FEATURES CARDCON ™ Edge Connector Commercial ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ .100" (2.54mm) Density Dip Solder AT and XT versions available. Dip solder tails on .200" (5.08mm) row centers double readout. Bifurcated semi-bellows contacts for added contact reliability. Ideal for applications involving vibration or board irregularities. Contact positions: 12, 15, 18, 20, 22, 25, 28, 30, 31, 36, 37, 40, 43, 44, 49, 50, 52, 60, 70, AT, and XT. Accepts .062" (1.59mm) thick PC boards. Available less mounting ears, or with .128" (3.25mm) mounting holes or 4-40 threaded holes. Meets applicable performance criteria of MIL-C-21097. Tube packaging available. UL Recognized - file E170218 (UL1977) E130965 (UL1863). MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS Insulation Material: UL 94V-0 rated glass-filled polyester, black Contact Material: Spring brass Standard Contact Plating: 10µin. selective gold over nickel, 50µin. nickel in contact area, tin on tails XT, AT Plating: 30µin. selective gold over 50µin. nickel in contact area, tin on tails Shock: Per MIL-STD-202E, Method 213, Condition C Operating Temperature: -65°C to +105°C Vibration: Per MIL-STD-202E, Method 204, Condition B Humidity: Per MIL-STD-202, Method 103, Condition B Accessories: Polarizing Key: Two types (order separately): a) for between-contact polarization and b) for in-contact polarization. See page 2-74 for more information. Card Guide Posts: (order separately) Attach to mounting ears and guide PC board into connector. See page 2-74 for more information. Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: 650 VAC RMS (@ sea level) 3 Amps 10 Milliohms maximum 5000 Megohms minimum Individual Contact Insertion and Separation Force: 12oz. maximum with .070" (1.78mm) blade; 1 oz. minimum with .054" (1.37mm) blade Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-62 CARDCON ™ Edge Connector Commercial .100" (2.54mm) Density Dip Solder Dimensions No. of Pos./Cont. 12/24 15/30 18/36 18/36+ 31/62IBM 20/40 22/24 25/50 28/56 30/60 31/62 31/62IBM 36/72 37/74 40/80 43/86 44/88 49/98 50/100 52/104 60/120 70/140 A B C D E F in 1.000 1.300 1.600 mm 25.40 33.02 40.64 in 1.100 1.400 1.700 mm 27.94 35.56 43.18 in 1.300 1.600 1.900 mm 33.02 40.64 48.26 in 1.460 1.760 2.060 mm 37.08 44.70 52.32 in 1.775 2.075 2.375 mm 45.09 52.71 60.33 in 2.035 2.335 2.635 mm 51.69 59.31 66.93 5.000 1.800 2.000 2.300 2.600 2.800 2.900 2.900 3.400 3.500 3.800 4.100 4.200 4.700 4.800 5.000 5.800 6.800 127.00 45.72 50.80 58.42 66.04 71.12 73.66 73.66 86.36 88.90 96.52 104.14 106.68 119.38 121.92 127.00 147.32 172.72 5.100 1.900 2.100 2.400 2.700 2.900 3.000 3.000 3.500 3.600 3.900 4.200 4.300 4.800 4.900 5.100 5.900 6.900 129.54 48.26 53.34 60.96 68.58 73.66 76.20 76.20 88.90 91.44 99.06 106.68 109.22 121.92 124.46 129.54 149.86 175.26 5.300 2.100 2.300 2.600 2.900 3.100 3.200 3.200 3.700 3.800 4.100 4.400 4.500 5.000 5.100 5.300 6.100 7.100 134.62 53.34 58.42 66.04 73.66 78.74 81.28 81.28 93.98 96.52 104.14 111.76 114.30 127.00 129.54 134.62 154.94 180.34 5.460 2.260 2.460 2.760 3.060 3.260 3.360 3.360 3.860 3.960 4.260 4.560 4.660 5.160 5.260 5.460 6.260 7.260 138.68 57.40 62.48 70.10 77.72 82.80 85.34 85.34 98.04 100.58 108.20 115.82 118.36 131.06 133.60 138.68 159.00 184.40 5.775 2.575 2.775 3.075 3.375 3.575 3.675 3.675 4.175 4.275 4.575 4.875 4.975 5.475 5.575 5.775 6.575 7.575 146.69 65.41 70.49 78.11 85.73 90.81 93.35 93.35 106.05 108.59 116.21 123.83 126.37 139.07 141.61 146.69 167.01 192.41 6.035 2.835 3.035 3.335 3.635 3.835 3.935 3.935 4.435 4.535 4.835 5.135 5.235 5.735 5.835 6.035 6.835 7.835 153.29 72.01 77.09 84.71 92.33 97.41 99.95 99.95 112.63 115.19 122.81 130.43 132.97 145.67 148.21 153.29 173.61 199.01 Ordering Information No. of Pos./Cont. 12/24 15/30 18/36 18/36+ 31/62 IBM 20/40 22/44 25/50 28/56 30/60 31/62 31/62 IBM 36/72 37/74 40/80 43/86 44/88 49/98 50/100 52/104 60/120 70/140 Less Mounting Ears Catalog No. 50-12SN-12 50-15SN-12 50-18SN-12 .128" (3.25mm) Mounting Holes Catalog No. 50-12SN-11 50-15SN-11 50-18SN-11 4-40 Threaded Holes Catalog No. 50-12SN-13 50-15SN-13 50-18SN-13 50-52SN-AT 50-20SN-12 50-22SN-12 50-25SN-12 50-28SN-12 50-30SN-12 50-31SN-12 50-31SN-XT 50-36SN-12 50-37SN-12 50-40SN-12 50-43SN-12 50-44SN-12 50-49SN-12 50-50SN-12 50-52SN-12 50-60SN-12 50-70SN-12 50-20SN-11 50-22SN-11 50-25SN-11 50-28SN-11 50-30SN-11 50-31SN-11 50-36SN-11 50-37SN-11 50-40SN-11 50-43SN-11 50-44SN-11 50-49SN-11 50-50SN-11 50-52SN-11 50-60SN-11 50-70SN-11 50-20SN-13 50-22SN-13 50-25SN-13 50-28SN-13 50-30SN-13 50-31SN-13 50-36SN-13 50-37SN-13 50-40SN-13 50-43SN-13 50-44SN-13 50-49SN-13 50-50SN-13 50-52SN-13 50-60SN-13 50-70SN-13 Marketed exclusively through distribution. 2-63 Call Toll Free: 1 (800) 323-9612 MATERIALS FEATURES CARDCON ™ Edge Connector Commercial .156" (3.96mm) Density Dip Solder/Solder Eyelet ■ Dip solder tails single readout and double readout on .140" (3.56mm) row centers or .200" (5.08mm) row centers. ■ Solder eyelet, single readout and double readout on .200" (5.08mm) row centers. ■ Available with unique tails for PC board retention; holds the connector firmly on the board during wave soldering operations. ■ Bifurcated semi-bellows contacts for added contact reliability. ■ Ideal for applications involving vibration or board irregularities. ■ Contact positions: 6, 10, 12, 15, 18, 22, 24, and 25. ■ Accepts single- or double-sided .062" (1.59mm) thick PC boards. ■ Available less mounting ears or with .128" (3.25mm) mounting hole. ■ Meets applicable performance criteria of MIL-C-21097. ■ UL Recognized - file E170218 (UL1977) E130965 (UL1863). Insulation Material: UL 94V-0 rated glass-filled polyester, black Contact Material: Spring brass Contact Plating: 10µ" selective gold over 30µ" nickel in contact area, tin on tails Shock: Per MIL-STD-202E, Method 213, Condition C ENVIRONMENTAL Operating Temperature: -65°C to +105°C Vibration: Per MIL-STD-202E, Method 204, Condition B Humidity: Per MIL-STD-202, Method 103, Condition B Accessories: Polarizing Key: Two types (order separately): a) for between-contact polarization and b) for in-contact polarization See page 2-72 for more information. MECHANICAL ELECTRICAL Card Guide Posts: (order separately): Attach to mounting ears and guide PC board into connector See page 2-72 for more information. Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: 1800 VAC RMS (@ sea level) 5 Amps 6 Milliohms maximum 5000 Megohms minimum Individual Contact Insertion and Separation Force: 16 oz. maximum with .070" (1.78mm) blade; 1 oz. minimum with .054" (1.37mm) blade Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-64 CARDCON ™ Edge Connector Commercial [.050” (1.27mm) Density .156" (3.96mm) Density Solder Cup/Wire Dip Solder/Solder Eyelet D-Microminiature] 2 Dimensions No. of Pos./Cont. 6/12 10/20 12/24 15/30 18/36 22/44 24/48 25/50 A In 1.785 2.410 2.723 3.191 3.660 4.285 4.598 4.754 mm 45.34 61.21 69.16 81.05 92.96 108.84 116.79 120.75 B in mm 1.531 38.89 2.156 54.76 2.469 62.71 2.937 74.60 3.406 86.51 4.031 102.39 4.344 110.34 4.500 114.30 C in 1.239 1.874 2.177 2.645 3.114 3.739 4.052 4.208 mm 31.47 47.34 55.30 67.18 79.10 94.94 102.92 106.88 D in 1.100 1.724 2.036 2.504 2.972 3.596 3.911 4.067 mm 27.94 43.79 51.71 63.60 75.49 91.34 99.34 103.30 Ordering Information No. of Less Mounting Ears .128 Mounting Hole Pos./Cont. Catalog No. Catalog No. Solder eyelet, single readout 6/6 10/10 12/12 15/15 18/18 22/22 24/24 25/25 50-6SN-8 50-10SN-8 50-12SN-8 50-15SN-8 50-18SN-8 50-22SN-8 50-24SN-8 50-25SN-8 50-6SN-7 50-10SN-7 50-12SN-7 50-15SN-7 50-18SN-7 50-22SN-7 50-24SN-7 50-25SN-7 No. of Less Mounting Ears .128 Mounting Hole Pos./Cont. Catalog No. Catalog No. Dip solder tails, single readout, .156" (3.96mm) long No. of Less Mounting Ears .128 Mounting Hole Pos./Cont. Catalog No. Catalog No. Dip solder tails, double readout, .140" (3.55mm) row spacing, .125" (3.18mm) long 6/6 10/10 12/12 15/15 18/18 22/22 24/24 25/25 6/12 10/20 12/24 15/30 18/36 22/24 24/48 25/50 50-6SN-6 50-10SN-6 50-12SN-6 50-15SN-6 50-18SN-6 50-22SN-6 50-24SN-6 50-25SN-6 50-6SN-5 50-10SN-5 50-12SN-5 50-15SN-5 50-18SN-5 50-22SN-5 20-24SN-5 50-25SN-5 50-12SN-4 50-20SN-4 50-24SN-4 50-30SN-4 50-36SN-4 50-44SN-4 50-48SN-4 50-50SN-4 50-12SN-2 50-20SN-2 50-24SN-2 50-30SN-2 50-36SN-2 50-44SN-2 50-48SN-2 50-50SN-2 Solder eyelet, double readout, .200" (5.08mm) row spacing Dip solder tails, double readout, .200" (5.08mm) row spacing, .156" (3.96mm) long Dip solder tails with unique board retention feature .200" (5.08mm) row spacing, .156" (3.96mm) long 6/12 10/20 12/24 15/30 18/36 22/24 24/28 25/50 6/12 10/20 12/24 15/30 18/36 22/44 24/48 25/50 6/12 10/20 12/24 15/30 18/36 22/44 24/48 25/50 50-12SN-10 50-20SN-10 50-24SN-10 50-30SN-10 50-36SN-10 50-44SN-10 50-48SN-10 50-50SN-10 50-12SN-9 50-20SN-9 50-24SN-9 50-30SN-9 50-36SN-9 50-44SN-9 50-48SN-9 50-50SN-9 50-12SN-3 50-20SN-3 50-24SN-3 50-30SN-3 50-36SN-3 50-44SN-3 50-48SN-3 50-50SN-3 50-12SN-1 50-20SN-1 50-24SN-1 50-30SN-1 50-36SN-1 50-44SN-1 50-48SN-1 50-50SN-1 50-12SN-3R 50-20SN-3R 50-24SN-3R 50-30SN-3R 50-36SN-3R 50-44SN-3R 50-48SN-3R 50-50SN-3R 50-12SN-1R 50-20SN-1R 50-24SN-1R 50-30SN-1R 50-36SN-1R 50-44SN-1R 50-48SN-1R 50-50SN-1R Marketed exclusively through distribution. 2-65 Call Toll Free: 1 (800) 323-9612 .156" (3.96mm) Density Dip Solder/Solder Eyelet Edge Connector High Reliability ■ Dip solder tails, single readout, .156" (3.96mm) long or .234" (5.94mm) long. FEATURES ■ Dip solder tails, double readout, .156" (3.96mm) or .234" (5.94mm) long on .200" (5.08mm) row spacing, or .125" (3.18mm) long on .140" (3.56mm) row spacing. ■ Solder eyelet, single readout and double readout on .200" (5.08mm) row spacing. ■ Patented bifurcated bellows contacts for added contact reliability. ■ Ideal for applications involving vibration or board irregularities. ■ Contact positions: 6, 10, 12, 15, 18, 22, and 25. ■ Available with or without mounting ears. ■ Accepts single- or double-sided .062" (1.59mm) thick PC boards. MATERIALS Shock: Per MIL-STD-202E, Method 202 Operating Temperature: Dip solder: -65°C to +105°C Solder eyelet: -65°C to +125°C Vibration: Per MIL-STD-202E, Method 204, Condition B Humidity: Per MIL-STD-202E, Method 103, Condition B Accessories: Polarizing Key: Two types (order separately): a) for between-contact polarization and b) for in-contact polarization See page 2-74 for more information. Card Guide Posts: (order separately): Attach to mounting ears and guide PC board into connector See page 2-74 for more information. MECHANICAL ELECTRICAL Insulation Material: Diallyl phthalate, green Contact Material: Phosphor bronze Contact Plating: 30µ" selective gold over 50µ" copper in the contact areas, 5µ" gold on tails ENVIRONMENTAL ■ UL Recognized - file E170218 (UL1977) E130965 (UL1863). Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: 1800 VAC RMS (@ sea level) 5 Amps Dip solder: 6 Milliohms Solder eyelet: 10 Milliohms 5000 Megohms minimum Individual Contact Insertion and Separation Force: 16 oz. maximum with .070" (1.78mm) blade; 1 oz. minimum with .054" (1.37mm) blade Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-66 Edge Connector High Reliability .156" (3.96mm) Density Dip Solder/Solder Eyelet Single Readout Double Readout With Plain Mounting Holes Dimensions No. of Pos./Cont. 6 10 12 15 18 20 22 25 A in 1.100 1.724 2.036 2.504 2.972 3.286 3.596 4.067 mm 27.94 43.79 51.71 63.60 75.49 83.46 91.34 103.30 B in 1.239 1.864 2.177 2.645 3.114 3.427 3.739 4.208 C mm 31.47 47.35 55.30 67.18 79.10 87.05 94.97 106.88 in 1.531 2.156 2.469 2.937 3.406 3.719 4.031 4.500 mm 38.80 54.76 62.71 74.60 86.51 94.46 102.39 114.30 D in 1.785 2.410 2.723 3.191 3.660 3.973 4.285 4.754 mm 45.34 61.21 69.16 81.05 92.96 100.91 108.84 120.75 Marketed exclusively through distribution. 2-67 Call Toll Free: 1 (800) 323-9612 DURA-CON® Edge Connector High Reliability High Reliability All-Plastic [.050” (1.27mm) Density .156" (3.96mm) Density Dip Solder Cup/Wire Solder/Solder Eyelet D-Microminiature] Ordering Information Single Readout No. of Pos./Cont. 2 6/6 10/10 12/12 15/15 18/18 20/20 22/22 25/25 .128" (3.25mm) Mounting Hole Dip Solder Tails Dip Solder Tails .156" (3.96mm) Long .234" (5.94mm) Long Catalog No. Catalog No. 50-6H-10 50-6S-10 50-10H-10 50-10S-10 50-12R-10 50-12S-10 50-15H-10 50-15S-10 50-18H-10 50-18S-10 50-20C-10 50-20S-10 50-22H-10 50-22S-10 50-25H-10 50-25S-10 Solder Eyelet Catalog No. 50-6H-20 50-10H-20 50-12H-20 50-15H-20 50-18H-20 50-20A-20 50-22H-20 50-25H-20 Double Readout .128" (3.25mm) Mounting Hole Less Mounting Ears Solder Eyelet Dip Solder Tails Dip Solder Tails Dip Solder Tails Dip Solder Tails No. of .234" (5.94mm) Long .156" (3.96mm) Long .125" (3.18mm) Long .125" (3.18mm) Long Pos./Cont. .200" (5.08mm) Between .200" (5.08mm) Between .140" (3.56mm) Between .140" (3.56mm) Between Row Spacing Row Spacing Row Spacing Row Spacing Catalog No. Catalog No. Catalog No. Catalog No. Catalog No. 6/12 50-12H-30 50-12S-20 50-12H-10 50-12H-30-2 50-12H-30-1 10/20 50-20H-30 50-20S-20 50-20H-10 50-20H-30-2 50-20H-30-1 12/24 50-24H-30 50-24S-20 50-24H-10 50-24H-30-2 50-24H-30-1 15/30 50-30H-30 50-30S-20 50-30H-10 50-30H-30-2 50-30H-30-1 18/36 50-36H-30 50-36S-20 50-36H-10 50-36H-30-2 50-36H-30-1 20/40 50-40A-30 50-40S-20 50-40B-10 22/44 50-44H-30 50-44S-20 50-44H-10 50-44H-30-2 50-44H-30-1 25/50 50-50H-30 50-50S-20 50-50H-10 50-50H-30-2 50-50H-30-1 Call Toll Free: 1 (800) 323-9612 2-68 .156" (3.96mm) Density Card Extender Edge Connector High Reliability FEATURES ■ Solder terminations, double readout. ■ Bifurcated bellows type contacts. ■ Contact positions: 6, 10, 12, 15, 18, 22, and 25. MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS ■ Accepts .062" (1.59mm) thick double-sided PC boards. Insulation Material: Diallyl phthalate, green Contact Material: Beryllium copper Contact Plating: 30µin. select gold over 50µin. nickel in the contact areas, 10µin. gold tails Shock: Per MIL-STD-202E, Method 213, Condition C Operating Temperature: -65°C to +125°C Vibration: Per MIL-STD-202E, Method 204, Condition B Humidity: Per MIL-STD-202E, Method 103, Condition B Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: 830 VAC RMS (@ sea level) 5 Amps 5 Milliohms maximum 5000 Megohms minimum Individual Contact Insertion and Separation Force: 16 oz. maximum with .070" (1.78mm) blade; 1 oz. minimum with .054" (1.37mm) blade Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-70 Edge Connector High Reliability .156" (3.96mm) Density Card Extender Dimensions Dimensions No. of Pos./Cont. 6/12 10/20 12/24 15/30 18/36 22/44 25/50 A in 1.100 1.724 2.036 2.504 2.972 3.596 4.067 B mm 27.94 43.79 51.71 63.60 75.48 91.33 103.30 in 1.239 1.864 2.177 2.645 3.114 3.739 4.208 C mm 31.47 47.34 55.29 67.18 79.09 94.97 106.88 in 1.531 2.156 2.469 2.937 3.406 4.031 4.500 mm 38.88 54.76 62.71 74.59 86.51 102.38 114.30 D in 1.785 2.410 2.723 3.191 3.660 4.285 4.754 mm 45.33 61.21 69.16 81.05 92.96 108.83 120.75 Ordering Information No. of Pos./Cont. 6/12 10/20 12/24 15/30 18/36 22/44 25/50 Catalog No. 50-12S-30 50-20S-30 50-24S-30 50-30S-30 50-36S-30 50-44S-30 50-50S-30 Marketed exclusively through distribution. 2-71 Call Toll Free: 1 (800) 323-9612 Card Guides Polarizing Keys Edge Connector Accessories Card Guides Card guide for .100" (2.54mm) and .156" (3.96mm) density edge connectors. Accepts .062" (1.59mm) thick PC boards. Card guides attach to mounting ears and guide printed circuit board into connector. Order separately. Material: Polypropylene Part No. 50-GP-1 (Green) Part No. 50-GP-1B (Black) Polarizing Keys Style A Description Between-contact In-contact type Between-contact Between-contact Between-contact In-contact type Style B type type type type Connector Family .156" .156" .156" .156" .100" .156" Style C Material Cellulose acetate Thermoset plastic Glass epoxy Glass epoxy Glass-filled nylon Thermoplastic Style D Style B B A D C B Catalog No. 50-PK 50-PK1 50-PK2 50-PK2M 50-PK3 50-PK4 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-72 Socket Commercial Miscellaneous Plug Buttons Plug Buttons Dimensions Nickel-plated steel. Spring tension prongs. 41V provides ventilation wherever required. For Hole Diameter in mm .250 6.35 .375 9.53 .500 12.70 .625 15.88 .750 19.05 .875 22.23 1.000 25.40 1.250 31.75 1.000 25.40 Call Toll Free: 1 (800) 323-9612 2-74 Cup Diameter in mm .406 10.32 .500 12.70 .656 16.67 .797 20.24 .938 23.81 1.062 26.99 1.156 29.37 1.438 36.51 1.156 29.37 Catalog No. 41A 41B 41C 41D 41E 41F 41G 41H 41V Press-Fit BNC Coaxial Connector Board Mount Receptacle for 75 Ω Applications FEATURES ■ Solderless, Press-Fit Installation. ■ Strong, One-Piece Cast Body. ■ Standard BNC Interface. Ω Impedance. ■ 75Ω MATERIALS ■ Meets Lucent Technologies (AT&T) Requirements. Body: One-piece diecast zinc per QQ-Z-363 Plating: Nickel, 150µin. min. per QQ-N-290 over copper, 200µin. min. per MIL-C-14550 Center Contact: Beryllium copper Plating: Gold, 30µin. minimum over nickel, 50µin. minimum Insulator: Teflon TFE per ASTM D1710 Compliant version, Pt. No. 299 99 00 134 is also available. For more information please contact us at 1-800-323-9612 Unique patented press-fit connector design allows for multiple insertions into a backplane without loss of mechanical retention or electrical ELECTRICAL Impedance: Frequency Range: RF Leakage: Insertion Loss: VSWR: performance. 75Ω 0 to 4 GHz The design requirements for nominal PC board > -55 dB mounting holes and thickness are as follows: .2dB maximum @ 2 GHz Insertion Forces: 1.024 Working Voltage: < 500 VAC RMS @ sea level Insulation Resistance: > 5000 MOhms @ 500 VDC .093 Board Thickness: 200 lb. max. .250 Board Thickness: 500 lb. max. MECHANICAL Withdraw Forces: Connector Insertion Force: 100 lb.* Center Contact Insertion Force: < 2.0 lb.* Center Contact Removal Force: > 2.0 oz.* *Requirements are for two connector insertions into the same PC board mounting holes. PC board thickness can range from .093" to .300" thick. PC board hole requirements are as follows: Ground Legs: .059" Nom. Center Contact: .040" Nom. Call Toll Free: 1 (800) 323-9612 2-76 .093 Board Thickness: 100 lb. max. .250 Board Thickness: 200 lb. max. The Cinch Press-Fit BNC surpasses these requirements with a unique, non-symmetrical ground leg design. This design allows the connector to be inserted, removed, rotated 180o, and reinserted into the same location on the board without loss of mechanical or electrical performance. Press-Fit BNC Coaxial Connector Board Mount Receptacle for 75 Ω Applications Production Insertion Tool Design Press-Fit BNC Connector Dimensions Ordering Information Catalog Number: Standard Package: BNC-1-PF Anti-Static Tube, 48 Connectors Per Tube 2-77 Call Toll Free: 1 (800) 323-9612 CYLINDRICAL C48 Series/MIL-C-26500 Accessories & Application Tooling Boeing: BACC45 / BACC63 Series MIL-C-26500 C48 Series Introduction ■ Qualified to MIL-C-26500. ■ Styles qualified to Boeing BACC45 Series. FEATURES ■ Styles qualified to Boeing BACC63 Series. ■ Power Contact Sizes: 20, 16, and 12. ■ Coax Contacts Available: Size 12 and 8. ■ Contacts: Crimp - Front release. ■ Optional Fixed Contacts: PC Termination. ■ Coupling Styles: Bayonet and Threaded. MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS ■ Environmentally Sealed. Shell: Aluminum, stainless-steel options available Finish: Aluminum - Anodize, optional electroless nickel / cadmium over nickel Rubber: Silicone / fluorosilicone Dielectric: Glass-filled epoxy Temperature Extremes: +200°C / 392°F to -55°C / -65°F Ozone Resistance: 0.015% by volume Temperature Life: Internal 238°C for 1,000 hours Moisture Resistance: 1,000 megohms minimum / MIL-STD-202, Method 106 Thermal Shock: -55°C (-67°F) to 260°C (500°F) Dielectric Strength: 1,500 volts VAC RMS Current Rating (Test): Size 20 7.5 Amps D.C. Size 16 13.0 Amps D.C. Size 12 23.0 Amps D.C. Insulation Resistance: 5,000 megohms minimum Contact Retention: Size 20 - 20 lb. minimum Size 16 - 25 lb. minimum Size 12 - 30 lb. minimum Durability: Threaded - 200 mating cycles Bayonet - 500 mating cycles Vibration: Std - 20 g’s; 12 hours (Synasoidal) MMB / Self-Lock - 39.6 g’s RMS, 48 hours (Random) Shock: 50 g’s Call Toll Free: 1 (800) 323-9612 3-1 MIL-C-26500 C48 Series Introduction GENERAL DESCRIPTION The C48 Series describes a family of connectors qualified to MIL-C-26500. While maintaining the MIL-C-26500 mating interface, this product has also been expanded to include qualifications to numerous Boeing specifications to satisfy general purpose requirements and unique product challenges for shielding, environmental sealing, fluid resistance, and vibration. Design Features A. Positive Location Captivated Insert (Mechanical Interlock) B. Insert Face Seal C. Pin Contact, MIL-C-39029/31 D. Contact Pressuring Seal E. Anti-Deflection Disc F. Resilient Pin Insert G. Insert Rim Seal H. Dynamic “O” Ring Shell Seal I. Five-Key Shell Polarization J. Metal-to-Metal Shoulder K. Bayonet or Threaded Coupling, Permanent Captivation L. Contact Retention Clip M. Socket Contact, MIL-C-39029/32 N. Wire Sealing Risers O. Grommet The expanded Cinch C48 product family offers numerous product options qualified to Boeing high-performance requirements and product solutions developed for alternate termination styles/low-profile packaging. Product Description Cinch Series • Threaded non-decoupling design CN0966 • High-vibration bayonet plug with metal-to-metal bottoming shells C0909 CN1020 • Connectors for shell grounding / shielding effectiveness, non-rotating accessory teeth, and advanced fluid-resistance elastometers CN0966 CN0967 CN1020 CN1021 • Firewall Conformance CN0966 CN0967 • Low-profile connectors crimp - removable contacts CN0915 • Low-profile connectors fixed contacts / alternate termination styles CN0942 CN0944 3-2 Call Toll Free: 1 (800) 323-9612 C48 Series Cinch Numbers How to Order C48-0 6 R 22-55 P 6-102 Series Designation C48 -- Order Code (Deviations) 100 - Connector With Contacts & Cable Support 102 - Connector Less Cable Support With Contacts 105 - Connector Less Contacts With Cable Support 106 - Connector Less Contacts & Less Cable Support See order codes for Boeing on page 3-14 Coupling Style 0 -- Threaded 1 -- Bayonet Alternate Shell Positions 6, 7, 8, 9, 10 per table on page 3-4 (Omit for normal position) Shell Style 0 -- Square Flange Receptacle 3 -- Single-Hole Mounting Receptacle 6 -- Straight Plug Contact Style P -- Pin S -- Socket Environmental Class R -- Meets MIL-C-26500 (USAF) 3 Insert Arrangements (See page 3-4) Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24 Military Standard Part Numbers You can use MS* as well as C48 Series part numbers when ordering C48 Series connectors. *MS part numbers are supplied less cable support. If cable support is desired, it must be ordered separately. MS24266 R 22 T 55 P 6 Military Designation MS24264 -- Square-Flange Receptacle MS24265 -- Single-Hole Mounting Receptacle MS24266 -- Straight Plug Alternate Shell Positions N, 6, 7, 8, 9, Y per table on page 3-4 Contact Style P -- Pin S -- Socket Environmental Class R -- Meets MIL-C-26500 (USAF) Insert Arrangements (See page 3-4) Shell Size 8, 10, 12, 14, 16, 18, 20, 22, or 24 Coupling Style T -- Threaded B -- Bayonet Part numbers for the contacts and assembly tools are listed on page 3-12. Call Toll Free: 1 (800) 323-9612 3-3 Inserts Available C48 Series (Showing Front Face of Socket Inserts) Shell Size-12 Shell Size-10 Shell Size-8 (Y) (Y) (Y) (Y) (Y) Shell Size-16 Shell Size-14 (Y) (Y) (Y) Shell Size-18 (Y) 3 Shell Size-20 (Y) (Y) (Y) (Y) Shell Size-22 (Y) (Y) Shell Size-24 (Y) (Y) (Y) Shell Size-28 CN096X CN102X Series Only Alternate Shell Positions (Front face of receptacle shown) NOTE: Alternate positions 6 through Y incorporate special shell polarizing key and keyways. All inserts remain in the normal position. For Connector Size † = #1 shielded contact is interchangeable with #12 power contact. (Y) = Available in Boeing Insert Style. For Connector Size 8 and 10 12, 14, 16, 18, 20, 22, 24, and 28 Positions A B C D A B C D Normal (N) 105° 140° 215° 265° 105° 140° 215° 265° 6 102° 132° 248° 320° 18° 149° 192° 259° 7 80° 118° 230° 312° 92° 152° 222° 342° 8 35° 140° 205° 275° 84° 152° 204° 334° 9 64° 155° 234° 304° 24° 135° 199° 240° 10 or Y* 25° 115° 220° 270° 98° 152° 268° 338° *Not available in Size 8 Connector. See individual part number systems. 3-4 Call Toll Free: 1 (800) 323-9612 C48 Series Plug Connectors Threaded Coupling C48-06RXX-XXXX MS24266RXXTXXXX BACC45FS1 3 1.345 (34.164) Max. Bayonet Coupling C48-16RXX-XXXX MS24266RXXBXXXX BACC45FT1 1.345 (34.164) Max. Dimensions Shell Size 8 10 12 14 16 18 20 22 24 A. Dia. in mm .328 8.331 .420 10.668 .580 14.732 .664 16.866 .769 19.533 .902 22.911 1.033 26.238 1.152 29.261 1.282 32.253 B. Dia. in mm .437 11.100 .562 14.275 .750 19.050 .812 20.625 .938 23.825 1.062 26.975 1.182 30.023 1.312 33.325 1.432 36.373 C. Max. in mm .776 19.712 .906 23.013 1.078 27.381 1.141 28.982 1.266 32.157 1.375 34.925 1.510 38.354 1.625 41.275 1.760 44.704 D. Thread UNEF-2A .437-28 .562-24 .750-20 .812-20 .937-20 1.062-18 1.187-18 1.312-18 1.437-18 1 Boeing Specifications, see page 3-14. Call Toll Free: 1 (800) 323-9612 3-5 C48 Series Receptacle Connectors Square Flange, Threaded Coupling C48-OORXX-XXXX MS24264RXXTXXX BACC45FM1 1.407 (35.738) Max. Square Flange, Bayonet Coupling C48-1ORXX-XXXX MS24264RXXBXXX BACC45FN1 1.407 (35.738) Max. 3 Dimensions Shell Size 8 10 12 14 16 18 20 22 24 1 A +.005 (.127) in mm .812 20.625 .937 23.800 1.031 26.188 1.125 28.575 1.250 31.750 1.343 34.112 1.437 36.500 1.562 39.675 1.703 43.256 B +.005 (.127) in mm .594 15.088 .719 18.263 .812 20.625 .906 23.013 .969 24.613 1.062 26.975 1.156 29.363 1.250 31.750 1.375 34.925 C Max. Dia. in mm .125 3.175 .125 3.175 .125 3.175 .125 3.175 .125 3.175 .125 3.175 .125 3.175 .125 3.175 .154 3.912 D Max. in mm .561 14.250 .696 17.679 .875 22.225 .935 23.749 1.062 26.975 1.187 30.150 1.312 33.325 1.437 36.500 1.562 39.675 F Max. in mm .437 11.100 .562 14.275 .750 19.050 .812 20.625 .938 23.825 1.062 26.975 1.182 30.023 1.312 33.325 1.432 36.373 G H J Thread Thread Min. UNEF-2A UNEF-2A in mm .562-24 .437-28 .620 15.748 .687-24 .562-24 .748 18.999 .875-20 .750-20 .913 23.190 .937-20 .812-20 .980 24.892 1.062-18 .937-20 1.107 28.119 1.187-18 1.062-18 1.209 30.709 1.312-18 1.187-18 1.337 33.960 1.437-18 1.312-18 1.452 36.881 1.562-18 1.437-18 1.577 40.056 K Min. in .447 .572 .760 .822 .948 1.072 1.192 1.322 1.442 = Boeing specifications, see page 3-14. 3-6 Call Toll Free: 1 (800) 323-9612 mm 11.354 14.529 19.304 20.879 24.079 27.229 30.277 33.579 36.627 C48 Series Receptacle Connectors Single-Hole Mount, Threaded Coupling C48-03RXX-XXXX MS24265RXXTXXX 3 1.407 (35.738) Max. Single-Hole Mount, Bayonet Coupling C48-13RXX-XXXX MS24265RXXBXXX 1.407 (35.738) Max. Dimensions Shell Size A B C D E G H J K +.005 (.127) Max. Hex +.003 (.076) Max. Max. Dia. Max. Thread Thread Thread UNEF-2A UNEF-2A in mm in mm in mm in mm in mm in mm UNEF-2A 8 .979 24.867 .828 21.031 .593 15.062 1.068 27.127 .561 14.249 .437 11.100 .562-24 .625-20* .437-28 10 1.104 28.042 .953 24.206 .718 18.237 1.192 30.277 .696 17.678 .562 14.275 .687-24 .750-20 .562-24 12 1.291 32.791 1.140 28.956 .905 22.987 1.380 35.052 .875 22.225 .750 19.050 .875-20 .937-20 .750-20 14 1.391 35.331 1.250 31.750 .968 24.587 1.505 38.227 .935 23.749 .812 20.625 .937-20 1.000-20 .812-20 16 1.516 38.506 1.329 33.757 1.093 27.762 1.630 41.402 1.062 26.975 .938 23.825 1.062-18 1.125-20* .937-20 18 1.641 41.681 1.455 36.957 1.217 30.912 1.740 44.196 1.187 30.150 1.062 26.975 1.187-18 1.250-20* 1.062-18 20 1.766 44.856 1.642 41.707 1.342 34.087 1.860 47.244 1.312 33.325 1.182 30.023 1.312-18 1.375-18 1.187-18 22 1.954 49.632 1.705 43.307 1.467 37.262 2.040 51.816 1.437 36.500 1.312 33.325 1.437-18 1.500-20* 1.312-18 24 2.079 52.807 1.892 48.057 1.592 40.437 2.160 54.864 1.562 39.675 1.432 36.373 1.562-18 1.625-18 1.437-18 * Thread: UN-2A NOTES: Contact factory for information about Boeing specifications. For mounting hole dimensions and jam nut torques, see page 3-20. Call Toll Free: 1 (800) 323-9612 3-7 C48/CN0915 Series Limited Wiring Space Receptacle Connectors Crimp Removal Contacts Square-Flange, Threaded Coupling CN0915B-XXXXXXX-XXX Square-Flange, Bayonet Coupling CN0915A-XXXXXXX-XXX 3 Dimensions Shell Size 8 10 12 14 16 18 20 22 24 A +.0045 (.114) in mm .812 20.625 .937 23.800 1.031 26.187 1.125 28.575 1.150 29.210 1.343 35.382 1.437 36.500 1.562 39.675 1.703 43.256 Ordering Information1 B +.005 (.127) in mm .594 15.088 .719 18.263 .812 20.625 .906 23.012 .969 24.613 1.062 26.975 1.156 29.362 1.250 31.750 1.375 34.925 C +.004 (.102) in mm .121 3.073 .121 3.073 .121 3.073 .121 3.073 .121 3.073 .121 3.073 .121 3.073 .121 3.073 .154 3.912 D Max. in mm .561 14.250 .696 17.679 .875 22.225 .935 23.749 1.062 26.975 1.187 30.150 1.312 33.325 1.437 36.500 1.562 39.675 CN0915 A 10 A 05 P N - 000 Ordering Information1 Order Code 000 - Less Contacts 200 - Gold-Plated Contacts * See below Series Designation CN0915 Series Modification A - Bayonet Coupling B - Threaded Coupling Shell Size 8, 10, 12, 14, 16, 18, 20, 22, & 24 NOTES: F G +.0015 (.038) Thread in mm UNEF-2A .497 12.624 .562-24 .503 15.799 .687-24 .745 18.923 .875-20 .871 22.123 .937-20 .995 25.273 1.062-18 1.058 26.873 1.187-18 1.184 30.074 1.312-18 1.307 33.198 1.437-18 1.432 36.373 1.562-18 Environmental Class A - Anodized Aluminum N - Electroless Nickel-Plated Aluminum S - Stainless Steel Shell Position N, 6, 7, 8, 9, 10 (See page 3-4) Contact Style P - Pin S - Socket Insert Arrangement (See page 3-4) 1 For other modifications, classes, etc., contact factory. • For mounting hole dimensions, see page 3-20. • Uses CRIM-LOK contacts. See page 3-12. * Former order code - 100 designated rhodium plated contacts 3-8 Call Toll Free: 1 (800) 323-9612 CN0942/CN0944 Series (C48 Family) Short Receptacle Connectors Non-Removable Contacts Single-Hole Mount, Bayonet Coupling CN0942D XXXXXXXXX CN0944D XXXXXXXXX S** T** 3 Square Flange, Bayonet Coupling CN0942B XXXXXXXXX CN0944B XXXXXXXXX S* T* Dimensions A Shell Max. Size in mm 8 .984 24.994 10 1.109 28.169 12 1.296 32.919 14 1.396 35.459 16 1.521 38.634 18 1.646 41.809 20 1.771 44.984 22 1.959 49.759 24 2.084 52.934 B Max. in mm .828 21.031 .953 24.206 1.140 28.956 1.250 31.750 1.329 33.757 1.455 36.957 1.642 41.707 1.705 43.307 1.892 48.057 C Max. in mm 1.068 27.127 1.192 30.277 1.380 35.052 1.505 38.227 1.630 41.402 1.740 44.196 1.860 47.244 2.040 51.816 2.160 54.864 D Max. in mm .561 14.250 .696 17.679 .875 22.225 .935 23.749 1.062 26.975 1.187 30.150 1.312 33.325 1.437 36.500 1.562 39.675 * Th’d: UN-2A ** See “S” and “T” dimensions on page 3-10. Call Toll Free: 1 (800) 323-9612 3-9 F Thread UNEF-2A .625-20* .750-20 .937-20 1.000-20 1.125-20* 1.250-20* 1.375-18 1.500-20* 1.625-18 J +.005 (.127) in mm .812 20.625 .937 23.800 1.031 26.188 1.125 28.575 1.250 31.750 1.343 34.112 1.437 36.500 1.562 39.675 1.703 43.256 K +.005 (.127) in mm .594 15.088 .719 18.263 .812 20.625 .906 23.013 .969 24.613 1.062 26.975 1.156 29.363 1.250 31.750 1.375 34.925 L +.003 (.176) in mm .593 15.062 .718 18.237 .905 22.987 .968 24.587 1.093 27.762 1.217 30.912 1.342 34.087 1.467 37.262 1.592 40.437 CN0942/CN0944 Series (C48 Family) Short Receptacle Connectors Non-Removable Contacts CN0942 Series: Fluorosilicone Inserts Ordering Information1 Termination Designator 01* 02* 03** 04** 06* Contact Style P&S X&Y P&S X &Y T&W Termination T Min. S + .002 .250 .025 .230 N/A .144 .025 .124 N/A .900 .025 * Applies to CN0942B/CN0942C. ** Applies to CN0942D/CN0942E. CN0942 B 10 J 05 P N O1 Series Designation Termination (See table) Series Modification B - Square-Flange Mount Bayonet Coupled C - Square-Flange Mount Thread Coupled D - Single-Hole Mount Bayonet Coupled E - Single-Hole Mount Thread Coupled Shell Position N, 6, 7, 8, 9, Y (See page 3-4) Shell Size 8, 10, 12, 14, 16, 18, 20, 22, & 24 Class G - Cadmium/Nickel Finish J - Anodized Finish N - Electroless Nickel Finish Insert Arrangement (See page 3-4) Contact Style • Solder Pin Terminal P - Pin S - Socket • Solder Cup Terminal X - Pin Y - Socket • Wire Wrap Terminal T - Pin W - Socket NOTES: 1 For other modifications, class, etc., consult factory. For mounting hole dimensions, see page 3-20. 3 CN0944 Series: Neoprene Inserts Ordering Information1 Termination Term Designator Type 01* B 02* C 03** B 04** C 06* W Termination T Min. S + .002 .250 .025 .230 N/A .144 .025 .124 N/A .900 .025 * Applies to CN0944B/CN0944C. ** Applies to CN0944D/CN0944E. CN0944 B 10 R 05 P N C O1 Series Designation CN0944 Termination (See table) Series Modification B - Square-Flange Mount Bayonet Coupled C - Square-Flange Mount Thread Coupled D - Single-Hole Mount Bayonet Coupled E - Single-Hole Mount Thread Coupled Termination Type B - Solder Pin C - Solder Cup W - Wire Wrap Shell Size 8, 10, 12, 14, 16, 18, 20, 22, & 24 Environmental Class G - Cadmium/Nickel Finish N - Electroless Nickel Finish R - Anodized Finish Shell Position N, 6, 7, 8, 9, Y (See page 3-4) Contact Style P - Pin S - Socket Insert Arrangement (See page 3-4) NOTES: 1 For other modifications, class, etc., consult factory. For mounting hole dimensions, see page 3-20. 3-10 Call Toll Free: 1 (800) 323-9612 C48 Series Accessories Cable Support Assembly Cable clamps support cable or wire at the plug or receptacle and prevent twisting and pulling. C Thread Dimensions 3 Cinch Size Part No. 8 C48-2840 10 C48-2341 12 C48-2342 14 C48-2343 16 C48-2344 18 C48-2345 20 C48-2643 22 C48-2346 24 C48-2644 MS MS27291-13 MS27291-1 MS27291-2 MS27291-3 MS27291-4 MS27291-5 MS27291-14 MS27291-6 MS27291-15 A Max. Dia. in mm .606 15.393 .731 18.568 .919 23.343 .981 24.918 1.106 28.093 1.231 31.268 1.356 34.443 1.481 37.618 1.606 40.793 Call Toll Free: 1 (800) 323-9612 B +.015 (.381) in mm .935 23.749 .935 23.749 .935 23.749 1.170 29.718 1.170 29.718 1.170 29.718 1.170 29.718 1.170 29.718 1.170 29.178 3-11 X I.D. +.005 (.127) in mm .186 4.725 .270 6.858 .400 10.160 .460 11.684 .610 15.494 .690 17.526 .816 20.728 .940 23.876 1.066 27.078 C Th’d UNEF-2B .437-28 .562-24 .750-20 .812-20 .937-20 1.062-18 1.187-18 1.312-18 1.437-18 P Max. in .789 .914 1.026 1.090 1.250 1.358 1.481 1.604 1.729 mm 20.042 23.216 26.061 27.686 31.750 34.493 37.619 40.742 43.919 [.050” (1.27mm) Density Solder Crim-Lok Cup/Wire Contacts D-Microminiature] C48 Series Accessories Contacts When you order Cinch C48 Series connectors with contacts, the contact package contains enough contacts to complete the insert arrangement plus two spares. The package also includes sealing plugs for 15% of the contacts in the inserts, minimum of three. To provide proper sealing, insert unwired contacts and sealing plugs in all unused holes. (Use a #12 contact for a #1 shielded hole.) To order contacts and sealing plugs separately use the part numbers in the table below. Contact Size No. 20 No. 16 No. 12 No. 1* (Shielded) Max. Wire Size AWG 24 22 20 18 16 14 12 ** **** ***** Current Rating Cinch Amps Pin 3.0 5.0 CN0900-253 7.5 16 22 CN0900-252 32 41 CN0900-256 3 C48-1226-02 1 C48-1226-54 1 C48-1226-55 Part No. Socket Pin MS Part No. Socket CN0900-255 M39029/31-241 M39029/32-260 CN0900-254 M39029/31-229 M39029/32-248 CN0900-257 C48-1227-02 C48-1227-54 C48-1227-55 M32029/31-235 ---- M39029/32-254 ---- C48-2188-02 -- -- No. 2 (Shielded) *** 7.5 C48-2187-02 * Fits into No. 12 power contact cavity. ** Accommodates cables RG174/U, RG179U, RG179A/U, RG187/U, RG188/U, RG161/U, as well as shielded wire. Can also accommodate Cable MIL-C-27500-22 KING (Extruded) or 22 AWG per MIL-C-7078 type II. *** Accommodates Cable MIL-C-27500 KING; 20 KING; 18 KING (Extruded) or 22, 20, 18 AWG, per MIL-C-7078 type II. **** For use with RG195/U and RG180/U, RG180A/U, and RG1808/U. ***** Accommodates Cables RG178/U, RG178A/U, RG1788/U, and RG196/U. Grommet Sealing Plugs Color Code Yellow Blue Red White Size Cinch Part No. 12 & #1 Shielded C48-2221-12 16 C48-2221-16 20 C48-2221-20 #2 Shielded C48-1458-01 MS Part No. MS27488-12 MS27488-16 MS27488-20 -- Tools Contact Size No. 20 No. 16 No. 12 No. 20 No. 16 No. 12 No. 1 (Shielded) No. 2 (Shielded) Crimp Tool M22520/1-01 M22520/1-01 M22520/1-01 Adjustable Turret M22520/1-02 M22520/1-02 M22520/1-02 Insertion Tool Superseded No. Current No. MS24256A20 M81969/17-03 MS24256A16 M81969/17-04 MS24256A12 M81969/17-05 Removal Tool Superseded No. Current No. MS24256R20 M81969/19-06 MS24256R16 M81969/19-01 MS24256R12 M81969/19-02 MS24256A12 M81969/17-05 MS24256R12 M81969/19-09 -- 294-128 -- 294-127 3-12 Call Toll Free: 1 (800) 323-9612 3 C48 Family High-Performance Options ■ Cinch has qualified a series of connectors to Boeing Specifications in bayonet and threaded styles that meet high-performance requirements for: + Vibration + Shielding Effectiveness + Fluid Resistance BACC63 Series BN • FEATURES ■ Vibration-resistant Bayonet Plug BV CB CC • • ■ Vibration-resistant Self-Locking threaded Plug • • • • • • • • • • • • • • ■ Optional Ground Spring on Plug ■ Shielded Connectors ■ Advanced fluid-resistant elastometers ■ Non-rotating accessory teeth conforming to MS3155 • • ■ Optional Stainless Steel Shells Call Toll Free: 1 (800) 323-9612 BP 3-13 C48 Family High-Performance Options BOEING TO Cinch CROSS-REFERENCE DATA Cinch Part Numbers and Order Codes For Applicable Purchase Order Exceptions, see Note 6. Boeing Part Numbers BACC45FM**-**P A P6 See Note 2 B P7 C P8 See Note 5 D P9 E P10 BACC45FN**-**P6 BACC45FS**-**P6 BACC45FT**-**P6 No Exceptions Less Contacts Less Contacts & Cable Support C48-00R**Y**P-402 P6-410 See Note 3 P7-420 P8-430 P9-440 P10-450 C48-10R**Y**P6-402 C48-06R**Y**P6-402 C48-16R**Y**P6-402 -406 -415 -425 -435 -445 -455 -406 -406 -406 Less Cable Support -406 -416 -426 -436 -446 -456 -406 -406 -402 -402 -412 -422 -432 -442 -452 -402 -402 -406 (BACC63 Types) - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - BACC63BN*-**P6 See Note 5 B C BACC63BP**A**P6 B C See Note 7 D BACC63BV**A**P6 B F BACC63CB**-**P6 BACC63CC**-**P6 C0909A**-**P6Y402 Y420 See Note 3 Y430 CN0966A**A**P6Y140 A**S**P6Y140 B**G**P6Y140 B**S**P6Y140 CN0967C**A**P6Y140 S**P6Y140 G**P6Y140 CN1020A**G**P6Y140 CN1021A**G**P6Y140 Y406 Y425 Y435 Y040 Y040 Y040 Y040 Y040 Y040 Y040 Y040 Y040 Y406 Y426 Y436 N/A N/A N/A N/A N/A N/A N/A N/A N/A Y402 Y422 Y432 N/A N/A N/A N/A N/A N/A N/A N/A N/A See Note 4 NOTES: 1. All parts are marked with Boeing part number. 2. Part number system also applies to BACC45FN, BACC45FS, and BACC45FT. 3. May be “Y” or “–” (dash) designator “Y” = Insert arrangements with size 20 contacts (see page 3-4) use small wire grommet seals, Boeing insert discs, and hard socket inserts. “-” = Insert arrangements that contain no size 20 contact locations. Use standard “MS” grommets, discs, and inserts. 4. “P6” represents contact style and shell polarities defined in individual part numbering systems. 5. Specifies optional cable support: "–" = No cable support "A" = BACC10GH Straight Single-Leg Clamp "B" = MS27559 Right-Angle Saddle Clamp "C" = MS27291 Straight Saddle Clamp "D" = BACC10JC Right-Angle Single Leg Clamp "E" = BACC10JS Straight Single-Leg Composite Clamp 6. The Boeing specifications permit omission of contacts and/or cable support through purchase order exceptions. 7. Specifies material and shell designs. See Boeing specification. ** These part number fields represent shell size and insert arrangement as defined in individual part number systems. 3-14 Call Toll Free: 1 (800) 323-9612 CN0966 Series (C48 Family) Self-Locking Plug Connectors Threaded Coupling CN0966XXXXXXXX BACC63BP1 1.345** (34.164) Max. 360° LOCKING ACCESSORY TEETH 3 Dimensions Shell Size 8 10 12 14 16 18 20 22 24 28 A + .005 (.127) in mm .835 21.209 .972 23.698 1.165 27.254 1.230 30.124 1.355 33.198 1.470 34.798 1.607 38.100 1.735 41.148 1.858 44.069 2.113 52.070 B Max. Dia. in mm .306 7.773 .371 9.423 .547 13.894 .613 15.570 .758 19.253 .865 21.971 .986 25.044 1.106 28.092 1.235 31.369 1.485 37.719 Ordering Information2 C Thread UNEF-2A .500-20 .625-24 .750-20 .875-20 1.000-20 1.0625-18 1.1875-18 1.3125-18 1.4375-18 1.750-18* CN0966 B 10 S 05 P N - 000 Series Designation CN0966 Order Code (Deviations)1 000 - Less Contacts 100 - * See below 200 - With Gold-Plated Contacts Series Modification A - Ungrounded B - Grounded (Conductive) Alternate Shell Positions N, 6, 7, 8, 9, 10 Per table on page 3-4 Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 Class A - Anodized Aluminum G - Cadmium/Nickel-Plated Aluminum K - Stainless Steel Flame Resistant N - Electroless Nickel-Plated Aluminum S - Stainless Steel Contact Style P - Pin Insert S - Socket Insert Insert Arrangements (See page 3-4) Notes: 1 For Boeing Specification, see page 3-14. 2 For modifications, classes, etc. not listed, consult factory. * Th’d: UNS-2A ** Size 28 = 1.395 (35.434) * Former order code - 100 designated rhodium plated contacts Call Toll Free: 1 (800) 323-9612 3-15 CN0967 (C48 Series) Vibration-Resistant Receptacle Threaded Coupling CN0967XXXXXXXX BACC63BV1 1.407** (35.738) Max. 360° LOCKING ACCESSORY TEETH Dimensions A Shell +.0045 (.114) Size in mm 8 .812 20.625 10 .937 23.800 12 1.031 26.187 14 1.125 28.575 16 1.250 31.750 18 1.343 34.112 20 1.437 36.500 22 1.562 39.675 24 1.703 43.256 28 2.000 50.800 B +.005 (.127) in mm .594 15.088 .719 18.263 .812 20.625 .906 23.012 .969 24.613 1.062 26.975 1.156 29.362 1.250 31.750 1.375 34.925 1.562 39.675 C Max. in mm .561 14.250 .696 14.250 .875 17.679 .935 22.225 1.062 23.749 1.187 30.150 1.312 33.325 1.437 36.500 1.562 39.675 1.810 45.976 Ordering Information2 D Max. Dia. in mm .328 8.331 .371 9.423 .547 13.894 .609 15.469 .758 19.253 .865 21.971 .986 25.044 1.106 28.092 1.235 31.369 1.485 37.719 J Thread UNEF-2A .5265-24 .6875-24 .8750-20 .9375-20 1.0625-18 1.1875-18 1.3125-18 1.4375-18 1.5625-18 1.8125-16 L Thread UNEF-2A .5000-20 .6250-24 .7500-20 .8750-20 1.0000-20 1.0625-18 1.1875-18 1.3125-18 1.4375-18 1.750-18* CN0967 C 10 S 05 P N - 000 Series Designation CN0967 Series Modification C - Square-Flange Mount G - Square-Flange with Clinch Nuts Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 Environmental Class A - Anodized Aluminum G - Cadmium/Nickel-Plated Aluminum K - Stainless Steel, Flame Resistant N - Electroless Nickel-Plated Aluminum S - Stainless Steel Order Code (Deviations) 000 - Less Contacts 100 - * See below 200 - With Gold-Plated Contacts Alternate Shell Position N, 6, 7, 8, 9, 10 Per table on page 3-4. Contact Style P - Pin S - Socket Insert Arrangements (See page 3-4) NOTES: 1 For Boeing Specification, see page 3-14. 2 For modifications, classes, etc., not listed, consult factory. • For mounting hole dimensions, see page 3-20. * Th’d: UNS-2A **Size 28 = 1.457 (37.008) * Former order code - 100 designated rhodium plated contacts 3-16 Call Toll Free: 1 (800) 323-9612 3 CN1020 Series (C48 Family) Vibration-Proof Plug Connector Bayonet Coupling CN1020-XXXXXXXX BACC63CB1 1.345* * (34.164) Max. 360° LOCKING ACCESSORY TEETH Dimensions 3 Shell Size 8 10 12 14 16 18 20 22 24 28 A + .005 (.127) in mm .765 19.447 .967 24.561 1.078 27.381 1.187 30.149 1.309 33.248 1.375 34.925 1.505 38.227 1.625 41.275 1.755 44.577 2.161 54.889 B Max. Dia. in mm .306 7.773 .371 9.423 .547 13.894 .613 15.570 .758 19.253 .865 21.971 .986 25.044 1.106 28.092 1.235 31.369 1.485 37.719 Ordering Information2 C Thread UNEF-2A .500-20 .625-24 .750-20 .875-20 1.000-20 1.0625-18 1.1875-18 1.3125-18 1.4375-18 1.750-18* CN1020 A 10 G 05 P N - 000 Series Designation CN1020 Order Code (Deviations)1 000 - Less Contacts 100 - * See below 200 - With Gold-Plated Contacts Series Modification A - Standard Plug Alternate Shell Positions N, 6, 7, 8, 9, 10 Per table on page 3-4. Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 Environmental Class A - Anodized Aluminum G - Cadmium//Nickel-Plated Aluminum Contact Style P - Pin S - Socket Insert Arrangements (See page 3-4) Notes: 1 For Boeing Specification, see page 3-14. 2 For modification, classes, etc., not listed, consult factory. * Th’d: UNS-2A ** Size 28 = 1.395 (35.434) * Former order code - 100 designated rhodium plated contacts Call Toll Free: 1 (800) 323-9612 3-17 CN1021 Series (C48 Family) Vibration-Resistant Receptacle Bayonet Coupling CN1021XXXXXXXX BACC63CC1 1.407** (35.738) Max. 360° LOCKING ACCESSORY TEETH Dimensions Shell Size 8 10 12 14 16 18 20 22 24 28 A +.0045 (.114) in mm .812 20.625 .937 23.800 1.031 26.187 1.125 28.575 1.250 31.750 1.343 34.112 1.437 36.500 1.562 39.675 1.703 43.256 2.000 50.800 B +.005 (.127) in mm .594 15.088 .719 18.263 .812 20.625 .906 23.012 .969 24.613 1.062 26.975 1.156 29.362 1.250 31.750 1.375 34.925 1.562 39.675 Ordering Information2 C Max. in mm .561 14.250 .696 14.250 .875 17.679 .935 22.225 1.062 23.749 1.187 30.150 1.312 33.325 1.437 36.500 1.562 39.675 1.810 45.976 D Max. Dia. in mm .328 8.331 .371 9.423 .547 13.894 .609 15.469 .758 19.253 .865 21.971 .986 25.044 1.106 28.092 1.235 31.369 1.485 37.719 3 L Thread UNEF-2A .500-20 .625-24 .750-20 .875-20 1.000-20 1.0625-18 1.1875-18 1.3125-18 1.4375-18 1.750-18* CN1021 A 10 G 05 P N - 000 Order Code (Deviations) 000 - Less Contacts 100 - * See below 200 - With Gold-Plated Contacts Series Designation CN1021 Series Modification A - Square-Flange Mount C - Square-Flange with Clinch Nuts Alternate Shell Position N, 6, 7, 8, 9, 10 Per table on page 3-4. Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28 Contact Style P - Pin S - Socket Environmental Class A - Anodized Aluminum G - Cadmium/Nickel-Plated Aluminum Insert Arrangements (See page 3-4) Notes: 1 For Boeing Specification, see page 3-14. 2 For modifications, classes, etc. not listed, consult factory. • For mounting hole dimensions, see page 3-20. * Th’d: UNS-2A ** Size 28 = 1.457 (37.008) * Former order code - 100 designated rhodium plated contacts 3-18 Call Toll Free: 1 (800) 323-9612 C0909A MMB Series (C48 Family) Vibration-Proof Plug Connector 1.345 (34.164) Max. Bayonet Coupling C0909AXXXXXXX BACC63BN1 3 Dimensions Shell Size 8 10 12 14 16 18 20 22 24 A Dia. in .328 .420 .580 .664 .769 .902 1.033 1.152 1.282 B Dia. mm 8.331 10.668 14.732 16.866 19.533 22.911 26.238 29.261 32.253 Ordering Information2 in .437 .562 .750 .812 .938 1.062 1.182 1.312 1.432 C Max. mm 11.100 14.275 19.050 20.625 23.825 26.975 30.023 33.325 36.373 in .766 .906 1.078 1.141 1.266 1.375 1.510 1.625 1.760 mm 19.456 23.012 27.381 28.981 32.156 34.925 38.354 41.275 44.704 D Thread UNEF-2A .437-28 .562-24 .750-20 .812-20 .937-20 1.062-18 1.187-18 1.312.18 1.437-18 C0909A 10 - 05 P 8 - XXX Order Code (Deviations) 202 - With Gold-Plated Contacts* 106 - Less Contacts Series Designation C0909A Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24 Alternate Shell Positions N, 6, 7, 8, 9, 10 Per table on page 3-4. Class (Dash) - Anodized Aluminum E - Cadmium/Nickel-Plated Aluminum N - Nickel-Plated Aluminum Contact Style P - Pin Insert S - Socket Insert Insert Arrangements (See page 3-4) Notes: 1 For Boeing Specification, see page 3-14. 2 For deviations, classes, etc. not listed, consult factory. * Former order code - 102 designated rhodium plated contacts Call Toll Free: 1 (800) 323-9612 3-19 C48 Series & C48 Family Mounting Panel Data Square-Flange Mount Single-Hole Mount (Jam-Nut Mount) 3 Dimensions Shell Size 8 10 12 14 16 18 20 22 24 28 M Min. in .620 .748 .913 .980 1.107 1.209 1.337 1.452 1.577 1.827 mm 15.748 18.999 23.190 24.892 28.119 30.709 33.906 36.881 40.056 46.406 N Min. in .447 .572 .760 .822 .948 1.072 1.192 1.322 1.442 1.760 mm 11.354 14.529 19.304 20.879 24.079 27.229 30.277 33.579 36.627 44.704 G +.005 (.127) in mm .605 15.638 .730 18.542 .917 23.292 .980 24.892 1.105 28.067 1.225 31.115 1.350 34.290 1.475 37.465 1.600 40.640 1.856 47.143 H +.005 (.127) in mm .635 16.129 .760 19.304 .947 24.054 1.010 25.654 1.135 28.829 1.260 32.004 1.385 35.179 1.510 38.354 1.635 41.529 1.885 47.879 K +.005 (.127) in mm .594 15.088 .719 18.263 .812 20.625 .906 23.013 .969 24.613 1.062 26.975 1.156 29.363 1.250 31.750 1.375 34.925 1.562 39.675 Recommended Minimum Torque for Jam Nut Shell Size Torque (Inch/lb.) 8 28 10 36 12 56 14 64.5 3-20 16 69 18 81 20 102 22 122.5 Call Toll Free: 1 (800) 323-9612 24 144 D-SUBMINIATURE D*KL Series HTD/HPD Series D*A Series Overmold Kits D*U Series T* Series Basic D Series Series 1 - High Reliability Series 3 - High Reliability M24308 Series Backshells/Junctionshells/Hoods Accessories Application Tooling D-subminiature Connectors Information Introduction The D-subminiature is one of the most popular styles of connectors in the I/O category. It is used in computer, telecom, datacom, medical, and test instrumentation applications as well as in the military and aerospace fields. Types of D-subminiature connectors manufactured by Cinch • • Printed Circuit Board connectors: - Vertical connectors for panel mounting with Dip Solder PC tails. - Right-Angle connectors for board mounting with Dip Solder PC tails. Wire Termination connectors for cable assemblies or wire harnesses: - Crimp and Poke connectors. - Solder Cup connectors. - Insulation Displacement connectors IDCS to terminate discrete wire or flat cable. - Wire Wrap connectors. How to read this section • The information pages provide standard data common to all D-subminiature connectors. These include: - D-subminiature contact arrangements - see page 4-5. Panel mounting specifications/hardware - see page 4-6. D-subminiature shell dimensions - see page 4-7. D-subminiature and combo D layouts - see pages 4-5, 4-8 thru 4-10, and 4-56. General Performance Specifications - see page 4-2. PCB thickness chart - see page 4-8. • D-subminiature pages are grouped by series. A series is a family of connectors with a similar performance level. Each series shares a set of features and specifications, from economical and commercial grade product to high-reliability and military connectors. Each series begins with a page outlining general features and specifications of connectors, followed by the pages on individual connectors with drawings or features specific to that connector. Drawings reflect clarifications of dimensions not called out in the information pages of this catalog. The features of each series can be found in the chart on page 4-4. • Accessories including backshells, junction shells, and hoods as well as hardware can be found on pages 4-80 thru 4-99. • Termination tooling for Cinch connectors can be found at the end of the D-subminiature section of this catalog on pages 4-100 thru 4-104. 4-1 Call Toll Free: 1 (800) 323-9612 4 D-subminiature Connectors Information Introduction General Information • All connectors are intermateable with any Cinch D-subminiature of comparable pin count and density, or the D-sub connector of any other manufacturer complying dimensionally with MIL-C-24308. • Solder terminations and boardlocks meet the requirements for solderability in accordance with MIL-STD-202, Method 208. • DURABILITY - Mated connectors are subjected to cycles of insertions and withdrawals specified on the catalog page. After the prescribed cycles the connectors will meet the Cinch requirements concerning insertionwithdrawal force, individual contact insertion-withdrawal force, and contact resistance. • APPROVALS - Most Cinch connectors have UL recognition and CSA approval; however, the specific approvals are listed on the individual catalog pages. • CONTACTS - 4 • METAL SHELLS - Commercial-grade steel shells are usually available in zinc plating with yellow chromate finish or tin plating. Tin-plated plugs have grounding indents. - Military grade M24308 Series connector shells are generally steel or in certain cases non-magnetic brass with cadmium plating and yellow chromate finish. Insulator materials are glass-filled polyester, glass-filled nylon, and diallyl phthalate. • Cinch connector contacts are generally offered in Gold Flash or 30µin. gold plating for commercial product, and 50µin. gold plating for M24308 Series Military D-subminiature connectors. Cinch connectors utilize economical stamped and formed contacts and/or screw machine contacts for enhanced performance. Standard density connectors utilize size 20 contacts. Cinch 1.5 Density Series connectors utilize size 22 contacts for greater density in a standard size D-subminiature outer shell. The connectors are usually available in plugs and sockets in 9, 15, 25, 37, and 50 position sizes. Call Toll Free: 1 (800) 323-9612 4-2 D-subminiature Connectors Information Introduction Printed Circuit Board Connectors • Cinch provides connectors in various footprints, contact diameters, and lengths in both vertical and right-angle PC mount styles with dip solder tails. • Cinch PCB connectors have metal shells. Connectors for Terminating Cable Wire • Wire Wrap connectors are available in two tail lengths for two-wrap and three-wrap terminations. The contact is terminated by wrapping wire around it using a wire wrap gun. This connector is especially useful for prototyping since the wire can be unwrapped and rewrapped if necessary. • Solder Cup connectors allow reliable long-term termination by soldering the wire directly into the connector contact. Cinch Solder Cups accommodate up to 20 AWG wire. • Crimp and Poke connectors allow the wire to be terminated more economically than wire wrap or solder cup styles. Contacts are crimped and inserted into the connector. In our D*U Series, the contact is crimped around the conductor wire. In our D*A Series, the contact is crimped around the wire and the insulation. Crimp and Poke connectors can be selectively loaded to save labor and material cost. • IDC connectors are an alternative to other types of wire termination connectors. IDC is much faster and very reliable when all contacts are terminated and the volume is high. IDC utilizes mass termination of the cable wire. This can save considerable time and expense in the cable assembly process. The estimated time of terminating two ends of a 25-conductor discrete wire cable with 25-position D-subminiature connectors is about 5-1/2 to 6 minutes less per cable assembly using IDC connectors and Cinch Auto-Clinch termination tooling versus using Crimp and Poke connectors. This may vary considerably based on the operator, cable wire, and process. Cinch offers IDC connectors in two versions-for discrete wire or flat ribbon termination. 4 4-3 Call Toll Free: 1 (800) 323-9612 D-subminiature Connectors Information Introduction Feature Guide The chart below contains Cinch D-subminiature product features and styles grouped by series. Performance Level Series D*KL Termination Type Vertical PCB Right-Angle PCB Crimp and Poke Solder Cup IDC Wire Wrap Insulator Material G-F Nylon G-F Polyester Diallyl Phthalate 4 Economical Shell Material All Plastic Steel Shell Shell Plating Tin-Lead Plating Zinc Plating-Y/C finish Cadmium Plating-Y/C finish HPD/HTD Commercial D*A 4-12 4-12 D*U T 4-26 4-16 4-16 High-Reliability Basic D Series 1 4-42 4-50 4-76 • 4-76 4-26 4-34 • • • 4-42 M24308 • 4-50 4-26 4-20 Series 3 Military 4-72 4-50 4-76 4-76 4-34 • 4-42 • • • • • • • • • • • • • • • •* • • • • • •* • • • • • • • • • • • • • • • • • • • • • • Contact Plating Gold-Flash Plating 30µin. Gold Plating 50µin. Gold Plating • • • • • • • • • • • • Contact Type Stamped Contacts Machined Contacts • • • • • • • • Accessories information starts on page 4-80. Tooling information starts on page 4-100. * Applies to Combination Layout Only. Call Toll Free: 1 (800) 323-9612 4-4 D-subminiature Connectors Information Introduction Contact Arrangements Standard Density Plug Inserts 4 1.5 Density Plug Inserts NOTE: Mating face of plug is shown; socket is mirror image. 4-5 Call Toll Free: 1 (800) 323-9612 D-subminiature Connectors Information Introduction Shells and Mounts Panel Mounting Specifications Dimensions Shell Size E A B C 4 D Mounting Method Front/ Positions Rear Panel in Front 0.98 9 Rear 0.98 Front 1.31 15 Rear 1.31 Front 1.85 25 Rear 1.85 Front 2.50 37 Rear 2.50 Front 2.41 50 Rear 2.41 A mm 24.89 24.89 33.27 33.27 46.99 46.99 63.50 63.50 61.21 61.21 B in 0.49 0.49 0.66 0.66 0.93 0.93 1.25 1.25 1.20 1.20 mm 12.45 12.45 16.76 16.76 23.62 23.62 31.75 31.75 30.48 30.48 in 0.87 0.81 1.10 1.13 1.74 1.67 2.39 2.33 2.30 2.22 C mm 22.10 20.57 27.94 28.70 44.20 42.42 60.71 59.18 58.42 56.39 D in 0.44 0.40 0.60 0.57 0.87 0.84 1.20 1.16 1.15 1.11 E mm 11.18 10.16 15.24 14.48 22.10 21.34 30.48 29.46 29.21 28.19 in 0.51 0.45 0.51 0.45 0.51 0.45 0.51 0.45 0.62 0.56 mm 12.95 11.43 12.95 11.43 12.95 11.43 12.95 11.43 15.75 14.22 F in 0.26 0.23 0.26 0.23 0.26 0.23 0.26 0.23 0.31 0.28 mm 6.60 5.84 6.60 5.84 6.60 5.84 6.60 5.84 6.60 5.84 PANEL MOUNTING HARDWARE: Aids in alignment of plug and receptacle. Float Bushing Reverse Float Bushing Rear panel mounting Front panel mounting Floating Dual Bushing 4-40 Clinch Nut Rear panel mounting Front and rear panel mounting Call Toll Free: 1 (800) 323-9612 4-6 H in 0.08 0.13 0.08 0.13 0.08 0.13 0.08 0.13 0.08 0.13 mm 2.03 3.30 2.03 3.30 2.03 3.30 2.03 3.30 2.03 3.30 D-subminiature Connectors Information Introduction Shells and Mounts Two Holes .120 + .005 (3.05 + 0.13) Dia. Termination Side Mating Side Shell Connector Size Positions Type E 9 A 15 B 25 C D 37 50 A +.015" (0.38mm) in mm B +.010" (0.25mm) in mm B1 +.005" (0.13 mm) in mm Plug 1.213 30.81 -- -- .666 Socket 1.213 30.81 .640 16.26 -- Plug 1.541 39.14 -- Socket 1.541 39.14 .968 24.59 -- Plug 2.088 53.04 -- -- 1.534 Socket 2.088 53.04 1.508 38.30 -- Plug 2.729 69.32 -- Socket 2.729 69.32 2.156 --- --- .994 2.182 54.76 -- Plug 2.635 66.93 -- -- 2.079 Socket 2.635 66.93 2.062 52.34 -- 16.90 -25.30 -39.00 -55.40 -52.80 -- G +.010" H +.010" J +.010" Shell Connector (0.25mm) (0.25mm) (0.25 mm) Size Positions Type in mm in mm in mm E 9 Plug .759 19.28 .422 10.72 .030 0.76 Socket .759 19.28 .422 10.72 .030 0.76 A 15 Plug 1.083 27.51 .422 10.72 .030 0.76 Socket 1.083 27.51 .422 10.72 .030 0.76 B 25 Plug 1.625 41.27 .422 10.72 .039 0.99 Socket 1.625 41.27 .422 10.72 .030 0.76 C 37 Plug 2.272 57.71 .422 10.72 .039 0.99 Socket 2.272 57.71 .422 10.72 .030 0.76 D 50 Plug 2.178 55.32 .534 13.56 .039 0.99 Socket 2.178 55.32 .534 13.56 .030 0.76 B and D are outside dimensions for socket. D and B are inside dimensions for plug. 4-7 C +.005" (0.13mm) in mm D +.010" (0.25mm) in mm D1 +.010" (0.25mm) in mm E +.010" (0.25mm) in mm 0.984 24.99 -- -- .329 8.40 .494 0.984 24.99 .308 7.82 -- -- .494 12.55 12.55 1.312 33.32 -- --- .329 8.40 .494 12.55 1.312 33.32 .308 7.82 -- -- .494 12.55 1.852 47.04 -- -- .329 8.40 .494 12.55 1.852 47.04 .308 7.82 -- -- .494 12.55 2.500 63.50 -- --- .329 8.40 .494 12.55 2.500 63.50 .308 7.82 -- --- .494 12.55 -- -- .436 11.07 .605 15.37 -- -- .605 15.37 2.406 61.11 2.406 61.11 K +.005" (0.25mm) in mm .236 5.99 .243 6.17 .236 5.99 .253 6.17 .231 5.87 .243 6.17 .231 5.87 .243 6.17 .231 5.87 .243 6.17 .420 10.67 L +.010" (0.25mm) in mm .045 1.14 .045 1.14 .045 1.14 .045 1.14 .060 1.52 .045 1.14 .060 1.52 .045 1.14 .060 1.52 .045 1.14 M +.010" (0.25mm) in mm .422 10.72 .429 10.92 .422 10.72 .429 10.92 .426 10.82 .429 10.92 .426 10.82 .429 10.92 .426 10.82 .429 10.92 Call Toll Free: 1 (800) 323-9612 4 D-subminiature Connectors Information Introduction Printed Circuit Board Layout Hole Dimensions Standard Density D-subminiature Mounting Dimensions Board Layouts Footprints (Component side shown) 9 Position Shell Size E 25X 4 25 Position Shell Size B 15X 15 Position Shell Size A PC Board Lead Hole Size The footprints on this page are standard for all metal shell D-subminiature connectors. Terminal Dia. Hole in mm .040 1.02 .030 0.76 .024-.025 0.61-0.64 On all right-angle D-subminiature connectors, the short row of contacts is positioned closest to the edge of the board. Call Toll Free: 1 (800) 323-9612 4-8 Dia. in .055 .045 .039 mm 1.40 1.14 0.99 D-subminiature Connectors Information Introduction Printed Circuit Board Layout Hole Dimensions Standard Density D-subminiature Mounting Dimensions Board Layouts Footprints (Component side shown) 4 37 Position Shell Size C 50 Position Shell Size D PC Board Lead Hole Size The footprints on this page are standard for all metal shell D-subminiature connectors. Terminal Dia. Hole in mm .040 1.02 .030 0.76 .024-.025 0.61-0.64 On all right-angle D-subminiature connectors, the short row of contacts is positioned closest to the edge of the board. 4-9 Dia. in .055 .045 .039 mm 1.40 1.14 0.99 Call Toll Free: 1 (800) 323-9612 D-subminiature Connectors Information Introduction Printed Circuit Board Layout Hole Dimensions 1.5 Density D-subminiature Recommended PCB Layout for Footprint (Component side shown) ) 15 Position Shell Size E 44 Position Shell Size B 4 62 Position Shell Size C 26 Position Shell Size A PC Board Lead Hole Size The footprints on this page are standard for all metal shell D-subminiature connectors. Terminal Dia. Hole in mm .040 1.02 .030 0.76 .024-.025 0.61-0.64 On all right-angle D-subminiature connectors, the short row of contacts is positioned closest to the edge of the board. Call Toll Free: 1 (800) 323-9612 4-10 Dia. in .055 .045 .039 mm 1.40 1.14 0.99 D-subminiature Metal Shell Right-Angle and Vertical PCB D*KL Series ■ Offered in right-angle or vertical PCB mount versions. FEATURES ■ Available with gold flash or 30µin. gold plating. ■ Metal Shell provides grounding and shielding capability. ■ Approvals: • UL Recognized: File E130965. • CSA Approved: File LR97981. ENVIRONMENTAL MATERIALS ■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel mounting specifications. Insulator Material: Glass-filled polyester (black), UL 94V-O rated Contact Material: Socket - Phosphor bronze (stamped) Plug - Brass (stamped) Contact Plating: Gold flash or 30µin. gold in mating area and tin/lead on tails. All over nickel. Metal Shell: Steel with tin plating (grounding indents on plug) Operating Temperature: -55°C to +125°C Shock: 50G peak per MIL-STD-202, Method 213, Condition G Vibration: 12 cycles in three perpendicular directions @ 10-2000Hz, per MIL-STD-202, Method 204, Condition D Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per MIL-STD-202, Method 103 MECHANICAL ELECTRICAL Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: Right Angle - minimum AC 1250V RMS @ sea level, Vertical minimum AC 1000V RMS @ sea level 5 Amps 15 milliohms maximum 5000 megohms maximum (initial); 1000 megohms (minimum) after environmental testing Individual Contact Insertion and Separation Force (minimum/maximum): 0.7 oz./12 oz. Durability: 500 mating cycles Call Toll Free: 1 (800) 323-9612 4-12 Economical D-subminiature Metal Shell Right-Angle PCB D*KL Series Right-Angle Connectors • 0.318" footprint. • Available in 9, 15, and 25 position plugs and sockets. • Offered with 4-40 threaded inserts for secure mounting to panels or with female screwlocks. • Boardlocks to provide mechanical hold-down during wave soldering process. • Materials: - Boardlock: Brass with tin plating. Female Screwlock: Brass with nickel plating. Ordering Information Right-Angle Plugs 4-40 Threaded Inserts Female Screwlocks Size Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DEKL-9PATI-E DEKL-9PATI-E2 DEKL-9PATI-F DEKL-9PATI-F2 15 DAKL-15PATI-E DAKL-15PATI-E2 DAKL-15PATI-F DAKL-15PATI-F2 25 DBKL-25PATI-E DBKL-25PATI-E2 DBKL-25PATI-F DBKL-25PATI-F2 Right-Angle Sockets 4-40 Threaded Inserts Female Screwlocks Size Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DEKL-9SAT-E DEKL-9SAT-E2 DEKL-9SAT-F DEKL-9SAT-F2 15 DAKL-15SAT-E DAKL-15SAT-E2 DAKL-15SAT-F DAKL-15SAT-F2 25 DBKL-25SAT-E DBKL-25SAT-E2 DBKL-25SAT-F DBKL-25SAT-F2 4-13 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Vertical PCB D*KL Series • Vertical Connectors: - Available in 9, 15, 25, 37, and 50 position plugs and sockets with straight dip solder tails. - 0.024" contact diameter. - Offered with standard mounting holes. Plug Ordering Information 4 Vertical PCB Connectors Plugs Sockets Size Gold Flash 30µin. Gold 9 Gold Flash 30µin. Gold DEKL-9PUTI DEKL-9PUTI-2 DEKL-9SUT DEKL-9SUT-2 15 DAKL-15PUTI DAKL-15PUTI-2 DAKL-15SUT DAKL-15SUT-2 25 DBKL-25PUTI DBKL-25PUTI-2 DBKL-25SUT DBKL-25SUT-2 37 DCKL-37PUTI DCKL-37PUTI-2 DCKL-37SUT DCKL-37SUT-2 50 DDKL-50PUTI DDKL-50PUTI-2 DDKL-50SUT DDKL-50SUT-2 Call Toll Free: 1 (800) 323-9612 4-14 ■ 1.5 Density means the connector uses small size #22 contacts for a higher pin count in a standard size shell. Also accepts standard D-subminiature accessories (hoods, backshells, etc.) per the following chart: 1.5 D-sub Standard D-sub Shell Size No. of Pins No. of Pins E 15 9 A 26 15 B 44 25 C 62 37 Connector Shell: Steel with tin plating (grounding indents on plug) Contact Material: Phosphor bronze (stamped) Contact Plating: • Sockets: Gold flash or 30µin. gold in mating area and tin/lead on tails. All over nickel. • Plugs: Gold flash or 30µin. gold in mating area and gold flash on remainder. All over nickel. Operating Temperature: -55°C to +125°C Shock: 50G peak per MIL-STD-202, Method 213, Condition G Vibration: 12 cycles in three perpendicular directions @10-2000Hz, per MIL-STD-202, Method 204, Condition D Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per MlL-STD-202, Method 103 MECHANICAL ELECTRICAL MATERIALS ■ Offered in cable plugs and right-angle PCB mount sockets. ■ Metal Shell provides grounding and shielding capability. ■ Approvals: Plugs: • UL Recognized - Files E170218 (UL1977) & E130965 (UL1863). • CSA Approved - File LR31996-7. Sockets: UL Recognized - File E170218. ■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel mounting specifications. ENVIRONMENTAL FEATURES D-subminiature 1.5 Density Metal Shell Crimp and Poke and Right-Angle PCB HPD/HTD Series Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: Minimum 1000V RMS @ sea level 3 Amps 15 milliohms maximum 5000 megohms maximum (initial); 1000 megohms (minimum) after environmental testing Individual Contact Insertion and Separation Force (minimum/maximum): 0.7 oz./12 oz. Durability: • Plugs - 200 mating cycles • Sockets - 200 mating cycles Call Toll Free: 1 (800) 323-9612 4-16 D-subminiature 1.5 Density Metal Shell Crimp and Poke Plugs HTD Series Connectors: • Offered with .120 mounting holes. • Shells offered with tin plating and grounding indents. • These connectors are designed to accommodate one repair cycle. Contacts: (Not included with connectors, order separately) • Available with gold-flash plating or 30µin. gold. • Crimp and Poke versions are offered in reels of 15,000 or 300 contacts. • Solder and Poke contacts are packed loose. • Will accommodate 22-30 AWG wire. • Order contacts separately. See page 4-18. Termination Tooling: • Semi-automatic Stripper Crimper Tool for 15,000 reels: #HTD-518. See page 4-102. • Crimp Contact Hand Tool for 300-piece reels: #HTD-266. See page 4-101. • Semi-automatic Hand Crimping Tool for individual contact termination: #HTD-544. See page 4-101. • Contact Insertion/Extraction Tool: Cinch #CIET-22-DF. See page 4-101. Materials: • Insulator Material: Black UL 94 V-0 glass-filled nylon. Ordering Information HTD Series 1. 5 Density Crimp and Poke Plug Connectors Size 15 26 44 62 Shell Size E A B C Catalog Number HTDE-15PTI-FO HTDA-26PTI-FO HTDB-44PTI-FO HTDC-62PTI-FO 4-17 Call Toll Free: 1 (800) 323-9612 D-subminiature 1.5 Density Metal Shell Crimp and Poke Plugs HTD Series • Use with HTD Series 1.5 D-Sub Crimp and Poke connectors and overmold kits. • All Crimp and Poke contacts are on right-hand feed reels. Crimp and Poke Plug Contact 4 Solder and Poke Plug Ordering Information HTD Series 1. 5 D-sub Male Crimp and Poke and Solder and Poke Contacts Type of Crimp and Poke Packing 15,000 Reel Plating Gold Flash 30µin. Gold Pin HTD-CP-9-15000 HTD-CP-1-15000 Call Toll Free: 1 (800) 323-9612 Crimp and Poke 300 Reel Gold Flash 30µin. Gold HTD-CP-9-300 HTD-CP-1-300 4-18 Solder and Poke Loose Gold Flash 30µin. Gold HTD-SP-9-10 Not Available D-subminiature 1.5 Density Metal Shell Right-Angle PCB Sockets HPD Series • .350" footprint. • Offered with fixed 4-40 threaded inserts for secure mounting to panels or with assembled female screwlocks. • Boardlocks to maintain electrical continuity between shell and PC board ground and provide mechanical hold-down during wave soldering process. • Available in standard configuration sockets, sizes 15, 26, 44, and 62 with black insulator. • 15 position socket also available with royal blue insulator in Windows ‘95® configuration with Pin #9 recessed 0.050". Materials: • Insulator Material: Glass-filled polyester (standard configuration - black, -9R configuration - blue), UL 94V-0 rated. • Boardlock: Brass with tin plating. • Female Screwlock: Brass with Nickel plating. 4 WITH #4-40 FEMALE SCREWLOCKS (ASSEMBLED) Dimensions Positions 15 26 44 62 A +.015 (+0.038) in mm 1.214 30.84 1.545 39.24 2.088 53.04 2.730 69.34 +.010 in 0.984 1.312 1.852 2.500 B (+0.25) mm 24.99 33.32 47.04 63.50 +.010 in 0.640 0.967 1.508 2.156 C (+0.25) mm 16.26 24.56 38.30 54.76 D in 0.090 0.090 0.090 0.095 mm 2.29 2.29 2.29 2.41 Ordering Information HPD Series 1.5 Density Right-Angle Socket Connectors Size 15 26 44 62 15 Shell Size E A B C E Type Standard Standard Standard Standard Windows ‘95® Color Black Black Black Black Blue 4-40 Threaded Inserts Gold Flash 30µin. Gold HPDEB-15SAT-E HPDEB-15SAT-E2 HPDAB-26SAT-E HPDAB-26SAT-E2 HPDBB-44SAT-E HPDBB-44SAT-E2 HPDCB-62SAT-E HPDCB-62SAT-E2 HPDEB-15SAT-E-9R HPDEB-15SAT-E2-9R Female Screwlocks Gold Flash 30µin. Gold HPDEB-15SAT-F HPDEB-15SAT-F2 HPDAB-26SAT-F HPDAB-26SAT-F2 HPDBB-44SAT-F HPDBB-44SAT-F2 HPDCB-62SAT-F HPDCB-62SAT-F2 HPDEB-15SAT-F-9R HPDEB-15SATF2-9R Windows '95 is a registered trademark of Microsoft. 4-19 Call Toll Free: 1 (800) 323-9612 FEATURES D-subminiature Metal Shell Crimp and Poke D*A Series ■ Offered in 9, 15 , 25, 37, and 50 position plugs and sockets. ■ Contacts: - Available with gold flash or 30µin. gold plating. - Offered in 15,000 contact reel or 300 contact reel, or in loose-piece bags of 100 or 1000 each. - Accommodate 20-24 AWG wire or 26-30 AWG wire. - Not included with connector - order stamped contacts separately. ■ Approvals: - UL Recognized - Files E170218 (UL1977) and E130965 (UL1863). - CSA Approved - File LR31996. MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS ■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel mounting specifications. Insulator Material: Glass-filled nylon (black), UL 94 V-O rated Connector Shell: Steel with zinc plating and yellow chromate finish or tin plating (plug has grounding indents) Contact Material: • Plug - Brass (stamped) • Socket - Phosphor bronze (stamped) Contact Plating: Gold flash or 30µin. gold in mating area and gold flash on the remainder. All over nickel. 4-40 Clinch Nut: Steel with cadmium plating and yellow chromate finish Dual Float Bushing: Stainless steel, passivated Operating Temperature: -65°C to + 125°C Shock: 50G peak per MIL-STD-202, Method 213, Condition G Vibration: 12 cycles in three perpendicular directions @ 10-2000Hz, per MIL-STD-202, Method 204, Condition D Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per MIL-STD-202, Method 103 Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: Minimum 1000V RMS @ sea level 5 Amps 2.7 milliohms maximum 5000 megohms maximum (initial); 1000 megohms (minimum) after environmental testing Individual Contact Insertion and Separation Force (minimum/maximum): 0.7 oz./12 oz. Durability: 500 mating cycles Call Toll Free: 1 (800) 323-9612 4-20 D-subminiature Metal Shell Crimp and Poke Connectors D*A Series • Offered with .120 mounting holes or 4-40 clinch nuts. .453 (11.51) MAX. Termination Tools • Semi-Automatic Stripper Crimper Tool for 15K reels: #GSC-20-30. See page 4-102. • Contact Insertion/Extraction Tool: #CIET-20-HDB. See page 4-101. • Crimp Contact Hand Tool for 300-piece reels: #GHC-B (20-26 AWG wire) or Catalog #GHC-B1 (28-30 AWG wire). See page 4-101. Crimp Contact Hand Tool for loose piece contacts: #HTD-544. See page 4-101. • Ordering Information D*A Series Crimp and Poke Connectors - Plugs Zinc-plated shell with yellow chromate finish Positions 9 Tin-plated shell with grounding indents Mounting Holes 4-40 Clinch Nuts Mounting Holes 4-40 Clinch Nuts DEA-9P-FO DEAE-9P-FO DEA-9PTI-FO DEAE-9PTI-FO 15 DAA-15P-FO DAAE-15P-FO DAA-15PTI-FO DAAE-15PTI-FO 25 DBA-25P-FO DBAE-25P-FO DBA-25PTI-FO DBAE-25PTI-FO 37 DCA-37P-FO DCAE-37P-FO DCA-37PTI-FO DCAE-37PTI-FO 50 DDA-50P-FO DDAE-50P-FO DDA-50PTI-FO DDAE-50PTI-FO D*A Series Crimp and Poke Connectors - Sockets Zinc-plated shell with yellow chromate finish Positions Tin-plated shell Mounting Holes 4-40 Clinch Nuts Mounting Holes 4-40 Clinch Nuts DEA-9S-FO DEAE-9S-FO DEA-9ST-FO DEAE-9ST-FO 15 DAA-15S-FO DAAE-15S-FO DAA-15ST-FO DAAE-15ST-FO 25 DBA-25S-FO DBAE-25S-FO DBA-25ST-FO DBAE-25ST-FO 37 DCA-37S-FO DCAE-37S-FO DCA-37ST-FO DCAE-37ST-FO 50 DDA-50S-FO DDAE-50S-FO DDA-50ST-FO DDAE-50ST-FO 9 4-21 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Crimp and Poke Insulation Grip Contacts D*A Series Contacts Pin Socket Ordering Information D*A Series Crimp and Poke Contacts on Reels Contacts per Reel Wire Gauge 4 Plating 15,000 15,000 20-24 AWG Gold Flash 30µin. Gold DGP-15-1 DGP-15-2 Pin Socket DGS-15-1 DGS-15-2 300 300 26-30 AWG 20-24 AWG 26-30 AWG Gold Flash 30µin. Gold DGP-15-3 DGP-15-4 Gold Flash 30µin. Gold DGP-3-1 DGP-3-2 Gold Flash 30µin. Gold DGP-3-3 DGP-3-4 DGS-15-3 DGS-15-4 DGS-3-1 DGS-3-2 DGS-3-3 DGS-3-4 D*A Series Crimp and Poke Loose-Piece Contacts Contacts per Bag Wire Gauge 100 100 20-24 AWG 30µin Gold 1000 26-30 AWG Gold Flash 20-24 AWG Gold Flash Pin DGP-100L-1 DGP-100L-2 DGP-100L-3 DGP-100L-4 DGP-1000L-1 DGP-1000L-2 DGP-1000L-3 DGP-100L-4 Socket DGS-100L-1 DGS-100L-2 DGS-100L-3 DGS-100L-4 DGS-1000L-1 DGS-1000L-2 DGS-1000L-3 DGS-100L-4 4-22 Gold Flash 30µin. Gold 26-30 AWG Plating Call Toll Free: 1 (800) 323-9612 30µin Gold 1000 Gold Flash 30µin. Gold MATERIALS FEATURES D-subminiature Metal Shell Overmold Kits D*A and HTD Series ■ Cinch overmold kits enable you to overmold the connector of the cable assembly for less material and process cost (versus a metal backshell), improved appearance, and improved shielding of the connector to help meet RFI/EMI requirements. ■ An Overmold Kit catalog number consists of: - D*A or HTD Crimp and Poke connector. - Inside shielding cover. - Outside shielding cover. ■ You will also need to order the following: - Crimp and Poke stamped contacts must be ordered separately on page 4-22 for D*A and page 4-18 for HTD connectors. - Ferrules are required, but must be ordered separately according to the size necessary to accommodate the wire. See page 4-25. - Termination tooling is required to crimp the wires on the connector. - A hand tool and appropriate crimping die are required for crimping the ferrule. ■ All specifications on the connector portion of the overmold kit can be found on pages 4-16 thru 4-17 for HPD 1.5 density and pages 4-20 thru 4-21 for D*A series. Shield Covers: Steel (stamped) with tin/lead finish Ferrule: Brass Dimensions Overmold Shielding Kits C Positions 9 Plug 9 Socket 15 Plug 15 Socket 25 Plug 25 Socket 37 Plug 37 Socket in 0.270 0.285 0.270 0.285 0.275 0.285 0.275 0.285 D mm 6.86 7.24 6.86 7.24 6.99 7.24 6.99 7.24 Call Toll Free: 1 (800) 323-9612 in 0.705 0.705 1.050 1.050 1.590 1.590 2.240 2.240 E mm 17.91 17.91 26.67 26.67 40.39 40.39 56.90 56.90 4-24 in 1.320 1.320 1.320 1.320 1.320 1.320 1.620 1.620 mm 33.53 33.53 33.53 33.53 33.53 33.53 41.15 41.15 F in 0.520 0.520 0.520 0.520 0.520 0.520 0.750 0.750 mm 13.21 13.21 13.21 13.21 13.21 13.21 19.05 19.05 G Deg. 75° 75° 58° 58° 40° 40° 32° 32° H in 0.440 0.440 0.440 0.440 0.440 0.440 0.520 0.520 mm 11.18 11.18 11.18 11.18 11.18 11.18 13.21 13.21 D-subminiature Metal Shell Overmold Kits and Ferrules D*A and HTD Series Overmold Kits (Cont’d) Ordering Information D*A Series Crimp and Poke Overmold Kits Tin-plated Plugs DEAO-9PTI-FO1 DAAO-15PTI-FO1 DBAO-25PTI-FO1 DCAO-37PTI-FO1 Positions 9 15 25 37 shell Sockets DEAO-9ST-FO1 DAAO-15ST-FO1 DBAO-25ST-FO1 DCAO-37ST-FO1 HTD Series 1. 5 Density Plugs Overmold Kits Size 15 26 44 Shell Size E A B Catalog Number HTDEO-15PTI-FO1 HTDAO-26PTI-FO1 HTDBO-44PTI-FO1 Crimp Ferrule Ordering Information Catalog Number CF-51 CF-42 CF-43 CF-44 CF-45 CF-46 CF-47 CF-50 J Type 1 1 1 1 1 1 2 2 in .437 .437 .437 .437 .437 .437 .437 .460 mm 11.10 11.10 11.10 11.10 11.10 11.10 11.10 11.68 K in .200 .235 .250 .325 .350 375 .437 .460 L mm 5.08 5.97 6.35 8.26 8.89 9.53 11.10 11.68 in .450 .450 .450 .450 .450 .450 .450 .450 mm 11.43 11.43 11.43 11.43 11.43 11.43 11.43 11.43 Crimp Die Catalog No. CD-07 CD-00 CD-01 CD-02 CD-03 CD-04 CD-05 CD-06 • Pneumatic Bench Top Press for Crimping Ferrules #FCT-551. See page 4-103. • Hand Tool for Crimping Ferrules #FCT-552. See page 4-103. 4-25 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Crimp and Poke, Right-Angle and Vertical PCB D*U Series FEATURES ■ Offered in 9, 15, 25, 37, and 50 position plugs and sockets (except right-angle PCB connectors9 , 15, and 25 positions). ■ Available with gold flash or 30µin. gold plating. ■ Offered with .120 mounting holes, optional 4-40 clinch nuts, or dual float bushings (except rightangle PCB connectors-mounting holes only). ■ Approvals: • UL Recognized - Files E170218 (UL1977) and E130965 (UL1863). • CSA Approved - File LR31996. ■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel mounting specifications. MATERIALS Insulator Material: Glass-filled nylon (black), UL 94 V-O rated Connector Shell: Steel with zinc plating and yellow chromate finish or tin plating (grounding indents on plug) 4-40 Clinch Nut: Steel with cadmium plating and yellow chromate finish ENVIRONMENTAL Dual Float Bushing: Stainless steel, passivated Operating Temperature: -65°C to + 125°C Shock: 50G peak per MIL-STD-202, Method 213, Condition G Vibration: 12 cycles in three perpendicular directions @ 10-2000Hz, per MIL-STD-202, Method 204, Condition D Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per MIL-STD-202, Method 103 ELECTRICAL Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: Minimum 1000V RMS @ sea level 5 Amps 2.7 milliohms maximum 5000 megohms maximum (initial); 1000 megohms (minimum) MECHANICAL after environmental testing Individual Contact Insertion and Separation Force (minimum/maximum): 0.7 oz./12 oz. Durability: 500 mating cycles Call Toll Free: 1 (800) 323-9612 4-26 D-subminiature Metal Shell Crimp and Poke D*U Series • Machined contacts supplied loose with connector or can be ordered separately. Use with 20-24 AWG wire. • Stamped Contacts (order separately) for use when ordering connector with contacts not included (-FO option). Use with 20-28 AWG wire. - Available in 10K reel. Order reels of stamped contacts separately. Materials • Contact Material: Plug - Brass (stamped) or copper alloy (machined). Socket - Phosphor bronze (stamped) or copper alloy (machined). • Contact Plating: - Stamped Plugs and Sockets: Gold flash or 30µin. gold and gold flash on the remainder. All over nickel. - Machined Plugs and Sockets: Gold flash or 30µin. gold. All over nickel. Termination Tooling • Semi-Automatic Stripper Crimper for Stamped Contacts on 10K PC reels: #ESC-20-3. See page 4-102. • Contact Insertion/Extraction: #CIET-20-HDB. See page 4-101. • Loose Contact Crimp Tool: Machined Contact - #M22520/2-01. See page 4-103. For Positioner as required see page 4-103. 4 Stamped Contacts #BT-20-HC see page 4-101. No positioner required. 4-27 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Crimp and Poke D*U Series Ordering Information D*U Crimp and Poke Plugs Zinc-Plated Shell with Yellow Chromate Finish Position 9 15 25 37 50 Mounting Holes Contacts Without Included Contacts DEU-9P DEU-9P-FO DAU-15P DAU-15P-FO DBU-25P DBU-25P-FO DCU-37P DCU-37P-FO DDU-50P DDU-50P-FO 4-40 Clinch Nuts Contacts Without Included Contacts DEUE-9-P DEUE-9P-FO DAUE-15-P DAUE-15-P-FO DBUE-25-P DBUE-25P-FO DCUE-37-P DCUE-37P-FO DDUE-50-P DDUE-50P-FO Dual Float Contacts Included DEUY-9P DAUY-15P DBUY-25P DCUY-37P DDUY-50P Bushings Without Contacts DEUY-9P-FO DAUY-15P-FO DBUY-25P-FO DCUY-37P-FO DDUY-50P-FO 4-40 Clinch Nuts Contacts Without Included Contacts DEUE-9PTI DEUE-9PTI-FO DAUE-15PTI DAUE-15PTI-FO DBUE-25PTI DBUE-25PTI-FO DCUE-37PTI DCUE-37PTI-FO DDUE-50PTI DDUE-50PTI-FO Dual Float Contacts Included DEUY-9PTI DAUY-15PTI DBUY-25PTI DCUY-37PTI DDUY-50PTI Bushings Without Contacts DEUY-9PTI-FO DAUY-15PTI-FO DBUY-25PTI-FO DCUY-37PTI-FO DDUY-50PTI-FO 4-40 Clinch Nuts Contacts Without Included Contacts DEUE-9S DEUE-9S-FO DAUE-15S DAUE-15S-FO DBUE-25S DBUE-25S-FO DCUE-37S DCUE-37S-FO DDUE-50S DDUE-50S-FO Dual Float Contacts Included DEUY-9S DAUY-15S DBUY-25S DCUY-37S DDUY-50S Bushings Without Contacts DEUY-9S-FO DAUY-15S-FO DBUY-25S-FO DCUY-37S-FO DDUY-50S-FO Mounting Holes Contacts Without Included Contacts DEU-9ST DEU-9ST-FO DAU-15ST DAU-15ST-FO DBU-25ST DBU-25ST-FO DCU-37ST DCU-37ST-FO DDU-50ST DDU-50ST-FO 4-40 Clinch Nuts Contacts Without Included Contacts DEUE-9ST DEUE-9ST-FO DAUE-15ST DAUE-15ST-FO DBUE-25ST DBUE-25ST-FO DCUE-37ST DCUE-37ST-FO DDUE-50ST DDUE-50ST-FO Dual Float Contacts Included DEUY-9ST DAUY-15ST DBUY-25ST DCUY-37ST DDUY-50ST Bushings Without Contacts DEUY-9ST-FO DAUY-15ST-FO DBUY-25ST-FO DCUY-37ST-FO DDUY-50ST-FO Call Toll Free: 1 (800) 323-9612 4-28 Tin-Plated Shell with Grounding Indents 4 Position 9 15 25 37 50 Mounting Holes Contacts Without Included Contacts DEU-9PTI DEU-9PTI-FO DAU-15PTI DAU-15PTI-FO DBU-25PTI DBU-25PTI-FO DCU-37PTI DCU-37PTI-FO DDU-50PTI DDU-50PTI-FO D*U Crimp and Poke Sockets Zinc-Plated Shell with Yellow Chromate Finish Position 9 15 25 37 50 Mounting Holes Contacts Without Included Contacts DEU-9S DEU-9S-FO DAU-15S DAU-15S-FO DBU-25S DBU-25S-FO DCU-37S DCU-37S-FO DDU-50S DDU-50S-FO Tin-Plated Shell Position 9 15 25 37 50 D-subminiature Metal Shell Crimp and Poke Contacts D*U Series Machined Contacts • 20-24 AWG Wire Plug Socket Dimensions A Description Pin Socket Wire AWG #20, 22, 24 #20, 22, 24 in .066 .066 B mm 1.67 1.67 in .045 .045 C Max. mm 1.14 1.14 in .537 .523 mm 13.64 13.28 Ordering Information D*U Series Loose-Piece Machined Contacts Pin Socket Gold Flash 030-1952-000 030-1953-000 30µin. Gold 030-1952-030 030-1953-030 4 Stamped Contacts • 20-28 AWG Wire Plug Socket Ordering Information D*U Series Stamped Contacts on 10K Reels Pin Socket Gold Flash BCL-1964-20P BCL-1963-20S 30µin. Gold D110238-034 D110238-035 4-29 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Right-Angle Dip Solder PCB D*U Series • • .445" footprint. .024" contact diameter. Materials • Contact Material: Socket - Copper alloy (machined), Plug - Brass (machined). • Contact Plating: Gold flash or 30µin. gold. All over nickel. • Mounting bracket: Black nylon. Can be removed if necessary. .375 (9.50) .040 (1.02) .030 (0.76) .010 (0.25) Ref. .164 (4.17) .149 (3.78) .453 (11.51) .437 11.10) .026 (0.66) .022 (0.56) .117 (2.97) .107 (2.72) Typ. .657 (16.69) .637 (16.18) 4 Ordering Information D*U Right-Angle Plugs Zinc-Plated Shell with Yellow Chromate Finish Positions 9 15 25 Gold Flash DEU-9PAD DAU-15PAD DBU-25PAD 30µin. Gold DEU-9PAD-30 DAU-15PAD-30 DBU-25PAD-30 Tin-Plated Shell with Grounding Indents Gold Flash DEU-9PADTI DAU-15PADTI DBU-25PADTI 30µin. Gold DEU-9PADTI-30 DAU-15PADTI-30 DBU-25PADTI-30 D*U Right-Angle Sockets Zinc-Plated Shell with Yellow Chromate Finish Positions 9 Gold Flash DEU-9SAD 15 25 Tin-Plated Shell 30µin. Gold DEU-9SAD-30 Gold Flash DEU-9SADT 30µin. Gold DEU-9SADT-30 DAU-15SAD DAU-15SAD-30 DAU-15SADT DAU-15SADT-30 DBU-25SAD DBU-25SAD-30 DBU-25SADT DBU-25SADT-30 Call Toll Free: 1 (800) 323-9612 4-30 D-subminiature Metal Shell Vertical Dip Solder PCB D*U Series • • .024" contact diameter. Longer rear insulator provides integral standoff from PCB. Materials • • Contact Material: Plug - Brass (machined), Socket - Copper alloy (machined). Contact Plating: Gold flash or 30µin. gold. All over nickel. .159 (4.04) .129 (3.28) .375 (9.50) Max. .026 (066) Typ. .022 (0.56) .514 (13.06) .483 (12.27) 4 Ordering Information Vertical Plugs Zinc-Plated Shell with Yellow Chromate Finish Mounting Holes 4-40 Clinch Nuts Positions Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DEU-9PBF DEU-9PBF-30 DEUE-9PBF DEUE-9PBF-30 15 DAU-15PBF DAU-15PBF-30 DAUE-15PBF DAUE-15PBF-30 25 DBU-25PBF DBU-25PBF-30 DBUE-25PBF DBUE-25PBF-30 37 DCU-37PBF DCU-37PBF-30 DCUE-37PBF DCUE-37PBF-30 50 DDU-50PBF DDU-50PBF-30 DDUE-50PBF DDUE-50PBF-30 Dual Float Gold Flash DEUY-9PBF DAUY-15PBF DBUY-25PBF DCUY-37PBF DDUY-50PBF Tin-Plated Shell with Grounding Indents Mounting Holes Positions Gold Flash 30µin. Gold 9 DEU-9PBFTI DEU-9PBFTI-30 15 DAU-15PBFTI DAU-15PBFTI-30 25 DBU-25PBFTI DBU-25PBFTI-30 37 DCU-37PBFTI DCU-37PBFTI-30 50 DDU-50PBFTI DDU-50PBFTI-30 Dual Float Bushings Gold Flash 30µin. Gold DEUY-9PBFTI DEUY-9PBFTI-30 DAUY-15PBFTI DAUY-15PBFTI-30 DBUY-25PBFTI DBUY-25PBFTI-30 DCUY-37PBFTI DCUY-37PBFTI-30 DDUY-50PBFTI DDUY-50PBFTI-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEUE-9PBFTI DEUE-9PBFTI-30 DAUE-15PBFTI DAUE-15PBFTI-30 DBUE-25PBFTI DBUE-25PBFTI-30 DCUE-37PBFTI DCUE-37PBFTI-30 DDUE-50PBFTI DDUE-50PBFTI-30 4-31 Bushings 30µin. Gold DEUY-9PBF-30 DAUY-15PBF-30 DBUY-25PBF-30 DCUY-37PBF-30 DDUY-50PBF-30 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Vertical Dip Solder PCB D*U Series Ordering Information (Cont’d) Vertical Sockets Zinc-Plated Shell with Yellow Chromate Finish Mounting Holes 4-40 Clinch Nuts Positions Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DEU-9SBF DEU-9SBF-30 DEUE-9SBF DEUE-9SBF-30 15 DAU-15SBF DAU-15SBF-30 DAUE-15SBF DAUE-15SBF-30 25 DBU-25SBF DBU-25SBF-30 DBUE-25SBF DBUE-25SBF-30 37 DCU-37SBF DCU-37SBF-30 DCUE-37SBF DCUE-37SBF-30 50 DDU-50SBF DDU-50SBF-30 DDUE-50SBF DDUE-50SBF-30 Dual Float Gold Flash DEUY-9SBF DAUY-15SBF DBUY-25SBF DCUY-37SBF DDUY-50SBF Bushings 30µin. Gold DEUY-9SBF-30 DAUY-15SBF-30 DBUY-25SBF-30 DCUY-37SBF-30 DDUY-50SBF-30 Dual Float Gold Flash DEUY-9SBFT DAUY-15SBFT DBUY-25SBFT DCUY-37SBFT DDUY-50SBFT Bushings 30µin. Gold DEUY-9SBFT-30 DAUY-15SBFT-30 DBUY-25SBFT-30 DCUY-37SBFT-30 DDUY-50SBFT-30 Tin-Plated Shell Positions 9 15 25 37 50 Mounting Holes Gold Flash 30µin. Gold DEU-9SBFT DEU-9SBFT-30 DAU-15SBFT DAU-15SBFT-30 DBU-25SBFT DBU-25SBFT-30 DCU-37SBFT DCU-37SBFT-30 DDU-50SBFT DDU-50SBFT-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEUE-9SBFT DEUE-9SBFT-30 DAUE-15SBFT DAUE-15SBFT-30 DBUE-25SBFT DBUE-25SBFT-30 DCUE-37SBFT DCUE-37SBFT-30 DDUE-50SBFT DDUE-50SBFT-30 Call Toll Free: 1 (800) 323-9612 4-32 4 D-subminiature Metal Shell and All Plastic Solder Cup and IDC T* Series ■ Offered in 9, 15, 25, and 37 position plugs and sockets. ■ Available in Solder Cup and IDC (insulation displacement) terminations for discrete wire. FEATURES ■ Offered with .120 mounting holes. ■ Approvals: • • UL Recognized - Files E170218 (UL1977) and E130965 (UL1863). CSA Approved - File LR31996. ENVIRONMENTAL MATERIALS ■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel mounting specifications. Insulator Material: Glass-filled polyester (black), UL 94 V-O rated Connector Shell: Steel with zinc plating and yellow chromate finish or tin plating (grounding indents on plug) Contact Material: Phosphor bronze (stamped) Contact Plating: Gold flash or 30µin. gold in mating area and gold flash on the remainder. All over nickel. Operating Temperature: -65°C to + 125°C Shock: 50G peak per MIL-STD-202, Method 213, Condition G Vibration: 12 cycles in three perpendicular directions @ 10-2000Hz, per MIL-STD-202, Method 204, Condition D Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per MIL-STD-202, Method 103 MECHANICAL ELECTRICAL Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: Minimum 1000V RMS @ sea level 3 Amps 2.7 milliohms maximum 5000 megohms maximum (initial); 1000 megohms (minimum) after environmental testing Individual Contact Insertion and Separation Force (minimum/maximum): 0.7 oz./12 oz. Durability: 500 mating cycles Call Toll Free: 1 (800) 323-9612 4-34 D-subminiature Metal Shell Solder Cup for Discrete Cable Wire T* Series • • Solder channels between barriers permit single-pass soldering of each row without solder bridging. Will accommodate up to 22 AWG wire. Ordering Information Solder Cup Plugs Positions 9 15 25 37 Zinc-Plated Shell with Yellow Chromate Finish Gold Flash 30µin. Gold TE-9PS TE-9PS-30 TA-15PS TA-15PS-30 TB-25PS TB-25PS-30 TC-37PS TC-37PS-30 Tin-Plated Shell with Grounding Indents Gold Flash 30µin. Gold TE-9PTIS TE-9PTIS-30 TA-15PTIS TA-15PTIS-30 TB-25PTIS TB-25PTIS-30 TC-37PTIS TC-37PTIS-30 Solder Cup Sockets Positions 9 15 25 37 Zinc-Plated Shell with Yellow Chromate Finish Gold Flash 30µin. Gold TE-9SS TE-9SS-30 TA-15SS TA-15SS-30 TB-25SS TB-25SS-30 TC-37SS TC-37SS-30 Tin-Plated Shell Gold Flash TE-9STS TA-15STS TB-25STS TC-37STS 4-35 30µin. Gold TE-9STS-30 TA-15STS-30 TB-25STS-30 TC-37STS-30 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell IDC for Discrete Cable Wire T* Series • Will accommodate 24-26 AWG solid or stranded PVC wire. Ordering Information IDC Plugs 4 Positions 9 15 25 37 Zinc-Plated Shell with Yellow Chromate Finish Gold Flash 30µin. Gold TE-9PSH TE-9PSH-30 TA-15PSH TA-15PSH-30 TB-25PSH TB-25PSH-30 TC-37PSH TC-37PSH-30 Tin-Plated Shell with Grounding Indents Gold Flash 30µin. Gold TES-9PTI TES-9PTI-30 TAS-15PTI TAS-15PTI-30 TBS-25PTI TBS-25PTI-30 TCS-37PTI TCS-37PTI-30 IDC Sockets Positions 9 15 25 37 Zinc-Plated Shell with Yellow Chromate Finish Gold Flash 30µin. Gold TE-9SSH TE-9SSH-30 TA-15SSH TA-15SSH-30 TB-25SSH TB-25SSH-30 TC-37SSH TC-37SSH-30 Call Toll Free: 1 (800) 323-9612 Tin-Plated Shell Gold Flash TES-9ST TAS-15ST TBS-25ST TCS-37ST 30µin. Gold TES-9ST-30 TAS-15ST-30 TBS-25ST-30 TCS-37ST-30 4-36 D-subminiature Metal Shell IDC for Discrete Cable Wire T* Series • • • • Auto-Clinch D Semi-Automatic Termination Tool #ACD-432: See page 4-100. Certi-Clinch D Manual Termination Tool #SD-CCWN: For 24-26 AWG wire: See page 4-100. Uni-Clinch D Single-Wire Hand Insertion Tool #SD-UC: See page 4-100. Super D Manual Stay Band Tool #SD-MSBT: See page 4-100. • Optional strain relief covers for connectors when backshell is not required. Ordering Information Positions 9 15 25 37 Catalog No. SSD-WC9 SSD-WC15 SSD-WC25 SSD-WC37 • One-piece cover for 9 contact size. Order one per connector. Two-piece cover for other sizes. Order two per connector. • Cover fits both plug and socket. 4-37 Call Toll Free: 1 (800) 323-9612 4 D-subminiature All-Plastic IDC for Discrete Cable Wire T* Series • • • • For use only with SDH Series Gray Backshell on pages 4-89 thru 4-90. Offered in 9, 15, 25, and 37 position plugs and sockets. Connector will accommodate 24-28 AWG wire. Offered with plain flanges and .120 mounting holes, threaded bushings, latch blocks, or latch blocks and threaded bushings. • • • • Auto-Clinch D Semi-Automatic Termination Tool #ACD-432: See page 4-100. Certi-Clinch D Manual Termination Tool #SD-CC for 24-28 AWG wire: See page 4-100. Uni-Clinch D Single-Wire Hand Insertion Tool #SD-UC: See page 4-100. Super D Manual Stay Band Tool #SD-MSBT: See page 4-100. 4 Plug with Latching Blocks Socket with Latching Blocks Dimensions A Positions 9 15 25 37 in 1.209 1.536 2.079 2.724 A mm 30.71 39.01 52.81 69.19 in 1.309 1.636 2.179 2.824 mm 33.25 41.55 55.35 71.73 B in .984 1.312 1.852 2.500 Call Toll Free: 1 (800) 323-9612 mm 24.99 33.32 47.04 63.50 CP in mm .668 16.96 .995 25.28 1.535 38.99 2.183 55.45 4-38 CS in mm .642 16.31 .970 24.64 1.512 38.40 2.158 54.81 D in .592 .918 1.462 2.114 mm 15.04 23.31 37.13 53.70 D-subminiature All-Plastic IDC for Discrete Wire T* Series Ordering Information IDC All-Plastic Plugs Plain Flange Positions 9 15 25 37 Mounting Holes Gold Flash 30µin. Gold TE-9P TE-9P-30 TA-15P TA-15P-30 TB-25P TB-25P-30 TC-37P TC-37P-30 Flange with Latch Block Mounting Holes Positions Gold Flash 30µin. Gold 9 TE-9PLB TE-9PLB-30 15 TA-15PLB TA-15PLB-30 25 TB-25PLB TB-25PLB-30 37 TC-37PLB TC-37PLB-30 4-40 Threaded Bushings Gold Flash 30µin. Gold TE-9PTB TE-9PTB-30 TA-15PTB TA-15PTB-30 TB-25PTB TB-25PTB-30 TC-37PTB TC-37PTB-30 4-40 Threaded Bushings Gold Flash 30µin. Gold TE-9PLB-1 TE-9PLB-1-30 TA-15PLB-1 TA-15PLB-1-30 TB-25PLB-1 TB-25PLB-1-30 TC-37PLB-1 TC-37PLB-1-30 IDC All-Plastic Sockets 4 Plain Flange Positions 9 15 25 37 Mounting Holes Gold Flash 30µin. Gold TE-9S TE-9S-30 TA-15S TA-15S-30 TB-25S TB-25S-30 TC-37S TC-37S-30 Flange with Latch Block Mounting Holes Positions Gold Flash 30µin. Gold 9 TE-9SLB TE-9SLB-30 15 TA-15SLB TA-15SLB-30 25 TB-25SLB TB-25SLB-30 37 TC-37SLB TC-37SLB-30 4-40 Threaded Bushings Gold Flash 30µin. Gold TE-9STB TE-9STB-30 TA-15STB TA-15STB-30 TB-25STB TB-25STB-30 TC-37STB TC-37STB-30 4-40 Threaded Bushings Gold Flash 30µin. Gold TE-9SLB-1 TE-9SLB-1-30 TA-15SLB-1 TA-15SLB-1-30 TB-25SLB-1 TB-25SLB-1-30 TC-37SLB-1 TC-37SLB-1-30 4-39 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Solder Cup, Vertical PCB Mount, and Wire Wrap Basic D Series ■ Offered in Wire Wrap and Solder Cup styles for wire termination and vertical style for PCB mount. FEATURES ■ Offered with .120 mounting holes, 4-40 clinch nuts, and dual float bushings. ■ Offered in 9, 15, 25, 37, and 50 position plugs and sockets. ■ Available with gold flash or 30µin. gold plating. ■ Approvals: • UL Recognized - Files E170218 (UL1977) and E130965 (UL1863). • CSA Approved - File LR31996. ■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel mounting specifications. MATERIALS Insulator Material: Glass-filled polyester (white), UL 94V-O rated Connector Shell: Steel with zinc plating and yellow chromate finish or tin plating (grounding indents on plug) 4-40 Clinch Nut: Steel with cadmium plating and yellow chromate finish ENVIRONMENTAL Dual Float Bushing: Stainless steel, passivated Operating Temperature: -65°C to + 125°C Shock: 50G peak per MIL-STD-202, Method 213, Condition G Vibration: 12 cycles in three perpendicular directions @ 10-2000Hz, per MIL-STD-202, Method 204, Condition D Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per MIL-STD-202, Method 103 MECHANICAL ELECTRICAL Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: Minimum 1250V RMS @ sea level 5 Amps 2.7 milliohms maximum 5000 megohms maximum (initial); 1000 megohms (minimum) after environmental testing Individual Contact Insertion and Separation Force (minimum/maximum): 0.7 oz./12 oz. Durability: 500 mating cycles Call Toll Free: 1 (800) 323-9612 4-40 D-subminiature Metal Shell Solder Cup Basic D Series • • Available with stamped or machined contacts. Will accommodate up to 20 AWG wire. Materials • Contact Material: Copper Alloy • Contact Plating: - Stamped contacts with gold flash or 30µin. gold in mating area, gold flash or tin/lead on remainder. All over nickel. - Screw machine contacts with gold flash or 30µin. gold. All over nickel. .312 (7.92) .200 (5.08) REF. Ordering Information Solder Cup Plugs 4 Zinc-Plated Shell with Yellow Chromate Finish Stamped Contact with Gold Flash in Solder Cup Mounting Holes 4-40 Clinch Nuts Positions Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DE-9P DE-9P-30 DEE-9P DEE-9P-30 15 DA-15P DA-15P-30 DAE-15P DAE-15P-30 25 DB-25P DB-25P-30 DBE-25P DBE-25P-30 37 DC-37P DC-37P-30 DCE-37P DCE-37P-30 50 DD-50P DD-50P-30 DDE-50P DDE-50P-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9P DEY-9P-30 DAY15P DAY-15P-30 DBY-25P DBY-25P-30 DCY-37P DCY-37P-30 DDY-50P DDY-50P-30 Stamped Contact with Tin/Lead in Solder Cup Mounting Holes 4-40 Clinch Nuts Positions Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DE-9P-II DE-9P-II-30 DEE-9P-II DEE-9P-II-30 15 DA-15P-II DA-15P-II-30 DAE-15P-II DAE-15P-II-30 25 DB-25P-II DB-25P-II-30 DBE-25P-II DBE-25P-II-30 37 DC-37P-II DC-37P-II-30 DCE-37P-II DCE-37P-II-30 50 DD-50P-II DD-50P-II-30 DDE-50P-II DDE-50P-II-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9P-II DEY-9P-II-30 DAY-15P-II DAY-15-PII-30 DBY-25P-II DBY-25-PII-30 DCY-37-P-II DCY-37-PII-30 DDY-50-P-II DDY-50-PII-30 Screw Machine Contact Mounting Holes Positions Gold Flash 30µin. Gold 9 DE-9P-SM DE-9P-SM-30 15 DA-15P-SM DA-15P-SM-30 25 DB-25P-SM DB-25P-SM-30 37 DC-37P-SM DC-37P-SM-30 50 DD-50P-SM DD-50P-SM-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9P-SM DEY-9P-SM-30 DAY-15P-SM DAY-15P-SM-30 DBY-25P-SM DBY-25P-SM-30 DCY-37P-SM DCY-37P-SM-30 DDY-50P-SM DDY-50P-SM-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9P-SM DEE-9P-SM-30 DAE-15P-SM DAE-15P-SM-30 DBE-25P-SM DBE-25P-SM-30 DCE-37P-SM DCE-37P-SM-30 DDE-50P-SM DDE-50P-SM-30 4-41 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Solder Cup Basic D Series Ordering Information Solder Cup Plugs (Cont’d) Tin-Plated Shell with Grounding Indents Stamped Contact with Gold Flash in Solder Cup Mounting Holes 4-40 Clinch Nuts Positions Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DE-9PTI DE-9PTI-30 DEE-9PTI DEE-9PTI-30 15 DA-15PTI DA-15PTI-30 DAE-15PTI DAE-15PTI-30 25 DB-25PTI DB-25PTI-30 DBE-25PTI DBE-25PTI-30 37 DC-37PTI DC-37PTI-30 DCE-37PTI DCE-37PTI-30 50 DD-50PTI DD-50PTI-30 DDE-50PTI DDE-50PTI-30 4 Dual Float Bushings Gold Flash 30µin. Gold DEY-9PTI DEY-9PTI-30 DAY-15PTI DAY-15PTI-30 DBY-25PTI DBY-25PTI-30 DCY-37PTI DCY-37PTI-30 DDY-50PTI DDY-50PTI-30 Stamped Contact with Tin/Lead in Solder Cup Mounting Holes 4-40 Clinch Nuts Positions Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DE-9PTI-II DE-9PTI-II-30 DEE-9PTI-II DEE-9PTI-II-30 15 DA-15PTI-II DA-15PTI-II-30 DAE-15PTI-II DAE-15PTI-II-30 25 DB-25PTI-II DB-25PTI-II-30 DBE-25PTI-II DBE-25PTI-II-30 37 DC-37PTI-II DC-37PTI-II-30 DCE-37PTI-II DCE-37PTI-II-30 50 DD-50PTI-II DD-50PTI-II-30 DDE-50PTI-II DDE-50PTI-II-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9PTI-II DEY-9PTI-II-30 DAY-15PTI-II DAY-15PTI-II-30 DBY-25PTI-II DBY-25PTI-II-30 DCY-37PTI-II DCY-37PTI-II-30 DDY-50PTI-II DDY-50PTI-II-30 Screw Machine Contact Mounting Positions Gold Flash 9 DE-9PTI-SM 15 DA-15PTI-SM 25 DB-25PTI-SM 37 DC-37PTI-SM 50 DD-50PTI-SM Dual Float Bushings Gold Flash 30µin. Gold DEY-9PTI-SM DEY-9PTI-SM-30 DAY-15PTI-SM DAY-15PTI-SM-30 DBY-25PTI-SM DBY-25PTI-SM-30 DCY-37PTI-SM DCY-37PTI-SM-30 DDY-50PTI-SM DDY-50PTI-SM-30 Holes 30µin. Gold DE-9PTI-SM-30 DA-15PTI-SM-30 DB-25PTI-SM-30 DC-37PTI-SM-30 DD-50PTI-SM-30 Call Toll Free: 1 (800) 323-9612 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9PTI-SM DEE-9PTI-SM-30 DAE-15PTI-SM DAE-15PTI-SM-30 DBE-25PTI-SM DBE-25PTI-SM-30 DCE-37PTI-SM DCE-37PTI-SM-30 DDE-50PTI-SM DDE-50PTI-SM-30 4-42 D-subminiature Metal Shell Solder Cup Basic D Series Ordering Information Solder Cup Sockets Zinc-Plated Shell with Yellow Chromate Finish Stamped Contact with Gold Flash in Solder Cup Mounting Holes 4-40 Clinch Nuts Positions Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DE-9S DE-9S-30 DEE-9S DEE-9S-30 15 DA-15S DA-15S-30 DAE-15S DAE-15S-30 25 DB-25S DB-25S-30 DBE-25S DBE-25S-30 37 DC-37S DC-37S-30 DCE-37S DCE-37S-30 50 DD-50S DD-50S-30 DDE-50S DDE-50S-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9S DEY-9S-30 DAY-15S DAY-15S-30 DBY-25S DBY-25S-30 DCY-37S DCY-37S-30 DDY-50S DDY-50S-30 Stamped Contact Tin/Lead in Solder Cup Mounting Holes Positions Gold Flash 30µin. Gold 9 DE-9S-II DE-9S-II-30 15 DA-15S-II DA-15S-II-30 25 DB-25S-II DB-25S-II-30 37 DC-37S-II DC-37S-II-30 50 DD-50S-II DD-50S-II-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9S-II DEE-9S-II-30 DAE-15S-II DAE-15S-II-30 DBE-25S-II DBE-25S-II-30 DCE-37S-II DCE-37S-II-30 DDE-50S-II DDE-50S-II-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9S-II DEY-9S-II-30 DAY-15S-II DAY-15S-II-30 DBY-25S-II DBY-25S-II-30 DCY-37S-II DCY-37S-II-30 DDY-50S-II DDY-50S-II-30 Screw Machine Contact Mounting Positions Gold Flash 9 DE-9S-SM 15 DA-15S-SM 25 DB-25S-SM 37 DC-37S-SM 50 DD-50S-SM 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9S-SM DEE-9S-SM-30 DAE-15S-SM DAE-15S-SM-30 DBE-25S-SM DBE-25S-SM-30 DCE-37S-SM DCE-37S-SM-30 DDE-50S-SM DDE-50S-SM-30 Holes 30µin. Gold DE-9S-SM-30 DA-15S-SM-30 DB-25S-SM-30 DC-37S-SM-30 DD-50S-SM-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9S-SM DEY-9S-SM-30 DAY-15S-SM DAY-15S-SM-30 DBY-25S-SM DBY-25S-SM-30 DCY-37S-SM DCY-37S-SM-30 DDY-50S-SM DDY-50S-SM-30 Tin-Plated Shell Stamped Contact with Gold Flash in Solder Cup Mounting Holes 4-40 Clinch Nuts Positions Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DE-9ST DE-9ST-30 DEE-9ST DEE-9ST-30 15 DA-15ST DA-15ST-30 DAE-15ST DAE-15ST-30 25 DB-25ST DB-25ST-30 DBE-25ST DBE-25ST-30 37 DC-37ST DC-37ST-30 DCE-37ST DCE-37ST-30 50 DD-50ST DD-50ST-30 DDE-50ST DDE-50ST-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9ST DEY-9ST-30 DAY-15ST DAY-15ST-30 DBY-25ST DBY-25ST-30 DCY-37ST DCY-37ST-30 DDY-50ST DDY-50ST-30 Stamped Contact with Tin/Lead in Solder Cup Mounting Holes 4-40 Clinch Nuts Positions Gold Flash 30µin. Gold Gold Flash 30µin. Gold 9 DE-9ST-II DE-9ST-II-30 DEE-9ST-II DEE-9ST-II-30 15 DA-15ST-II DA-15ST-II-30 DAE-15ST-II DAE-15ST-II-30 25 DB-25ST-II DB-25ST-II-30 DBE-25ST-II DBE-25ST-II-30 37 DC-37ST-II DC-37ST-II-30 DCE-37ST-II DCE-37ST-II-30 50 DD-50ST-II DD-50ST-II-30 DDE-50ST-II DDE-50ST-II-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9ST-II DEY-9ST-II-30 DAY-15ST-II DAY-15ST-II-30 DBY-25ST-II DBY-25ST-II-30 DCY-37ST-II DCY-37ST-II-30 DDY-50ST-II DDY-50ST-II-30 Screw Machine Contact Mounting Positions Gold Flash 9 DE-9ST-SM 15 DA-15ST-SM 25 DB-25ST-SM 37 DC-37ST-SM 50 DD-50ST-SM Dual Float Bushings Gold Flash 30µin. Gold DEY-9ST-SM DEY-9ST-SM-30 DAY-15ST-SM DAY-15ST-SM-30 DBY-25ST-SM DBY-25ST-SM-30 DCY-37ST-SM DCY-37ST-SM-30 DDY-50ST-SM DDY-50ST-SM-30 Holes 30µin. Gold DE-9ST-SM-30 DA-15ST-SM-30 DB-25ST-SM-30 DC-37ST-SM-30 DD-50ST-SM-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9ST-SM DEE-9ST-SM-30 DAE-15ST-SM DAE-15ST-SM-30 DBE-25ST-SM DBE-25ST-SM-30 DCE-37ST-SM DCE-37ST-SM-30 DDE-50ST-SM DDE-50ST-SM-30 4-43 Call Toll Free: 1 (800) 323-9612 4 D-subminiature Metal Shell Vertical Dip Solder PCB Basic D Series • .040" contact diameter. • Short rear insulator provides low profile on PCB. • Offered with .120 mounting holes, dual float bushings, or optional 4-40 clinch nuts. Materials • Contact Material: Socket - Phosphor bronze (machined), Plug - Brass (machined). • Contact Plating: Gold flash or 30µin. gold over nickel. .130 (3.30) .104 (2.64) .042 (1.07) .038 (0.97) .200 (5.08) REF. Ordering Information Vertical PCB Plugs 4 Zinc-Plated Shell with Yellow Chromate Finish Mounting Holes Positions Gold Flash 30µin. Gold 9 DE-9PV DE-9PV-30 15 DA-15PV DA-15PV-30 25 DB-25PV DB-25PV-30 37 DC-37PV DC-37PV-30 50 DD-50PV DD-50PV-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9PV DEE-9PV-30 DAE-15PV DAE-15PV-30 DBE-25PV DBE-25PV-30 DCE-37PV DCE-37PV-30 DDE-50PV DDE-50PV-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9PV DEY-9PV-30 DAY-15PV DAY-15PV-30 DBY-25PV DBY-25PV-30 DCY-37PV DCY-37PV-30 DCY-50PV DDY-50PV-30 Tin-Plated Shell with Grounding Indents Mounting Holes Positions Gold Flash 30µin. Gold 9 DE-9PVTI DE-9PVTI-30 15 DA-15PVTI DA-15PVTI-30 25 DB-25PVTI DB-25PVTI-30 37 DC-37PVTI DC-37PVTI-30 50 DD-50PVTI DD-50PVTI-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9PVTI DEE-9PVTI-30 DAE-15PVTI DAE-15PVTI-30 DBE-25PVTI DBE-25PVTI-30 DCE-37PVTI DCE-37PVTI-30 DDE-50PVTI DDE-50PVTI-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9PVTI DEY-9PVTI-30 DAY-15PVTI DAY-15PVTI-30 DBY-25PVTI DBY-25PVTI-30 DCY-37PVTI DCY-37PVTI-30 DCY-50PVTI DDY-50PVTI-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9SV DEE-9SV-30 DAE-15SV DAE-15SV-30 DBE-25SV DBE-25SV-30 DCE-37SV DCE-37SV-30 DDE-50SV DDE-50SV-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9SV DEY-9SV-30 DAY-15SV DAY-15SV-30 DBY-25SV DBY-25SV-30 DCY-37SV DCY-37SV-30 DCY-50SV DDY-50SV-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9SVT DEE-9SVT-30 DAE-15SVT DAE-15SVT-30 DBE-25SVT DBE-25SVT-30 DCE-37SVT DCE-37SVT-30 DDE-50SVT DDE-50SVT-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9SVT DEY-9SVT-30 DAY-15SVT DAY-15SVT-30 DBY-25SVT DBY-25SVT-30 DCY-37SVT DCY-37SVT-30 DDY-50SVT DDY-50SVT-30 Vertical PCB Sockets Zinc-Plated Shell with Yellow Chromate Finish Mounting Holes Positions Gold Flash 30µin. Gold 9 DE-9SV DE-9SV-30 15 DA-15SV DA-15SV-30 25 DB-25SV DB-25SV-30 37 DC-37SV DC-37SV-30 50 DD-50SV DD-50SV-30 Tin-Plated Shell Positions 9 15 25 37 50 Mounting Gold Flash DE-9SVT DA-15SVT DB-25SVT DC-37SVT DD-50SVT Holes 30µin. Gold DE-9SVT-30 DA-15SVT-30 DB-25SVT-30 DC-37SVT-30 DD-50SVT-30 Call Toll Free: 1 (800) 323-9612 4-44 D-subminiature Metal Shell Wire Wrap Basic D Series • Reliable wire wrap termination. • Two contact lengths: .375" or .585". • .025" square contact tails. Materials • Contact Material: Copper alloy (machined). • Contact Plating: Gold flash or 30µin. gold. All over nickel. .375 (9.53) or .585 (14.86) .200 (5.08) REF. Ordering Information 4 Wire Wrap Plugs .375" Tail Length Zinc-Plated Shell with Yellow Chromate Finish Positions 9 15 25 37 50 Mounting Holes Gold Flash 30µin. Gold DE-9P-F179 DE-9P-F179-30 DA-15P-F179 DA-15P-F179-30 DB-25P-F179 DB-25P-F179-30 DC-37P-F179 DC-37P-F179-30 DD-50P-F179 DD-50P-F179-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9P-F179 DEE-9P-F179-30 DAE-15P-F179 DAE-15P-F179-30 DBE-25P-F179 DBE-25P-F179-30 DCE-37P-F179 DCE-37P-F179-30 DDE-50P-F179 DDE-50P-F179-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9P-F179 DEY-9P-F179-30 DAY-15P-F179 DAY-15P-F179-30 DBY-25P-F179 DBY-25P-F179-30 DCY-37P-F179 DCY-37P-F179-30 DDY-50P-F179 DDY-50P-F179-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9PTI-F179 DEE-9PTI-F179-30 DAE-15PTI-F179 DAE-15PTI-F179-30 DBE-25PTI-F179 DBE-25PTI-F179-30 DCE-37PTI-F179 DCE-37PTI-F179-30 DDE-50PTI-F179 DDE-50PTI-F179-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9PTI-F179 DEY-9PTI-F179-30 DAY-15PTI-F179 DAY-15PTI-F179-30 DBY-25PTI-F179 DBY-25PTI-F179-30 DCY-37PTI-F179 DCY-37PTI-F179-30 DDY-50PTI-F179 DDY-50PTI-F179-30 Tin-Plated Shell with Grounding Indents Positions 9 15 25 37 50 Mounting Holes Gold Flash 30µin. Gold DE-9PTI-F179 DE-9PTI-F179-30 DA-15PTI-F179 DA-15PTI-F179-30 DB-25PTI-F179 DB-25PTI-F179-30 DC-37PTI-F179 DC-37PTI-F179-30 DD-50PTI-F179 DD-50PTI-F179-30 4-45 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Wire Wrap Basic D Series Ordering Information Wire Wrap Plugs (Cont’d) .585" Tail Length Zinc-Plated Shell with Yellow Chromate Finish Positions 9 15 25 37 50 Mounting Holes Gold Flash 30µin. Gold DE-9P-F179C DE-9P-F179C-30 DA-15P-F179C DA-15P-F179C-30 DB-25P-F179C DB-25P-F179C-30 DC-37P-F179C DC-37P-F179C-30 DD-50P-F179C DD-50P-F179C-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9P-F179C DEE-9PF-179C-30 DAE-15P-F179C DAE-15PF-179C-30 DBE-25P-F179C DBE-25PF-179C-30 DCE-37P-F179C DCE-37PF-179C-30 DDE-50P-F179C DDE-50PF-179C-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9P-F179C DEY-9P-F179C-30 DAY-15P-F179C DAY-15P-F179C-30 DBY-25P-F179C DBY-25P-F179C-30 DCY-37P-F179C DCY-37P-F179C-30 DDY-50P-F179C DDY-50P-F179C-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9PTI-F179C DEE-9PTI-F179C-30 DAE-15PTI-F179C DAE-15PTI-F179C-30 DBE-25PTI-F179C DBE-25PTI-F179C-30 DCE-37PTI-F179C DCE-37PTI-F179C-30 DDE-50PTI-F179C DDE-50PTI-F179C-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9PTI-F179C DEY-9PTI-F179C-30 DAY-15PTI-F179C DAY-15PTI-F179C-30 DBY-25PTI-F179C DBY-25PTI-F179C-30 DCY-37PTI-F179C DCY-37PTI-F179C-30 DDY-50PTI-F179C DDY-50PTI-F179C-30 Tin-Plated Shell with Grounding Indents Positions 9 15 25 37 50 Mounting Holes Gold Flash 30µin. Gold DE-9PTI-F179C DE-9PTI-F179C-30 DA-15PTI-F179C DA-15PTI-F179C-30 DB-25PTI-F179C DB-25PTI-F179C-30 DC-37PTI-F179C DC-37PTI-F179C-30 DD-50PTI-F179C DD-50PTI-F179C-30 4 Call Toll Free: 1 (800) 323-9612 4-46 D-subminiature Metal Shell Wire Wrap Basic D Series Ordering Information Wire Wrap Sockets .375" Tail Length Zinc-Plated Shell with Yellow Chromate Finish Positions 9 15 25 37 50 Mounting Holes Gold Flash 30µin. Gold DE-9S-F179 DA-15S-F179 DB-25S-F179 DC-37S-F179 DD-50S-F179 DE-9S-F179-30 DA-15S-F179-30 DB-25S-F179-30 DC-37S-F179-30 DD-50S-F179-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9S-F179 DAE-15S-F179 DBE-25S-F179 DCE-37S-F179 DDE-50S-F179 Dual Float Bushings Gold Flash 30µin. Gold DEE-9S-F179-30 DAE-15S-F179-30 DBE-25S-F179-30 DCE-37S-F179-30 DDE-50S-F179-30 DEY-9S-F179 DAY-15S-F179 DBY-25S-F179 DCY-37S-F179 DDY-50S-F179 DEY-9S-F179-30 DAY-15S-F179-30 DBY-25S-F179-30 DCY-37S-F179-30 DDY-50S-F179-30 Tin-Plated Shell Positions 9 15 25 37 50 Mounting Holes Gold Flash 30µin. Gold DE-9ST-F179 DA-15ST-F179 DB-25ST-F179 DC-37ST-F179 DD-50ST-F179 DE-9ST-F179-30 DA-15ST-F179-30 DB-25ST-F179-30 DC-37ST-F179-30 DD-50ST-F179-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9ST-F179 DAE-15ST-F179 DBE-25ST-F179 DCE-37ST-F179 DDE-50ST-F179 Dual Float Bushings Gold Flash 30µin. Gold DEE-9ST-F179-30 DAE-15ST-F179-30 DBE-25ST-F179-30 DCE-37ST-F179-30 DDE-50ST-F179-30 DEY-9ST-F179 DAY-15ST-F179 DBY-25ST-F179 DCY-37ST-F179 DDY-50ST-F179 DEY-9ST-F179-30 DAY-15ST-F179-30 DBY-25ST-F179-30 DCY-37ST-F179-30 DDY-50ST-F179-30 .585" Tail Length Zinc-Plated Shell with Yellow Chromate Finish Positions 9 15 25 37 50 Mounting Holes Gold Flash 30µin. Gold DE-9S-F179C DA-15S-F179C DB-25S-F179C DC-37S-F179C DD-50S-F179C DE-9S-F179C-30 DA-15S-F179C-30 DB-25S-F179C-30 DC-37S-F179C-30 DD-50S-F179C-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9S-F179C DAE-15S-F179C DBE-25S-F179C DCE-37S-F179C DDE-50S-F179C DEE-9S-F179C-30 DAE-15S-F179C-30 DBE-25S-F179C-30 DCE-37S-F179C-30 DDE-50S-F179C-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9S-F179C DAY-15S-F179C DBY-25S-F179C DCY-37S-F179C DDY-50S-F179C DEY-9S-F179C-30 DAY-15S-F179C-30 DBY-25S-F179C-30 DCY-37S-F179C-30 DDY-50S-F179C-30 Tin-Plated Shell Positions 9 15 25 37 50 Mounting Holes Gold Flash 30µin. Gold DE-9ST-F179C DA-15ST-F179C DB-25ST-F179C DC-37ST-F179C DD-50ST-F179C DE-9ST-F179C-30 DA-15ST-F179C-30 DB-25ST-F179C-30 DC-37ST-F179C-30 DD-50ST-F179C-30 4-40 Clinch Nuts Gold Flash 30µin. Gold DEE-9ST-F179C DAE-15ST-F179C DBE-25ST-F179C DCE-37ST-F179C DDE-50ST-F179C 4-47 DEE-9ST-F179C-30 DAE-15ST-F179C-30 DBE-25ST-F179C-30 DCE-37ST-F179C-30 DDE-50ST-F179C-30 Dual Float Bushings Gold Flash 30µin. Gold DEY-9ST-F179C DAY-15ST-F179C DBY-25ST-F179C DCY-37ST-F179C DDY-50ST-F179C DEY-9ST-F179C-30 DAY-15ST-F179C-30 DBY-25ST-F179C-30 DCY-37ST-F179C-30 DDY-50ST-F179C-30 Call Toll Free: 1 (800) 323-9612 4 Insulator Material: Glass-filled diallyl phthalate (green) UL 94V-0 rated Connector Shell: Steel with zinc plating and yellow chromate finish or tin plating (grounding indents on plug) Contact Material: Plug - Brass (machined), Socket - Phosphor bronze (machined) Contact Plating: 30µin. gold over nickel 4-40 Clinch Nut: Steel with cadmium plating and yellow chromate finish Dual Float Bushing: Stainless steel, passivated Operating Temperature: -65°C to + 125°C Shock: 50G peak per MIL-STD-202, Method 213, Condition G Vibration: 12 cycles in three perpendicular directions @ 10-2000Hz, per MIL-STD-202, Method 204, Condition D Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per MIL-STD-202, Method 103 MECHANICAL ELECTRICAL MATERIALS ■ Available in vertical and right-angle dip solder PCB connectors and solder cup version for wire termination. ■ Commercial version of M24308 military connectors with tin-plated or zinc-plated shell and 30µin. gold plating. ■ Monoblock green diallyl phthalate insulator for improved electrical performance. ■ Machined contacts for precision performance. ■ Offered in 9, 15, 25, 37, and 50 (except right-angle version) position plugs and sockets. ■ Offered with .120 mounting holes, 4-40 clinch nuts (except right-angle version), or dual float bushings (except right-angle version). ■ Approvals: • UL Recognized - Files E170218 (UL1977)and E130965 (UL1863). • CSA Approved - File LR31996. ■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel mounting specifications. ENVIRONMENTAL FEATURES D-subminiature Metal Shell Solder Cup, Right-Angle, and Vertical PCB Series 1 - High Reliability Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: Minimum 1250V RMS @ sea level 5 Amps 2.7 milliohms maximum 5000 megohms maximum (initial); 1000 megohms (minimum) after environmental testing Individual Contact Insertion and Separation Force (minimum/maximum): 0.7 oz./12 oz. Durability: 500 mating cycles Call Toll Free: 1 (800) 323-9612 4-48 D-subminiature Metal Shell Solder Cup Series 1 - High Reliability • Will accommodate up to 20 AWG wire. .390 (9.91) .200 (5.08) REF. Ordering Information Solder Cup Plugs Zinc-Plated Shell with Yellow Chromate Finish Tin-Plated Shell with Grounding Indents Positions Mounting Hole 4-40 Clinch Nut Dual Float Bushings Mounting Hole 4-40 Clinch Nut Dual Float Bushings 9 DEM-9P DEME-9P DEMY-9P DEM-9PTI DEME-9PTI DEMY-9PTI 15 DAM-15P DAME-15P DAMY-15P DAM-15PTI DAME-15PTI DAMY-15PTI 25 DBM-25P DBME-25P DBMY-25P DBM-25PTI DBME-25PTI DBMY-25PTI 37 DCM-37P DCME-37P DCMY-37P DCM-37PTI DCME-37PTI DCMY-37PTI 50 DDM-50P DDME-50P DDMY-50P DDM-50PTI DDME-50PTI DDMY-50PTI Solder Cup Sockets Zinc-Plated Shell with Yellow Chromate Finish Tin-Plated Shell Positions Mounting Hole 4-40 Clinch Nut Dual Float Bushings Mounting Hole 4-40 Clinch Nut Dual Float Bushings 9 DEM-9S DEME-9S DEMY-9S DEM-9ST DEME-9ST 15 DAM-15S DAME-15S DAMY-15S DAM-15ST DAME-15ST DAMY-15ST 25 DBM-25S DBME-25S DBMY-25S DBM-25ST DBME-25ST DBMY-25ST 37 DCM-37S DCME-37S DCMY-37S DCM-37ST DCME-37ST DCMY-37ST 50 DDM-50S DDME-50S DDMY-50S DDM-50ST DDME-50ST DDMY-50ST 4-49 DEMY-9ST Call Toll Free: 1 (800) 323-9612 4 D-subminiature Metal Shell Right-Angle Dip Solder PCB Series 1 - High Reliability • .283" footprint uses minimal board space. • Available with three contact tail lengths (.125", .158", and .185") and two contact diameters (.030" and .040"). Materials • 4 Mounting bracket: Black nylon. Can be removed if necessary. Ordering Information Right-Angle PCB Plugs Zinc-Plated Shell with Yellow Chromate Finish Positions 9 15 25 37 .125 Tail Length .030 Contact Diameter DEM-9PD DAM-15PD DBM-25PD DCM-37PD .158 Tail Length .030 Contact Diameter DEM-9PL DAM-15PL DBM-25PL DCM-37PL .185 Tail Length .030 Contact Diameter DEM-9PS DAM-15PS DBM-25PS DCM-37PS .125 Tail Length .040 Contact Diameter DEM-9PA DAM-15PA DBM-25PA DCM-37PA .158 Tail Length .040 Contact Diameter DEM-9PG DAM-15PG DBM-25PG DCM-37PG .185 Tail Length .040 Contact Diameter DEM-9PW DAM-15PW DBM-25PW DCM-37PW .185 Tail Length .030 Contact Diameter DEM-9PSTI DAM-15PSTI DBM-25PSTI DCM-37PSTI .125 Tail Length .040 Contact Diameter DEM-9PATI DAM-15PATI DBM-25PATI DCM-37PATI .158 Tail Length .040 Contact Diameter DEM-9PGTI DAM-15PGTI DBM-25PGTI DCM-37PGTI .185 Tail Length .040 Contact Diameter DEM-9PWTI DAM-15PWTI DBM-25PWTI DCM-37PWTI Tin-Plated Shell with Grounding Indents Positions 9 15 25 37 .125 Tail Length .030 Contact Diameter DEM-9PDTI DAM-15PDTI DBM-25PDTI DCM-37PDTI .158 Tail Length .030 Contact Diameter DEM-9PLTI DAM-15PLTI DBM-25PLTI DCM-37PLTI Call Toll Free: 1 (800) 323-9612 4-50 D-subminiature Metal Shell Right-Angle Dip Solder PCB Series 1 - High Reliability Ordering Information Right-Angle PCB Sockets Zinc-Plated Shell with Yellow Chromate Finish Positions 9 15 25 37 .125 Tail Length .030 Contact Diameter DEM-9SD DAM-15SD DBM-25SD DCM-37SD .158 Tail Length .030 Contact Diameter DEM-9SL DAM-15SL DBM-25SL DCM-37SL .185 Tail Length .030 Contact Diameter DEM-9SS DAM-15SS DBM-25SS DCM-37SS .125 Tail Length .040 Contact Diameter DEM-9SA DAM-15SA DBM-25SA DCM-37SA .158 Tail Length .040 Contact Diameter DEM-9SG DAM-15SG DBM-25SG DCM-37SG .185 Tail Length .040 Contact Diameter DEM-9SW DAM-15SW DBM-25SW DCM-37SW .158 Tail Length .030 Contact Diameter DEM-9SLT DAM-15SLT DBM-25SLT DCM-37SLT .185 Tail Length .030 Contact Diameter DEM-9SST DAM-15SST DBM-25SST DCM-37SST .125 Tail Length .040 Contact Diameter DEM-9SAT DAM-15SAT DBM-25SAT DCM-37SAT .158 Tail Length .040 Contact Diameter DEM-9SGT DAM-15SGT DBM-25SGT DCM-37SGT .185 Tail Length .040 Contact Diameter DEM-9SWT DAM-15SWT DBM-25SWT DCM-37SWT Tin-Plated Shell Positions 9 15 25 37 .125 Tail Length .030 Contact Diameter DEM-9SDT DAM-15SDT DBM-25SDT DCM-37SDT 4 4-51 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Vertical Dip Solder PCB Series 1 - High Reliability • Available with three contact tail lengths (.125", .158", and .185") and two contact diameters (.030" and .040"). SEE CHART SEE CHART .200 REF. Ordering Information Vertical PCB Plugs Zinc-Plated Shell with Yellow Chromate Finish Positions 4 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEM-9PE DAM-15PE DBM-25PE DCM-37PE DDM-50PE .158 Tail Length .030 Contact Diameter DEM-9PM DAM-15PM DBM-25PM DCM-37PM DDM-50PM .185 Tail Length .030 Contact Diameter DEM-9PZ DAM-15PZ DBM-25PZ DCM-37PZ DDM-50PZ .125 Tail Length .040 Contact Diameter DEM-9PB DAM-15PB DBM-25PB DCM-37PB DDM-50PB .158 Tail Length .040 Contact Diameter DEM-9PH DAM-15PH DBM-25PH DCM-37PH DDM-50PH .185 Tail Length .040 Contact Diameter DEM-9PX DAM-15PX DBM-25PX DCM-37PX DDM-50PX .158 Tail Length .040 Contact Diameter DEME-9PH DAME-15PH DBME-25PH DCME-37PH DDME-50PH .185 Tail Length .040 Contact Diameter DEME-9PX DAME-15PX DBME-25PX DCME-37PX DDME-50PX .158 Tail Length .040 Contact Diameter DEMY-9PH DAMY-15PH DBMY-25PH DCMY-37PH DDMY-50PH .185 Tail Length .040 Contact Diameter DEMY-9PX DAMY-15PX DBMY-25PX DCMY-37PX DDMY-50PX Zinc-Plated Shell with Yellow Chromate Finish and 4-40 Clinch Nuts Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEME-9PE DAME-15PE DBME-25PE DCME-37PE DDME-50PE .158 Tail Length .030 Contact Diameter DEME-9PM DAME-15PM DBME-25PM DCME-37PM DDME-50PM .185 Tail Length .030 Contact Diameter DEME-9PZ DAME-15PZ DBME-25PZ DCME-37PZ DDME-50PZ .125 Tail Length .040 Contact Diameter DEME-9PB DAME-15PB DBME-25PB DCME-37PB DDME-50PB Zinc-Plated Shell with Yellow Chromate Finish and Dual Float Bushings Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEMY-9PE DAMY-15PE DBMY-25PE DCMY-37PE DDMY-50PE .158 Tail Length .030 Contact Diameter DEMY-9PM DAMY-15PM DBMY-25PM DCMY-37PM DDMY-50PM Call Toll Free: 1 (800) 323-9612 .185 Tail Length .030 Contact Diameter DEMY-9PZ DAMY-15PZ DBMY-25PZ DCMY-37PZ DDMY-50PZ .125 Tail Length .040 Contact Diameter DEMY-9PB DAMY-15PB DBMY-25PB DCMY-37PB DDMY-50PB 4-52 D-subminiature Metal Shell Vertical Dip Solder PCB Series 1 - High Reliability Ordering Information Vertical PCB Plugs (Cont’d) Tin-Plated Shell with Grounding Indents Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEM-9PETI DAM-15PETI DBM-25PETI DCM-37PETI DDM-50PETI .158 Tail Length .030 Contact Diameter DEM-9PMTI DAM-15PMTI DBM-25PMTI DCM-37PMTI DDM-50PMTI .185 Tail Length .030 Contact Diameter DEM-9PZTI DAM-15PZTI DBM-25PZTI DCM-37PZTI DDM-50PZTI .125 Tail Length .040 Contact Diameter DEM-9PBTI DAM-15PBTI DBM-25PBTI DCM-37PBTI DDM-50PBTI .158 Tail Length .040 Contact Diameter DEM-9PHTI DAM-15PHTI DBM-25PHTI DCM-37PHTI DDM-50PHTI .185 Tail Length .040 Contact Diameter DEM-9PXTI DAM-15PXTI DBM-25PXTI DCM-37PXTI DDM-50PXTI Tin-Plated Shell with Grounding Indents and 4-40 Clinch Nuts Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEME-9PETI DAME-15PETI DBME-25PETI DCME-37PETI DDME-50PETI .158 Tail Length .185 Tail Length .125 Tail Length .158 Tail Length .185 Tail Length .030 Contact .030 Contact .040 Contact .040 Contact .040 Contact Diameter Diameter Diameter Diameter Diameter DEME-9PMTI DEME-9PZTI DEME-9PBTI DEME-9PHTI DEME-9PXTI DAME-15PMTI DAME-15PZTI DAME-15PBTI DAME-15PHTI DAME-15PXTI DBME-25PMTI DBME-25PZTI DBME-25PBTI DBME-25PHTI DBME-25PXTI DCME-37PMTI DCME-37PZTI DCME-37PBTI DCME-37PHTI DCME-37PXTI DDME-50PMTI DDME-50PZTI DDME-50PBTI DDME-50PHTI DDME-50PXTI Tin-Plated Shell with Grounding Indents and Dual Float Bushings Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEMY-9PETI DAMY-15PETI DBMY-25PETI DCMY-37PETI DDMY-50PETI .158 Tail Length .185 Tail Length .125 Tail Length .030 Contact .030 Contact .040 Contact Diameter Diameter Diameter DEMY-9PMTI DEMY-9PZTI DEMY-9PBTI DAMY-15PMTI DAMY-15PZTI DAMY-15PBTI DBMY-25PMTI DBMY-25PZTI DBMY-25PBTI DCMY-37PMTI DCMY-37PZTI DCMY-37PBTI DDMY-50PMTI DDMY-50PZTI DDMY-50PBTI .158 Tail Length .040 Contact Diameter DEMY-9PHTI DAMY-15PHTI DBMY-25PHTI DCMY-37PHTI DDMY-50PHTI .185 Tail Length .040 Contact Diameter DEMY-9PXTI DAMY-15PXTI DBMY-25PXTI DCMY-37PXTI DDMY-50PXTI .158 Tail Length .040 Contact Diameter DEM-9SH DAM-15SH DBM-25SH DCM-37SH DDM-50SH .185 Tail Length .040 Contact Diameter DEM-9SX DAM-15SX DBM-25SX DCM-37SX DDM-50SX Vertical PCB Sockets Zinc-Plated Shell with Yellow Chromate Finish Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEM-9SE DAM-15SE DBM-25SE DCM-37SE DDM-50SE .158 Tail Length .030 Contact Diameter DEM-9SM DAM-15SM DBM-25SM DCM-37SM DDM-50SM .185 Tail Length .030 Contact Diameter DEM-9SZ DAM-15SZ DBM-25SZ DCM-37SZ DDM-50SZ 4-53 .125 Tail Length .040 Contact Diameter DEM-9SB DAM-15SB DBM-25SB DCM-37SB DDM-50SB Call Toll Free: 1 (800) 323-9612 4 D-subminiature Metal Shell Vertical Dip Solder PCB Series 1 - High Reliability Ordering Information Vertical PCB Sockets (Cont’d) Zinc-Plated Shell with Yellow Chromate Finish and 4-40 Clinch Nuts Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEME-9SE DAME-15SE DBME-25SE DCME-37SE DDME-50SE .158 Tail Length .030 Contact Diameter DEME-9SM DAME-15SM DBME-25SM DCME-37SM DDME-50SM .185 Tail Length .030 Contact Diameter DEME-9SZ DAME-15SZ DBME-25SZ DCME-37SZ DDME-50SZ .125 Tail Length .040 Contact Diameter DEME-9SB DAME-15SB DBME-25SB DCME-37SB DDME-50SB .158 Tail Length .040 Contact Diameter DEME-9SH DAME-15SH DBME-25SH DCME-37SH DDME-50SH .185 Tail Length .040 Contact Diameter DEME-9SX DAME-15SX DBME-25SX DCME-37SX DDME-50SX Zinc-Plated Shell with Yellow Chromate Finish and Dual Float Bushings Positions 9 15 25 37 50 4 .125 Tail Length .030 Contact Diameter DEMY-9SE DAMY-15SE DBMY-25SE DCMY-37SE DDMY-50SE .158 Tail Length .030 Contact Diameter DEMY-9SM DAMY-15SM DBMY-25SM DCMY-37SM DDMY-50SM .185 Tail Length .030 Contact Diameter DEMY-9SZ DAMY-15SZ DBMY-25SZ DCMY-37SZ DDMY-50SZ .125 Tail Length .040 Contact Diameter DEMY-9SB DAMY-15SB DBMY-25SB DCMY-37SB DDMY-50SB .158 Tail Length .040 Contact Diameter DEMY-9SH DAMY-15SH DBMY-25SH DCMY-37SH DDMY-50SH .185 Tail Length .040 Contact Diameter DEMY-9SX DAMY-15SX DBMY-25SX DCMY-37SX DDMY-50SX .158 Tail Length .030 Contact Diameter DEM-9SMT DAM-15SMT DBM-25SMT DCM-37SMT DDM-50SMT .185 Tail Length .030 Contact Diameter DEM-9SZT DAM-15SZT DBM-25SZT DCM-37SZT DDM-50SZT .125 Tail Length .040 Contact Diameter DEM-9SBT DAM-15SBT DBM-25SBT DCM-37SBT DDM-50SBT .158 Tail Length .040 Contact Diameter DEM-9SHT DAM-15SHT DBM-25SHT DCM-37SHT DDM-50SHT .185 Tail Length .040 Contact Diameter DEM-9SXT DAM-15SXT DBM-25SXT DCM-37SXT DDM-50SXT .185 Tail Length .030 Contact Diameter DEME-9SZT DAME-15SZT DBME-25SZT DCME-37SZT DDME-50SZT .125 Tail Length .040 Contact Diameter DEME-9SBT DAME-15SBT DBME-25SBT DCME-37SBT DDME-50SBT .158 Tail Length .040 Contact Diameter DEME-9SHT DAME-15SHT DBME-25SHT DCME-37SHT DDME-50SHT .185 Tail Length .040 Contact Diameter DEME-9SXT DAME-15SXT DBME-25SXT DCME-37SXT DDME-50SXT .185 Tail Length .030 Contact Diameter DEMY-9SZT DAMY-15SZT DBMY-25SZT DCMY-37SZT DDMY-50SZT .125 Tail Length .040 Contact Diameter DEMY-9SBT DAMY-15SBT DBMY-25SBT DCMY-37SBT DDMY-50SBT .158 Tail Length .040 Contact Diameter DEMY-9SHT DAMY-15SHT DBMY-25SHT DCMY-37SHT DDMY-50SHT .185 Tail Length .040 Contact Diameter DEMY-9SXT DAMY-15SXT DBMY-25SXT DCMY-37SXT DDMY-50SXT Tin-Plated Shell Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEM-9SET DAM-15SET DBM-25SET DCM-37SET DDM-50SET Tin-Plated Shell with 4-40 Clinch Nuts Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEME-9SET DAME-15SET DBME-25SET DCME-37SET DDME-50SET .158 Tail Length .030 Contact Diameter DEME-9SMT DAME-15SMT DBME-25SMT DCME-37SMT DDME-50SMT Tin-Plated Shell with Dual Float Bushings Positions 9 15 25 37 50 .125 Tail Length .030 Contact Diameter DEMY-9SET DAMY-15SET DBMY-25SET DCMY-37SET DDMY-50SET .158 Tail Length .030 Contact Diameter DEMY-9SMT DAMY-15SMT DBMY-25SMT DCMY-37SMT DDMY-50SMT Call Toll Free: 1 (800) 323-9612 4-54 D-subminiature Metal Shell - Combination Layout Solder Cup and Vertical PCB Series 1 - High Reliability • • • Shell Sizes (equivalent to standard size): E (Size 9), A (Size 15 ), B (Size 25 ), C (Size 25 ), and D (Size 25 ). Offered in a variety of combination layouts in vertical style for PCB mount or solder cup style for wire termination. Signal Contacts (Size 20) are fixed and non-removable. - • • • Vertical Dip Solder Contacts are available with three contact tail lengths (.125", .158", and .185") and two contact diameters (.030" and .040"). Removable Coaxial, High Power, High Voltage contacts must be ordered separately. See Series 1 page 4-48 for specifications. Available with 30µin. or 50µin. gold contact plating. Materials Connector Shell: • Steel with zinc or cadmium plating and yellow chromate finish or tin plating (grounding indents on plug). 4 4-55 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell - Combination Layout Series 1 - High Reliability Combination Layouts Shell Size Contact Arrangement Signal Contacts Coax Cavities Shell Size Contact Arrangement Signal Contacts Coax Cavities 4 E 5W1 4 1 A 3W3 0 1 B 9W4 5 4 A 7W2 5 1 A 11W1 10 1 B 13W3 10 3 B 17W2 15 2 B 21W1 20 1 Shell Size Contact Arrangement Signal Contacts Coax Cavities C C C 13W6 7 5 8W8 0 8 17W5 12 5 Shell Size Contact Arrangement Signal Contacts Coax Cavities C C C 21WA-4 17 4 25W3 22 3 27W2 25 2 Shell Size Contact Arrangement Signal Contacts Coax Cavities D 24W7 25 2 D 36W4 32 4 D 43W2 41 2 NOTE: Mating face of plug is shown, socket is mirror image. Position numbers are for male only. Call Toll Free: 1 (800) 323-9612 4-56 D-subminiature Metal Shell - Combination Layout Solder Cup Series 1 - High Reliability • Will accommodate up to 20 AWG wire. Ordering Information Combo D-sub Solder Cup Plugs 30µin. Gold Plating Shell Zinc-Plated Shell with Yellow Chromate Finish Size Mounting Holes 4-40 Clinch Nuts Dual Float Bushings E DEM-XXWX*P DEME XXWX*P DEMY-XXWX*P A DAM-XXWX*P DAME-XXWX*P DAMY-XXWX*P B DBM-XXWX*P DBME-XXWX*P DBMY-XXWX*P C DCM-XXWX*P DCME-XXWX*P DCMY-XXWX*P D DDM-XXWX*P DDME-XXWX*P DDMY-XXWX*P Tin-Plated Shell with Grounding Indents Mounting Holes 4-40 Clinch Nuts Dual Float Bushings DEM-XXWX*PTI DEME-XXWX*PTI DEMY-XXWX*PTI DAM-XXWX*PTI DAME-XXWX*PTI DAMY-XXWX*PTI DBM-XXWX*PTI DBME-XXWX*PTI DBMY-XXWX*PTI DCM-XXWX*PTI DCME-XXWX*PTI DCMY-XXWX*PTI DDM-XXWX*PTI DDME-XXWX*PTI DDMY-XXWX*PTI Combo D-sub Solder Cup Sockets 30µin. Gold Plating Shell Zinc-Plated Shell with Yellow Chromate Finish Size Mounting Holes 4-40 Clinch Nuts Dual Float Bushings E DEM-XXWX*S DEME-XXWX*S DEMY-XXWX*S A DAM-XXWX*S DAME-XXWX*S DAMY-XXWX*S B DBM-XXWX*S DBME-XXWX*S DBMY-XXWX*S C DCM-XXWX*S DCME-XXWX*S DCMY-XXWX*S D DDM-XXWX*S DDME-XXWX*S DDMY-XXWX*S Mounting Holes DEM-XXWX*ST DAM-XXWX*ST DBM-XXWX*ST DCM-XXWX*ST DDM-XXWX*ST Tin-Plated Shell 4-40 Clinch Nuts Dual Float Bushings DEME-XXWX*ST DEMY-XXWX*ST DAME-XXWX*ST DAMY-XXWX*ST DBME-XXWX*ST DBMY-XXWX*ST DCME-XXWX*ST DCMY-XXWX*ST DDME-XXWX*ST DDMY-XXWX*ST Mounting Holes DEMM-XXWX*S DAMM-XXWX*S DBMM-XXWX*S DCMM-XXWX*S DDMM-XXWX*S Sockets 4-40 Clinch Nuts DEMME-XXWX*S DAMME-XXWX*S DBMME-XXWX*S DCMME-XXWX*S DDMME-XXWX*S Combo D-sub Solder Cup Plugs and Sockets 50µin. Gold Plating Cadmium-Plated Shell with Yellow Chromate Finish Shell Size Mounting Holes E DEMM-XXWX*P A DAMM-XXWX*P B DBMM-XXWX*P C DCMM-XXWX*P D DDMM-XXWX*P Plugs 4-40 Clinch Nuts Dual Float Bushings DEMME-XXWX*P DEMMY-XXWX*P DAMME-XXWX*P DAMMY-XXWX*P DBMME-XXWX*P DBMMY-XXWX*P DCMME-XXWX*P DCMMY-XXWX*P DDMME-XXWX*P DDMMY-XXWX*P Dual Float Bushings DEMMY-XXWX*S DAMMY-XXWX*S DBMMY-XXWX*S DCMMY-XXWX*S DDMMY-XXWX*S *Note: XXWX means insert combo layout contact arrangement from page 4-56 in catalog number i.e., 13W3. 4-57 Call Toll Free: 1 (800) 323-9612 4 D-subminiature Metal Shell - Combination Layout Vertical PCB Dip Solder Tails Series 1 - High Reliability Ordering Information Combo D-sub Vertical PCB Plugs 30µin. Gold Plating Zinc-Plated Shell with Yellow Chromate Finish and Mounting Holes .125 Tail Length .158 Tail Length .185 Tail Length .125 Tail Length .030 Contact .030 Contact .030 Contact .040 Contact Shell Size Diameter Diameter Diameter Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEM-XXWX*PH DAM-XXWX*PH DBM-XXWX*PH DCM-XXWX*PH DDM-XXWX*PH DEM-XXWX*PX DAM-XXWX*PX DBM-XXWX*PX DCM-XXWX*PX DDM-XXWX*PX .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEME-XXWX*PB DAME-XXWX*PB DBME-XXWX*PB DCME-XXWX*PB DDME-XXWX*PB DEME-XXWX*PH DAME-XXWX*PH DBME-XXWX*PH DCME-XXWX*PH DDME-XXWX*PH DEME-XXWX*PX DAME-XXWX*PX DBME-XXWX*PX DCME-XXWX*PX DDME-XXWX*PX Zinc-Plated Shell with Yellow Chromate Finish and Dual Float Bushings .125 Tail Length .158 Tail Length .185 Tail Length .125 Tail Length .030 Contact .030 Contact .030 Contact .040 Contact Shell Size Diameter Diameter Diameter Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEMY-XXWX*PB DAMY-XXWX*PB DBMY-XXWX*PB DCMY-XXWX*PB DDMY-XXWX*PB DEMY-XXWX*PH DAMY-XXWX*PH DBMY-XXWX*PH DCMY-XXWX*PH DDMY-XXWX*PH DEMY-XXWX*PX DAMY-XXWX*PX DBMY-XXWX*PX DCMY-XXWX*PX DDMY-XXWX*PX Tin-Plated Shell with Grounding Indents and Mounting Holes .125 Tail Length .158 Tail Length .185 Tail Length .125 Tail Length .030 Contact .030 Contact .030 Contact .040 Contact Shell Size Diameter Diameter Diameter Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEM-XXWX*PHTI DAM-XXWX*PHTI DBM-XXWX*PHTI DCM-XXWX*PHTI DDM-XXWX*PHTI DEM-XXWX*PXTI DAM-XXWX*PXTI DBM-XXWX*PXTI DCM-XXWX*PXTI DDM-XXWX*PXTI E A B C D 4 DEM-XXWX*PE DAM-XXWX*PE DBM-XXWX*PE DCM-XXWX*PE DDM-XXWX*PE DEM-XXWX*PM DAM-XXWX*PM DBM-XXWX*PM DCM-XXWX*PM DDM-XXWX*PM DEM-XXWX*PZ DAM-XXWX*PZ DBM-XXWX*PZ DCM-XXWX*PZ DDM-XXWX*PZ DEM-XXWX*PB DAM-XXWX*PB DBM-XXWX*PB DCM-XXWX*PB DDM-XXWX*PB Zinc-Plated Shell with Yellow Chromate Finish and 4-40 Clinch Nuts .125 Tail Length .158 Tail Length .185 Tail Length .125 Tail Length .030 Contact .030 Contact .030 Contact .040 Contact Shell Size Diameter Diameter Diameter Diameter E A B C D E A B C D E A B C D DEME-XXWX*PE DAME-XXWX*PE DBME-XXWX*PE DCME-XXWX*PE DDME-XXWX*PE DEMY-XXWX*PE DAMY-XXWX*PE DBMY-XXWX*PE DCMY-XXWX*PE DDMY-XXWX*PE DEM-XXWX*PETI DAM-XXWX*PETI DBM-XXWX*PETI DCM-XXWX*PETI DDM-XXWX*PETI DEME-XXWX*PM DAME-XXWX*PM DBME-XXWX*PM DCME-XXWX*PM DDME-XXWX*PM DEMY-XXWX*PM DAMY-XXWX*PM DBMY-XXWX*PM DCMY-XXWX*PM DDMY-XXWX*PM DEM-XXWX*PMTI DAM-XXWX*PMTI DBM-XXWX*PMTI DCM-XXWX*PMTI DDM-XXWX*PMTI DEME-XXWX*PZ DAME-XXWX*PZ DBME-XXWX*PZ DCME-XXWX*PZ DDME-XXWX*PZ DEMY-XXWX*PZ DAMY-XXWX*PZ DBMY-XXWX*PZ DCMY-XXWX*PZ DDMY-XXWX*PZ DEM-XXWX*PZTI DAM-XXWX*PZTI DBM-XXWX*PZTI DCM-XXWX*PZTI DDM-XXWX*PZTI DEM-XXWX*PBTI DAM-XXWX*PBTI DBM-XXWX*PBTI DCM-XXWX*PBTI DDM-XXWX*PBTI * Note: XXWX means insert combo layout contact arrangement from page 4-56 in catalog number i.e., 13W3. Call Toll Free: 1 (800) 323-9612 4-58 D-subminiature Metal Shell - Combination Layout Vertical PCB Dip Solder Tails Series 1 - High Reliability Ordering Information Combo D-sub Vertical PCB Plugs 30µin. Gold Plating (Cont’d) Tin-Plated Shell with Grounding Indents and 4-40 Clinch Nuts Shell Size .125 Tail Length .030 Contact Diameter .158 Tail Length .030 Contact Diameter E A B C D DEME-XXWX*PETI DAME-XXWX*PETI DBME-XXWX*PETI DCME-XXWX*PETI DDME-XXWX*PETI DEME-XXWX*PMTI DAME-XXWX*PMTI DBME-XXWX*PMTI DCME-XXWX*PMTI DDME-XXWX*PMTI .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEME-XXWX*PZTI DAME-XXWX*PZTI DBME-XXWX*PZTI DCME-XXWX*PZTI DDME-XXWX*PZTI DEME-XXWX*PBTI DAME-XXWX*PBTI DBME-XXWX*PBTI DCME-XXWX*PBTI DDME-XXWX*PBTI DEME-XXWX*PHTI DAME-XXWX*PHTI DBME-XXWX*PHTI DCME-XXWX*PHTI DDME-XXWX*PHTI DEME-XXWX*PXTI DAME-XXWX*PXTI DBME-XXWX*PXTI DCME-XXWX*PXTI DDME-XXWX*PXTI Tin-Plated Shell with Grounding Indents and Dual Float Bushings Shell Size .125 Tail Length .030 Contact Diameter .158 Tail Length .030 Contact Diameter .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter E A B C D DEMY-XXWX*PETI DAMY-XXWX*PETI DBMY-XXWX*PETI DCMY-XXWX*PETI DDMY-XXWX*PETI DEMY-XXWX*PMTI DAMY-XXWX*PMTI DBMY-XXWX*PMTI DCMY-XXWX*PMTI DDMY-XXWX*PMTI DEMY-XXWX*PZTI DAMY-XXWX*PZTI DBMY-XXWX*PZTI DCMY-XXWX*PZTI DDMY-XXWX*PZTI DEMY-XXWX*PBTI DAMY-XXWX*PBTI DBMY-XXWX*PBTI DCMY-XXWX*PBTI DDMY-XXWX*PBTI DEMY-XXWX*PHTI DAMY-XXWX*PHTI DBMY-XXWX*PHTI DCMY-XXWX*PHTI DDMY-XXWX*PHTI DEMY-XXWX*PXTI DAMY-XXWX*PXTI DBMY-XXWX*PXTI DCMY-XXWX*PXTI DDMY-XXWX*PXTI 50µin. Gold Plating Cadmium-Plated Shell with Yellow Chromate Finish and Mounting Holes Shell Size E A B C D .125 Tail Length .030 Contact Diameter DEMM-XXWX*PE DAMM-XXWX*PE DBMM-XXWX*PE DCMM-XXWX*PE DDMM-XXWX*PE .158 Tail Length .030 Contact Diameter .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEMM-XXWX*PM DAMM-XXWX*PM DBMM-XXWX*PM DCMM-XXWX*PM DDMM-XXWX*PM DEMM-XXWX*PZ DAMM-XXWX*PZ DBMM-XXWX*PZ DCMM-XXWX*PZ DDMM-XXWX*PZ DEMM-XXWX*PB DAMM-XXWX*PB DBMM-XXWX*PB DCMM-XXWX*PB DDMM-XXWX*PB DEMM-XXWX*PH DAMM-XXWX*PH DBMM-XXWX*PH DCMM-XXWX*PH DDMM-XXWX*PH DEMM-XXWX*PX DAMM-XXWX*PX DBMM-XXWX*PX DCMM-XXWX*PX DDMM-XXWX*PX Cadmium-Plated Shell with Yellow Chromate Finish and 4-40 Clinch Nuts Shell Size .125 Tail Length .030 Contact Diameter .158 Tail Length .030 Contact Diameter E A B C D DEMME-XXWX*PE DAMME-XXWX*PE DBMME-XXWX*PE DCMME-XXWX*PE DDMME-XXWX*PE DEMME-XXWX*PM DAMME-XXWX*PM DBMME-XXWX*PM DCMME-XXWX*PM DDMME-XXWX*PM .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEMME-XXWX*PZ DAMME-XXWX*PZ DBMME-XXWX*PZ DCMME-XXWX*PZ DDMME-XXWX*PZ DEMME-XXWX*PB DAMME-XXWX*PB DBMME-XXWX*PB DCMME-XXWX*PB DDMME-XXWX*PB DEMME-XXWX*PH DAMME-XXWX*PH DBMME-XXWX*PH DCMME-XXWX*PH DDMME-XXWX*PH DEMME-XXWX*PX DAMME-XXWX*PX DBMME-XXWX*PX DCMME-XXWX*PX DDMME-XXWX*PX Cadmium-Plated Shell with Yellow Chromate Finish and Dual Float Bushings Shell Size .125 Tail Length .030 Contact Diameter .158 Tail Length .030 Contact Diameter .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter E A B C D DEMMY-XXWX*PE DAMMY-XXWX*PE DBMMY-XXWX*PE DCMMY-XXWX*PE DDMMY-XXWX*PE DEMMY-XXWX*PM DAMMY-XXWX*PM DBMMY-XXWX*PM DCMMY-XXWX*PM DDMMY-XXWX*PM DEMMY-XXWX*PZ DAMMY-XXWX*PZ DBMMY-XXWX*PZ DCMMY-XXWX*PZ DDMMY-XXWX*PZ DEMMY-XXWX*PB DAMMY-XXWX*PB DBMMY-XXWX*PB DCMMY-XXWX*PB DDMMY-XXWX*PB DEMMY-XXWX*PH DAMMY-XXWX*PH DBMMY-XXWX*PH DCMMY-XXWX*PH DDMMY-XXWX*PH DEMMY-XXWX*PX DAMMY-XXWX*PX DBMMY-XXWX*PX DCMMY-XXWX*PX DDMMY-XXWX*PX *Note: XXWX means insert combo layout contact arrangement from page 4-56 in catalog number i.e., 13W3. 4-59 Call Toll Free: 1 (800) 323-9612 4 D-subminiature Metal Shell - Combination Layout Vertical PCB Mount Dip Solder Tails Series 1 High Reliability Ordering Information Combo D-sub Vertical PCB Sockets 30µin. Gold Plating Zinc-Plated Shell with Yellow Chromate Finish and Mounting Holes Shell Size E A B C D .125 Tail Length .030 Contact Diameter DEM-XXWX*SE DAM-XXWX*SE DBM-XXWX*SE DCM-XXWX*SE DDM-XXWX*SE .158 Tail Length .030 Contact Diameter DEM-XXWX*SM DAM-XXWX*SM DBM-XXWX*SM DCM-XXWX*SM DDM-XXWX*SM .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEM-XXWX*SZ DAM-XXWX*SZ DBM-XXWX*SZ DCM-XXWX*SZ DDM-XXWX*SZ DEM-XXWX*SB DAM-XXWX*SB DBM-XXWX*SB DCM-XXWX*SB DDM-XXWX*SB DEM-XXWX*SH DAM-XXWX*SH DBM-XXWX*SH DCM-XXWX*SH DDM-XXWX*SH DEM-XXWX*SX DAM-XXWX*SX DBM-XXWX*SX DCM-XXWX*SX DDM-XXWX*SX Zinc-Plated Shell with Yellow Chromate Finish and 4-40 Clinch Nuts Shell Size E A B C D 4 .125 Tail Length .030 Contact Diameter DEME-XXWX*SE DAME-XXWX*SE DBME-XXWX*SE DCME-XXWX*SE DDME-XXWX*SE .158 Tail Length .030 Contact Diameter DEME-XXWX*SM DAME-XXWX*SM DBME-XXWX*SM DCME-XXWX*SM DDME-XXWX*SM .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEME-XXWX*SZ DAME-XXWX*SZ DBME-XXWX*SZ DCME-XXWX*SZ DDME-XXWX*SZ DEME-XXWX*SB DAME-XXWX*SB DBME-XXWX*SB DCME-XXWX*SB DDME-XXWX*SB DEME-XXWX*SH DAME-XXWX*SH DBME-XXWX*SH DCME-XXWX*SH DDME-XXWX*SH DEME-XXWX*SX DAME-XXWX*SX DBME-XXWX*SX DCME-XXWX*SX DDME-XXWX*SX Zinc-Plated Shell with Yellow Chromate Finish and Dual Float Bushings Shell Size E A B C D .125 Tail Length .030 Contact Diameter DEMY-XXWX*SE DAMY-XXWX*SE DBMY-XXWX*SE DCMY-XXWX*SE DDMY-XXWX*SE .158 Tail Length .030 Contact Diameter DEMY-XXWX*SM DAMY-XXWX*SM DBMY-XXWX*SM DCMY-XXWX*SM DDMY-XXWX*SM .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEMY-XXWX*SZ DAMY-XXWX*SZ DBMY-XXWX*SZ DCMY-XXWX*SZ DDMY-XXWX*SZ DEMY-XXWX*SB DAMY-XXWX*SB DBMY-XXWX*SB DCMY-XXWX*SB DDMY-XXWX*SB DEMY-XXWX*SH DAMY-XXWX*SH DBMY-XXWX*SH DCMY-XXWX*SH DDMY-XXWX*SH DEMY-XXWX*SX DAMY-XXWX*SX DBMY-XXWX*SX DCMY-XXWX*SX DDMY-XXWX*SX .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEM-XXWX*SZT DAM-XXWX*SZT DBM-XXWX*SZT DCM-XXWX*SZT DDM-XXWX*SZT DEM-XXWX*SBT DAM-XXWX*SBT DBM-XXWX*SBT DCM-XXWX*SBT DDM-XXWX*SBT DEM-XXWX*SHT DAM-XXWX*SHT DBM-XXWX*SHT DCM-XXWX*SHT DDM-XXWX*SHT DEM-XXWX*SXT DAM-XXWX*SXT DBM-XXWX*SXT DCM-XXWX*SXT DDM-XXWX*SXT Tin-Plated Shell with Mounting Holes Shell Size E A B C D .125 Tail Length .030 Contact Diameter DEM-XXWX*SET DAM-XXWX*SET DBM-XXWX*SET DCM-XXWX*SET DDM-XXWX*SET .158 Tail Length .030 Contact Diameter DEM-XXWX*SMT DAM-XXWX*SMT DBM-XXWX*SMT DCM-XXWX*SMT DDM-XXWX*SMT * Note: XXWX means insert combo layout contact arrangement from page 4-56 in catalog number i.e., 13W3. Call Toll Free: 1 (800) 323-9612 4-60 D-subminiature Metal Shell - Combination Layout Vertical PCB Mount Dip Solder Tails Series 1 - High Reliability Ordering Information Combo D-sub Vertical PCB Sockets (Cont’d) 30µin. Gold Plating (Cont’d) Tin-Plated Shell with 4-40 Clinch Nuts Shell Size .125 Tail Length .030 Contact Diameter .158 Tail Length .030 Contact Diameter .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter E A B C D DEME-XXWX*SET DAME-XXWX*SET DBME-XXWX*SET DCME-XXWX*SET DDME-XXWX*SET DEME-XXWX*SMT DAME-XXWX*SMT DBME-XXWX*SMT DCME-XXWX*SMT DDME-XXWX*SMT DEME-XXWX*SZT DAME-XXWX*SZT DBME-XXWX*SZT DCME-XXWX*SZT DDME-XXWX*SZT DEME-XXWX*SBT DAME-XXWX*SBT DBME-XXWX*SBT DCME-XXWX*SBT DDME-XXWX*SBT DEME-XXWX*SHT DAME-XXWX*SHT DBME-XXWX*SHT DCME-XXWX*SHT DDME-XXWX*SHT DEME-XXWX*SXT DAME-XXWX*SXT DBME-XXWX*SXT DCME-XXWX*SXT DDME-XXWX*SXT Tin-Plated Shell and Dual Float Bushings Shell Size E A B C D .125 Tail Length .030 Contact Diameter .158 Tail Length .030 Contact Diameter .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEMY-XXWX*SET DAMY-XXWX*SET DBMY-XXWX*SET DCMY-XXWX*SET DDMY-XXWX*SET DEMY-XXWX*SMT DAMY-XXWX*SMT DBMY-XXWX*SMT DCMY-XXWX*SMT DDMY-XXWX*SMT DEMY-XXWX*SZT DAMY-XXWX*SZT DBMY-XXWX*SZT DCMY-XXWX*SZT DDMY-XXWX*SZT DEMY-XXWX*SBT DAMY-XXWX*SBT DBMY-XXWX*SBT DCMY-XXWX*SBT DDMY-XXWX*SBT DEMY-XXWX*SHT DAMY-XXWX*SHT DBMY-XXWX*SHT DCMY-XXWX*SHT DDMY-XXWX*SHT DEMY-XXWX*SXT DAMY-XXWX*SXT DBMY-XXWX*SXT DCMY-XXWX*SXT DDMY-XXWX*SXT 50µin. Gold Plating Cadmium-Plated Shell with Yellow Chromate Finish and Mounting Holes Shell Size E A B C D .125 Tail Length .030 Contact Diameter DEMM-XXWX*SE DAMM-XXWX*SE DBMM-XXWX*SE DCMM-XXWX*SE DDMM-XXWX*SE .158 Tail Length .030 Contact Diameter .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEMM-XXWX*SM DAMM-XXWX*SM DBMM-XXWX*SM DCMM-XXWX*SM DDMM-XXWX*SM DEMM-XXWX*SZ DAMM-XXWX*SZ DBMM-XXWX*SZ DCMM-XXWX*SZ DDMM-XXWX*SZ DEMM-XXWX*SB DAMM-XXWX*SB DBMM-XXWX*PB DCMM-XXWX*SB DDMM-XXWX*SB DEMM-XXWX*SH DAMM-XXWX*SH DBMM-XXWX*SH DCMM-XXWX*SH DDMM-XXWX*SH DEMM-XXWX*SX DAMM-XXWX*SX DBMM-XXWX*SX DCMM-XXWX*SX DDMM-XXWX*SX Cadmium-Plated Shell with Yellow Chromate Finish and 4-40 Clinch Nuts Shell Size .125 Tail Length .030 Contact Diameter .158 Tail Length .030 Contact Diameter E A B C D DEMME-XXWX*SE DAMME-XXWX*SE DBMME-XXWX*SE DCMME-XXWX*SE DDMME-XXWX*SE DEMME-XXWX*SM DAMME-XXWX*SM DBMME-XXWX*SM DCMME-XXWX*SM DDMME-XXWX*SM .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter DEMME-XXWX*SZ DAMME-XXWX*SZ DBMME-XXWX*SZ DCMME-XXWX*SZ DDMME-XXWX*SZ DEMME-XXWX*SB DAMME-XXWX*SB DBMME-XXWX*SB DCMME-XXWX*SB DDMME-XXWX*SB DEMME-XXWX*SH DAMME-XXWX*SH DBMME-XXWX*SH DCMME-XXWX*SH DDMME-XXWX*SH DEMME-XXWX*SX DAMME-XXWX*SX DBMME-XXWX*SX DCMME-XXWX*SX DDMME-XXWX*SX Cadmium-Plated Shell with Yellow Chromate Finish and Dual Float Bushings Shell Size .125 Tail Length .030 Contact Diameter .158 Tail Length .030 Contact Diameter .185 Tail Length .030 Contact Diameter .125 Tail Length .040 Contact Diameter .158 Tail Length .040 Contact Diameter .185 Tail Length .040 Contact Diameter E A B C D DEMMY-XXWX*SE DAMMY-XXWX*SE DBMMY-XXWX*SE DCMMY-XXWX*SE DDMMY-XXWX*SE DEMMY-XXWX*SM DAMMY-XXWX*SM DBMMY-XXWX*SM DCMMY-XXWX*SM DDMMY-XXWX*SM DEMMY-XXWX*SZ DAMMY-XXWX*SZ DBMMY-XXWX*SZ DCMMY-XXWX*SZ DDMMY-XXWX*SZ DEMMY-XXWX*SB DAMMY-XXWX*SB DBMMY-XXWX*SB DCMMY-XXWX*SB DDMMY-XXWX*SB DEMMY-XXWX*SH DAMMY-XXWX*SH DBMMY-XXWX*SH DCMMY-XXWX*SH DDMMY-XXWX*SH DEMMY-XXWX*SX DAMMY-XXWX*SX DBMMY-XXWX*SX DCMMY-XXWX*SX DDMMY-XXWX*SX *Note: XXWX means insert combo layout contact arrangement from page 4-56 in catalog number i.e., 13W3. 4-61 Call Toll Free: 1 (800) 323-9612 4 D-subminiature Contacts Coaxial - High Power - High Voltage Ω and 75Ω Ω), High-Voltage, and High-Power styles. ■ Available in Coaxial (50Ω FEATURES ■ Cable termination and PCB mount contacts are available in right-angle and straight plugs and receptacles. ■ Precision screw machine construction results in uniform contact impedance and excellent contact retention. ■ Available with 30µin. or 50µin. gold contact plating. ■ Cable braid can be soldered or crimped. ■ See pages 4-55 thru 4-61 for Cinch combination layout D-subminiature connectors. Termination Tooling • • No tools are required for coaxial contact insertion. Contacts snap into connector. Coaxial and high-voltage contact extraction tool #CET-C6B for removing contacts after termination. See page 4-103. Tool to crimp sleeve over cable braid: Use 3-cavity die #CCD-26 with crimp frame #FCT-552. See page 4-103. NOTE: In order to determine which contact to use with a cable wire not specifically listed: • Check the style of contact required: straight or right-angle, solder braid or crimp braid, etc. • Refer to the cable wire manufacturer’s specifications to determine: - The O.D. of the insulator. - The O.D. of the jacket. • Compare the above with the corresponding dimensions C and E in the straight contacts and dimensions B and C in the right-angle contacts. Call Toll Free: 1 (800) 323-9612 4-62 D-subminiature Contacts Coaxial - 50 Ω Right-Angle and Straight Materials • • • Receptacle: Body - Beryllium copper, Insulator - Teflon, Contacts - Brass. Plug: Body - Brass, Insulator - Teflon, Contacts - Beryllium copper. Plating: 30µin. gold over nickel, 50µin. gold over copper. Electrical Characteristics Dielectric Withstanding Voltage: • • Cable Contacts: minimum AC 1000V RMS @ sea level. PCB Contacts: minimum AC 800V RMS @ sea level. Frequency Range: 0-900 MHz. Right-Angle Receptacle Plug Straight Receptacle Plug Ordering Information Ω Right-Angle PCB Coaxial Contacts - 50Ω Plug Recept. 30µin. Gold DM53761-30 DM53763-30 50µin. Gold DM53761-50 DM53763-50 Ω Straight PCB Coaxial Contacts - 50Ω Plug Recept. 4-63 30µin. Gold DM53760-30 DM53762-30 50µin. Gold DM53760-50 DM53762-50 Call Toll Free: 1 (800) 323-9612 D-subminiature Contacts Ω Coaxial - 50Ω Straight • Material and electrical specifications: See page 4-63. Plug 4 Receptacle Ordering Information Straight Solder Braid Coaxial Contacts Plug Plug Plug Plug Recept. Recept. Recept. Recept. Plug Recept. 30µin. Gold DM53740-5008 DM53740-5001 DM53740-5002 DM53740-5005 DM53742-5006 DM53742-5001 DM53742-5002 DM53742-5004 DM53740-5000 DM53742-5000 50µin. Gold DM53740-5105 DM53740-5099 DM53740-5104 DM53740-5101 DM53742-5092 DM53742-5089 DM53742-5091 DM53742-5086 DM53740-5100 DM53742-5085 A in .739 .739 .847 .847 .739 .739 .847 .847 .670 .670 Max. mm 18.77 18.77 21.51 21.51 18.77 18.77 21.51 21.51 17.02 17.02 B Ref. in mm 0.929 23.60 0.929 23.60 1.037 26.34 1.037 26.34 0.929 23.60 0.929 23.60 1.037 26.34 1.037 26.34 0.860 21.84 0.860 21.84 in .093 .125 .202 .202 .093 .125 .202 .202 .093 .093 C B Ref. in mm .929 23.60 .929 23.60 1.037 26.34 1.037 26.34 .929 23.60 .929 23.60 1.037 1.037 E +.005" in mm .040 1.02 .067 1.70 .110 2.79 .125 3.18 .040 1.02 .067 1.70 .110 2.79 .125 3.18 .040 1.02 .040 1.02 RG Cable Old New 196/U 178B/U 187/U 179B/U 195/U 180B/U 58/U 58B/U 196/U 178B/U 187/U 179B/U 195/U 180B/U 58/U 58B/U 196/U 178B/U 196/U 178B/U mm 3.15 3.86 5.97 5.97 3.15 3.86 E +.005" in mm .040 1.02 .067 1.70 .110 2.79 .125 3.18 .040 1.02 .067 1.70 5.97 5.97 .110 .125 RG Cable Old New 196/U 178B/U 187/U 179B/U 195/U 180B/U 58/U 58B/U 196/U 178B/U 187/U, 179B/U, 188/U 316/BU 195/U 180B/U 58/U 58B/U D mm 2.36 3.18 5.13 5.13 2.36 3.18 5.13 5.13 2.36 2.36 in .124 .152 .235 .235 .124 .152 .235 .235 .124 .124 in .093 .125 .202 .202 .093 .125 mm 2.36 3.18 5.13 5.13 2.36 3.18 in .124 .152 .235 .235 .124 .152 .202 .202 5.13 5.13 .235 .235 mm 3.15 3.86 5.97 5.97 3.15 3.86 5.97 5.97 3.15 3.15 Straight Crimp Braid Coaxial Contacts Plug Plug Plug Plug Recept. Recept. 30µin. Gold DM53740 DM53740-1 DM53740-3 DM53740-5 DM53742 DM53742-1 50µin. Gold DM53740-17 DM53740-15 DM53740-16 DM53740-18 DM53742-18 DM53742-16 A in .739 .739 .847 .847 .739 .739 Max. mm 18.77 18.77 21.51 21.51 18.77 18.77 Recept. Recept. DM53742-3 DM53742-5 DM53742-17 DM53742-19 .847 .847 21.51 21.51 Call Toll Free: 1 (800) 323-9612 26.34 26.34 4-64 C D 2.79 3.18 D-subminiature Contacts Ω Coaxial - 50Ω Right Angle • Material and electrical specifications: See page 4-63. Plug Receptacle Ω Right-Angle Solder Braid Coaxial Contacts - 50Ω A 30µin. Gold 50µin. Gold in mm in B mm in C mm in D mm in E mm in F mm Old RG Cable New Plugs DM53741-5000 DM53741-5001 DM53741-5059 DM53741-5062 .530 .530 13.46 13.46 .734 .734 18.64 18.64 .492 12.50 .492 12.50 .040 1.02 .067 1.70 .093 .125 2.36 3.18 .125 .152 3.18 3.86 RG 196/U RG 187/U DM53741-5003 DM53741-5004 DM53741-5063 DM53741-5060 .530 .530 13.46 13.46 .734 .734 18.64 18.64 .601 15.27 .601 15.27 .110 2.79 .125 3.18 .202 .202 5.13 5.13 .235 .235 5.97 5.97 RG 195/U RG 196/U Receptacles DM53743-5000 DM53743-5001 DM53743-5073 DM53743-5076 .530 .530 13.46 13.46 .734 .734 18.64 18.64 .492 12.50 .492 12.50 .040 1.02 .067 1.70 .093 .125 2.36 3.18 .125 .152 3.18 3.86 RG 196/U RG 187/U DM53743-5003 DM53743-5004 DM53743-5077 DM53743-5074 .530 .530 13.46 13.46 .734 .734 18.64 18.64 .601 15.27 .601 15.27 .110 2.79 .125 3.18 .202 .202 5.13 5.13 .235 .235 5.97 5.97 RG 195/U RG 58/U D mm in mm in mm Old RG RG RG RG RG 178B/U 179B/U, 316B/U 180B/U 58B/U RG RG RG RG RG 178B/U 179B/U, 316B/U 180B/U 58B/U Ω Right-Angle Crimp Braid Coaxial Contacts - 50Ω 30µin. Gold 50µin. Gold in A mm in B mm Plugs DM53741-0 DM53741-1 DM53741-12 DM53741-11 .530 .530 13.46 13.46 .734 .734 18.64 18.64 .492 12.50 .492 12.50 .040 1.02 .067 1.70 .093 .125 2.36 3.18 .125 .152 3.18 3.86 DM53741-3 DM53741-4 DM53741-10 DM53741-13 .530 .530 13.46 13.46 .734 .734 18.64 18.64 .601 15.27 .601 15.27 .110 2.79 .125 3.18 .202 .202 5.13 5.13 .235 .235 5.97 5.97 Receptacles DM53743-2 DM53743-3 DM53743-18 DM53743-16 .530 .530 13.46 13.46 .734 .734 18.64 18.64 .492 12.50 .492 12.50 .040 1.02 .067 1.70 .093 .125 2.36 3.18 .125 .152 3.18 3.86 DM53743-5 DM53743-6 DM53743-17 DM53743-19 .530 .530 13.46 13.46 .734 .734 18.64 18.64 .601 15.27 .601 15.27 .110 2.79 .125 3.18 .202 .202 5.13 5.13 .235 .235 5.97 5.97 in C mm 4-65 in E F RG Cable New RG RG RG RG RG 196/U 187/U 188/U 195/U 58/U RG RG RG RG RG 178B/U 179B/U, 316B/U 180B/U 58B/U RG RG RG RG RG 196/U 187/U 188/U 195/U 58/U RG RG RG RG RG 178B/U 179B/U, 316B/U 180B/U 58B/U Call Toll Free: 1 (800) 323-9612 4 D-subminiature Contacts Ω Coaxial - 75Ω Straight Materials • • • Receptacle: Body - Brass or beryllium copper, Insulator - Teflon, Contacts - Brass. Plug: Body - Brass, Insulator - Teflon, Contacts - Beryllium copper. Plating: 30µin. gold over nickel, 50µin. gold over copper Electrical Characteristics Nominal Impedance: 75Ω. Dielectric Withstanding Voltage: Minimum 1000V RMS @ sea level. VWSR: 1.05 max. for 0-1 GHz and 1.25 max for 1-2 GHz Receptacle Plug 150/.153 Dia. .187 Dia. Ref. .187 Dia. Ref. .201 Dia. Ref. .201 Dia. Ref. 4 Ordering Information Ω Crimp/Solder Termination Straight Coaxial Contacts 75Ω Plug Plug Recept. Recept. Recept. Recept. 30µin. Gold DM53750-12 DM53750-11 DM53752-8 DM53752-7 DM53752-6 DM53752-5 50µin. Gold DM53750-52 DM53750-51 DM53752-58 DM53752-57 DM53752-56 DM53752-55 A in 1.037 0.929 1.037 0.929 1.037 0.929 B mm 26.34 23.60 26.34 23.60 26.34 23.60 in .108 .067 .108 .067 .108 .067 mm 2.74 1.70 2.74 1.70 2.74 1.70 Material Brass Brass Brass Brass Beryllium Copper Beryllium Copper Cable Belden 8218 RG 179 B/U Belden 8218 RG 179 B/U Belden 8218 RG 179 B/U mm 2.74 1.70 2.74 1.70 2.74 1.70 Material Brass Brass Brass Brass Beryllium Copper Beryllium Copper Cable Belden 8218 RG 179 B/U Belden 8218 RG 179 B/U Belden 8218 RG 179 B/U Ω Crimp/Crimp Termination Straight Coaxial Contacts 75Ω Plug Plug Recept. Recept. Recept. Recept. 30µin. Gold DM53750-010 DM53750-009 DM53752-004 DM53752-003 DM53752-002 DM53752-001 50µin. Gold DM53750-510 DM53750-509 DM53752-504 DM53752-503 DM53752-502 DM53752-501 Call Toll Free: 1 (800) 323-9612 A in 1.050 1.050 1.090 1.090 1.090 1.090 B mm 26.67 26.67 27.69 27.69 27.69 27.69 4-66 in .108 .067 .108 .067 .108 .067 D-subminiature Contacts High Voltage Right-Angle and Straight Materials • • Contact: Body - Nylon per MIL-P-20693 Plating: 30µin. gold over nickel, 50µin. gold over copper Electrical Characteristics Dielectric Withstanding Voltage: Minimum AC 2800VAC RMS to shell @ sea level High-Voltage Contacts - For #20 AWG wire Right-Angle Straight Plug Plug Receptacle Receptacle 4 Ordering Information Straight High-Voltage Contacts - #20 AWG Wire Plug Recept. 30µin. Gold DM51157-0 DM51155-0 50µin. Gold DM51157-8 DM51155-7 A in mm .539 13.69 .539 13.69 B in mm .734 18.64 .734 18.64 Wire Size #20 #20 B in mm .697 17.70 .697 17.70 Wire Size #20 #20 Right-Angle High-Voltage Contacts - #20 AWG Wire Plug Recept. 30µin. Gold 50µin. Gold DM51157-5000 DM51157-5005 DM51155-5000 DM51155-5004 A in mm .491 12.47 .491 12.47 4-67 Call Toll Free: 1 (800) 323-9612 D-subminiature Contacts High-Power Straight • High-Power Contacts will accommodate up to 40 Amps current rating. Materials • Contact Plating: - 30µin. gold over nickel - 50µin. gold over copper • Receptacle: Beryllium copper • Plug: Brass Plug 4 Receptacle Ordering Information Straight High-Power Contacts A Plug Plug Plug Recept. Recept. Recept. 30µin. Gold DM53745-1 DM53745-7 DM53745-8 DM53744-1 DM53744-6 DM53744-7 50µin. Gold DM53745-28 DM53745-27 DM53745-25 DM53744-21 DM53744-25 DM53744-24 in .666 .666 .666 .666 .666 .666 Call Toll Free: 1 (800) 323-9612 mm 16.92 16.92 16.92 16.92 16.92 16.92 B in .866 .866 .866 .866 .866 .866 4-68 mm 22.00 22.00 22.00 22.00 22.00 22.00 C in .188 .112 .069 .188 .112 .069 mm 4.78 2.84 1.75 4.78 2.84 1.75 Current Rating (Amps) 40 20 10 40 20 10 Wire Size (AWG) #8 #12 #16 #8 #12 #16 ■ ■ ■ ■ ■ Insulator Material: Glass fiber-filled diallyl phthalate (green), UL 94V-0 Connector Shell: Steel with zinc plating and yellow chromate finish Contact Material: Plug - Brass (machined), Socket - Phosphor bronze (machined) Contact Plating: 30µin. gold over nickel 4-40 Clinch Nut: Steel with cadmium plating and yellow chromate finish Dual Float Bushing: Stainless steel, passivated Operating Temperature: -65°C to + 125°C Shock: 50G peak per MIL-STD-202, Method 213, Condition G Vibration: 12 cycles in three perpendicular directions @ 10-2000Hz, per MIL-STD-202, Method 204, Condition D Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per MIL-STD-202, Method 103 MECHANICAL ELECTRICAL MATERIALS High-reliability in a commercial grade connector. Monoblock diallyl phthalate insulator for improved electrical performance. Offered in 9, 15, 25, 37, and 50 position plugs and sockets. Offered with .120 mounting holes, 4-40 clinch nuts, or dual float bushings. Commercial version of M24308 Military connectors with tin-plated or zinc-plated shell and 30µin. gold contact plating. ■ Screw Machine Crimp and Poke contacts available as follows: • Note that all contacts are packed loose. • Plating options: 30µin. gold. • Can be included with the connector or purchased separately (FO part numbers). ■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel mounting specifications. ENVIRONMENTAL FEATURES D-subminiature Metal Shell Crimp and Poke Series 3 - High Reliability Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: Minimum 1250V RMS @ sea level 5 Amps 2.7 milliohms maximum 5000 megohms maximum (initial); 1000 megohms (minimum) after environmental testing Individual Contact Insertion and Separation Force (minimum/maximum): 0.7 oz./12 oz. Durability: 500 mating cycles Call Toll Free: 1 (800) 323-9612 4-70 D-subminiature Metal Shell Crimp and Poke Series 3 - High Reliability .375 (9.53) max. Termination Tooling • • • Contact Insertion/Extraction Tool: #CIET-20-HD (Military #M81969/39-01). See page 4-103. Crimp Contact Hand Tool: Military #M22520/2-01. See page 4-103. Contact Positioner (below) required. Positioner for machine contacts for Hand Tool #M22520/2-01 (locates contact in the correct position): #M22520/2-08. See page 4-103. Ordering Information Crimp and Poke - Plugs Zinc-Plated Shell with Yellow Chromate Finish Positions 9 15 25 37 50 Mounting Holes 30µin. Gold Without Contacts Contacts DEMA-9P DEMA-9P-FO DAMA-15P DAMA-15P-FO DBMA-25P DBMA-25P-FO DCMA-37P DCMA-37P-FO DDMA-50P DDMA-50P-FO 4-40 Clinch Nuts 30µin. Gold Without Contacts Contacts DEMAE-9P DEMAE-9P-FO DAMAE-15P DAMAE-15P-FO DBMAE-25P DBMAE-25P-FO DCMAE-37P DCMAE-37P-FO DDMAE-50P DDMAE-50P-FO Dual Float 30µin. Gold Contacts DEMAY-9P DAMAY-15P DBMAY-25P DCMAY-37P DDMAY-50P Bushings Without Contacts DEMAY-9P-FO DAMAY-15P-FO DBMAY-25P-FO DCMAY-37P-FO DDMAY-50P-FO 4-40 Clinch Nuts 30µin. Gold Without Contacts Contacts DEMAE-9PTI DEMAE-9PTI-FO DAMAE-15PTI DAMAE-15PTI-FO DBMAE-25PTI DBMAE-25PTI-FO DCMAE-37PTI DCMAE-37PTI-FO DDMAE-50PTI DDMAE-50PTI-FO Dual Float 30µin. Gold Contacts DEMAY-9PTI DAMAY-15PTI DBMAY-25PTI DCMAY-37PTI DDMAY-50PTI Bushings Without Contacts DEMAY-9PTI-FO DAMAY-15PTI-FO DBMAY-25PTI-FO DCMAY-37PTI-FO DDMAY-50PTI-FO Tin-Plated Shells with Grounding Indents Positions 9 15 25 37 50 Mounting Holes 30µin. Gold Without Contacts Contacts DEMA-9PTI DEMA-9PTI-FO DAMA-15PTI DAMA-15PTI-FO DBMA-25PTI DBMA-25PTI-FO DCMA-37PTI DCMA-37PTI-FO DDMA-50PTI DDMA-50PTI-FO 4-71 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell Crimp and Poke Series 3 - High Reliability Ordering Information Crimp and Poke - Sockets Zinc-Plated Shell with Yellow Chromate Finish Mounting Holes 30µin. Gold Without Contacts Contacts DEMA-9S DEMA-9S-FO DAMA-15S DAMA-15S-FO DBMA-25S DBMA-25S-FO DCMA-37S DCMA-37S-FO DDMA-50S DDMA-50S-FO Positions 9 15 25 37 50 4-40 Clinch Nuts 30µin. Gold Without Contacts Contacts DEMAE-9S DEMAE-9S-FO DAMAE-15S DAMAE-15S-FO DBMAE-25S DBMAE-25S-FO DCMAE-37S DCMAE-37S-FO DDMAE-50S DDMAE-50S-FO Dual Float 30µin. Gold Contacts DEMAY-9S DAMAY-15S DBMAY-25S DCMAY-37S DDMAY-50S Bushings Without Contacts DEMAY-9S-FO DAMAY-15S-FO DBMAY-25S-FO DCMAY-37S-FO DDMAY-50S-FO 4-40 Clinch Nuts 30µin. Gold Without Contacts Contacts DEMAE-9ST DEMAE-9ST-FO DAMAE-15ST DAMAE-15ST-FO DBMAE-25ST DBMAE-25ST-FO DCMAE-37ST DCMAE-37ST-FO DDMAE-50ST DDMAE-50ST-FO Dual Float 30µin. Gold Contacts DEMAY-9ST DAMAY-15ST DBMAY-25ST DCMAY-37ST DDMAY-50ST Bushings Without Contacts DEMAY-9ST-FO DAMAY-15ST-FO DBMAY-25ST-FO DCMAY-37ST-FO DDMAY-50ST-FO Tin-Plated Shell Mounting Holes 30µin. Gold Without Contacts Contacts DEMA-9ST DEMA-9ST-FO DAMA-15ST DAMA-15ST-FO DBMA-25ST DBMA-25ST-FO DCMA-37ST DCMA-37ST-FO DDMA-50ST DDMA-50ST-FO Positions 9 15 25 37 50 4 Crimp and Poke Machined Contacts • Will accommodate 20, 22, and 24 AWG wire. Ordering Information Contacts Description Pin Socket M39029/64-369 M39029/63-368 Call Toll Free: 1 (800) 323-9612 4-72 Meets all MIL-C-24308 Class G specifications. Offered in Crimp and Poke and Solder Cup and PCB vertical and right-angle. Offered in 9, 15, 25, 37, and 50 position plugs and sockets except right-angle (9 to 37 positions). Monoblock green diallyl phthalate insulator for improved electrical performance. See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel mounting specifications. MATERIALS ■ ■ ■ ■ ■ Insulator Material: Glass-filled diallyl phthalate (green) per MIL-M-14, Type SDG-F Connector Shell: Steel with cadmium plating and yellow chromate finish Contact Material: Plug - Brass (machined), Socket - Phosphor bronze (machined) Contact Plating: 50µin. gold over copper or nickel Dual Float Bushing: Stainless steel, passivated or non-magnetic brass ENVIRONMENTAL FEATURES D-subminiature Metal Shell MIL-C-24308 M24308 Series Operating Temperature: -65°C to + 125°C Shock: 50G peak per MIL-STD-202, Method 213, Condition G Vibration: 12 cycles in three perpendicular directions @ 10-2000Hz, per MIL-STD-202 Method 204, Condition D Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per MIL-STD-202, Method 103 ELECTRICAL Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: Minimum 1250V RMS @ sea level 5 Amps 2.7 milliohms maximum 5000 megohms maximum (initial); 1000 megohms (minimum) after MECHANICAL environmental testing Individual Contact Insertion and Separation Force (minimum/maximum): 0.7 oz./12 oz. Durability: 500 mating cycles Call Toll Free: 1 (800) 323-9612 4-74 D-subminiature Metal Shell MIL-C-24308 Crimp and Poke M24308 Series • • • Available with .120 mounting holes, float bushings, or dual float bushings. Order with contacts included or separately. Order with contact Insertion/Extraction Tool included or order tool #CIET-20-HD separately. See page 4-103. Ordering Information Crimp and Poke Plugs Steel Shell Contacts Included. Insertion/Extraction Tool Not Included. Positions Mounting Holes Float Bushings 9 M24308/4-1F M24308/4-302F 15 M24308/4-2F M24308/4-303F 25 M24308/4-3F M24308/4-304F 37 M24308/4-4F M24308/4-305F 50 M24308/4-5F M24308/4-306F Dual Float Bushings M24308/4-435F M24308/4-436F M24308/4-437F M24308/4-438F M24308/4-439F Contacts Included. Insertion/Extraction Tool Included. Positions Mounting Holes Float Bushings 9 M24308/4-6F M24308/4-313F 15 M24308/4-7F M24308/4-314F 25 M24308/4-8F M24308/4-315F 37 M24308/4-9F M24308/4-316F 50 M24308/4-10F M24308/4-317F Dual Float Bushings M24308/4-446F M24308/4-447F M24308/4-448F M24308/4-449F M24308/4-450F Contacts Not Included. Insertion/Extraction Tool Not Included. Positions Mounting Holes Float Bushings Dual Float Bushings 9 M24308/4-259F M24308/4-324F M24308/4-457F 15 M24308/4-260F M24308/4-325F M24308/4-458F 25 M24308/4-261F M24308/4-326F M24308/4-459F 37 M24308/4-262F M24308/4-327F M24308/4-460F 50 M24308/4-263F M24308/4-328F M24308/4-461F 4-75 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell MIL-C-24308 Crimp and Poke M24308 Series Ordering Information Crimp and Poke Sockets Steel Shell 4 Contacts Included. Insertion/Extraction Tool Not Included. Positions Mounting Holes Float Bushings 9 M24308/2-1F M24308/2-23F 15 M24308/2-2F M24308/2-24F 25 M24308/2-3F M24308/2-25F 37 M24308/2-4F M24308/2-26F 50 M24308/2-5F M24308/2-27F Dual Float Bushings M24308/2-342F M24308/2-343F M24308/2-344F M24308/2-345F M24308/2-346F Contacts Included. Insertion/Extraction Tool Included. Positions Mounting Holes Float Bushings 9 M24308/2-6F M24308/2-34F 15 M24308/2-7F M24308/2-35F 25 M24308/2-8F M24308/2-36F 37 M24308/2-9F M24308/2-37F 50 M24308/2-10F M24308/2-38F Dual Float Bushings M24308/2-353F M24308/2-354F M24308/2-355F M24308/2-356F M24308/2-357F Contacts Not Included. Insertion/Extraction Tool Not Included. Positions Mounting Holes Float Bushings Dual Float Bushings 9 M24308/2-281F M24308/2-292F M24308/2-482F 15 M24308/2-282F M24308/2-293F M24308/2-483F 25 M24308/2-283F M24308/2-294F M24308/2-484F 37 M24308/2-284F M24308/2-295F M24308/2-485F 50 M24308/2-285F M24308/2-296F M24308/2-486F Call Toll Free: 1 (800) 323-9612 4-76 D-subminiature Metal Shell MIL-C-24308 Crimp and Poke M24308 Series Ordering Information Tooling • Contact Insertion/Extraction Tool: #CIET-20-HD (Military #M81969/39-01). See page 4-103. • Wire termination hand tool: #M22520/2-01. See page 4-103. • Positioner for machine contacts for hand tool #M22520/2-08 (locates contact in the correct position). See page 4-103. Crimp and Poke Contacts Ordering Information • Will accommodate 20, 22, and 24 AWG wire. Description Pin Socket 4 M39029/64-369 M39029/63-368 4-77 Call Toll Free: 1 (800) 323-9612 D-subminiature Metal Shell MIL-C-24308 Solder Cup M24308 Series • • Available with .120" mounting holes, float bushings, or dual float bushings. Will accommodate up to 20 AWG wire. Ordering Information Solder Cup Plugs Steel Shell Positions 9 15 25 37 50 4 Mounting Holes M24308/3-1F M24308/3-2F M24308/3-3F M24308/3-4F M24308/3-5F Float Bushings M24308/3-12F M24308/3-13F M24308/3-14F M24308/3-15F M24308/3-16F Dual Float Bushings M24308/3-17F M24308/3-18F M24308/3-19F M24308/3-20F M24308/3-21F Brass Non-Magnetic Shell Positions Mounting Holes 9 M24308/7-1F 15 M24308/7-2F 25 M24308/7-3F 37 M24308/7-4F 50 M24308/7-5F Float Bushings M24308/7-12F M24308/7-13F M24308/7-14F M24308/7-15F M24308/7-16F Dual Float Bushings M24308/7-17F M24308/7-18F M24308/7-19F M24308/7-20F M24308/7-21F Mounting Holes M24308/1-1F M24308/1-2F M24308/1-3F M24308/1-4F M24308/1-5F Float Bushings M24308/1-12F M24308/1-13F M24308/1-14F M24308/1-15F M24308/1-16F Dual Float Bushings M24308/1-23F M24308/1-24F M24308/1-25F M24308/1-26F M24308/1-27F Brass Non-Magnetic Shell Positions Mounting Holes 9 M24308/5-1F 15 M24308/5-2F 25 M24308/5-3F 37 M24308/5-4F 50 M24308/5-5F Float Bushings M24308/5-12F M24308/5-13F M24308/5-14F M24308/5-15F M24308/5-16F Dual Float Bushings M24308/5-23F M24308/5-24F M24308/5-25F M24308/5-26F M24308/5-27F Solder Cup Sockets Steel Shell Positions 9 15 25 37 50 Call Toll Free: 1 (800) 323-9612 4-78 D-subminiature Metal Shell MIL-C-24308 PCB M24308 Series Right-Angle Right-Angle Connector 0.396 • • • • • .283" footprint requires minimal PCB space. 0.340 Available with three contact tail lengths (.127", .158", and .183") with .030" contact diameter. Available with two contact tail lengths (.127" and .183") with .040" contact diameter. Offered with .120" mounting holes. Mounting bracket: Black nylon. Can be removed if necessary. 0.283 See Chart 0.122 (2.84) Ordering Information Right-Angle PCB Plugs (Sockets not available) Steel Shell .127 Tail Length .158 Tail Length .183 Tail Length .127 Tail Length .183 Tail Length Positions .030 Contact Diameter .030 Contact Diameter .030 Contact Diameter .040 Contact Diameter .040 Contact Diameter 9 M24308/24-25F M24308/24-31F M24308/24-49F M24308/24-37F M24308/24-55F 15 M24308/24-26F M24308/24-32F M24308/24-50F M24308/24-38F M24308/24-56F 25 M24308/24-27F M24308/24-33F M24308/24-51F M24308/24-39F M24308/24-57F 37 M24308/24-28F M24308/24-34F M24308/24-52F M24308/24-40F M24308/24-58F Vertical Vertical Connector • • 4 Available with two contact tail lengths (.158" and .183") and two contact diameters (.030" and .040"). Offered with .120" mounting holes. Ordering Information Vertical PCB Plugs Steel Shell .158 Tail Length .183 Tail Length .158 Tail Length .183 Tail Length Positions .030 Contact Diameter .030 Contact Diameter .040 Contact Diameter .040 Contact Diameter 9 M24308/24-1F M24308/24-7F M24308/24-13F M24308/24-19F 15 M24308/24-2F M24308/24-8F M24308/24-14F M24308/24-20F 25 M24308/24-3F M24308/24-9F M24308/24-15F M24308/24-21F 37 M24308/24-4F M24308/24-10F M24308/24-16F M24308/24-22F 50 M24308/24-5F M24308/24-11F M24308/24-17F M24308/24-23F Vertical PCB Sockets Steel Shell .158 Tail Length .183 Tail Length .158 Tail Length .183 Tail Length Positions .030 Contact Diameter .030 Contact Diameter .040 Contact Diameter .040 Contact Diameter 9 M24308/23-1F M24308/23-7F M24308/23-13F M24308/23-19F 15 M24308/23-2F M24308/23-8F M24308/23-14F M24308/23-20F 25 M24308/23-3F M24308/23-9F M24308/23-15F M24308/23-21F 37 M24308/23-4F M24308/23-10F M24308/23-16F M24308/23-22F 50 M24308/23-5F M24308/23-11F M24308/23-17F M24308/23-23F 4-79 Call Toll Free: 1 (800) 323-9612 D-subminiature Backshells/Junction Shells/Hoods Accessories FEATURES Cinch backshells are offered in a variety of styles, each having a specific strength. • Backshells have two-piece construction and are frequently used where appearance is a major factor. RFI/EMI shielding capability is also an option: - Plastic Backshells: No shielding. - Metallized Plastic: Economical method of shielding. - Diecast Backshells: Maximum shielding. • Cinch SDH Series backshells utilize Cinch’s Latch-N-Lock™ system with quick release disconnect. Just squeeze the latch levers to release the connector. Also available with standard 4-40 mounting hardware. • Junction Shells come in a variety of sizes and shapes including right-angle and low profile. They are generally of one-piece construction with an adjustable clamp, but there is no shielding. • Hoods have an improved appearance versus junction shells but no shielding. They are all-plastic and come in right-angle or straight configurations. • Hardware, in the form of adjustable grommets or strain relief clamps and 4-40 screws, is generally supplied with the product; however, a variety of optional hardware is also available in the accessories section of this catalog. Call Toll Free: 1 (800) 323-9612 4-80 D-subminiature Backshells/Junction Shells/Hoods Accessories The following is a summary of the various backshells, junction shells, and hoods that Cinch offers: Backshells Type Material Series 2-Piece Plastic DPH Shell Sizes* EABC Cable Exit 180° Fits Connector Series marked with “•”: D*A Series • HTD Series • D*U Series • Series 3 • T Series Metal Shell • T Series All-Plastic Basic D • Series 1 • 2-Piece 2-Piece Metallized Diecast DCH DMH EABCD EABCD 180° 180° • • • • • • • • • • 2-Piece Diecast Ethernet Black Plastic Gray Plastic SDH - B SDH - G A EABC EABC 90°/180° Super-D Connection System 90°/180° • • • • • • • • 90°/180° • • • • • • • • • Junction Shells/Hoods Junction Shells Straight Round Clamp Clamp Metal Metal Type Material Hoods Rt. Angle Deep Straight Switching Clamp Metal Clamp Metal Shell Sizes* ABCD ABCD EABCD EABCD Cable Exit 180° 180° 90° 180° Fits Connector Series marked with “•”: D*A Series • • • • D*U Series • • • • Series 3 • • • • T Series Metal Shell • • • • T Series All-Plastic Basic D Series • • • • Series 1 • • • • Shell Metal Phenolic Straight Rt. Angle Plastic Plastic Plastic ABCD AB EAB AB 180° 180° 180° 90° • • • • • • • • • • • • • • • • • • • • • • • • *Conversion Chart between Standard Density Connectors and HPD/HTD Series 1.5 Density Connectors Shell Size E A B C D Standard D-sub 9 15 25 37 50 1.5 D-Sub HTD 15 26 44 62 N/A 4-81 Call Toll Free: 1 (800) 323-9612 D-subminiature Backshells - Two-Piece D*H Series • • • • • • • Standard two-piece construction available in plastic, metallized plastic, or diecast zinc versions with 180° straight cable entry. Fits standard metal shell D-subminiature plugs and sockets as well as HTD Series 1.5 D-subs. Ethernet hoods are available in diecast 15 position versions only with both 90° and 180° cable entry. Included in all backshells: - Hardware: 4-40 screws, hex nuts, 4-40 screw mounting bracket. - Grommets: To accommodate most cable sizes. Grommets also function as strain reliefs. Backshells are individually bagged. Note that slide locks may not be used with these backshells. Optional thumbscrew for backshell must be ordered separately if required. Materials • • • 4-40 screws, hex nuts, mounting bracket: Steel with zinc plating and clear chromate coating. Standard Backshells: - Plastic Backshells: ABS (black), hardware - steel with zinc plating, grommets - polyphenylene, (black). - Metallized Plastic Backshells: ABS with nickel over copper plating, hardware - steel with zinc plating, grommets - PVC (black). - Diecast Backshells: Diecast zinc, grommets - PVC (black). Ethernet Backshells: Diecast zinc, grommets - PVC (black). 4 Plastic Metallized Ethernet Straight Call Toll Free: 1 (800) 323-9612 Diecast Ethernet Right-Angle 4-82 D-subminiature Backshells - Two-Piece D*H Series Straight (180°) Standard Backshells Plastic and Metallized Plastic Backshells Dimensions Shell Size E A B C D A in 1.225 1.540 2.090 2.730 2.645 B mm 31.12 39.12 53.09 69.34 67.18 in 1.547 1.516 1.655 1.830 1.855 mm 39.29 38.51 42.04 46.48 41.12 C in 0.640 0.640 0.710 0.906 0.940 D mm 16.26 16.26 18.03 23.01 23.88 4-83 in 0.645 0.645 0.645 0.645 0.750 mm 16.38 16.38 16.38 16.38 19.05 E in mm 0.400 10.16 0.400 10.16 0.522 13.26 0.725 18.42 0.725 18.42 F in 0.984 1.312 1.857 2.500 2.406 mm 24.99 33.32 47.17 63.50 61.11 Call Toll Free: 1 (800) 323-9612 4 D-subminiature Backshells - Two-Piece D*H Series EMI/RFI Shielded Diecast Backshells 4 Dimensions Shell Size in A mm in B mm C E A B C D 1.225 1.540 2.090 2.730 2.624 31.12 39.12 53.09 69.34 66.65 1.465 1.600 1.570 1.810 1.800 37.21 40.64 39.88 45.97 45.72 in 0.620 0.620 0.690 0.862 0.862 D E F mm in mm in mm in mm 15.75 15.75 17.53 21.89 21.89 0.620 0.620 0.620 0.620 0.730 15.75 15.75 15.75 15.75 18.54 0.400 0.400 0.525 0.725 0.725 10.16 10.16 13.34 18.42 18.42 0.984 1.312 1.857 2.500 2.406 24.99 33.32 47.17 63.50 61.11 Ordering Information D*H Two-Piece Backshells Fits Shell Standard Size Density Fits HTD 1.5 Density Cable Entry Style Plastic Cable Dia. (in) Metallized Plastic Cable Dia. (in) Diecast Metal Cable Dia. (in) E 9 15 Straight (180°) DPH-E-001 .210-.320 DCH-E-001 .210-.350 DMH-E-001 .210-.320 A 15 26 Straight (180°) DPH-A-001 .210-.320 DCH-A-001 .210-.350 DMH-A-001 .210-.320 B 25 44 Straight (180°) DPH-B-001 .230-.450 DCH-B-001 .230-.450 DMH-B-001 .230-.450 C 37 62 Straight (180°) DPH-C-001 .350-.650 DCH-C-001 .350-.640 DMH-C-001 .350-.650 D 50 N/A Straight (180°) DPH-D-001 .350-.650 DCH-D-001 .350-.640 DMH-D-001 .350-.640 Call Toll Free: 1 (800) 323-9612 4-84 D-subminiature Backshells - Two-Piece D*H Series Straight (180°) Diecast Ethernet Backshells Right-Angle (90°) Diecast Ethernet Backshells 4 Ordering Information D*H Ethernet Diecast Backshells Fits Shell Size A A Fits Standard Cable Cable Entry Density Diameter (in) Style 15 .210-.320 Straight (180°) DMH-A-001XL 15 .210-.320 Rt. Angle (90°) DMH-A-901X A in mm 1.550 39.37 1.550 39.37 B in mm 1.880 47.75 1.880 47.75 C in mm 0.710 18.03 0.710 18.03 D in mm 0.64 16.26 0.64 16.26 E in mm 0.522 13.26 0.522 13.26 F in mm 1.312 33.32 1.312 33.32 THUMBSCREWS (OPTIONAL) FOR D*H BACKSHELLS Order #4-40-THMB-1 (two each required per backshell). (Will not work with ethernet type backshells) 4-85 Call Toll Free: 1 (800) 323-9612 MATERIALS FEATURES D-subminiature Backshells - Super D SDH Series ■ The Cinch Super D Interconnection System is a simple, fast, economical, and reliable way for mating connectors from cable to cable or cable to panel. ■ Snap-on Super D plastic hoods captivate connectors providing positive, self-latching, audible mating with reliable retention and Latch-N-Lock quick release disconnect. ■ Snap-on Super-D plastic hoods are also available with filler ends to utilize 4-40 mounting hardware. ■ Super D hoods are available: - Straight (180°) or Right-Angle (90°) cable entry. - Sizes: 9, 15, 25, and 37. - Sizes 15, 25, and 37 are available in standard or large cable openings. ■ Black SDH backshells accommodate any standard metal shell IDC, solder cup, or crimp and poke D-subminiature connector. ■ Gray SDH backshells accommodate the Cinch All-Plastic IDC T-Series connector on pages 4-38 thru 4-39. ■ Each Super-D plastic hood includes a stay band to strain relief the cable wire. Stay band tool SD-MSBT is required. Extra stay bands are available on page 4-90. Hood: Modified phenylene oxide - black for metal shell connectors or gray for all-plastic IDC connectors Latch Block: Diecast zinc Screws for Latching Blocks: Steel with nickel plating Stay Band: Steel with zinc plating and clear chromate finish Call Toll Free: 1 (800) 323-9612 4-86 D-subminiature Backshells - For use with Metal Shell Connectors SDH Series Straight (180°) Cable Entry Black Backshells for Metal Shell Connectors Adapter Hood with Latches Adapter Hood with Filler Ends Right-Angle (90°) Cable Entry Black Backshells for Metal Shell Connectors Right-Angle Adapter Hood 4 Dimensions Positions 9 15 25 37 A + .020" in 1.47 1.80 2.35 2.99 (.58mm) mm 37.34 45.72 59.69 75.95 B +.020" in .31 .31 .33 .37 (.58mm) mm 7.87 7.87 8.40 9.40 C +.020" (.58mm) in mm .41 10.41 .47 11.94 .50 12.70 4-87 D +.020" in 1.94 2.25 2.94 3.59 (.58mm) mm 49.21 57.15 74.61 91.28 E+.020" in 1.25 1.34 1.50 1.53 (.58mm) mm 31.75 34.13 38.10 38.89 Call Toll Free: 1 (800) 323-9612 D-subminiature Backshells - For use with Metal Shell Connectors SDH Series Ordering Information Straight (180°) Cable Entry Black Backshells for Metal Shell Connectors Latches Standard Large Positions Cable Opening Cable Opening 9 SDH-9BL N/A 15 SDH-15BL SDH-15BLL 25 SDH-25BL SDH-25BLL 37 SDH-37BL SDH-37BLL Filler Ends Standard Large Cable Opening Cable Opening SDH-9BF N/A SDH-15BF SDH-15BFL SDH-25BF SDH-25BFL SDH-37BF SDH-37BFL Filler Ends w/4-40 Screws Standard Large Cable Opening Cable Opening SDH-9BFCS N/A SDH-15BFCS SDH-15BFLCS SDH-25BFCS SDH-25BFLCS SDH-37BFCS SDH-37BFLCS Right-Angle (90°) Cable Entry Black Backshells for Metal Shell Connectors Ordering Information 4 Standard Cable Positions Opening 9 SDH-9RBL 15 SDH-15RBL 25 SDH-25RBL 37 SDH-37RBL Latches Large Cable Opening N/A SDH-15RBLL SDH-25RBLL SDH-37RBLL Latching Blocks for Super D Adapter System Ordering Information Description Latching Block Latching Block with SEM Screws Removable Mounting Screws for Adapter Hood Latching Block with SEM Screws Latching Block with SEM Screws For Panel Thickness N/A Up to .060" Qty per pack 1 each 2 each N/A .060" to .080" .080” to .125" Call Toll Free: 1 (800) 323-9612 1 each 2 each 2 each 4-88 Qty Required Per SDH Hood 2 each 2 each 2 each 2 each 2 each Catalog Number SD-LB SD-LB-060 4-40UNC2AX3/4 SD-LB-060-080 SD-LB-125 D-subminiature Backshells - Gray with All-Plastic Connectors SDH Series • Fits only T Series All-Plastic IDC connector on pages 4-38 thru 4-39. Straight (180°) Cable Entry Gray Backshells for All-Plastic Connectors Dimensions Positions 9 15 25 37 A +.020" (.58mm) in mm 1.47 37.34 1.80 45.72 2.35 59.69 2.99 75.95 B +.020" in .31 .31 .33 .37 (.58mm) mm 7.87 7.87 8.40 9.40 C +.020" (.58mm) in mm ----.41 10.41 .47 11.94 .50 12.70 4 Ordering Information Straight (180°) Cable Entry Gray Backshells for All-Plastic Connectors Latches Standard Large Positions Cable Opening Cable Opening 9 15 25 37 SDH-9GL SDH-15GL SDH-25GL SDH-37GL N/A SDH-15GLL SDH-25GLL SDH-37GLL Filler Ends Standard Large Cable Opening Cable Opening SDH-9GF SDH-15GF SDH-25GF SDH-37GF 4-89 N/A SDH-15GFL SDH-25GFL SDH-37GFL Filler Ends w/4-40 Screws Standard Large Cable Opening Cable Opening SDH-9GFCS SDH-15GFCS SDH-25GFCS SDH-37GFCS N/A SDH-15GFLCS SDH-25GFLCS SDH-37GFLCS Call Toll Free: 1 (800) 323-9612 D-subminiature Backshells - Gray use with All-Plastic Connectors SDH Series Right-Angle (90°) Cable Entry Gray Backshells for All-Plastic Connectors • Fits only IDC connectors on pages 4-38 thru 4-39. Dimensions Positions 9 15 25 37 A +.020" (.58mm) in mm 1.94 49.21 2.25 57.15 2.94 74.61 3.59 91.28 B +.020" in .31 .31 .33 .37 (.58mm) mm 7.87 7.87 8.40 9.40 C +.020" (.58mm) in mm ---.41 10.41 .47 11.94 .50 12.70 D +.020" in 1.25 1.34 1.50 1.53 Ordering Information 4 Right-Angle (90°) Cable Entry Gray Backshells for All-Plastic Connectors Standard Cable Positions Opening 9 SDH-9RGL 15 SDH-15RGL 25 SDH-25RGL 37 SDH-37RGL Latches Large Cable Opening N/A SDH-15RGLL SDH-25RGLL SDH-37RGLL Ordering Information Accessories for Gray Backshells Positions 9 15 25 37 Optional Additional Strain Reliefs* Stay Bands** SD-WC9 SD-9-15-SB SD-WC15 SD-9-15-SB SD-WC25 SD-25-37-SB SD-WC37 SD-25-37-SB * Two each required per backshell. ** Stay band tool #SD-MSBT required. See page 4-100.. Screw for screwlocking connector assembly - (2 each required): 4-40UNC2AX3/4. See page 4-85 for latch block drawing. Call Toll Free: 1 (800) 323-9612 4-90 (.58mm) mm 31.75 34.13 38.10 38.89 MATERIALS D-subminiature Junction Shells ■ Shell Material: Zinc-plated low carbon steel with yellow chromate finish. ■ Clamp: Zinc-plated steel with yellow chromate finish. ■ Screw: Zinc-plated steel with yellow chromate finish. ■ Stop Nut: Zinc-plated brass with yellow chromate finish. Straight Clamp E Shell Size A B C D A Positions in 15 1.531 25 2.078 37 2.718 50 2.625 B mm 38.89 52.78 69.04 66.68 in .500 .500 .500 .609 mm 38.89 52.78 in .500 .500 mm 30.56 38.89 52.78 69.04 66.68 in 0.718 0.718 0.968 1.187 1.250 C mm 12.70 12.70 12.70 15.47 in 1.312 1.852 2.500 2.406 mm 12.70 12.70 in 1.312 1.852 mm 18.24 18.24 24.59 30.15 31.75 in .984 1.312 1.852 2.500 2.406 mm 33.32 47.04 63.50 61.11 E in .296 .296 .296 .390 mm 7.52 7.52 7.52 9.91 F in mm .312 7.92 .796 20.22 .687 17.45 .687 17.45 in .640 .640 .640 .703 G mm 10.31 15.06 E in mm .984 23.72 1.515 38.48 in .125 .187 mm 16.26 16.26 16.26 17.86 Round Clamp Shell Size A B A Positions in 15 1.531 25 2.078 B C mm 33.32 47.04 D in .406 .593 F mm 3.18 4.75 G in mm 1.031 26.19 1.062 26.97 Right-Angle Clamp Shell Size E A B C D A Positions in 9 1.203 15 1.531 25 2.078 37 2.718 50 2.625 B Call Toll Free: 1 (800) 323-9612 C mm 24.99 33.32 47.04 63.50 61.11 4-92 E in .437 .437 .437 .437 .562 F mm 11.10 11.10 11.10 11.10 14.27 in .437 .437 .625 .812 .906 G mm 11.10 11.10 15.88 20.62 23.01 in .468 .468 .468 .468 .531 H mm 11.89 11.89 11.89 11.89 13.49 in .281 .281 .281 .281 .343 mm 7.14 7.14 7.14 7.14 8.71 D-subminiature Junction Shells Deep Straight Clamp F ± .015 Shell Size E A B C D A Positions 9 15 25 37 50 in 1.203 1.531 2.078 2.718 2.625 B mm 30.56 38.89 52.78 69.04 66.68 in .484 .484 .484 .484 .593 mm 12.29 12.29 12.29 12.29 15.06 C in 0.984 1.312 1.852 2.500 2.406 mm 24.99 33.32 47.04 63.50 61.11 in .578 .578 .578 .578 .687 D mm 14.68 14.68 14.68 14.68 17.45 E in .375 .713 1.000 1.375 1.406 mm 9.53 18.11 25.40 34.93 35.71 F in .375 .312 .312 .312 .406 G mm 9.53 7.92 7.92 7.92 10.31 in .750 .750 1.000 1.000 1.125 H mm 19.05 19.05 25.40 25.40 28.58 in 1.219 1.250 1.531 1.531 1.656 mm 30.96 31.75 38.89 38.89 42.06 Switching Shell Shell Size A B C D A Positions 15 25 37 50 in 1.531 2.078 2.718 2.625 mm 38.89 52.78 69.04 66.68 B in .500 .500 .500 .609 C mm 12.70 12.70 12.70 15.47 in 1.312 1.852 2.500 2.406 mm 33.32 47.04 63.50 61.11 Ordering Information Junction Shells - Metal Shell Size E A B C D Fits Standard Density 9 15 25 37 50 Straight Clamp N/A DA-19678-1 DB-19678-2 DC-19678-3 DD-19678-4 Round Clamp N/A DA-20961 DB-20962 N/A N/A Right-Angle Clamp DE-19977-5 DA-19977-1 DB-19977-2 DC-19977-3 DD-19977-4 4-93 Deep Straight Clamp DE-24657 DA-24658 DB-24659 DC-24660 DD-24661 Switching Shell N/A DA-19678-6 DB-19678-7 DC-19678-8 DD-19678-9 Call Toll Free: 1 (800) 323-9612 D-subminiature Plastic Hoods Phenolic Hood Shell Material: Phenolic (black). #4-40 Screws: Steel with nickel plating. Shell Size A B A Positions in 15 1.297 25 1.406 B mm 32.94 35.71 in 1.219 1.797 C mm 30.96 45.64 in .266 .328 D mm 6.76 8.33 in 1.312 1.852 mm 33.32 47.04 E in mm 1.641 41.68 2.203 55.96 All-Plastic Straight (180°) Hood Shell Material: Nylon (gray). #4-40 Screws: Steel with nickel plating. Connector Not Included Shell Size E A B A Positions in 9 1.218 15 1.546 25 2.093 B mm 30.94 38.27 53.16 in 1.000 1.000 1.250 C mm 25.40 25.40 31.75 in .984 1.312 1.852 D mm 23.72 33.32 47.04 in .500 .500 .500 mm 12.70 12.70 12.70 E in mm .562 14.27 .562 14.27 .562 14.27 in .281 .360 .493 F E in mm .562 14.28 .562 14.28 in .360 .360 mm 7.14 9.14 12.52 All-Plastic Right-Angle (90°) Hood Shell Material: Nylon (gray). #4-40 Screws: Steel with nickel plating. Connector Not Included Shell Size A B A Positions in 15 1.822 25 2.368 B mm 46.28 60.15 in 1.000 1.250 C mm 25.40 31.75 in 1.312 1.852 D mm 33.32 47.04 in .500 .500 Ordering Information Plastic Hoods Shell Size E A B C D Standard Density 9 15 25 37 50 Phenolic Hood N/A DA-51225-1 DB-51226-1A N/A N/A Call Toll Free: 1 (800) 323-9612 Straight Hood DE-51218-1 DA-51210-1 DB-51212-1 N/A N/A Right Angle N/A DA-51211-1 DB-51213-1 N/A N/A 4-94 mm 12.70 12.70 F mm 9.14 9.14 in .218 .360 .360 G mm 7.14 9.14 9.14 D-subminiature Accessories Dust Caps • • • For use with all Cinch D-subminiature connectors. Used to protect connector contacts when connector is not mated. Made of polyethylene (black). Ordering Information Fits Shell Size E E A A B B C C D D Fits Standard Density Catalog No. Description 9 DE-59-20 Socket 9 DE-60-20 Plug 15 DA-59-20 Socket 15 DA-60-20 Plug 25 DB-59-20 Socket 25 DB-60-20 Plug 37 DC-59-20 Socket 37 DC-60-20 Plug 50 DD-59-20 Socket 50 DD-60-20 Plug A in .694 .749 1.022 1.077 1.562 1.635 2.210 2.283 2.116 2.179 B mm 17.63 19.02 25.95 27.36 39.67 41.52 56.13 57.99 53.75 55.35 in .627 .682 .955 1.010 1.495 1.568 2.143 2.216 2.049 2.112 C mm 15.93 17.32 24.25 25.65 37.97 39.83 54.43 56.29 52.04 53.64 in .362 .412 .362 .412 .362 .430 .362 .430 .474 .536 D in mm .295 7.49 .345 8.76 .295 7.49 .345 8.76 .295 7.49 .363 9.22 .295 7.49 .363 9.22 .407 10.34 .469 11.91 mm 9.19 10.46 9.19 10.46 9.19 10.92 9.19 10.92 12.04 13.61 Guide Pin Plates • Aligns connectors before actual mating. Generally used in blind mate applications. • • • • Male or female guide plates will accommodate Cinch male or female connectors. Plate: Cold-rolled steel with cadmium plating and yellow chromate finish. Guide pin (male): Stainless steel, passivated. Screws, rivets (male plate), washers (male plate): Steel with cadmium plating and yellow chromate finish. Socket Plug Ordering Information Fits Shell Standard Size Density A Plug Socket N/A N/A in mm in B mm C in D mm in F mm in mm in G mm K in mm E 9 A 15 DA-22213 DA-22214 2.281 57.93 1.000 25.40 1.312 33.32 .750 19.05 .898 22.81 1.663 42.24 1.906 48.41 B 25 DB-22255 DB-22254 2.820 71.63 1.000 25.40 1.852 47.04 .750 19.05 1.168 29.67 2.203 55.96 2.446 62.13 C 37 DC-22070 DC-22071 3.468 88.09 1.000 25.40 2.500 63.50 .750 19.05 1.492 37.90 2.851 72.42 3.094 78.59 D 50 DD-21962 DD-21961 3.375 85.73 1.125 28.58 2.406 61.112 .874 21.88 1.437 36.50 2.749 69.82 3.000 76.20 Call Toll Free: 1 (800) 323-9612 4-96 D-subminiature Accessories Slide Lock Assemblies • A slide lock assembly is a metal bracket offered with hardware necessary to mount into the standard connector mounting holes. It consists of the lock retainer plate, two screws, two washers, and two nuts. Two lock posts are required to fit into the mounting holes of the mating connector. These must be ordered separately. • Compatible with all Cinch Backshells, Hoods, and Junction Shells except D*H Series, SDH Series, and phenolic hood. • Compatible with all Cinch metal shell D-subminiature connectors. Materials • Slide Lock Plate: Stainless steel, passivated. • • Slide lock hex nut, washer #4-40 screw: Steel with zinc plating and yellow chromate finish. Lockpost, washer, lockwasher, and hex nut: Steel with zinc plating and yellow chromate finish. .145 Consists of Lock Retainer and two lock posts (order separately). NOTE: Not compatible with D*H Series or SDH Series backshells. Ordering Information Shell Size E A B C D Fits Standard Density 9 15 25 37 50 Lock Retainer DE-51224-1 DA-51220-1 DB-51221-1 DC-51222-1 DD-51223-1 A in 1.442 1.770 2.293 2.958 2.847 B mm 36.63 44.96 58.24 75.13 72.31 in .500 .500 .500 .500 .609 C mm 12.70 12.70 12.70 12.70 15.47 in 0.984 1.312 1.852 2.500 2.406 mm 24.99 33.27 47.04 63.50 62.48 Lock Post: #D53018. Two (2) required with each Slide Lock Assembly. 4-97 Call Toll Free: 1 (800) 323-9612 4 D-subminiature Hardware Accessories Screwlocks • • • • • Screwlocks are designed to retain the same size mated connectors together or to secure the connector to a rack/panel. Screwlocks may be used on plugs or sockets. Female screwlocks consist of one #4-40 screw with a #4-40 hole in the top, two flat washers to accommodate different panel thicknesses, one lockwasher, and one #4-40 nut. Military female screwlocks include three flat washers. Male screwlocks consist of one #4-40 slotted screw and a spring tension clip. Different sizes accommodate the various connector flange sizes and types of backshells or hoods (if applicable). Two screwlocks are required per connector. Military screwlocks meet all requirements of MIL-C-24308. Materials Commercial Screwlock Assemblies: • Male Screwlock Assembly: Clip and screw are steel with zinc plating and yellow chromate finish. • Female Screwlock Assembly: Washers (2), lockwashers, hex nuts, and nuts are steel with zinc plating and yellow chromate finish. M24308 Military Screwlock Assemblies: • Male Screwlock Assembly: Clip and screw are steel with cadmium plating and yellow chromate finish. • Female Screwlock Assembly: Washers (3), lockwashers, hex nuts, and nuts are steel with cadmium plating and yellow chromate finish. 4 Female Screwlock Call Toll Free: 1 (800) 323-9612 Male Screwlock 4-98 D-subminiature Accessories • Screwlock assemblies will not fit D*H or SDH Series backshells. Male Screwlocks Ordering Information Shell Size Positions Commercial: D20419-0 D20419-16 D20419-21 D20420-0 D20420-12 D20420-15 A B in mm in mm 0.250 0.250 0.281 0.250 0.281 0.281 56.35 56.35 63.34 56.35 63.34 63.34 0.033 0.048 0.059 0.033 0.048 0.059 0.84 1.22 1.50 0.84 1.22 1.50 Military MIL-C-24308: M24308/25-9F Per MIL spec M24308/25-10F Per MIL spec E 9 A 15 B 25 C 37 P/S S* P/S S* P* S P/S* P* S P/S* D 50 S P/S* P* P/S P/S P/S P/S P/S NOTE: P = Plug, S= Socket * Indicates use with junction shell Female Screwlocks Ordering Information Shell Size Positions in A E 9 A 15 B 25 C 37 D 50 P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S P/S mm Commercial: D20418-2 D20418-39 0.312 0.628 Military MIL-C-24308: M24308/26-1F M24308/26-2F Per MIL spec Per MIL spec 70.32 141.55 NOTE: P = Plug, S= Socket 4-99 Call Toll Free: 1 (800) 323-9612 4 D-subminiature IDC Termination Tools Auto-Clinch™ D Semi-Automatic Termination Tool Auto Clinch D is a semi-automatic, pneumatically powered, and electrically controlled termination machine designed to terminate IDC D-subminiature connectors. It employs a selective programmer and a common nest for all four connector sizes and can be equipped to terminate metal shell connectors. It can also be optionally equipped with remote visual color code display for training sequences. It has a provision for omission of wires. Auto-Clinch D Tool Part No.: ACD-432 Certi-Clinch™ D Field Termination Tool *For 24-26 AWG Wire Certi-Clinch D is designed for mass termination of individual wires, eliminating wire stripping, soldering, and crimping. It handles all four connector sizes, is readily portable, and requires no set-up time and little operator time. Rugged, all-metal construction affords trouble-free long life. For metal shell IDC D-subminiature connectors. Part No. SD-CCWN Certi-Clinch D Field Termination Tool For all-plastic IDC D-subminiature connectors. Part No. SD-CC Conversion nest for converting all-plastic type to metal shell. Part No. SD-CCN Uni-Clinch™ D Single-Wire Hand Insertion Tool Designed to insert one 22-26 AWG wire at a time, Uni-Clinch D is used as a field repair tool by field service engineers. Part No. SD-UC Uni-Clinch Hand Insertion Tool Super D™ Manual Stay Band Tool Designed for applying the steel stay band/strain relief to the cable before termination of wires to the connector, the manual Stay Band Tool applies both stay band sizes to the full range of cable sizes. Part No. SD-MSBT Manual Tool NOTE: All termination tools on this page are used in conjunction with T* Series D-subminiature connectors. Call Toll Free: 1 (800) 323-9612 4-100 Crimp and Poke Termination Tools D-subminiature Hand Crimping Tool for Stamped Contact 300 PC Reels Two types of transport for connector chains are available with crimping ranges of 20 through 30 AWG for B crimpings Part Number D*A Series 20 through 26 AWG Wire GHC-B D*A Series 28 through 30 AWG Wire GHC-B1 HTD Series HTD-266 Contact Crimp Hand Tool (300 Contact Reel) Hand Crimping Tool for Loose Stamped Contacts D*A Series D*U Series HTD Series Part Number HTD-544 BT-20-HC HTD-544 Contact Crimp Hand Tool (HTD-544) Contact Insertion/Extraction Tool for Stamped Contacts D*A Series D*U Series HTD Series Part Number CIET-20-HDB CIET-20-HDB CIET-22-DF Contact Insertion/Extraction Hand Tool For D*A and D*U Series for Stamped Contacts (CIET-20-HDB) Contact Crimp Hand Tool (BT-20-HC) Contact Insertion/Extraction Hand Tool For D1/2 Contacts (CIET-22-DF) 4-101 Call Toll Free: 1 (800) 323-9612 Crimp and Poke Termination Tools D-subminiature Semi-Automatic Stripping and Crimping Tool Advantages and Characteristics • Stripping and crimping in one easy operation • Easy to install and adjust • Requires little maintenance • Wearing parts replaced in a matter of minutes • Long service life thanks to best-quality materials • Different quick change applicators in the same stripper crimper • Increased productivity Our GSC-20-30 crimp machine in operation with stripper crimper and quick change tool Ordering Information Stripper Crimper 4 Description D*A Series Stripper Crimper Only D*A Series Applicator Only For 20-24 AWG D*A Series Applicator Only For 26-30 AWG HTD Series Stripper Crimper Only HTD Series Applicator Only 22-28 AWG D*U Series Stripper Crimper Only D*U Series Applicator Only 20-28 Part Number 599-11-11-578 598-98-97-630 598-98-97-632 599-11-11-518 598-98-97-636 599-11-11-258 598-98-97-638 Comments Comes equipped with the applicator for 20-24 AWG contacts Applicator only For 20-24 AWG contacts Applicator only For 26-30 AWG contacts Comes equipped with applicator for 22-28 AWG contacts Applicator only For 22-28 AWG contacts Comes equipped with applicator for 20-28 AWG contacts Applicator only For 20-28 AWG contacts Stripper Crimper Spare Parts Part Number 598-98-97-631 598-98-97-633 598-98-97-637 598-98-97-639 598-98-97-640 598-98-97-641 598-98-97-642 598-98-97-643 598-98-97-644 598-98-97-645 Description D*A Punch & Anvil Kit 20-24 AWG D*A Punch & Anvil Kit 26-30 AWG HTD Series Punch & Anvil Kit D*U Series Punch & Anvil Kit Stripping Blades for 20-24 AWG Wire Stripping Blades for 26-30 AWG Wire D*A Series Contact shear blade Shear blade holder Sensor switch Strip blade holder Call Toll Free: 1 (800) 323-9612 Catalog Number SCPA-631 SCPA-633 SCPA-637 SCPA-639 SCSB-640 SCSB-641 SCCS-642 SCSH-643 SCSS-644 SCBH-645 4-102 Catalog Number GSC-20-30 ASC-20-24 ASC-26-30 HTD-518 ASC-DH ESC-20-3 ASC-DU D-subminiature Crimp and Poke Termination Tools Metal Shell High-Reliability Crimp and Poke Termination Tool Hand crimping tool for high-reliability machined D*U, Series 3, and M24308 Crimp and Poke contacts. M22520/2-01 M22520/2-01 NOTE: Positioner required with crimping tool Metal Shell Military Crimp and Poke Insertion/Extraction Tool Positioner--A device when attached to a crimping tool that locates the contact in the correct position. Positioner for machined contacts D*U Series Positioner Part No.: 599-11-11-580 Catalog No.: EP-580 Series 3 and M24308 Connector Positioner Part No.: 598-98-97-618 Catalog No.: M22520/2-08 For inserting or extracting machined D*U, Series 3, or M24308 Crimp and Poke contacts. Part No.: CIET-20-HD CIET-20-HD Military Extraction Tip Only For extracting high-reliability machined D*U, Series 3, or M24308 Crimp and Poke contacts. Part No.: CET-20-11 4 CET-20-11 Crimp Ferrule Coaxial and High-Voltage Contact Extraction Tool For extracting co-axial and high-voltage contacts from metal shell high-reliability connectors. Part No.: CET-C6B CET-C6B Pneumatic Bench Top Press for Crimping Ferrules This lightweight, portable press is used to crimp the ferrules on the overmold shielding hardware kits. Crimp dies ordered separately. FCT-551 Part No.: 599-11-11-551 Catalog No.: FCT-551 Hand Tool for Crimping Ferrules and Coax Contacts Uses same crimp dies as pneumatic tool. Part No.: 599-11-11-552 Catalog No.: FCT-552 Catalog Number CF-51 CF-42 CF-43 CF-44 CF-45 CF-46 CF-47 CF-50 Part Number Type 462-44-22-451 1 462-44-22-442 1 462-44-22-443 1 462-44-22-444 1 462-44-22-445 1 462-44-22-446 1 462-44-22-447 2 462-44-22-450 2 Crimp Die Part No. 598-98-97-607 598-98-97-600 598-98-97-601 598-98-97-602 598-98-97-603 598-98-97-604 598-98-97-605 598-98-97-606 FCT-552 4-103 Call Toll Free: 1 (800) 323-9612 Crimp Die Catalog No. CD-07 CD-00 CD-01 CD-02 CD-03 CD-04 CD-05 CD-06 DURA-CON All-Plastic Strip Connectors Metal Shell Mil-C-83513 Connectors Terminal Blocks Microedge .050" D-microminiature Dura-Con Introduction Cinch Dura-ConTM connectors are designed for applications that require a rugged, durable, and high-performance interconnect. Dura-Con is the ideal connector for applications where weight and space must be kept to a minimum while maintaining maximum reliability. Miniaturized airborne electronics and data processing equipment, where shorter signal paths are needed, represent typical applications for these unique connectors. The heart of the Dura-Con system is the Dura-Con pin contact. The Cinch Dura-Con pin contact is made from a precision miniature spring cable with a welded tip. The expanded cable provides seven spring members peripherally around the pin so that contact is maintained with the mating socket wall no matter what radial forces are applied. This spring may be flexed many times without any evidence of metal fatigue. Reliable mating is further ensured by protecting the pin contact in a tightly toleranced recessed cavity. Cinch’s family of Dura-Con connectors includes MIL-C-83513 Series connectors along with our own commercial equivalents. The commercial Dura-Con product line offers an expanded range of termination and hardware options for all-plastic and metal shell wire versions and right-angle and straight PC board mount “terminal blocks”. Cinch also packages the Dura-Con contact in a very low profile plastic strip connector on .050" centers and in a line of high-density microminiature edge (Microedge) board connectors that meet the requirements of MIL-C-55302. Cinch has created a line of plastic and metal shell Dura-Con connector savers for very high mating cycle applications such as test equipment. Termination Options: Cinch offers the following termination methods for its Dura-Con connectors: Insulated Wire - Insulated wire is crimped to the Dura-Con contacts then epoxy backpotted at the factory. Wire is available in standard lengths of 18, 24, 36, and 48 inches. Uninsulated Wire - 24 AWG, gold-plated, uninsulated wire is crimped to the Dura-Con contact at the factory. Wire is available in standard lengths of 0.5, 1.0, and 2.0 inches. This option allows the user greater flexibility when installing the connector. Solder Cup - For applications that require the lowest contact resistance, Cinch offers Dura-Con connectors with solder cups for termination by the user. 5 Dura-Con is a trademark of Cinch Connectors. 5-1 Call Toll Free: 1 (800) 323-9612 Dura-Con Introduction Custom Capabilities: Standard Cinch Dura-Con connectors satisfy a wide variety of applications. Cinch’s line of Dura-Con D-microminiature connectors is one of the most versatile in the industry. There are over 50,000 possible combinations of Cinch standard options such as connector type, size, materials, hardware, and termination. When special application requirements arise, Cinch Dura-Con connectors take this versatility to the next level. Whether specific needs entail new variations of simple end-to-end connector assemblies or more complex and intricate harness assemblies, Cinch Connector Division has the state-of-the-art engineering resources and research facilities in place to meet your needs. Cinch approaches your business with a well-defined goal: to ensure the integrity of your design and to execute our contribution to it in a responsible, cost-effective manner. This philosophy has led Cinch to a position of industry leadership. For complete information regarding the total capabilities of the Dura-Con connector series, or for custom application assistance, contact your nearest Cinch Connectors sales office. 5 Call Toll Free: 1 (800) 323-9612 5-2 Dura-Con High Reliability All-Plastic .050" (1.27mm) Density Solder Cup/Wire D-Microminiature ■ Both plug and socket available in 9, 15, 21, 25, 31, 37, and 51 positions. FEATURES ■ Termination styles - solder cup, gold-plated solid wire, and insulated stranded wire. ■ Several styles of mounting hardware are available for cable-to-cable, cable-to-board mount, and cable-to-panel mount applications. ■ High-performance Dura-Con twist-pin contact. ■ Economical all-plastic shell for lightweight applications where no shielding is required. MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS ■ Meets requirements of MIL-C-83513 except where noted. Insulator: UL94V-0 rated glass-filled polyester Contacts: Pins - Copper alloy, Sockets - Copper alloy (machined) Contact Plating: .000050 in gold Operating Temperature: -55° C to +135° C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level 8 milliohms maximum change Individual Contact: 6 oz. (170.40 g) maximum insertion; 0.5 oz. (14.20 g) minimum withdrawal Mating / Unmating Force: See table Call Toll Free: 1 (800) 323-9612 5-4 No. of Contacts 9 15 21 25 31 37 51 Maximum Mating Force Lb. Kg 5.63 2.56 9.38 4.26 13.13 5.96 15.63 7.10 19.38 8.80 23.13 10.50 31.88 14.47 Minimum Unmating Force Lb. Kg .28 .13 .47 .21 .66 .30 .78 .35 .97 .44 1.16 .53 1.59 .72 Dura-Con High Reliability All-Plastic .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Contact Arrangements (Face view of pin insulator) (Use reverse order for socket) Ordering Information DC D A 37 P 6 E 2 -18.0 K Cinch Dura-Con D Connector Mounting Hardware** B = No Hardware F = Float Mount R = Reverse Float Mount K = Jackscrew (Standard) L = Jackscrew (Low Profile) P = Jackpost, MIL-C-83513/5-07 Insulator Type *D = Thermoplastic Glass Reinforced Mounting Type *A = Screw Mount Flange Lead Length in inches*** 00.5 Solid copper wire only 01.0 Solid copper wire only 02.0 Solid copper wire only 18.0 Stranded wire only 24.0 Stranded wire only 36.0 Stranded wire only 48.0 Stranded wire only No. of Contacts 9, 15, 21, 25, 31, 37, 51 Contact Type P – Pin (Plug) S – Socket (Receptacle) Wire Size in AWG 5 = 25 AWG Solid Copper 6 = 26 AWG Stranded S = Solder Cup (Skip to Mounting Hardware) Insulation Color or Wire Finish 1 = White *2 = Yellow (Stranded Wire) 3 = Tin-Plated *4 = Gold-Plated (Solid Wire Only) *5 = Color Coded Per MIL-Std. (681) System 1. (Stranded Wire Only) Wire Type E = MIL-W-16878/4, 7 Strand C = Solid Copper - Uninsulated (Consult factory for non-standard wire types) * - Indicates Cinch std. option. ** - See p. 5-12 for std. hardware dims. See p. 5-13 for non-std. hardware & p. 5-31 for Mil spec. hardware both sold separately. ***- Length Tolerance: solid wire = ± 3/32”, standard wire = ± 1/4”. 5-5 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability All-Plastic .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Connector Dimensions - Plastic Shell Plug Socket 5 A No. of Contacts B Max. + .010 (.254) in mm in D E +.005 (.127) in mm F Max. +.010 (.254) in mm in mm 7.42 .398 10.11 .565 14.35 .208 5.28 .173 4.39 .376 9.55 .398 10.11 .565 14.35 .208 5.28 .173 4.39 .442 11.23 .548 13.92 .715 18.16 .208 5.28 .173 4.39 23.57 .526 13.36 .548 13.92 .715 18.16 .208 5.28 .173 4.39 1.078 27.38 .592 15.04 .698 17.73 .865 21.97 .208 5.28 .173 4.39 21 Socket 1.078 27.38 .676 17.17 .698 17.73 .865 21.97 .208 5.28 .173 4.39 25 Plug 1.178 29.92 .692 17.58 .798 20.27 .965 24.51 .208 5.28 .173 4.39 25 Socket 1.178 29.92 .776 19.71 .798 20.27 .965 24.51 .208 5.28 .173 4.39 31 Plug 1.328 33.73 .842 21.39 .948 24.08 1.115 28.32 .208 5.28 .173 4.39 31 Socket 1.328 33.73 .926 23.52 .948 24.08 1.115 28.32 .208 5.28 .173 4.39 37 Plug 1.478 37.54 .992 25.20 1.098 27.89 1.265* 32.13 .208 5.28 .173 4.39 37 Socket 1.478 37.54 1.076 27.33 1.098 27.89 1.265* 32.13 .208 5.28 .173 4.39 51 Plug 1.428 36.27 .942 23.93 1.048 26.62 1.215 30.86 .250 6.35 .220 5.59 51 Socket 1.428 36.27 1.026 26.06 1.048 26.62 1.215 30.86 .250 6.35 .220 5.59 9 Plug .778 19.76 .292 9 Socket .778 19.76 15 Plug .928 23.57 15 Socket .928 21 Plug Call Toll Free: 1 (800) 323-9612 mm C +.010 (.254) -.018 (.457) in mm 5-6 Dura-Con High Reliability All-Plastic .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Panel Mounting Dimensions Panel Cutout Dimensions Figure 1. Front Mounting Figure 3. Edgeboard Mounting Figure 2. Rear Mounting A No. of Contacts 9 15 21 25 31 37 51 Figure Number 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 +.004 -.000 in .408 .373 .558 .523 .708 .674 .808 .774 .958 .924 1.108 1.074 1.058 1.024 - B (.101) (.000) mm 10.36 9.47 14.17 13.28 17.98 17.12 20.52 19.66 24.33 23.47 28.14 27.28 26.87 26.01 - 5-7 +.004 -.000 in .172 .216 .172 .216 .172 .216 .172 .216 .172 .216 .172 .216 .215 .259 - C (.101) (.000) mm 4.37 5.49 4.37 5.49 4.37 5.49 4.37 5.49 4.37 5.49 4.37 5.49 5.46 6.58 - +.005 -.000 in .570 .570 .570 .720 .720 .720 .870 .870 .870 .970 .970 .970 1.120 1.120 1.120 1.270 1.270 1.270 1.220 1.220 1.220 (.127) (.000) mm 14.48 14.48 14.48 18.29 18.29 18.29 22.10 22.10 22.10 24.64 24.64 24.64 28.45 28.45 28.45 32.26 32.26 32.26 30.99 30.99 30.99 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density Solder Cup/Wire D-Microminiature ■ Both plug and socket available in 9, 15, 21, 25, 31, 37, 51, and 100 positions. FEATURES ■ Several styles of mounting are available for cable-to-cable, cable-to-panel mount, and cable-to-board mount. ■ Aluminum shell provides extra strength and EMI/RFI shielding capability. Plating options available. ■ Silicone elastomer compression interfacial seal protects contacts from moisture and humidity and isolates contacts from each other and the metal shell. ■ Meets requirements of MIL-C-83513 except where noted. ■ Rugged twist-pin contacts resistant to shock and vibration make metal shell Dura-Con an excellent choice for harsh environments such as airborne or space applications. MATERIALS Insulator: UL94V-0 rated glass-filled polyester or diallyl phthalate Contacts: Pins - Copper alloy, Sockets - Copper alloy (machined) Contact Plating: .000050 in gold Shell: Aluminum alloy Shell Plating: Yellow chromate over cadmium (std.) or MECHANICAL ELECTRICAL ENVIRONMENTAL electroless nickel Operating Temperature: -55°C to +135°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level 8 milliohms maximum Individual Contact: 6 oz. (170.40 g) maximum insertion; 0.5 oz. (14.20 g) minimum withdrawal Mating / Unmating Force: See table Call Toll Free: 1 (800) 323-9612 5-8 No. of Contacts 9 15 21 25 31 37 51 100 Maximum Mating Force Lb. Kg 5.63 2.56 9.38 4.26 13.13 5.96 15.63 7.10 19.38 8.80 23.13 10.50 31.88 14.47 62.50 28.38 Minimum Unmating Force Lb. Kg .28 .13 .47 .21 .66 .30 .78 .35 .97 .44 1.16 .53 1.59 .72 3.13 1.42 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Contact Arrangements (Face view of pin insert) (Use reverse order for socket side) Ordering Information DC D M 37 P 6 E 2-18.0 K N Cinch Dura-Con D Connector Shell Plating *No Letter = Yellow Chromate over Cadmium N = Electroless Nickel Insulator Type C = Diallyl Phthalate Glass-Reinforced D = Thermoplastic Glass-Reinforced Mounting Hardware** B = No Hardware F = Float Mount R = Reverse Float Mount K = Jackscrew (Standard) L = Jackscrew (Low Profile) P = Jackpost, Size 9 through 51 MIL-C-83513/5-07 Size 100 MIL-C-83513/5-17 Mounting Type M = Screw Mount Metal Shell No. of Contacts 9, 15, 21, 25, 31, 37, 51, 100 Contact Type P = Pin (Plug) S = Socket (Receptacle) Lead Length in inches*** 00.5 Solid copper wire only 01.0 Solid copper wire only 02.0 Solid copper wire only 18.0 Stranded wire only 24.0 Stranded wire only 36.0 Stranded wire only 48.0 Stranded wire only Wire Size in AWG 5 = 25 AWG Solid Copper 6 = 26 AWG Stranded S = Solder cup (Skip to Mounting Hardware) Insulation Color or Wire Finish 1 = White *2 = Yellow (Stranded Wire) 3 = Tin-Plated *4 = Gold-Plated (Solid Wire) *5 = Color Coded Per MIL-Std. 681, System 1. (Stranded Wire Only) Wire Type C = Solid Copper (Uninsulated) E = MIL-W-16878/4, 7 Strand (Consult factory for non-standard wire types) * - Indicates Cinch std. option. ** - See p. 5-12 for std. hardware dims. See p. 5-13 for non-std. hardware & p. 5-31 for Mil spec. hardware both sold separately. ***- Length Tolerance: solid wire = ± 3/32”, standard wire = ± 1/4”. 5-9 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Connector Dimensions - Metal Shell Plug Socket A 5 B Max. No. of Contacts 9 Plug + .010 (.254) in mm .775 19.68 in .333 mm 8.46 C +.010 (.254) -.018 (.457) in mm .390 9.91 9 Socket .775 19.68 .396 10.06 .390 9.91 .565 14.35 .298 7.57 .270 6.86 15 Plug .925 23.50 .483 12.27 .540 13.72 .715 18.16 .298 7.57 .270 6.86 15 Socket .925 23.50 .546 13.87 .540 13.72 .715 18.16 .298 7.57 .270 6.86 21 Plug 1.075 27.30 .633 16.08 .690 17.53 .865 21.97 .298 7.57 .270 6.86 21 Socket 1.075 27.30 .696 17.68 .690 17.53 .865 21.97 .298 7.57 .270 6.86 25 Plug 1.175 29.84 .733 18.62 .790 20.07 .965 24.51 .298 7.57 .270 6.86 25 Socket 1.175 29.84 .796 20.22 .790 20.07 .965 24.51 .298 7.57 .270 6.86 31 Plug 1.325 33.66 .883 21.16 .940 23.88 1.115 28.32 .298 7.57 .270 6.86 31 Socket 1.325 33.66 .946 24.03 .940 23.88 1.115 28.32 .298 7.57 .270 6.86 37 Plug 1.475 37.46 1.033 26.24 1.090 27.69 1.265 32.13 .298 7.57 .270 6.86 37 Socket 1.475 37.46 1.096 27.84 1.090 27.69 1.265 32.13 .298 7.57 .270 6.86 51 Plug 1.425 36.20 .983 24.97 1.040 26.42 1.215 30.86 .341 8.66 .310 7.87 51 Socket 1.425 36.20 1.046 26.57 1.040 26.42 1.215 30.86 .341 8.66 .310 7.87 100 Plug 2.160 54.86 1.383 35.13 1.432 36.38 1.800 45.71 .384 9.75 .360 9.15 100 Socket 2.160 54.86 1.446 36.73 1.432 36.38 1.800 45.71 .384 9.75 .360 9.15 Call Toll Free: 1 (800) 323-9612 5-10 D E F Max. + .005 (.127) in mm .565 14.35 + .010 (.254) in mm .298 7.57 in .270 mm 6.86 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Panel Mounting Dimensions Panel Cutout Dimensions A No. of Contacts 9 15 21 25 31 37 51 100 Figure Number 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 +.004 -.000 in .408 .408 .558 .558 .708 .708 .808 .808 .958 .958 1.108 1.108 1.058 1.058 1.450 1.562 - B (.101) (.000) mm 10.36 10.36 14.17 14.17 17.98 17.98 20.52 20.52 24.33 24.33 28.14 28.14 26.87 26.87 36.84 39.68 - +.004 -.000 in .270 .256 .270 .256 .270 .256 .270 .256 .270 .256 .270 .256 .315 .300 .361 .338 - 5-11 C (.101) (.000) mm 6.86 6.50 6.86 6.50 6.86 6.50 6.86 6.50 6.86 6.50 6.86 6.50 8.00 7.62 9.17 8.58 - +.005 -.000 in .570 .570 .570 .720 .720 .720 .870 .870 .870 .970 .970 .970 1.120 1.120 1.120 1.270 1.270 1.270 1.220 1.220 1.220 1.805 1.805 1.805 D (.127) (.000) mm 14.48 14.48 14.48 18.29 18.29 18.29 22.10 22.10 22.10 24.64 24.64 24.64 28.45 28.45 28.45 32.26 32.26 32.26 30.99 30.99 30.99 45.86 45.86 45.86 +.005 -.000 in .089 .089 .089 .089 .089 .089 .089 .117 .117 .117 (1.27) (.000) mm 2.26 2.26 2.26 2.26 2.26 2.26 2.26 2.97 2.97 2.97 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Mounting Hardware .050" (1.27mm) Density Solder Cup/Wire D-Microminiature Mounting Hardware For Plastic & Metal Shell Dura-Con Connectors Option “R” Option “F” 5 Option “L” Option “K” Option “P” Call Toll Free: 1 (800) 323-9612 5-12 Dura-Con High Reliability Mounting Hardware .050" (1.27mm) Density Solder Cup/Wire D-Microminiature P/N: DCSL1 Purchased Separately Jackpost - Rear Panel Mount (Purchased Separately) Panel Cutout Dimensions (Plug & Receptacle) Jackpost Part Number DCJPRM094 DCJPRM063 DCJPRM047 DCJPRM031 Part Number (by Shell Size) 9 15 21 25 31 37 51 100 Panel Thickness in mm .094 2.5 .063 1.6 .047 1.2 .031 0.8 A +.004 (.101) -.000 (.000) in mm .398 10.11 .548 13.92 .698 17.73 .798 20.27 .948 24.08 1.098 27.89 1.048 26.62 1.448 36.78 5-13 A Dimension in mm .092/.087 2.34/2.21 .061/.056 1.55/1.42 .047/.042 1.19/1.07 .030/.025 0.76/0.64 B +.004 (.101) -.000 (.000) in mm .249 6.32 .249 6.32 .249 6.32 .249 6.32 .249 6.32 .249 6.32 .292 7.42 .336 8.53 C +.005 (.127) in mm .565 14.35 .715 18.16 .865 21.97 .965 24.51 1.115 28.34 1.265 32.13 1.215 30.86 1.800 45.72 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block ■ Plug & socket versions available in 9, 15, 21, 25, 31, 37, 51, and 100 positions. ■ Flow-through design facilitates inspection and cleaning after soldering. FEATURES ■ All terminal block connectors use standard mounting hardware. ■ Metal shell provides EMI/RFI shielding capability. ■ Available in 3 styles: Straight mount, 90° right-angle mount, and 90° rightangle narrow profile mounting. ■ Silicone elastomer interfacial seal protects contacts from moisture and isolates them from each other and from the metal shell. ■ Meets requirements of MIL-C-83513. ■ Choice of insulator materials. ELECTRICAL ENVIRONMENTAL MATERIALS Insulator: UL94V-0 glass-filled polyester or diallyl phthalate Contacts: Pins - Copper alloy, Sockets - Copper alloy (machined) Contact Plating: .000050 in gold Shell: Aluminum alloy Shell Plating: Yellow chromate over cadmium (std.) or electroless nickel Operating Temperature: -55°C to +135°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level, 150 VAC @ 70,000 ft. 8 milliohms maximum MECHANICAL Insulation Resistance: 1,000 megohms min between adjacent pins Individual Contact: 6 oz. (170.40 g) maximum insertion force; 0.5 oz. (14.20 g) minimum withdrawal force Mating / Unmating Forces: See table Call Toll Free: 1 (800) 323-9612 5-14 No. of Contacts 9 15 21 25 31 37 51 100 Maximum Mating Force Lb. Kg 5.63 2.56 9.38 4.26 13.13 5.96 15.63 7.10 19.38 8.80 23.13 10.50 31.88 14.47 62.50 28.38 Minimum Unmating Force Lb. Kg .28 .13 .47 .21 .66 .30 .78 .35 .97 .44 1.16 .53 1.59 .72 3.13 1.42 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block Contact Arrangements Ordering Information DC D M 25 S BR -- -Shell Finish* No Letter = Standard Yellow Chromate over Cadmium N = Electroless Nickel Cinch Dura-Con D Connector Insulator Type C = Diallyl Phthalate Glass Reinforced D = Thermoplastic Glass Reinforced Hardware* No Letter = Less Hardware P = Jackpost Termination Style BR = 90° PCB BS = Straight 180° PCB CBR = 90° Narrow Profile PCB Mounting Type M = Screw Mount Metal Shell No. of Contacts 9, 15, 21, 25, 31, 37, 51, & 100 Contact Type P = Pin (Plug) S = Socket (Receptacle) * For other options consult factory. 5-15 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block Recommended Board Layout Typ. Hole Dia. = .040" (1.02 mm) NOTE: For additional connector dimensions, see page 5-10. 5 A Max. No. of Contacts in mm 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket 1.390 1.390 1.540 1.540 1.690 1.690 1.790 1.790 2.040 2.040 2.340 2.340 1.875 1.875 2.780 2.780 35.31 35.31 39.12 39.12 42.93 42.93 45.47 45.47 51.82 51.82 59.44 59.44 47.63 47.63 70.61 70.61 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket B + .007 (0.18) in mm 1.150 1.150 1.300 1.300 1.450 1.450 1.550 1.550 1.800 1.800 2.100 2.100 1.600 1.600 2.500 2.500 G Max. in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .394 .394 mm 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 8.92 8.92 10.00 10.00 29.21 29.21 33.02 33.02 36.83 36.83 39.37 39.37 45.72 45.72 53.34 53.34 40.64 40.64 63.50 63.50 H Max. in .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 Call Toll Free: 1 (800) 323-9612 mm 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 C + .005 (0.13) in mm .565 .565 .715 .715 .865 .865 .965 .965 1.115 1.115 1.265 1.265 1.215 1.215 1.800 1.800 14.35 14.35 18.16 18.16 21.97 21.97 24.51 24.51 28.32 28.32 32.13 32.13 30.86 30.86 45.72 45.72 J + .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 5-16 F Max. in mm .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .565 .565 .765 .765 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 14.35 14.35 19.43 19.43 K + .015 in .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .225 .225 mm 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 5.72 5.72 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block Straight (180°) Termination Recommended Board Layout Typ. Hole Dia. = .040" (1.02 mm) NOTE: For additional connector dimensions, see page 5-10. No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket A Max. in 1.390 1.390 1.390 1.390 1.690 1.690 1.740 1.740 2.040 2.040 2.340 2.340 2.270 2.270 3.070 3.070 mm 35.31 35.31 35.31 35.31 42.93 42.93 44.20 44.20 51.82 51.82 59.44 59.44 57.66 57.66 77.98 77.98 H Max. in .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 mm 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 B + .007 (0.18) in mm 1.150 29.21 1.150 29.21 1.150 29.21 1.150 29.21 1.450 36.83 1.450 36.83 1.500 38.10 1.500 38.10 1.800 45.72 1.800 45.72 2.100 53.34 2.100 53.34 2.000 50.80 2.000 50.80 2.800 71.12 2.800 71.12 J + .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 C + .005 (0.13) in mm .565 14.35 .565 14.35 .715 18.16 .715 18.16 .865 21.97 .865 21.97 .965 24.51 .965 24.51 1.115 28.32 1.115 28.32 1.265 32.13 1.265 32.13 1.215 30.86 1.215 30.86 1.800 45.72 1.800 45.72 D Max. in .885 .885 .945 .945 1.185 1.185 1.275 1.275 1.575 1.576 1.875 1.875 1.775 1.775 2.585 2.585 K Max. in .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .300 .300 5-17 mm 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 7.62 7.62 G Max. mm 22.48 22.48 24.0 24.0 30.09 30.09 32.38 32.38 40.00 40.00 47.62 47.62 45.08 45.08 65.55 65.65 in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .455 .455 mm 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 8.92 8.92 11.56 11.56 L Max. in .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .550 .550 mm 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 13.97 13.97 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Metal Shell .050" (1.27mm) Density PCB Mount Terminal Block Recommended Board Layout NOTE: For additional connector dimensions, see page 5-10. Typ. Hole Dia. = .040" (1.02 mm) 5 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket A Max. in .785 .785 .935 .935 1.085 1.085 1.085 1.185 1.335 1.335 1.485 1.485 1.435 1.435 2.175 2.175 mm 19.94 19.94 23.75 23.75 27.56 27.56 30.10 30.10 33.91 33.91 37.72 37.72 36.45 36.45 55.25 55.25 B + .005 (0.13) in mm .565 14.35 .565 14.35 .715 18.16 .715 18.16 .865 21.97 .865 21.97 .965 24.51 .965 24.51 1.115 28.32 1.115 28.32 1.265 32.13 1.265 32.13 1.215 30.86 1.215 30.86 1.800 45.72 1.800 45.72 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket F + .010 (0.25) in mm .230 5.84 .230 5.84 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .150 3.81 .150 3.81 .200 5.08 .200 5.08 G + .010 (0.25) in mm .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .300 7.62 .300 7.62 .400 10.16 .400 10.16 Call Toll Free: 1 (800) 323-9612 C Max. in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .394 .394 mm 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 8.92 8.92 10.00 10.00 H Max. in .420 .420 .420 .420 .420 .420 .420 .420 .520 .520 .520 .520 .650 .650 1.000 1.000 mm 10.67 10.67 10.67 10.67 10.67 10.67 10.67 10.67 13.21 13.21 13.21 13.21 16.51 16.51 25.40 25.40 5-18 J + .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .996 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature FEATURES ■ All-plastic and metal shell wire versions available in solder cup, gold-plated solid wire, and insulated stranded wire. ■ PCB mount “terminal block” type connectors available in straight or right angle. ■ Sizes offered - 9, 15, 21, 25, 31, 35, 51, and 100 (metal shell only). ■ All products are qualified to the requirements of MIL-C-83513 and marked with the M83513 part number. ■ Optional shell platings and insulator materials offer high performance in harsh environments. MECHANICAL ELECTRICAL ENVIRONMENTA L MATERIALS ■ Mounting hardware per MIL-C-83513. Insulator: UL94V-0 rated glass-filled polyester per MIL-M-24519 or diallyl phthalate (DAP) per MIL-M-14. Contacts: Pins - Copper alloy, Sockets - Copper alloy Contact Plating: .000050 in gold per MIL-G-45204 Shell Material (Metal Shell Only): Aluminum alloy Shell Plating (Metal Shell Only): Yellow chromate over cadmium (std.) or electroless nickel Operating Temperature: -55°C to +125°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level 8 milliohms maximum Durability: 500 mate/unmate cycles Individual Contact: Forces 6 oz. (170.40 g) maximum insertion; 0.5 oz. (14.20 g) minimum withdrawal Mating / Unmating Force: See table Call Toll Free: 1 (800) 323-9612 5-20 No. of Contacts 9 15 21 25 31 37 51 Maximum Mating Force Lb. Kg 5.63 2.56 9.38 4.26 13.13 5.96 15.63 7.10 19.38 8.80 23.13 10.50 31.88 14.47 Minimum Unmating Force Lb. Kg .28 .13 .47 .21 .66 .30 .78 .35 .97 .44 1.16 .53 1.59 .72 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature - Metal Shell Metal Shell Contact Arrangements (Face view of pin insert) (Use reverse order for socket side) Ordering Information M83513/04 - A 03 C Shell Finish C = Cadmium N = Electroless Nickel Connector Type 01 - Metal Shell D Plugs with Solder Cup Termination Wire Type (Use only for /03 & /04, otherwise omit) 01 - M22759/11-26-9, 18 inches, White (see note below) 02 - M22759/11-26-9, 36 inches, White (see note below) 03 - M22759/11-26-( ), 18 inches, Color Coded (see note below) 04 - M22759/11-26-( ), 36 inches, Color Coded (see note below) 05 - QQ-W-343, 25 AWG, 0.5 inch, Gold-Plated 06 - QQ-W-343, 25 AWG, 1.0 inch, Gold-Plated 07 - QQ-W-343, 25 AWG, 0.5 inch, Tin-Plated 08 - QQ-W-343, 25 AWG, 1.0 inch, Tin-Plated 09 - M22759/33-26-9, 18 inches, White 10 - M22759/33-26-9, 36 inches, White 11 - M22759/33-26-( ), 18 inches, Color Coded 12 - M22759/33-26-( ), 36 inches, Color Coded 13 - M22759/11-26-9, 72 inches, White 14 - M22759/11-26-( ), 72 inches, Color Coded 15 - M22759/33-26-9, 72 inches, White 16 - M22759/33-26-( ), 72 inches, Color Coded 02 - Metal Shell D Sockets with Solder Cup Termination 03 - Metal Shell D Plugs with Wire Leads 04 - Metal Shell D Sockets with Wire Leads Insert Arrangements (No. of Contacts) A=9 B = 15 C = 21 D = 25 E = 31 F = 37 G = 51 H = 100 Note: See page 5-31 for M83513 mounting hardware. 5-21 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature - Metal Shell Connector Dimensions - Metal Shell Plug Socket A 5 B Max. (Plug) Min. (Socket) mm 8.48 C + .010" (.254) - .018" (.457) in mm .390 9.91 .3342 8.49 .390 9.91 .565 14.35 .298 7.57 .270 6.68 .4838 12.29 .540 13.72 .715 18.16 .298 7.57 .270 6.68 23.50 .4842 12.30 .540 13.72 .715 18.16 .298 7.57 .270 6.68 27.30 .6338 16.10 .690 17.53 .865 21.97 .298 7.57 .270 6.68 1.075 27.30 .6342 16.11 .690 17.53 .865 21.97 .298 7.57 .270 6.68 1.175 29.84 .7338 18.64 .790 20.07 .965 24.51 .298 7.57 .270 6.68 25 Socket 1.175 29.84 .7342 18.65 .790 20.07 .965 24.51 .298 7.57 .270 6.68 31 Plug 1.325 33.66 .8838 22.45 .940 23.88 1.115 28.32 .298 7.57 .270 6.68 31 Socket 1.325 33.66 .8842 22.46 .940 23.88 1.115 28.32 .298 7.57 .270 6.68 37 Plug 1.475 37.46 1.0338 26.26 1.090 27.69 1.265 32.13 .298 7.57 .270 6.68 37 Socket 1.475 37.46 1.0342 26.27 1.090 27.69 1.265 32.13 .298 7.57 .270 6.68 51 Plug 1.425 36.20 .9838 24.99 1.040 26.42 1.215 30.86 .341 8.66 .310 7.87 51 Socket 1.425 36.20 .9842 25.00 1.040 26.42 1.215 30.86 .341 8.66 .310 7.87 100 Plug 2.160 54.86 1.3838 35.15 1.432 36.38 1.800 45.71 .384 9.75 .360 9.15 100 Socket 2.160 54.86 1.3842 35.16 1.432 36.38 1.800 45.71 .384 9.75 .360 9.15 No. of Contacts 9 Plug ± .010" (.254) in mm .775 19.68 in .3338 9 Socket .775 19.68 15 Plug .925 23.50 15 Socket .925 21 Plug 1.075 21 Socket 25 Plug Call Toll Free: 1 (800) 323-9612 5-22 D E F Max. ± .005" (.127) in mm .565 14.35 ± .010" (.254) in mm .298 7.57 in .270 mm 6.68 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature - Metal Shell Panel Mounting Dimensions - Metal Shell Panel Mounting Dimensions Panel Cutout Dimensions - Metal Shell No. of Contacts Front Mounting 9 15 21 25 31 37 51 100 No. of Contacts Rear Mounting 9 15 21 25 31 37 51 100 No. of Contacts Edgeboard Mounting 9 15 21 25 31 37 51 100 A +.004" (.101mm) -.000" (.000mm) in mm .408 .558 .708 .808 .958 1.108 1.058 1.450 10.36 14.17 17.98 20.52 24.33 28.14 26.87 36.84 A +.004" (.101mm) -.000" (.000mm) in mm .408 .558 .708 .808 .958 1.108 1.058 1.450 10.36 14.17 17.98 20.52 24.33 28.14 26.87 36.84 B +.004" (.101mm) -.000" (.000mm) in mm .270 .270 .270 .270 .270 .270 .315 .361 6.86 6.86 6.86 6.86 6.86 6.86 8.00 9.17 6.50 6.50 6.50 6.50 6.50 6.50 7.62 8.58 C +.005" (.127mm) -.000" (.000mm) in mm .570 .720 .870 .970 1.120 1.270 1.220 1.805 14.48 18.29 22.10 24.64 28.45 32.26 30.99 45.86 5-23 .570 .720 .870 .970 1.120 1.270 1.220 1.805 B +.004" (.101mm) -.000" (.000mm) in mm .256 .256 .256 .256 .256 .256 .300 .338 C +.005" (.127mm) -.000" (.000mm) in mm 14.48 14.48 22.10 24.64 28.45 32.26 30.99 45.86 C +.005" (.127mm) -.000" (.000mm) in mm .570 .720 .870 .970 1.120 1.270 1.220 1.805 D +.005" (.127mm) -.000" (.000mm) in mm .089 .089 .089 .089 .089 .089 .089 .117 D +.005" (.127mm) -.000" (.000mm) in mm 14.48 18.29 22.10 24.64 28.45 32.26 30.99 45.86 .089 .089 .089 .089 .089 .089 .089 .117 D +.005" (.127mm) -.000" (.000mm) in mm .089 .089 .089 .089 .089 .089 .089 .117 2.26 2.26 2.26 2.26 2.26 2.26 2.26 2.97 2.26 2.26 2.26 2.26 2.26 2.26 2.26 2.97 Call Toll Free: 1 (800) 323-9612 2.26 2.26 2.26 2.26 2.26 2.26 2.26 2.97 5 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire D-Microminiature - Plastic Plastic Shell Contact Arrangements (Face view of pin insert) (Use reverse order for socket side) Ordering Information M83513/06-A 04 Connector Type Wire Type (Use only for /08 & /09, otherwise omit) 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 06 - Plastic Shell Plugs with Solder Cup Termination 07 - Plastic Shell Sockets with Solder Cup Termination 5 08 - Plastic Shell Plugs with Wire Leads 09 - Plastic Shell Sockets with Wire Leads Insert Arrangements (No. of Contacts) A=9 B = 15 C = 21 D = 25 E = 31 F = 37 G = 51 Call Toll Free: 1 (800) 323-9612 - M22759/11-26-9, 18 inches, White M22759/11-26-9, 36 inches, White M22759/11-26-( ), 18 inches, Color Coded M22759/11-26-( ), 36 inches, Color Coded QQ-W-343, 25 AWG, 0.5 inch, Gold-Plated QQ-W-343, 25 AWG, 1.0 inch, Gold-Plated QQ-W-343, 25 AWG, 0.5 inch, Tin-Plated QQ-W-343, 25 AWG, 1.0 inch, Tin-Plated M22759/33-26-9, 18 inches, White M22759/33-26-9, 36 inches, White M22759/33-26-( ), 18 inches, Color Coded M22759/33-26-( ), 36 inches, Color Coded M22759/11-26-9, 72 inches, White M22759/11-26-( ), 72 inches, Color Coded M22759/33-26-9, 72 inches, White M22759/33-26-( ), 72 inches, Color Coded Note: See page 5-31 for M83513 mounting hardware. 5-24 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature - Plastic Shell Dimensions - (All-Plastic Version) Plug Socket A No. of Contacts B Max. (Plug) Min. (Socket) ±.010" (.254) in mm in mm C +.010" (.254) -.018" (.457) in mm D E ±.005" (.127) in mm F Max. ±.010" (.254) in mm in mm 9 Plug .778 19.76 .2918 7.41 .398 10.11 .565 14.35 .208 5.28 .173 4.39 9 Socket .778 19.76 .2922 7.42 .398 10.11 .565 14.35 .208 5.28 .173 4.39 15 Plug .928 23.57 .4418 11.22 .548 13.92 .715 18.16 .208 5.28 .173 4.39 15 Socket .928 23.57 .4422 11.23 .548 13.92 .715 18.16 .208 5.28 .173 4.39 21 Plug 1.078 27.38 .5918 15.03 .698 17.73 .865 21.97 .208 5.28 .173 4.39 21 Socket 1.078 27.38 .5922 15.04 .698 17.73 .865 21.97 .208 5.28 .173 4.39 25 Plug 1.178 29.92 .6918 17.57 .798 20.27 .965 24.51 .208 5.28 .173 4.39 25 Socket 1.178 29.92 .6922 17.58 .798 20.27 .965 24.51 .208 5.28 .173 4.39 31 Plug 1.328 33.73 .8418 21.38 .948 24.08 1.115 28.32 .208 5.28 .173 4.39 31 Socket 1.328 33.73 .8422 21.39 .948 24.08 1.115 28.32 .208 5.28 .173 4.39 37 Plug 1.478 37.54 .9918 25.19 1.098 27.89 1.265 32.13 .208 5.28 .173 4.39 37 Socket 1.478 37.54 .9922 25.20 1.098 27.89 1.265 32.13 .208 5.28 .173 4.39 51 Plug 1.428 36.27 .9418 23.92 1.048 26.62 1.215 30.86 .250 6.35 .220 5.59 51 Socket 1.428 36.27 .9422 23.93 1.048 26.62 1.215 30.86 .250 6.35 .220 5.59 5-25 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature - Plastic Panel Mounting Dimensions - All-Plastic Panel Cutout Dimensions No. of Contacts Front Mounting A +.004" (.101mm) -.000" (.000mm) in mm B +.004" (.101mm) -.000" (.000mm) in mm C +.005" (.127mm) -.000" (.000mm) in mm 9 .408 10.36 .172 4.37 .570 14.48 15 .558 14.17 .172 4.37 .720 14.48 21 .708 17.98 .172 4.37 .870 22.10 25 .808 20.52 .172 4.37 .970 24.64 31 .958 24.33 .172 4.37 1.120 28.45 37 1.108 28.14 .172 4.37 1.270 32.26 51 1.058 26.87 .215 5.46 1.220 30.99 Rear Cutout Dimensions No. of Contacts 5 Rear Mounting A +.004" (.101mm) -.000" (.000mm) in mm B +.004" (.101mm) -.000" (.000mm) in mm 9 .373 9.47 .216 5.49 .570 14.48 15 .523 13.28 .216 5.49 .720 18.29 21 .674 17.12 .216 5.49 .870 22.10 25 .774 19.66 .216 5.49 .970 24.64 31 .924 23.47 .216 5.49 1.120 28.45 37 1.074 27.28 .216 5.49 1.270 32.26 51 1.024 26.01 .259 6.58 1.220 30.99 Edgeboard Mounting Cutout Dimensions Edgeboard Mounting C +.005" (.127mm) -.000" (.000mm) in mm No. of Contacts D +.005" (.127mm) -.000" (.000mm) in mm 9 .570 14.48 15 .720 18.29 21 .870 22.10 25 .970 24.64 31 1.120 28.45 37 1.270 32.26 51 1.220 30.99 Call Toll Free: 1 (800) 323-9612 5-26 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density D-Microminiature PC Board Mount Terminal Block Contact Arrangements (Face view of pin insert) (Use reverse order for socket side) Ordering Information M83513/10 - C 02 C N Hardware N = No Jackpost P = Jackpost Attached Connector Description 10 = Plug, 9-37 Pos., Narrow Profile, Rt. Angle 11 = Plug, 51 Pos., Narrow Profile, Rt. Angle 12 = Plug, 100 Pos., Narrow Profile, Rt. Angle 13 = Socket, 9-37 Pos., Narrow Profile, Rt. Angle 14 = Socket, 51 Pos., Narrow Profile, Rt. Angle 15 = Socket, 100 Pos., Narrow Profile, Rt. Angle 16 = Plug, 9-37 Pos., Std. Profile, Rt. Angle 17 = Plug, 51 Pos., Std. Profile, Rt. Angle 18 = Plug, 100 Pos., Std. Profile, Rt. Angle 19 = Socket, 9-37 Pos., Std. Profile, Rt. Angle 20 = Socket, 51 Pos., Std. Profile, Rt. Angle 21 = Socket, 100 Pos., Std. Profile, Rt. Angle 22 = Plug, 9-37 Pos., Straight Mount 23 = Plug, 51 Pos., Straight Mount 24 = Plug, 100 Pos., Straight Mount 25 = Socket, 9-37 Pos., Straight Mount 26 = Socket, 51 Pos., Straight Mount 27 = Socket, 100 Pos., Straight Mount Shell Finish C = Cadmium N = Electroless Nickel Termination Length 01 = 0.109 02 = 0.140 03 = 0.172 Insert Arrangement Length (No. of Contacts) A=9 B = 15 C = 21 D = 25 E = 31 F = 37 G = 51 H = 100 5-27 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature Recommended Board Layout (/16-/21) Typ. Hole Dia. = .040" (1.02 mm) NOTE: For additional connector dimensions, see page 5-22. 5 A Max. No. of Contacts in mm 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket 1.390 1.390 1.540 1.540 1.690 1.690 1.790 1.790 2.040 2.040 2.340 2.340 1.875 1.875 2.780 2.780 35.31 35.31 39.12 39.12 42.93 42.93 45.47 45.47 51.82 51.82 59.44 59.44 47.63 47.63 70.61 70.61 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket B ± .007 (0.18) in mm 1.150 1.150 1.300 1.300 1.450 1.450 1.550 1.550 1.800 1.800 2.100 2.100 1.600 1.600 2.500 2.500 29.21 29.21 33.02 33.02 36.83 36.83 39.37 39.37 45.72 45.72 53.34 53.34 40.64 40.64 63.50 63.50 in .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 H Max. mm 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 G Max. in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .394 .394 mm 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 8.92 8.92 10.00 10.00 Call Toll Free: 1 (800) 323-9612 C ± .005 (0.13) in mm .565 .565 .715 .715 .865 .865 .965 .965 1.115 1.115 1.265 1.265 1.215 1.215 1.800 1.800 14.35 14.35 18.16 18.16 21.97 21.97 24.51 24.51 28.32 28.32 32.13 32.13 30.86 30.86 45.72 45.72 J ± .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 5-28 F Max. in mm .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .465 .565 .565 .765 .765 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 11.81 14.35 14.35 19.43 19.43 K ± .015 in .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .125 .225 .225 mm 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 3.18 5.72 5.72 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature Straight (180°) Termination (/22-/27) Recommended Board Layout Typ. Hole Dia. = .040" (1.02 mm) NOTE: For additional connector dimensions, see page 5-22. No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket A Max. in 1.390 1.390 1.390 1.390 1.690 1.690 1.740 1.740 2.040 2.040 2.340 2.340 2.270 2.270 3.070 3.070 mm 35.31 35.31 35.31 35.31 42.93 42.93 44.20 44.20 51.82 51.82 59.44 59.44 57.66 57.66 77.98 77.98 B ± .007 (0.18) in mm 1.150 29.21 1.150 29.21 1.150 29.21 1.150 29.21 1.450 36.83 1.450 36.83 1.500 38.10 1.500 38.10 1.800 45.72 1.800 45.72 2.100 53.34 2.100 53.34 2.000 50.80 2.000 50.80 2.800 71.12 2.800 71.12 mm 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 4.83 5.08 J ± .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 H Max. in .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 .190 .200 C ± .005 (0.13) in mm .565 14.35 .565 14.35 .715 18.16 .715 18.16 .865 21.97 .865 21.97 .965 24.51 .965 24.51 1.115 28.32 1.115 28.32 1.265 32.13 1.265 32.13 1.215 30.86 1.215 30.86 1.800 45.72 1.800 45.72 D Max. in .885 .885 .945 .945 1.185 1.185 1.275 1.275 1.575 1.576 1.875 1.875 1.775 1.775 2.585 2.585 K Max. in .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .165 .300 .300 5-29 G Max. mm 22.48 22.48 24.0 24.0 30.09 30.09 32.38 32.38 40.00 40.00 47.62 47.62 45.08 45.08 65.55 65.65 in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .455 .455 mm 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 7.75 8.92 8.92 11.56 11.56 L Max. mm 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 4.19 7.62 7.62 in .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .355 .550 .550 mm 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 9.02 13.97 13.97 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature Recommended Board Layout (/10-/15) NOTE: For additional connector dimensions, see page 5-22. Typ. Hole Dia. = .040" (1.02 mm) 5 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket A Max. in .785 .785 .935 .935 1.085 1.085 1.085 1.185 1.335 1.335 1.485 1.485 1.435 1.435 2.175 2.175 mm 19.94 19.94 23.75 23.75 27.56 27.56 30.10 30.10 33.91 33.91 37.72 37.72 36.45 36.45 55.25 55.25 B ± .005 (0.13) in mm .565 14.35 .565 14.35 .715 18.16 .715 18.16 .865 21.97 .865 21.97 .965 24.51 .965 24.51 1.115 28.32 1.115 28.32 1.265 32.13 1.265 32.13 1.215 30.86 1.215 30.86 1.800 45.72 1.800 45.72 No. of Contacts 9 Plug 9 Socket 15 Plug 15 Socket 21 Plug 21 Socket 25 Plug 25 Socket 31 Plug 31 Socket 37 Plug 37 Socket 51 Plug 51 Socket 100 Plug 100 Socket F ± .010 (0.25) in mm .230 5.84 .230 5.84 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .130 3.30 .150 3.81 .150 3.81 .200 5.08 .200 5.08 G ± .010 (0.25) in mm .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .250 6.35 .300 7.62 .300 7.62 .400 10.16 .400 10.16 Call Toll Free: 1 (800) 323-9612 C Max. in .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .308 .351 .351 .394 .394 mm 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 7.82 8.92 8.92 10.00 10.00 H Max. in .420 .420 .420 .420 .420 .420 .420 .420 .520 .520 .520 .520 .650 .650 1.000 1.000 mm 10.67 10.67 10.67 10.67 10.67 10.67 10.67 10.67 13.21 13.21 13.21 13.21 16.51 16.51 25.40 25.40 5-30 J ± .005 (0.13) in mm .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .996 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .096 2.44 .125 3.18 .125 3.18 Dura-Con High Reliability MIL-C-83513 .050" (1.27mm) Density Solder Cup/Wire/PCB D-Microminiature Mounting Hardware 5 Ordering Information Type Style Jackscrew Low Profile Jackscrew High Profile Jackscrew Low Profile Jackscrew High Profile Jackpost -Jackscrew Low Profile Jackscrew High Profile Jackscrew Low Profile Jackscrew High Profile Jackpost -*100 Size Only Screwhead Recessed Hex Recessed Hex Slotted Slotted -Hex Hex Slotted Slotted -- Thread 2/56 2/56 2/56 2/56 2/56 4/40* 4/40* 4/40* 4/40* 4/40* Military Part No. M83513/5-02 M83513/5-03 M83513/5-05 M83513/5-06 M83513/5-07 M83513/5-12 M83513/5-13 M83513/5-15 M83513/5-16 M83513/5-17 5-31 Call Toll Free: 1 (800) 323-9612 Dura-Con .050" (1.27mm) Density High Reliability Connector Saver All-Plastic & Metal Shell FEATURES ■ Designed to significantly reduce damage to already mounted Dura-Con connectors during routine system tests. ■ Eliminates numerous mating & unmating cycles experienced by connectors on test harnesses. ■ Plug connector on one end, socket connector on the other. ■ Available in all-plastic (polyester) or in metal shell with diallyl phthalate or polyester insulators (both UL94V-0 rated). ■ Locking hardware must be ordered separately. MATERIALS Insulator: UL94V-0 glass-filled polyester or diallyl phthalate Contacts: Copper alloy Contact Plating: .000050 in gold Shell (Metal Only): Aluminum alloy MECHANICAL ELECTRICAL ENVIRONMENTAL Shell Plating: Yellow chromate over cadmium Operating Temperature: -55°C to +135°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level 8 milliohms maximum Individual Contact: Insertion force, 6 oz. (170.40 g) maximum; Withdrawal force 0.5 oz. (14.20 g) minimum Mating / Unmating Forces: See previous tables No. of Contacts 9 15 21 25 31 37 51 100 Diallyl Phthalate Catalog No. DCCM9CS DCCM15CS DCCM21CS DCCM25CS DCCM31CS DCCM37CS DCCM51CS DCCM100CS Metal Shell Glass-Filled Polyester Catalog No. DCDM9CS DCDM15CS DCDM21CS DCDM25CS DCDM31CS DCDM37CS DCDM51CS DCDM100CS Call Toll Free: 1 (800) 323-9612 5-32 All Plastic Glass-Filled Polyester Catalog No. DCDA9CS DCDA15CS DCDA21CS DCDA25CS DCDA31CS DCDA37CS DCDA51CS – Dura-Con High Reliability Microedge Connectors FEATURES ■ ■ ■ ■ ■ ■ .050" (1.27mm) Density PC Board Mount Metal Shell Variety of available PC board mounting styles. - “Coke Bottle” for edge mounting on double-sided PCBs - Right-angle (90°) mounting for single- or double-sided daughter boards - “Claw Foot” leads - Gold-plated solid copper wire pigtails Harnessing capabilities exist for both plug & socket. Standard sizes are 128 and 184 positions. Utilizes high-reliability Dura-Con twist pin contact system assuring electrical continuity under extreme shock and vibration. Aluminum shells and diallyl phthalate insulators make Dura-Con microedge connectors ideal for airborne or space applications. Microedge metal shell connectors meet the requirement of MIL-C-55302. MATERIALS Insulator: UL94V-0 glass-filled polyester or diallyl phthalate per MIL-M-14 (green) Contacts: Copper alloy Contact Plating: .000050 in Gold Shell: Aluminum alloy MECHANICAL ELECTRICAL ENVIRONMENTAL Shell Plating: Electroless Nickel Operating Temperature: -55°C to +135°C Current Rating: Withstanding Voltage: Contact Resistance: 3 Amps maximum 600 VAC RMS @ sea level, 300 VAC @ 70,000 ft. 8 milliohms maximum Insertion/Withdrawal Force: 6 oz. (170.40 g[f]) maximum insertion force, per contact; 0.5 oz. (14.20 g[f]) minimum withdrawal force, per contact Call Toll Free: 1 (800) 323-9612 5-34 Dura-Con High Reliability Microedge Connectors .050" (1.27mm) Density PC Board Mount Metal Shell 5 5-35 Call Toll Free: 1 (800) 323-9612 Dura-Con High Reliability Microedge Connectors .050" (1.27mm) Density PC Board Mount Metal Shell Recommended PCB thickness .047-.062. Consult factory for other thicknesses. 5 * Narrow Version (DNEB) .250 Wide Call Toll Free: 1 (800) 323-9612 5-36 Dura-Con High Reliability Microedge Connectors .050" (1.27mm) Density PC Board Mount Metal Shell 184 Contact Plug (Standard Insulated Wire) Side View * Narrow Version (DNEB) .250 Wide Shell Polarization Kit Order No. DNEBP0L1 DMEBP0L1 “L” .250 .312 Key L Used On DNEB Narrow Only DMEB Std. Width Mounting Hardware Standard Jackscrew/Jackpost Assembly Removable Jackscrew/Jackpost Assembly Plug with Jackscrew Consult factory if required. Ordering Information Receptacle with Jackscrew DMEB 1-128 P 6 E 2 180 Series Prefix DMEB = Microedgeboard DNEB = Microedgeboard, Narrow (184 Only) Lead Length in Inches Contact Spacing 1 = .050" (1.27mm) centers 128/184 2 = .100" (2.54mm) centers 64/92 (every other contact hole) For other contact spacing accommodations, consult the factory. Termination, Color of Finish 1 = White *2 = Yellow 3 = Tin-Plated *4 = Gold-Plated (Solid Copper Wire Only) *5 = Color Coded per MIL-Std. 681, System 1 No. of Contacts 128, 184 Wire Type/Termination Style C = Solid Copper E = MIL-W-16878/4, 7 Strand BS = PC Board (Coke Bottle) BRA = PC Board Right-Angle (Formed to “A” Side) BRB = PC Board Right-Angle (Formed to “B” Side) W = PC Board (Claw Foot) Contact Type P = Pin S = Socket Wire Size in AWG 5 = 25 AWG Solid Copper 6 = 26 AWG Stranded Wire S = Solder Cup *Indicates Cinch std Option 5-37 Call Toll Free: 1 (800) 323-9612 5 Dura-Con High Reliability Strip Connectors .050" (1.27mm) Density Solder Cup/Wire All-Plastic ■ Lightweight. FEATURES ■ Slim Profile. ■ High-Density Interconnect. ■ High-reliability Dura-Con twist pin contact system for extreme shock & vibration applications. ■ Optional polarization with guide pins to prevent mismating connectors. MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS ■ Plug & socket available in sizes from 1 to 60 positions. Insulator: UL94V-0 glass-filled polyester Contacts: Copper alloy Contact Plating: .000050 in gold Operating Temperature: -55°C to +135°C Current Rating: 3 Amps maximum Withstanding Voltage: 600 VAC @ sea level; 150 VAC @ 70,000 ft. Contact Resistance: 8 milliohms maximum Insertion & Withdrawal Force (Per Contact): 6 oz. (170.40 g[f]) maximum insertion; 0.5 oz. (14.20 g[f]) minimum withdrawal Call Toll Free: 1 (800) 323-9612 5-38 Dura-Con High Reliability Strip Connectors .050" (1.27mm) Density Solder Cup/Wire All Plastic Dimensions Socket Connector Pin Connector Epoxy 24 Gauge Stainless Steel Guide Pin* NOTE: Dimension A is number of positions less 1 multiplied by .050 * Assembly in socket connector only. Ordering Information CS A 1 10 P 4 C 4-00.5 G Cinch Dura-Con Strip Thermoplastic Glass-Reinforced Strip Connector Guide Pin (Socket Only) Empty Cavity (Pin Only) G02 = Guide Pin Position No. 2 GX = Special Position, Consult Factory Contact Centers A = .050 (24 Ga.) Contact Position 1 = Contacts in every position Lead Length in inches 00.5 Solid copper wire only 01.0 Solid copper wire only 02.0 Solid copper wire only 18.0 Stranded wire only 24.0 Stranded wire only 36.0 Stranded wire only 48.0 Stranded wire only No. of Contact Positions 1 through 60** Contact Type P = Pin S = Socket Insulation Color, Solid Wire Finish, Solid Cup Finish 1 = All White *2 = All Yellow 3 = Tin-Plated *4 = Gold-Plated (Solid Wire Only) *5 = Color Coded Per MIL-Std. 681, System 1 System 1. (Stranded Wire Only) Wire Size in AWG 5 = 25 AWG Solid Copper Wire 6 = 26 AWG Stranded Wire S = Solder Cup (Skip to guide pin field if necessary) Insulation Wire or Solid Wire Type C = Solid Copper E = MIL-W-168 78/4, 7 Strand * - Indicates Cinch std. option. ** - Consult factory for larger sizes and multi-row. 5-39 Call Toll Free: 1 (800) 323-9612 MINIATURE RIBBONS IDC SUPERIBBON™ & Metal Shell Vertical Mount Compliant Pin Solder Cup Right-Angle Solder Tail Wire Wrap Vertical Mount Solder Tail Accessories & Application Tooling .085 in. (2.16mm) Density Miniature Ribbon Introduction The Miniature Ribbon connector has been a mainstay in the electronics industry for decades. First widely used in telecommunications, it has proven itself to be a very reliable interconnection system, with generous wiping action, high contact pressure, large mating surface area in a relatively compact format, and polarized shells to ensure proper orientation in mating. The Miniature Ribbon connector gets its name from the ribbon-like shape of the mating end of the contact. It is a derivative of the first connector design to incorporate this type of interconnection where mating members are equally flexible. Each contact is backed up by its respective insulator, resulting in high contact pressure without concern over relaxation that can occur with a beam or cantilever design. Industry standard sizes for this product are 14, 24, 36, 50, and 64 positions. Cinch adheres to industry-standard contact numbering and mating geometry. Cinch has led the way in making the Miniature Ribbon connector one of the most cost-effective yet high-quality connector systems in the industry. From its roots in the telecommunications industry where it is traditionally known as the “Key Telephone” style connector (USOC Type RJ21), Cinch’s innovations in termination, latching, and accessories have helped make the Miniature Ribbon family the choice for applications in computers and instrumentation as well. It is called out as the standard connector for a parallel printer interface (IEEE 1284-B, also known as “Centronics”), multi-purpose peripheral interface (SCSI-1), and instrumentation interface (IEEE-488, also know as “GPIB”). Cinch manufactures one of the most diverse lines of Miniature Ribbon products in the industry. From SUPERIBBONTM all-plastic products with solderless termination to full-metal shell products with solder terminations, and even filtered versions designed to solve EMI problems, Cinch can provide the Miniature Ribbon products you need. Several options are available so you can find the right Cinch Miniature Ribbon product for your application. Cinch’s method of integrating features into the product often reduces overall installed cost compared to other alternatives. Select the termination type, the configuration, the latching and mounting methods to be used, and any accessories that would make the installation of the connector complete. All-Plastic 6-6 6-30 6-38 6-42 6-48 6-48 Metal Shell 6-14 6-24 6-30 6-34 6-42 6-46 IDC Solder Cup Wire Wrap Vertical-Mount Solder Tail Vertical-Mount Compliant Pin Right Angle Solder Tail Filtered Vertical-Mount Solder-Tail Male/Female Adapter Connector Face Views Accessories information starts on page 6-51. Tooling Information starts on pafe 6-54. SUPERIBBON is a trademark of Cinch Connectors, Inc.Systems, Inc. 6-1 Call Toll Free: 1 (800) 323-9612 6 .085 in. (2.16mm) Density Miniature Ribbon Introduction Termination Options Cinch offers products suitable for termination by various methods: • IDC -- Cinch’s patented Insulation Displacement Contact (IDC) provides reliable, low-cost termination to discrete wire, either loose or in jacketed cable. With the use of special tools designed for field and/or factory use, wires can be terminated to the connector without individual cutting, stripping, or soldering. Reliable performance is ensured by the exclusive 4-point contact termination, and the built-in wire strain relief prevents mechanical stress from reaching the termination points. Cinch IDC connectors are available in both Metal Shell and All-Plastic SUPERIBBON versions. They are available to terminate solid conductor (some 22 AWG, and 24-26 AWG) or stranded (24-28 AWG) wire. Likewise, a full range of termination tooling is available. • Wire Wrap -- This termination style, which is also solderless, is often used when termination must be done in place, such as in wired backplanes, etc. Cinch wirewrap terminated Miniature Ribbon connectors are available in both Metal Shell and All-Plastic versions, with either .025" or .045" sq. tails. • Solder Cup -- For those applications where nothing but the lowest termination resistance will do, Cinch offers Metal Shell Miniature Ribbon connectors with solder-cup termination. Available with or without insulator barriers between contact terminal areas, these products will accept up to one 22 AWG solid wire or one 24 AWG stranded wire per contact. • Solder Tail -- This style allows Cinch Miniature Ribbon connectors to be throughhole soldered directly to a printed circuit board. They are available in Vertical Mount and Right-Angle Mount versions. • Compliant Pin -- This style allows termination to a printed circuit board without soldering. This eliminates the costly cleaning/rework associated with soldering, yet the Cinch modified-C type termination will not damage the board’s plating as standard press-fit terminals can. Configuration 6 Cinch Miniature Ribbon and SUPERIBBON products are available as connectors alone to be mounted to a system’s panel or printed circuit board, or complete with hoods for use on various types of cable assemblies. Hooded products are available with cable exits straight back 180 degrees from the mating face (Top-Entry) or with cable exits on either end, 90, or 270 degrees from the mating face (Standard and Reverse Orientation EndEntry). Finally, overmold kits are available allowing you to efficiently and economically manufacture your own “custom” cable assemblies. End-Entry SuperShieldTM connectors and All-Plastic SUPERIBBON connectors feature an integral cable clamp that prevents stress on the termination area, even when the hood is removed during assembly or repair. Top-Entry products have cable clamps built into the hoods. These clamps are adjustable to fit a range of cable sizes. SuperShield is a trademark of Cinch Connectors , Inc. Call Toll Free: 1 (800) 323-9612 6-2 Termination section of IDC contact Piercing/compressing action as wire is pressed into contact .085 in. (2.16mm) Density Miniature Ribbon Introduction Latching Options Miniature Ribbon and SUPERIBBON products exhibit a degree of self-locking inherent in the contact design; however, additional locking means are recommended to prevent connectors from being unmated inadvertently. Choices include: • Screwlock Hardware -- the simplest connectors require the use of separate threaded hardware to lock mating connectors together. Some Cinch Miniature Ribbon cable connectors include locking screws; hardware for other configurations may be found in the Accessories section of the Miniature Ribbon line. Some panel-mount products are available with fixed female (internal thread) screwlocks that provide an integral threaded screwlock as part of the connector. • Bail Latches -- as an alternative to screwlock hardware, Cinch offers many configurations with industry-standard bail latches. These connectors have wire clips on each end of the socket, and mating plugs have notched ends that these clips snap into. Bail latches offer the advantage of operating without any tools. Because of this, they have been standardized into several applications, including “Centronics” 36-position parallel printer interface and SCSI-1 peripheral interface bus. Bail latch sockets include standard “straight” latches, suitable for top entry configurations. Special latches can be ordered to replace one standard latch to fit under the cable on end entry mating plug assemblies. • InstaLatchTM -- all Cinch SUPERIBBON all-plastic sockets and some metal shell Miniature Ribbon sockets are available with a Cinch-patented latching system called InstaLatch. In this passive latching system, spring clips at each end of the socket automatically lock into windows in the shell of the mating plug securing the two connectors together. Audible feedback confirms that the connectors are indeed locked. InstaLatches may be unlocked by depressing the latch at either end of the connector, using almost any small, pointed-end tool. A special tool is also available to unlatch InstaLatches when connectors are laid out in a tight arrangement. • J-Hooks -- These devices, available on selected Miniature Ribbon products, automatically lock onto the nose and hood of mating end entry connectors. They are easily unlatched without special tools and are more accessible than other latches in certain applications. 6 InstaLatch is a trademark of Cinch Connectors, Inc. 6-3 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Introduction Mounting Options Various mounting options are available with Cinch Miniature Ribbon and SUPERIBBON products: • Through-Hole/Threaded Hole -- These products require separate hardware to mount the connector to a panel or other component. Versions are available to accommodate #3, #4, and in some cases, through #8 hardware. Standard size cutouts are adequate for mounting panel-mount connectors to system panels with this type of hardware. They may be front- or rear-mounted. (Sockets with bail latches, however, must be front-mounted unless a modified cutout is used to clear the latch retaining hardware.) Metal Shell PC Mount products are available in some versions with standoffs to the printed circuit board. These may be conductive or insulated. Standard Panel Cutout Recommendations Rear Mounting Front Mounting Dimensions Plug or Fixed-Mount Socket Size 14 24 36 50 A 1.417 (35.99) 1.842 (46.79) 2.352 (59.74) 2.947 (74.85) B 1.098 1.523 2.033 2.628 C Float-Mount Socket D (27.89) .940 (23.88) .580 (38.68) 1.365 (34.67) .580 (51.64) 1.875 (47.63) .580 (66.75) 2.472 (62.79) .580 (14.73) (14.73) (14.73) (14.73) A 1.417 1.842 2.352 2.947 (35.99) (46.79) (59.74) (74.85) B 1.153 1.578 2.088 2.683 SUPERIBBON, Plug or Socket Size 14 24 36 50 64 6 A 1.417 (35.99) 1.842 (46.79) 2.352 (59.74) 2.947 (74.85) 3.592 (91.24) B 1.172 1.597 2.107 2.703 3.298 (29.77) (40.56) (53.52) (68.66) (83.77) C .787 1.212 1.722 2.317 2.912 (19.99) (30.78) (43.74) (58.85) (73.96) D .610 .610 .610 .610 .610 (15.49) (15.49) (15.49) (15.49) (15.49) • Panel Clips -- These devices are add-on accessories for All-Plastic products and are available as optional configurations on certain Metal Shell products. They allow you to mount the connector to the system panel without screws, nuts, or spacers, and leave the connector’s mounting holes free for use in latching, if so desired. • Boardlocks -- These devices, found on certain solder-tail PC mount products, fasten the connector to the printed circuit board with solder as part of the wave soldering process. Thus, there is no additional labor required to complete the assembly, and a cost savings can often be realized. Call Toll Free: 1 (800) 323-9612 6-4 C (29.29) .995 (25.27) (40.08) 1.420 (36.07) (53.04) 1.930 (49.02) (68.15) 2.525 (64.14) D .635 .635 .635 .635 (16.13) (16.13) (16.13) (16.13) .085 in. (2.16mm) Density Miniature Ribbon ■ ■ ■ FEATURES ■ ■ ■ ■ ■ ■ ENVIRONMENTAL MATERIALS ■ Patented contact terminates Discrete Wire (loose or jacketed cable) without stripping or soldering solid- and stranded-wire versions available. All-plastic design reduces cost. Available in plug and socket styles in 14, 24, 36, 50, and 64 position sizes. Includes InstaLatch passive latch feature for automatic latching. Sockets are also available without latches. Available with .125" or #4-40 mounting holes. 50-position size plug also available to lock with industry-standard Bail Latches. Designed for panel mount, 180° (Top-Entry), or 90° (Standard) / 270° (Reverse) End-Entry cable application. Integral Cable Clamp on End-Entry versions provides superior strain relief, even with hood removed. Full range of application tooling is available for termination, unlatching, etc. See page 6-54 for details. UL Recognized - Files E170218 (UL1977), E130965 (UL1863). CSA Approved - File LR31996-7. Insulator: Gray UL94V-0 rated glass-filled polyester, except where noted Contact: Copper alloy Contact Plating: select gold over 50µin. select nickel standard; 30µin. select gold over 50µin. select nickel available where indicated Operating Temperature: -40°C to +105°C Shock: 50G Peak, per EIA Std. RS364, TP27, Condition A Vibration: 3 cycles @ 10-55Hz in each of 3 axes per EIA Std. 364, TP28, Condition A Moisture Resistance: Per EIA Std. RS364, TP31, Condition B, with Step 7B excluded Voltage Rating: Withstanding Voltage: Contact Rating: Contact Resistance: ELECTRICAL IDC, SUPERIBBONTM All-Plastic 500 VAC @ sea level; 125 VAC @ 70,000 ft. 1200 VAC RMS @ sea level, per EIA Std. RS364, TP20 5 Amps (4 Amps per CSA) 6 milliohms maximum, per EIA Std. RS364, TP6 Contact Resistance Change During Life Conditioning: Resistance Change Wire Size (milliohms, max.) 24 AWG Solid 0.5 26 AWG Solid 0.5 26 AWG Stranded 2.0 28 AWG Stranded 5.0 Insulation Resistance: 5000 Megohms minimum initial; 1000 Megohms minimum after moisture Call Toll Free: 1 (800) 323-9612 6-6 .085 in. (2.16mm) Density Miniature Ribbon IDC, SUPERIBBONTM All-Plastic Mechanical Characteristics Durability: 200 mating/unmating cycles Mating / Unmating Forces: Size 14 24 36 50 64 Termination: Mating Force (max.) with InstaLatches Lb. Kg 12 5.44 17 7.71 23 10.43 32 14.52 37 16.78 Unmating Force (min.) without InstaLatches Lb. Kg 2 0.91 4 1.81 6 2.72 7 3.18 8 3.63 Solid IDC versions terminate 22 AWG - 26 AWG solid wire; Stranded IDC versions terminate 24 AWG - 28 AWG stranded wire; Recommended Wire Insulation: soft PVC, .040" (1.02mm) max. OD Wire Grip Strength (using recommended wire type): Wire Size 24 AWG Solid 26 AWG Solid 26 AWG Stranded Minimum Force Lb. Kg 7 3.42 5 2.44 5 2.44 6-7 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon IDC, SUPERIBBONTM All-Plastic Panel Mount Panel mount connectors provide signal I/O from a panel or system cabinet. See pages 6-51 thru 6-53 for accessories such as wire restraints, panel clips, mounting screws, and dust covers that make the use of Cinch SUPERIBBON connectors even more cost-effective in panel-mount applications. Dimensions A Size 14 24 36 50 64 in 1.745 2.170 2.680 3.275 3.875 B mm 44.32 55.12 68.07 83.19 98.43 in 1.417 1.842 2.352 2.947 3.542 D mm 35.99 46.79 59.74 74.85 89.97 in 0.738 1.163 1.673 2.268 2.863 mm 18.75 29.54 42.49 57.61 72.72 6 Call Toll Free: 1 (800) 323-9612 6-8 .085 in. (2.16mm) Density Miniature Ribbon IDC, SUPERIBBONTM All-Plastic Ordering Information, Panel Mount Plug, InstaLatching Mount .125 Hole #4-40 Hole Size 14 24 36 50 64 14 24 36 50 64 Solid Wire Commercial 30Au/Ni 97-12140-11 97-12140-11A 97-12240-11 97-12240-11A 97-12360-11 97-12360-11A 97-12500-11 97-12500-11A 97-12640-11 97-12640-11A 97-12140-01 97-12140-01A 97-12240-01 97-12240-01A 97-12360-01 97-12360-01A 97-12500-01 97-12500-01A 97-12640-01 97-12640-01A Size 14 24 36 50 64 14 24 36 50 64 14 24 36 50 64 14 24 36 50 64 Solid Wire Commercial 30Au/Ni 97-22140-11 97-22140-11A 97-22240-11 97-22240-11A 97-22360-11 97-22360-11A 97-22500-11 97-22500-11A 97-22640-11 97-22640-11A 97-22140-01 97-22140-01A 97-22240-01 97-22240-01A 97-22360-01 97-22360-01A 97-22500-01 97-22500-01A 97-22640-01 97-22640-01A 97-22140-12 97-22140-12A 97-22240-12 97-22240-12A 97-22360-12 97-22360-12A 97-22500-12 97-22500-12A 97-22640-12 97-22640-12A 97-22140-02 97-22140-02A 97-22240-02 97-22240-02A 97-22360-02 97-22360-02A 97-22500-02 97-22500-02A 97-22640-02 97-22640-02A Socket Latch Mount InstaLatches .125 Hole #4-40 Hole No Latches .125 Hole #4-40 Hole 6 6-9 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon IDC, SUPERIBBONTM All-Plastic 180° (Top-Entry) Cable Snap-on plastic top-entry hoods are available separately to provide strain relief to a cable when one of the mounting/ latching options from page 6-9 fits your requirements. See page 6-53 for details and ordering information for top-entry all-plastic hoods. 2.566(65.18) For bail latching applications, a 50-position size top-entry plug is available. It locks with industry-standard bail latches for positive locking/unlocking without tools. It also locks with InstaLatch latches for passive automatic latching. For these products, insulator material is blue UL94V-0 rated glass-filled polyester, and hood material is gray UL94V-0 rated glass-filled polyester. Ordering Information, 180° (Top-Entry) Cable Bail Latching Plug Size 50 Solid Wire Large (.296") Cable Opening Small (.250") Cable Opening Commercial 30Au/Ni Commercial 30Au/Ni 77-32500LP 77-32500LPA 77-32500SP 77-32500SPA 90° (Standard) / 270° (Reverse) End-Entry Cable End-Entry connectors include a hood and integral cable clamp for cable exit from the end of the connector. 6 • The standard-orientation plug has the cable clamp on the position-1 end, and the standard-orientation socket has the clamp on the high position end. • Cables may be extended end-to-end (i.e., “running cable”) by mating standardorientation plugs and sockets, or “doubled back” by mating a standard-orientation connector with a reverse-orientation mate. • Cables may exit either direction on a cable-to-panel application by choosing standard or reverse-orientation, depending on the desired direction of cable exit. • Pointed-nose versions of the standard-orientation, 50-position size are slightly smaller than the square-end product and are suited to applications with limited space such as bridging adapters, etc. • #4-40 versions include screws that are 3/4" long, suitable for locking directly to the body of another connector. For locking to connectors panel-mounted with screwlock hardware, shorter screws are required. See pages 6-51 thru 6-53 for these and other accessories, such as dust covers. Call Toll Free: 1 (800) 323-9612 6-10 Running Cable Application Doubled-Back Cable Application .085 in. (2.16mm) Density Miniature Ribbon IDC, SUPERIBBONTM All-Plastic Dimensions, Square End A Size 14 24 36 50 64 in 2.114 2.539 3.049 3.677 4.511 mm 53.70 64.49 77.44 93.40 114.58 Plug B in 1.417 1.842 2.352 2.947 3.542 mm 35.99 46.79 59.74 74.85 89.97 Socket Ordering Information, Square End Standard (90°) Orientation Plug, InstaLatching Mount .125 Hole #4-40 Hole with Screw Size 14 24 36 50 64 14 24 36 50 64 Solid Wire Commercial 30Au/Ni 97-12140-90 97-12140-90A 97-12240-90 97-12240-90A 97-12360-90 97-12360-90A 97-12500-90 97-12500-90A 97-12640-90 97-12640-90A 97-12140-91 97-12140-91A 97-12240-91 97-12240-91A 97-12360-91 97-12360-91A 97-12500-91 97-12500-91A 97-12640-91 97-12640-91A Size 14 24 36 50 64 14 24 36 50 64 14 24 36 50 64 14 24 36 50 64 Solid Wire Commercial 30Au/Ni 97-22140-90 97-22140-90A 97-22240-90 97-22240-90A 97-22360-90 97-22360-90A 97-22500-90 97-22500-90A 97-22640-90 97-22640-90A 97-22140-91 97-22140-91A 97-22240-91 97-22240-91A 97-22360-91 97-22360-91A 97-22500-91 97-22500-91A 97-22640-91 97-22640-91A 97-22140-92 97-22140-92A 97-22240-92 97-22240-92A 97-22360-92 97-22360-92A 97-22500-92 97-22500-92A 97-22640-92 97-22640-92A 97-22140-93 97-22140-93A 97-22240-93 97-22240-93A 97-22360-93 97-22360-93A 97-22500-93 97-22500-93A 97-22640-93 97-22640-93A Socket Latch Mount InstaLatches .125 Hole #4-40 Hole with Screw No Latches .125 Hole #4-40 Hole with Screw 6-11 6 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon IDC, SUPERIBBONTM All-Plastic Ordering Information, Square End (Cont’d) Reverse (270°) Orientation Plug, InstaLatching Mount .125 Hole #4-40 Hole with Screw Size 14 24 36 50 64 14 24 36 50 64 Solid Wire Commercial 30Au/Ni 97-12140-270 97-12140-270A 97-12240-270 97-12240-270A 97-12360-270 97-12360-270A 97-12500-270 97-12500-270A 97-12640-270 97-12640-270A 97-12140-271 97-12140-271A 97-12240-271 97-12240-271A 97-12360-271 97-12360-271A 97-12500-271 97-12500-271A 97-12640-271 97-12640-271A Size 14 24 36 50 64 14 24 36 50 64 14 24 36 50 64 14 24 36 50 64 Solid Wire Commercial 30Au/Ni 97-22140-270 97-22140-270A 97-22240-270 97-22240-270A 97-22360-270 97-22360-270A 97-22500-270 97-22500-270A 97-22640-270 97-22640-270A 97-22140-271 97-22140-271A 97-22240-271 97-22240-271A 97-22360-271 97-22360-271A 97-22500-271 97-22500-271A 97-22640-271 97-22640-271A 97-22140-272 97-22140-272A 97-22240-272 97-22240-272A 97-22360-272 97-22360-272A 97-22500-272 97-22500-272A 97-22640-272 97-22640-272A 97-22140-273 97-22140-273A 97-22240-273 97-22240-273A 97-22360-273 97-22360-273A 97-22500-273 97-22500-273A 97-22640-273 97-22640-273A Socket Latch Mount InstaLatches .125 Hole #4-40 Hole with Screw No Latches .125 Hole 6 #4-40 Hole with Screw Call Toll Free: 1 (800) 323-9612 6-12 .085 in. (2.16mm) Density Miniature Ribbon IDC, SUPERIBBONTM All-Plastic Pointed-End 50-Position 90° End-Entry Cable Ordering Information, Pointed-End Solid Wire #4-40 Threaded Hole with Screw Commercial 30Au/Ni Plug, InstaLatching With Dust Cover Without Dust Cover 97-12500-91PD 97-12500-91PDA 97-12500-91P 97-12500-91PA Socket, InstaLatching With Dust Cover Without Dust Cover 97-22500-91PD 97-22500-91PDA 97-22500-91P 97-22500-91PA Socket, No Latches With Dust Cover Without Dust Cover 97-22500-93PD 97-22500-93PDA 97-22500-93P 97-22500-93PA 6-13 Call Toll Free: 1 (800) 323-9612 6 .085 in. (2.16mm) Density Miniature Ribbon ■ ■ ■ FEATURES ■ ■ ■ ■ ■ ■ ■ IDC Metal Shell Patented contact terminates Discrete Wire (loose or jacketed cable) without stripping or soldering. Solid and stranded wire versions available. Metal shell provides grounding and shielding capability. Available in plug and socket styles in 14, 24, 36, and 50 position sizes. Designed for panel mount, 180° (Top-Entry), or 90° (Standard) / 270° (Reverse) End-Entry cable applications. Available as overmold kit in 36 and 50 position sizes. All Plugs lock with InstaLatch passive latch feature for automatic latching. Sockets available with InstaLatches where indicated. Industry-standard bail latch feature available for locking/unlocking without tools in applications such as SCSI-1 and Centronics. Full range of application tooling available for termination, unlatching, etc. See page 6-54 for details. UL Recognized - Files E170218 (UL1977), E130965 (UL1863). CSA Approved - File LR31996-7. Insulator: Blue UL94V-0 rated glass-filled polyester MATERIALS Contact: Copper alloy Contact Plating: Select gold over 50µin. select nickel standard; 30µin. select gold over 50µin. select nickel available where indicated Shell: Steel ENVIRONMENTAL Shell Plating: Zinc with clear chromate coating standard Tin available where indicated Operating Temperature: -40°C to +105°C Shock: 50G Peak, per EIA Std. RS364, TP27, Condition A Vibration: 3 cycles @ 10-55Hz in each of 3 axes per EIA Std. 364, TP28, Condition A Moisture Resistance: Per EIA Std. RS364, TP31, Condition B, with Step 7B excluded Voltage Rating: Withstanding Voltage: 500 VAC @ sea level; 125 VAC @ 70,000 ft. 1200 VAC RMS @ sea level, per EIA Std. RS364, TP20 ELECTRICAL Contact Rating: Contact Resistance: 5 Amps (4 Amps per CSA) 6 milliohms maximum, per EIA Std. RS364, TP6 Contact Resistance Change During Life Conditioning: Resistance Change Wire Size (milliohms, max.) 24 AWG Solid 0.5 26 AWG Solid 0.5 26 AWG Stranded 2.0 28 AWG Stranded 5.0 Insulation Resistance: 5000 Megohms minimum initial; 1000 Megohms minimum after moisture Call Toll Free: 1 (800) 323-9612 6-14 .085 in. (2.16mm) Density Miniature Ribbon IDC Metal Shell Mechanical Characteristics Durability: 200 mating/unmating cycles Mating / Unmating Forces: Size 14 24 36 50 Termination: Mating Force (max.) with InstaLatches Lb. Kg 12 5.44 17 7.71 23 10.43 32 14.52 Unmating Force (min.) without InstaLatches Lb. Kg 2 0.91 4 1.81 6 2.72 7 3.18 Solid IDC versions terminate 22 AWG - 26 AWG solid wire; Stranded IDC versions terminate 24 AWG - 28 AWG stranded wire; Recommended Wire Insulation: soft PVC, .040" (1.02mm) max. OD Wire Grip Strength (using recommended wire type): Wire Size 24 AWG Solid 26 AWG Solid 26 AWG Stranded Min. Force Lb. Kg 7 3.42 5 2.44 5 2.44 6-15 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon IDC Metal Shell Panel Mount “Panel mount” products are connectors without hoods. They are typically used to provide signal I/O from a system panel or cabinet, where strain relief to a cable jacket is not required. • Standard versions have .103" mounting holes (sockets have .103" with float bushings) for use with #3 hardware, or with .185" mounting holes for use with #8 hardware. • Select sizes are available with .120" or .113" mounting holes for use with #4 hardware, or with integral panel clips, which allow snap-in front mounting on .093" thick panels for more cost-effective assembly. • Bail latching sockets are available, as are bail latching plugs. While the plugs would not be panel-mounted, they are available for premold/solder overmolding applications. • SuperShield products include modified shells that assure interference fit between mated connectors for improved shielding performance. See page 6-4 for recommended standard panel cutout dimensions. See pages 6-51 thru 6-52 for accessories such as wire restraints, mounting screws, and dust covers, which make the use of Cinch Miniature Ribbon connectors even more cost-effective in panel-mount applications. See the appropriate cable connector section that follows for products that include hoods for exposed-cable applications. Dimensions Size 14 24 36 50 in 1.750 2.175 2.685 3.280 A mm 44.45 55.25 68.20 83.31 B in 1.417 1.842 2.352 2.947 C mm 35.99 46.79 59.74 74.85 in 0.910 1.335 1.845 2.440 mm 23.11 33.91 46.86 61.98 D in mm 2.426 61.62 3.020 76.71 Socket Plug A Max. A Max. B Max. B Max. 6 Call Toll Free: 1 (800) 323-9612 6-16 .085 in. (2.16mm) Density Miniature Ribbon IDC Metal Shell Ordering Information, Panel Mount Plug, InstaLatching Mount .103 Hole .103 Hole Tin-Plated Shells .185 Hole .185 Hole Tin-Plated Shells .120 Hole .120 Hole, Tin-Plated Shells * Integral Panel Clips SuperShield, .133 Hole Bail Latching Tin-Plated Shells .103 Hole Fixed 4-40 Screwlock SuperShield, .103 Hole Size 14 24 36 50 24 36 50 14 24 36 50 24 36 50 50 50 50 36 50 50 50 50 Solid Wire Commercial 30Au/Ni 77-12140 77-12140A 77-12240 77-12240A 77-12360 77-12360A 77-12500 77-12500A 77-12240-32 77-12240-32A 77-12360-32 77-12360-32A 77-12500-32 77-12500-32A 77-12140-185 77-12140-185A 77-12240-185 77-12240-185A 77-12360-185 77-12360-185A 77-12500-185 77-12500-185A 77-12240-186 77-12240-186A 77-12360-186 77-12360-186A 77-12500-186 77-12500-186A 77-12500-120 77-12500-120A 77-12500-121 77-12500-121A 77-12500-SH 77-12500-SHA 77-12360-5 77-12360-5A 77-12500-10 77-12500-10A 77-12500-41 77-12500-41A 77-12500-43 77-12500-43A 77-12500-SC 77-12500-SCA *Integral Panel Clips, for front-mount only, require modified panel cutout. See page 6-52 for details. Bail Latching Through Hole “D” Ref. “C” Max. 6 Integral Panel Clip 6-17 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon IDC Metal Shell Ordering Information, Panel Mount (Cont’d) Socket Mount No Latches Float Mounts with .103 Hole .103 Hole Tin-Plated Shells .185 Hole .185 Hole Tin-Plated Shells .120 Hole Integral Panel Clips*, .103 Hole InstaLatches Bail Latches Integral Panel Clips* Fixed 4-40 Screwlocks .116 Hole .116 Hole with Tin-Plated Shell .103 Hole Tin-Plated Shell .113 Hole Tin-Plated Shell Size 14 24 36 50 24 36 50 14 24 36 50 24 36 50 50 50 Solid Wire Commercial 30Au/Ni 77-22140 77-22140A 77-22240 77-22240A 77-22360 77-22360A 77-22500 77-22500A 77-22240-34 77-22240-34A 77-22360-34 77-22360-34A 77-22500-34 77-22500-34A 77-22140-185 77-22140-185A 77-22240-185 77-22240-185A 77-22360-185 77-22360-185A 77-22500-185 77-22500-185A 77-22240-186 77-22240-186A 77-22360-186 77-22360-186A 77-22500-186 77-22500-186A 77-22500-120 77-22500-120A 77-22500-41 77-22500-41A 50 14 24 36 50 36 50 77-22500-43 77-42140 77-42240 77-42360 77-42500 77-42360-5 77-42500-5 77-22500-43A 77-42140A 77-42240A 77-42360A 77-42500A 77-42360-5A 77-42500-5A 50 77- 22500-36 77- 22500-36A 50 77-22500-38 77-22500-38A 50 77-22500-SC 77-22500-SCA SuperShield, .103 Hole with Integral Panel Clips* * Integral Panel Clips, for front-mount only, require modified panel cutout. See page 6-52 for details. Bail Latching Through Hole 6 Float Mount Call Toll Free: 1 (800) 323-9612 6-18 .085 in. (2.16mm) Density Miniature Ribbon IDC Metal Shell 180° (Top-Entry) Cable Top-Entry products include a connector, hood (or overmold can), and associated hardware. They are typically used at the end of a cable, where it is subject to physical strain and protection of the termination area is required. • • • • • Includes all hardware required to attach hood to connector. Bail latching sockets have latch hardware integral to the connector body, making cable assembly more efficient. Bail latching plugs include notches that lock with industry-standard bail-latch sockets. Select configurations are available as overmold kits, which lower assembly costs by eliminating premolding and foil soldering. Kits include connector and overmold cans. Crimp ferrules, which ground cable shields and provide strain relief, must be ordered separately. Ordering information for crimp ferrules is at end of end-entry product section. See page 6-22. Plug C H Socket Dimensions A Size 14 24 36 50 in 1.417 1.842 2.352 2.947 B mm 35.99 46.79 59.74 74.85 in 1.750 2.175 2.685 3.270 C mm 44.45 55.25 68.20 83.06 in .306 .473 .639 .766 D mm 7.77 11.10 16.23 19.46 in 1.495 1.920 2.431 3.025 E mm 37.97 48.77 61.75 76.84 6-19 in 1.83 2.43 mm 46.48 61.72 F Deg. 37° 27° G in .422 .473 .473 .473 mm 10.72 12.01 12.01 12.01 H in .843 .825 .905 .995 M mm 21.41 20.96 22.99 25.27 in .52 .60 Call Toll Free: 1 (800) 323-9612 mm 13.21 15.24 6 .085 in. (2.16mm) Density Miniature Ribbon IDC Metal Shell Ordering Information, 180° (Top-Entry) Cable Plug, InstaLatching Solid Wire Overmold kit Mount Size 14 Bail Latching 24 36 50 Captive 4-40 Screws 50 Bail Latching, 36 Tin Shell 50 .103 Hole, Tin Shell 36 50 Commercial 77-32140 77-32240 77-32360 77-32500 77-32500-30 77-32360-51 77-32500-51 77-32360-52 77-32500-52 30Au/Ni 77-32140A 77-32240A 77-32360A 77-32500A 77-32500-30A 77-32360-51A 77-32500-51A 77-32360-52A 77-32500-52A Socket Solid Wire Mount Overmold kit InstaLatch With Bail Latches .103 Hole, Tin-Plated Shells .113 Hole, Tin-Plated Shells Size 14 24 36 50 Commercial 77-62140 77-62240 77-62360 77-62500 30Au/Ni 77-62140A 77-62240A 77-62360A 77-62500A 50 77-62500-54 77-62500-54A 50 77-62500-55 77-62500-55A 6 Call Toll Free: 1 (800) 323-9612 6-20 .085 in. (2.16mm) Density Miniature Ribbon IDC Metal Shell 90° (Standard) / 270° (Reverse) End-Entry Cable End-Entry connectors, available in 50 position size only, include a hood and integral cable clamp for cable exit from the end of the connector. • The standard-orientation plug has the cable clamp on the position 1/26 end, and the standard-orientation socket has the clamp on the position 25/50 end. • Cables may be extended end-to-end (i.e., “running cable”) by mating standardorientation plugs and sockets, or “doubled back” by mating a standardorientation connector with a reverse-orientation mate. • Cables may exit either direction on a cable-to-panel application by choosing standard or reverse-orientation, depending on the desired direction of cable exit. Running Cable Application • Include screw that is 5/8" long, suitable for locking directly to the body of another connector. For locking to connectors panel-mounted with screwlock hardware, shorter screws are required. See page 6-51 for these and other accessories, such as dust covers. Double-Back Cable Application Ordering Information, End-Entry Standard (90°) Orientation Solid Wire Socket no latches Plug Mount High (Standard) Hood Low-Profile Hood SuperShield, 4-40 Screw High (Standard) Hood Low-Profile Hood SuperShield, 4-40 Screw Size Commercial 50 50 50 50 50 50 77-72500 77-72500-1 77-72500-SS 77-82500 77-82500-1 77-82500-SS Size Commercial 30Au/Ni 6 77-72500A 77-72500-1A 77-72500-SSA 77-82500A 77-82500-1A 77-82500-SSA Reverse (270°) Orientation Solid Wire Socket no latches Plug Mount High (Standard) Hood Low-Profile Hood High (Standard) Hood Low-Profile Hood 50 50 50 50 77-72500-270 77-72500-271 77-82500-270 77-82500-271 30Au/Ni 77-72500-270A 77-72500-271A 77-82500-270A 77-82500-271A 6-21 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon IDC Metal Shell Overmold Kit, End-Entry (May be assembled with cable exit in either direction) Socket InstaLatch Ordering Information, End-Entry Overmold Kit Plug, Bail Latching, Tin Shell .103 Hole, Tin-Plated Shells .113 Hole, Tin-Plated Shells Size 50 50 50 Solid Wire Commercial 30Au/Ni 77-72500-51 77-72500-51A 77-82500-54 77-82500-54A 77-82500-55 77-82500-55A Overmold Crimp Ferrules • Connect cable’s shield to can of overmold kit • Seal off cable exit to keep molding compound from penetrating termination cavity See page 6-56 for tools and dies required to crimp ferrules onto overmold cans. Ferrule .50 Ref. Ordering Information, Overmold Crimp Ferrules 6 Kit Size 36 50 Max. Cable O.D. 0.400 0.390 0.480 Ferrule Part Number CF-64 CF-60 CF-57 Call Toll Free: 1 (800) 323-9612 Dimensions G H .480 (12.19) .400 (10.16) .580 (14.73) .390 (9.91) .580 (14.73) .480 (12.19) 6-22 .085 in. (2.16mm) Density Miniature Ribbon Solder Cup Metal Shell Terminates Discrete Wire (loose or jacketed cable) with ultra-low-resistance solder connections. ■ Metal shell provides grounding and shielding capability. ■ Available in plug and socket styles in 14, 24, 36, and 50 position sizes. FEATURES ■ ■ Designed for panel mount, 180° (Top-Entry), or 90° (Standard) / 270° (Reverse) End-Entry cable applications. All plugs lock with InstaLatch passive latch feature for automatic latching. ■ Industry-standard bail latch feature available for locking/unlocking without tools in applications such as SCSI-1 and Centronics. ■ UL Recognized - Files E170218 (UL1977), E130965 (UL1863). ■ CSA Approved - File LR31996-7. ■ MATERIALS Insulator: Blue UL94V-0 rated diallyl phthalate type MDG, per MIL-M14F Contact: Copper alloy Contact Plating: Select gold over 50µin. select nickel standard; 30µin. select gold over 50µin. select nickel available where indicated Shell: Steel ENVIRONMENTAL Shell Plating: Zinc with clear chromate coating Operating Temperature: -40°C to +105°C Shock: 50G Peak, per EIA Std. RS364, TP27, Condition A Vibration: 3 cycles @ 10-55Hz in each of 3 axes per EIA Std. 364, TP28, Condition A Moisture Resistance: Per EIA Std. RS364, TP31, Condition B, with Step 7B excluded ELECTRICAL Voltage Rating: Withstanding Voltage: Contact Rating: Contact Resistance: Insulation Resistance: 500 VAC @ sea level; 125 VAC @ 70,000 ft. 1200 VAC RMS @ sea level, per EIA Std. RS364, TP20 5 Amps (4 Amps per CSA) 6 Milliohms maximum, per EIA Std. RS364, TP6 5000 Megohms minimum initial; MECHANICAL 1000 Megohms minimum after moisture Durability: 200 mating/unmating cycles Mating / Unmating Forces: Mating Force (max.) Unmating Force (min.) Size Lb. Kg Lb. Kg 14 5 2.27 2 0.91 24 8 3.63 4 1.81 36 12 5.44 6 2.72 50 15 6.80 7 3.18 Termination: Each contact accepts maximum 22 AWG solid wire or maximum 24 AWG stranded wire Call Toll Free: 1 (800) 323-9612 6-24 .085 in. (2.16mm) Density Miniature Ribbon Solder Cup Metal Shell Panel Mount “Panel mount” products are connectors without hoods. They are typically used to provide signal I/O from a system panel or cabinet, where strain relief to a cable jacket is not required. • Available with high barrier insulators that extend beyond the end of the solder cup, physically isolating adjacent contacts. • Standard versions have .103" mounting holes (sockets have .103" with float bushings) for use with #3 hardware, or .185" mounting holes for use with #8 hardware. • Select sizes are available with .120" mounting holes for use with #4 hardware, or with integral panel clips, which allow snap-in front mounting for more cost-effective assembly. • Bail latching sockets are available, as are bail latching plugs. While the plugs would not be panelmounted, they are available for premold/solder overmolding applications. See page 6-4 for recommended standard panel cutout dimensions. See page 6-51 for accessories such as mounting screws and dust covers, which make the use of Cinch Miniature Ribbon connectors even more cost-effective in panel-mount applications. See the appropriate cable connector section that follows for products that include hoods for exposed-cable applications. Dimensions A Size 14 24 36 50 in 1.750 2.175 2.685 3.260 mm 44.45 55.25 68.20 82.80 B in 1.417 1.842 2.352 2.947 mm 35.99 46.79 59.74 74.85 C in 0.910 1.335 1.845 2.440 mm 23.11 33.91 46.86 61.98 B Max. A Max. B Max. A Max. 6-25 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Solder Cup Metal Shell Through Hole Bail Latches Integral Panel Clips Float Mounts Ordering Information, Panel Mount Plug, InstaLatching No Barrier Mount Size Commercial 14 57-10140 .103 Hole 24 57-10240 36 57-10360 50 57-10500 14 57-10140-185 .185 Hole 24 57-10240-4 36 57-10360-22 50 57-10500-48 .120 Hole 50 Integral Panel Clips*, .103 Hole 50 Bail Latching 36 Tin-Plated Shells 50 † IEEE 1284-B (for foil wrap & overmold applications) 30Au/Ni 57-10140A 57-10240A 57-10360A 57-10500A 57-10140-185A 57-10240-4A 57-10360-22A 57-10500-48A - High Barrier Commercial 30Au/Ni 57-10140-6 57-10140-6A 57-10240-6 57-10240-6A 57-10360-14 57-10360-14A 57-10500-6 57-10500-6A 57-10500-120 57-10500-120A 57-10500-41 57-10500-41A 57-10360-28† 57-10360-28A† 57-10500-79 57-10500-79A 30Au/Ni 57-20140A 57-20240A 57-20360A 57-20500A 57-20140-4A 57-20240-2A 57-20360-3A 57-20500-15A 57-40140A 57-40240A 57-40360A† 57-40500A High Barrier Commercial 30Au/Ni 57-20140-6 57-20140-6A 57-20240-6 57-20240-6A 57-20360-10 57-20360-10A 57-20500-6 57-20500-6A 57-20500-120 57-20500-120A 57-20500-41 57-20500-41A 57-40140-HB 57-40140-HBA 57-40240-HB 57-40240-HBA 57-40360-9† 57-40360-9A† 57-40500-4 57-40500-4A Socket No Barrier Latch No latches Float Mounts with .103 Hole .185 Hole .120 Hole Integral Panel Clips*, .103 Hole Bail latches 6 Mount .116 Hole Size 14 24 36 50 14 24 36 50 50 50 14 24 36 50 Commercial 57-20140 57-20240 57-20360 57-20500 57-20140-4 57-20240-2 57-20360-3 57-20500-15 57-40140 57-40240 57-40360† 57-40500 .116 Hole with Tin-Plated Shell 50 57-40500-5 57-40500-5A * Integral Panel Clips, for front-mount only, require modified panel cutout. See page 6-52 for details. † IEEE 1284-B Call Toll Free: 1 (800) 323-9612 6-26 57-40500-28† 57-40500-28A† .085 in. (2.16mm) Density Miniature Ribbon Solder Cup Metal Shell 180° (Top-Entry) Cable Top-Entry products include a connector, hood, and associated hardware. They are typically used at the end of a cable, where it is subject to physical strain and protection of the termination area is required. • Includes all hardware required to attach hood to connector. • Bail latching sockets have latch hardware integral to connector body, making cable assembly less costly. • Bail latching plugs include notches that lock with industry-standard bail-lock sockets. Socket Plug Dimensions A Size 14 24 36 50 in 1.417 1.842 2.352 2.947 B mm 35.99 46.79 59.74 74.85 in 1.750 2.175 2.685 3.270 C mm 44.45 55.25 68.20 83.06 in .306 .473 .639 .766 D mm 7.77 11.10 16.23 19.46 in 1.495 1.920 2.431 3.025 E mm 37.97 48.77 61.75 76.84 in .843 .825 .905 .995 F mm 21.41 20.96 22.99 25.27 in .306 .473 .640 .766 G mm 7.77 12.01 16.26 19.46 in .422 .473 .473 .473 mm 10.72 12.01 12.01 12.01 Ordering Information, 180° (Top-Entry) Cable Plug, InstaLatching Mount Bail Latching #4-40 Holes for captive screw Size 14 24 36 50 50 Commercial 57-30140 57-30240 57-30360 57-30500 57-30500-4 No Barrier 30Au/Ni 57-30140A 57-30240A 57-30360A 57-30500A 57-30500-4A High Barrier Commercial 30Au/Ni 57-30500-3 57-30500-3A - Size 14 24 36 50 Commercial 57-60140 57-60240 57-60360 57-60500 No Barrier 30Au/Ni 57-60140A 57-60240A 57-60360A 57-60500A High Barrier Commercial 30Au/Ni - Socket Mount With Bail Latches 6-27 Call Toll Free: 1 (800) 323-9612 6 .085 in. (2.16mm) Density Miniature Ribbon Solder Cup Metal Shell 90° (Standard) / 270° (Reverse) End-Entry Cable End-Entry connectors, available in 50 position size only, include a hood and integral cable clamp for cable exit from the end of the connector • The standard-orientation plug has the cable clamp on the position 1/26 end, and the standard-orientation socket has the clamp on the position 25/50 end. • Cables may be extended end-to-end (i.e., “running cable”) by mating standard-orientation plugs and sockets, or “doubled back” by mating a standard-orientation connector with a reverse-orientation mate. Running Cable Application • Cables may exit either direction on a cable-to-panel application by choosing standard- or reverse-orientation, depending on the desired direction of cable exit. • Include screw that is 5/8" long, suitable for locking directly to the body of another connector. For locking to connectors panel-mounted with screw-lock hardware, shorter screws are required. See page 6-51 for these and other accessories, such as dust covers. Double-Back Cable Application Ordering Information, End-Entry Plug, InstaLatching (High Barrier, with Dust Cover) 6 Mount High (Standard) Hood Low-Profile Hood Size 50 50 Standard (90°) Orientation Commercial 30Au/Ni 57-10500-14 57-10500-14A 57-10500-7 57-10500-7A Reverse (270°) Orientation Commercial 30Au/Ni 57-10500-270 57-10500-270A 57-10500-271 57-10500-271A Socket (High Barrier, with Dust Cover) Mount High (Standard) Hood Low-Profile Hood Size 50 50 Standard (90°) Orientation Commercial 30Au/Ni 57-20500-7 57-20500-7A 57-20500-19 57-20500-19A Call Toll Free: 1 (800) 323-9612 6-28 Reverse (270°) Orientation Commercial 30Au/Ni 57-20500-270 57-20500-270A 57-20500-271 57-20500-271A .085 in. (2.16mm) Density Miniature Ribbon ■ Wire Wrap Metal Shell and All-Plastic Terminates Discrete Wire without soldering, on .025" sq. or .045" sq. tails. FEATURES ■ All-plastic design reduces cost. Metal Shell available where indicated for improved shielding. ■ Available in plug and socket styles in 14, 24, 36, 50, and 64 position sizes. ■ All plugs lock with InstaLatch passive latch feature for automatic latching. Sockets available with InstaLatches where indicated. ■ Available with industry-standard bail latch feature for positive locking/unlocking without tools. ■ UL Recognized - Files E170218 (UL1977), E130965 (UL1863). ■ CSA Approved - File LR31996-7. Insulator (Metal Shell Product): Blue UL94V-0 rated dialyll phthalate type MDG per MIL-M14F MATERIALS Insulator (All-Plastic Product): Gray UL94V-0 rated dialyll phthalate type MDG per MIL-M14F Contact: Copper alloy Contact Plating: Select gold over 50µin. select nickel standard; 30µin. select gold over 50µin. select nickel available where indicated Wire-Wrap Terminal: Cupro nickel Shell (Metal Shell Product): Steel ENVIRONMENTAL Shell Plating (Metal Shell Product): Zinc with clear chromate coating Operating Temperature: -40°C to +105°C Shock: 50G Peak, per EIA Std. RS364, TP27, Condition A Vibration: 3 cycles @ 10-55Hz in each of 3 axes per EIA Std. 364, TP28, condition A Moisture Resistance: Per EIA Std. RS364, TP31, Condition B, with step 7B excluded ELECTRICAL Voltage Rating: Withstanding Voltage: Contact Rating: Contact Resistance: Insulation Resistance: 500 VAC @ sea level; 125 VAC @ 70,000 ft. 1200 VAC RMS @ sea level, per EIA Std. RS364, TP20 5 Amps (4 Amps per CSA) 6 milliohms maximum, per EIA Std. RS364, TP6 5000 Megohms minimum initial; 1000 Megohms minimum after moisture MECHANICAL Durability: 200 mating/unmating cycles Mating / Unmating Forces: Size 14 24 36 50 64 Mating Force (max.) with InstaLatches Lb. Kg 12 5.44 17 7.71 23 10.43 32 14.52 37 16.78 Call Toll Free: 1 (800) 323-9612 Unmating Force (min.) without InstaLatches Lb. Kg 2 0.91 4 1.81 6 2.72 7 3.18 8 3.63 6-30 .085 in. (2.16mm) Density Miniature Ribbon Wire Wrap Metal Shell and All-Plastic Metal Shell • Metal Shell Wire Wrap connectors are available with .025" sq. or .045" sq. x 1.35" (.56" wrap length) terminals. .045" sq. terminals are also available with .850" (.28" wrap length) terminals. • Available with .103" mounting holes for #3 hardware. Sockets also available with bail latches and .116" holes. See page 6-4 for recommended standard panel cutout dimensions. See page 6-51 for accessories such as mounting screws, bent bail latches, and dust covers, which make the use of Cinch Miniature Ribbon connectors even more cost-effective. Dimensions Bail Latches A Sizes 14 24 36 50 in 1.750 2.175 2.665 3.260 B mm 44.45 55.25 67.69 82.80 in 1.417 1.842 2.352 2.947 C mm 35.99 46.79 59.74 74.85 in 0.710 1.135 1.645 2.240 D mm 18.03 28.83 41.78 56.90 in 0.510 0.935 1.445 2.040 mm 12.95 23.75 36.70 51.82 Metal Socket Metal Plug Ordering Information, Metal Shell Plug, InstaLatching .025" sq. x 1.35" Terminals Size 14 .103 Hole .045" sq. x 1.35" Terminals .045" sq. x .85" Terminals Commercial 30Au/Ni Commercial 30Au/Ni Commercial 57-10140-WW1 57-10140-WW1A 57-10140-WW2 57-10140-WW2A 57-10140-WW3 30Au/Ni 57-10140-WW3A 24 57-10240-WW1 57-10240-WW1A 57-10240-WW2 57-10240-WW2A 57-10240-WW3 57-10240-WW3A 36 57-10360-WW1 57-10360-WW1A 57-10360-WW2 57-10360-WW2A 57-10360-WW3 57-10360-WW3A 50 57-10500-WW1 57-10500-WW1A 57-10500-WW2 57-10500-WW2A 57-10500-WW3 57-10500-WW3A Socket .025" sq. x 1.35" Terminals Size 14 .103 Hole .045" sq. x 1.35" Terminals .045" sq. x .85" Terminals Commercial 30Au/Ni Commercial 30Au/Ni Commercial 57-20140-WW1 57-20140-WW1A 57-20140-WW2 57-20140-WW2A 57-20140-WW3 30Au/Ni 57-20140-WW3A 24 57-20240-WW1 57-20240-WW1A 57-20240-WW2 57-20240-WW2A 57-20240-WW3 57-20240-WW3A 36 57-20360-WW1 57-20360-WW1A 57-20360-WW2 57-20360-WW2A 57-20360-WW3 57-20360-WW3A 50 57-20500-WW1 57-20500-WW1A 57-20500-WW2 57-20500-WW2A 57-20500-WW3 57-20500-WW3A 14 57-20140-WW4 57-20140-WW4A - - - - Bail Latches, .116 Hole 24 57-20240-WW4 57-20240-WW4A - - - - 36 57-20360-WW4 57-20360-WW4A - - - - 50 57-20500-WW4 57-20500-WW4A - - - - 6-31 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Wire Wrap Metal Shell and All-Plastic All-Plastic • All-plastic Wire Wrap connectors are available with .025" sq. or .045" sq. x 1.35" (.56" wrap length) terminals. • Available with .141" or .125" mounting holes as indicated, for #4 hardware. • Includes InstaLatch passive latch feature for automatic latching. Sockets also available without latches. See pages 6-4 and 6-52 for recommended panel cutout dimensions. See pages 6-51 thru 6-52 for accessories such as mounting screws and dust covers, which make the use of Cinch Miniature Ribbon connectors even more cost-effective in panel-mount applications. Plug All-Plastic Socket 6 Dimensions, All-Plastic A Size 14 24 36 50 64 in 1.745 2.170 2.680 3.275 3.875 mm 44.32 55.12 68.07 83.19 98.43 B in 1.417 1.842 2.352 2.947 3.542 mm 35.99 46.79 59.74 74.85 89.97 C in 0.710 1.135 1.645 2.240 2.835 Call Toll Free: 1 (800) 323-9612 mm 18.03 28.83 41.78 56.90 72.01 D in 0.510 0.935 1.445 2.040 2.635 6-32 mm 12.95 23.75 36.70 51.82 66.93 .085 in. (2.16mm) Density Miniature Ribbon Wire Wrap Metal Shell and All-Plastic Ordering Information, All-Plastic Plug, InstaLatching Mount .140 Hole Size 24 64 .025" sq. x 1.35" Terminals Commercial 30Au/Ni - .045" sq. x 1.35" Terminals Commercial 30Au/Ni 97-10240-WW2 97-10240-WW2A 97-10640-WW2 97-10640-WW2A Size 14 24 36 50 64 14 24 36 50 64 .025" sq. x 1.35" Terminals Commercial 30Au/Ni 97-22140-WW5 97-22140-WW5A 97-22240-WW5 97-22240-WW5A 97-22360-WW5 97-22360-WW5A 97-22500-WW5 97-22500-WW5A 97-22640-WW5 97-22640-WW5A 97-22140-WW1 97-22140-WW1A 97-22240-WW1 97-22240-WW1A 97-22360-WW1 97-22360-WW1A 97-22500-WW1 97-22500-WW1A 97-22640-WW1 97-22640-WW1A .045" sq. x 1.35" Terminals Commercial 30Au/Ni 97-22140-WW6 97-22140-WW6A 97-22240-WW6 97-22240-WW6A 97-22360-WW6 97-22360-WW6A 97-22500-WW6 97-22500-WW6A 97-22640-WW6 97-22640-WW6A 97-22140-WW2 97-22140-WW2A 97-22240-WW2 97-22240-WW2A 97-22360-WW2 97-22360-WW2A 97-22500-WW2 97-22500-WW2A 97-22640-WW2 97-22640-WW2A Socket No latches Mount .141 Hole InstaLatches .159 Hole .141 Hole .159 Hole 6 6-33 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Solder Tail Metal Shell ■ Straight Solder Tails for solder termination to printed circuit board in lengths for use on all standard ■ ■ FEATURES ■ ■ ■ ■ ■ ■ ■ ■ thickness boards. Surface Mount Compatible; withstands vapor-phase and IR reflow processes. Metal shell provides grounding and shielding capability. Available in plug and socket styles in 14, 24, 36, and 50 position sizes. All plugs lock with InstaLatch passive latch feature for automatic latching. Industry-standard bail latch feature available for locking/unlocking without tools in applications such as SCSI-1 and Centronics. Available, where indicated, with J-Hook latches that automatically lock down mating end-entry connectors. Available, where indicated, with through-hole or threaded standoffs for improved board mounting. Sockets available with through holes or with float mounts to provide limited self-alignment. UL Recognized - Files E170218 (UL1977), E130965 (UL1863). CSA Approved - File LR31996-7. Insulator: Blue UL94V-0 rated diallyl phthalate type MDG, per MIL-M14F MATERIALS Contact: Copper alloy Contact Plating: Select gold over 50µin. select nickel standard; 30µin. select gold over 50µin. select nickel available where indicated. Gold flash on solder tails Shell: Steel ENVIRONMENTAL Shell Plating: Zinc with clear chromate coating standard. Tin available where indicated. Operating Temperature: -40°C to +105°C Shock: 50G Peak, per EIA Std. RS364, TP27, Condition A Vibration: 3 cycles @ 10-55Hz in each of 3 axes per EIA Std. 364, TP28, Condition A Moisture Resistance: Per EIA Std. RS364, TP31, Condition B, with Step 7B excluded ELECTRICAL Voltage Rating: Withstanding Voltage: Contact Rating: Contact Resistance: Insulation Resistance: 500 VAC @ sea level; 125 VAC @ 70,000 ft. 1200 VAC RMS @ sea level, per EIA Std. RS364, TP20 5 Amps (4 Amps per CSA) 6 milliohms maximum, per EIA Std. RS364, TP6 5000 Megohms minimum initial; 1000 Megohms minimum after moisture MECHANICAL Durability: 200 mating/unmating cycles Mating / Unmating Forces: Mating Force (max.) Size Lb. Kg 14 5 2.27 24 8 3.63 36 12 5.44 50 15 6.80 Call Toll Free: 1 (800) 323-9612 Unmating Force (min.) Lb. Kg 2 0.91 4 1.81 6 2.72 7 3.18 6-34 .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Solder Tail Metal Shell Plug, InstaLatching Dimensions A Size 14 24 36 50 in 1.750 2.175 2.685 3.260 B mm 44.45 55.25 68.20 82.80 in 1.417 1.842 2.352 2.947 C mm 35.99 46.79 59.74 74.85 in 0.910 1.335 1.845 2.440 mm 23.11 33.91 46.86 61.98 J-Hook Latches Plug Insulated Standoff Conductive Standoff Ordering Information, Plug, InstaLatching .110" Tail Length (J) (for PCB thickness up to .062" nominal) Mount .103 Hole J-Hook Latches .185 Hole Conductive Standoff .120 (Ref) Hole Conductive Standoff 4-40 Hole Insulated Standoff .120 (Ref) Hole Insulated Standoff 4-40 Hole Conductive Standoff .120 (Ref) Hole Conductive Standoff 4-40 Hole Insulated Standoff .120 (Ref) Hole Insulated Standoff 4-40 Hole 30Au/Ni .145" Tail Length (J) (for PCB thickness up to .093" nominal) Commercial Size Commercial Commercial 30Au/Ni 14 24 36 50 14 24 36 50 57-10140-4 57-10240-3 57-10360-13 57-10500-27 57-DS14P1-1 57-DS24P1-1 57-DS36P1-1 57-DS50P1-1 57-10140-4A 57-10240-3A 57-10360-13A 57-10500-27A 57-DS14P1-1A 57-DS24P1-1A 57-DS36P1-1A 57-DS50P1-1A 57-10140-5 57-10240-5 57-10360-17 57-10500-46 57-DS14P1-2 57-DS24P1-2 57-DS36P1-2 57-DS50P1-2 57-10140-5A 57-10240-5A 57-10360-17A 57-10500-46A 57-DS14P1-2A 57-DS24P1-2A 57-DS36P1-2A 57-DS50P1-2A 57-DS14P2-3 57-10240-12 57-10360-25 57-10500-73 57-DS14P1-3 57-DS24P1-3 57-DS36P1-3 57-DS50P1-3 57-DS14P2-3A 57-10240-12A 57-10360-25A 57-10500-73A 57-DS14P1-3A 57-DS24P1-3A 57-DS36P1-3A 57-DS50P1-3A 50 - - - - 57-10500-76 57-10500-76A 50 - - - - 57-10500-77 57-10500-77A 50 - - - - 57-10500-68 57-10500-68A 50 - - - - 57-10500-69 57-10500-69A 50 - - - - 57-10500J-76 57-10500J-76A 50 - - - - 57-10500J-77 57-10500J-77A 50 - - - - 57-10500J-68 57-10500J-68A 50 - - - - 57-10500J-69 57-10500J-69A 6-35 30Au/Ni .190" Tail Length (J) (for PCB thickness up to .125" nominal) Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Solder Tail Metal Shell Socket Dimensions A Size 14 24 36 50 in 1.750 2.175 2.685 3.260 B mm 44.45 55.25 68.2 82.8 in 1.417 1.842 2.352 2.947 C mm 35.99 46.79 59.74 74.85 in 0.910 1.335 1.845 2.440 mm 23.11 33.91 46.86 61.98 Bail Latches with Standoffs Socket with Bail Latches .116 (2.95) Min. Dia. Socket with Float Bushing J-Hook Latches A B 6 Recommended PCB Hole Layout Call Toll Free: 1 (800) 323-9612 6-36 .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Solder Tail Metal Shell Socket Ordering Information .110" Tail Length (J) (for PCB thickness up to .062" nominal) J-Hook Latches Bail Latches No Latches Latch Mount Float Mounts with .103 Hole .185 Hole .116 Hole Size 14 24 36 50 14 24 36 50 14 24 36 50 Conductive Standoff 4-40 Hole 50 Insulated Standoff .120 (Ref) Hole 50 Insulated Standoff 4-40 Hole 50 Commercial 30Au/Ni .145" Tail Length (J) (for PCB thickness up to .093" nominal) Commercial 30Au/Ni .190" Tail Length (J) (for PCB thickness up to .125" nominal) Commercial 30Au/Ni 57-20140-8 57-20240-8 57-20360-9 57-20500-31 57-20140-12 57-20240-14 57-20360-15 57-20500-65 57-40140-8 57-40240-9 57-40360-12† 57-40500-9 57-20140-8A 57-20240-8A 57-20360-9A 57-20500-31A 57-20140-12A 57-20240-14A 57-20360-15A 57-20500-65A 57-40140-8A 57-40240-9A 57-40360-12A† 57-40500-9A 57-20140-10 57-20240-11 57-20360-13 57-20500-58 57-40140-11 57-40240-11 57-40360-16† 57-40500-16 57-20140-10A 57-20240-11A 57-20360-13A 57-20500-58A 57-40140-11A 57-40240-11A 57-40360-16A† 57-40500-16A 57-DS14S1-3 57-20240-23 57-20360-19 57-20500-85 57-DS14S-3 57-40240-14 57-40360-24† 57-40500-24 57-DS14S1-3A 57-20240-23A 57-20360-19A 57-20500-85A 57-DS14S-3A 57-40240-14A 57-40360-24A† 57-40500-24A - - - - 57-40500-26 57-40500-26A - - - - 57-20500J-78 57-20500J-78A - - - - 57-20500J-79 57-20500J-79A † IEEE 1284-B 6 6-37 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Solder Tail All-Plastic ■ Straight Solder Tails for solder termination to printed circuit board. ■ Available with .145" or .190" tail lengths to suit applications with any thickness PC board. FEATURES ■ All-plastic design reduces cost. ■ Available in plug and socket styles in 14, 24, 36, 50, and 64 position sizes. ■ All plugs lock with InstaLatch passive latch feature for automatic latching. Sockets available with InstaLatches, with Bail Latches in sizes indicated, or with no latches. ■ Available with through holes or with #4-40 holes for mounting/latching. ■ UL Recognized - Files E170218 (UL1977), E130965 (UL1863). ■ CSA Approved - File LR31996-7. MATERIALS Insulator: Gray UL94V-0 rated glass-filled polyester Contact: Copper Alloy Contact Plating: Select gold over 50µin. select nickel standard; 30µin. select gold over 50µin. select nickel available where indicated. Gold flash on ELECTRICAL ENVIRONMENTAL solder tails Operating Temperature: -40°C to +105°C Shock: 50G Peak, per EIA Std. RS364, TP27, Condition A Vibration: 3 cycles @ 10-55Hz in each of 3 axes per EIA Std. 364, TP28, Condition A Moisture Resistance: Per EIA Std. RS364, TP31, Condition B, with Step 7B excluded Voltage Rating: Withstanding Voltage: Contact Rating: Contact Resistance: Insulation Resistance: 500 VAC @ sea level; 125 VAC @ 70,000 ft. 1200 VAC RMS @ sea level, per EIA Std. RS364, TP20 5 Amps (4 Amps per CSA) 6 milliohms maximum, per EIA Std. RS364, TP6 5000 Megohms minimum initial; 1000 Megohms minimum after moisture MECHANICAL Durability: 200 mating/unmating cycles Mating / Unmating Forces: Mating Force (max.) with InstaLatches Size Lb. Kg 14 12 5.44 24 17 7.71 36 23 10.43 50 32 14.52 64 37 16.78 Call Toll Free: 1 (800) 323-9612 Unmating Force (min.) without InstaLatches Lb. Kg 2 0.91 4 1.81 6 2.72 7 3.18 8 3.63 6-38 .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Solder Tail All-Plastic Vertical-mount Miniature Ribbon connectors provide I/O directly from printed circuit boards, where the mating face of the connector is in a plane parallel to that of the board. See page 6-51 for accessories such as dust covers, bent bail latches, and mounting screws that make the use of Cinch Miniature Ribbon connectors even more cost-effective in board-mount applications. Dimensions Size 14 24 36 50 64 A in 1.745 2.170 2.680 3.275 3.875 B mm 44.32 55.12 68.07 83.19 98.43 in 1.417 1.842 2.352 2.947 3.542 mm 35.99 46.79 59.74 74.85 89.97 Recommended PCB Hole Layout Socket Plug With InstaLatches .238 (6.05) J With Bail Latches J 6-39 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Solder Tail All-Plastic Ordering Information, Vertical-Mount Solder Tail Plug, InstaLatching .138" Tail Length (J) (for PCB thickness up to .093" nominal) Mount Size .125 Hole #4-40 Hole 14 24 36 50 64 14 24 36 50 64 Commercial 97-DSP14-2 97-DSP24-2 97-DSP36-2 97-DSP50-2 97-DSP64-2 97-DSP14-12 97-DSP24-12 97-DSP36-12 97-DSP50-12 97-DSP64-12 30Au/Ni 97-DSP14-2A 97-DSP24-2A 97-DSP36-2A 97-DSP50-2A 97-DSP64-2A 97-DSP14-12A 97-DSP24-12A 97-DSP36-12A 97-DSP50-12A 97-DSP64-12A .183" Tail Length (J) (for PCB thickness up to .125" nominal) Commercial 97-DSP14-3 97-DSP24-3 97-DSP36-3 97-DSP50-3 97-DSP64-3 97-DSP14-13 97-DSP24-13 97-DSP36-13 97-DSP50-13 97-DSP64-13 30Au/Ni 97-DSP14-3A 97-DSP24-3A 97-DSP36-3A 97-DSP50-3A 97-DSP64-3A 97-DSP14-13A 97-DSP24-13A 97-DSP36-13A 97-DSP50-13A 97-DSP64-13A Socket .138" Tail Length (J) (for PCB thickness up to .093" nominal) Latch Mount No latches InstaLatches 6 Size 14 24 .125 Hole 36 64 .160 Hole 50 14 24 #4-40 Hole 36 50 64 14 24 .125 Hole 36 64 .160 Hole 50 14 24 #4-40 Hole 36 50 64 24 Bail Latches, .116 Hole 36 50 Commercial 97-DSS14-22 97-DSS24-22 97-DSS36-22 97-DSS64-22 97-DSS50-22 97-DSS14-32 97-DSS24-32 97-DSS36-32 97-DSS50-32 97-DSS64-32 97-DSS14-2 97-DSS24-2 97-DSS36-2 97-DSS64-2 97-DSS50-2 97-DSS14-12 97-DSS24-12 97-DSS36-12 97-DSS50-12 97-DSS64-12 97-DSS24-42 97-DSS36-42 97-DSS50-42 30Au/Ni 97-DSS14-22A 97-DSS24-22A 97-DSS36-22A 97-DSS64-22A 97-DSS50-22A 97-DSS14-32A 97-DSS24-32A 97-DSS36-32A 97-DSS50-32A 97-DSS64-32A 97-DSS14-2A 97-DSS24-2A 97-DSS36-2A 97-DSS64-2A 97-DSS50-2A 97-DSS14-12A 97-DSS24-12A 97-DSS36-12A 97-DSS50-12A 97-DSS64-12A 97-DSS24-42A 97-DSS36-42A 97-DSS50-42A Call Toll Free: 1 (800) 323-9612 .183" Tail Length (J) (for PCB thickness up to .125" nominal) Commercial 97-DSS14-23 97-DSS24-23 97-DSS36-23 97-DSS64-23 97-DSS50-23 97-DSS14-33 97-DSS24-33 97-DSS36-33 97-DSS50-33 97-DSS64-33 97-DSS14-3 97-DSS24-3 97-DSS36-3 97-DSS64-3 97-DSS50-3 97-DSS14-13 97-DSS24-13 97-DSS36-13 97-DSS50-13 97-DSS64-13 97-DSS24-43 97-DSS36-43 97-DSS50-43 6-40 30Au/Ni 97-DSS14-23A 97-DSS24-23A 97-DSS36-23A 97-DSS64-23A 97-DSS50-23A 97-DSS14-33A 97-DSS24-33A 97-DSS36-33A 97-DSS50-33A 97-DSS64-33A 97-DSS14-3A 97-DSS24-3A 97-DSS36-3A 97-DSS64-3A 97-DSS50-3A 97-DSS14-13A 97-DSS24-13A 97-DSS36-13A 97-DSS50-13A 97-DSS64-13A 97-DSS24-43A 97-DSS36-43A 97-DSS50-43A .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Compliant Pin All-Plastic and Metal Shell ■ Straight Compliant Pin for solderless termination to printed circuit board. ■ All-plastic design reduces cost. Metal Shell also available where indicated for FEATURES improved shielding. ■ Available in plug and socket styles in 14, 24, 36, 50, and 64 position sizes. ■ All plugs lock with InstaLatch passive latch feature for automatic latching. Sockets available with InstaLatches, with Bail Latches where indicated, or with no latches. ■ Available with through holes or with #4-40 holes for mounting/latching. ■ Includes Seating Cover that allows for flat-rock insertion and serves as dust cover after insertion. ■ UL Recognized - Files E170218 (UL1977), E130965 (UL1863). MATERIALS ENVIRONMENTAL Operating Temperature: -40°C to +105°C Shock: 50G Peak, per EIA Std. RS364, TP27, Condition A Vibration: 3 cycles @ 10-55Hz in each of 3 axes per EIA Std. 364, TP28, Condition A Moisture Resistance: Per EIA Std. RS364, TP31, Condition B, with Step 7B excluded Voltage Rating: 500 VAC @ sea level; 125 VAC @ 70,000 ft. Withstanding Voltage: 1200 VAC RMS @ sea level, per EIA Std. RS364, TP20 Contact Rating: 5 Amps (4 Amps per CSA) Contact Resistance: 6 milliohms maximum, per EIA Std. RS364, TP6 Insulation Resistance: 5000 Megohms minimum initial; 1000 Megohms minimum after moisture MECHANICAL Insulator and Seating Cover: Gray UL94V-0 rated glass-filled polyester Contact: Phosphor bronze Contact Plating: Select gold over 50µin. select nickel standard; 30µin. select gold over 50µin. select nickel available where indicated. Gold flash in termination area Shell (Metal Shell Version Only): Steel Shell Plating (Metal Shell Version Only): Tin ELECTRICAL ■ CSA Approved - File LR31996-7. Durability: 200 mating/unmating cycles Mating / Unmating Forces: Mating Force (max.) Unmating Force (min.) with InstaLatches without InstaLatches Size Lb. Kg Lb. Kg 14 12 5.44 2 0.91 24 17 7.71 4 1.81 36 23 10.43 6 2.72 50 32 14.52 7 3.18 64 37 16.78 8 3.63 Connector/PCB Insertion Force (maximum): 25 lbs (12.3Kg) per contact Connector/PCB Retention Force: 5 lb. (2.44Kg) per contact (minimum, without mounting hardware) Call Toll Free: 1 (800) 323-9612 6-42 .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Compliant Pin All-Plastic and Metal Shell Vertical-mount Miniature Ribbon connectors provide I/O directly from printed circuit boards, where the mating face of the connector is in a plane parallel to that of the board. Compliant-pin connectors terminate without solder to plated-through holes in printed circuit boards. The tail conforms to the hole, providing a gas-tight termination without damaging the plating in the printed circuit board. The seating cover acts as an insertion tool fixture, and must be left in place until the connector is installed on the PCB. It may also be left on after insertion to serve as a dust cover to protect the connector from contamination. See pages 6-51 through 6-53 for accessories such as bent bail latches and mounting screws that make the use of Cinch Miniature Ribbon connectors even more cost-effective in board-mount applications. Dimensions A Size 14 24 36 50 64 in 1.745 2.170 2.680 3.275 3.875 B mm 44.32 55.12 68.07 83.19 98.43 in 1.417 1.842 2.352 2.947 3.542 C mm 35.99 46.79 59.74 74.85 89.97 in .625 1.050 1.560 2.155 2.750 mm 15.88 26.67 39.62 54.74 69.85 Plug Socket with Bail Latches Recommended PCB Hole Layout Socket with InstaLatches Insertion Fixture Backer Plate "C" 6-43 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Vertical-Mount Compliant Pin All-Plastic and Metal Shell Ordering Information, Vertical-Mount Compliant Pin All-Plastic Plug, InstaLatching Mount Size 14 24 .125 Hole 36 50 64 14 24 #4-40 Hole 36 50 64 Commercial 97-CP-14 97-CP-24 97-CP-36 97-CP-50 97-CP-64 97-CP-14T 97-CP-24T 97-CP-36T 97-CP-50T 97-CP-64T 30Au/Ni 97-CP-14A 97-CP-24A 97-CP-36A 97-CP-50A 97-CP-64A 97-CP-14TA 97-CP-24TA 97-CP-36TA 97-CP-50TA 97-CP-64TA Commercial 97-CS-14 97-CS-24 97-CS-36 97-CS-50 97-CS-64 97-CS-14T 97-CS-24T 97-CS-36T 97-CS-50T 97-CS-64T 97-CSI-14 97-CSI-24 97-CSI-36 97-CSI-50 97-CSI-64 97-CSI-14T 97-CSI-24T 97-CSI-36T 97-CSI-50T 97-CSI-64T 97-CSB-14 97-CSB-24 97-CSB-36 97-CSB-50 97-CSB-64 30Au/Ni 97-CS-14A 97-CS-24A 97-CS-36A 97-CS-50A 97-CS-64A 97-CS-14TA 97-CS-24TA 97-CS-36TA 97-CS-50TA 97-CS-64TA 97-CSI-14A 97-CSI-24A 97-CSI-36A 97-CSI-50A 97-CSI-64A 97-CSI-14TA 97-CSI-24TA 97-CSI-36TA 97-CSI-50TA 97-CSI-64TA 97-CSB-14A 97-CSB-24A 97-CSB-36A 97-CSB-50A 97-CSB-64A All-Plastic Socket Bail latches InstaLatches No latches Latch Mount Size 14 24 .160 Hole 36 50 64 14 24 #4-40 Hole 36 50 64 14 24 .160 Hole 36 50 64 14 24 #4-40 Hole 36 50 64 14 24 .116 Hole 36 50 64 Metal Shell Socket, with InstaLatches Commercial 6 Conductive Standoff with .120 Hole 50 57-CSI-50 Call Toll Free: 1 (800) 323-9612 30Au/Ni 57-CSI-50A 6-44 .085 in. (2.16mm) Density Miniature Ribbon Right-Angle Solder Tail Metal Shell ■ Right-Angle Solder Tails for solder termination to printed circuit board. FEATURES ■ Metal shell provides grounding and shielding capability. ■ Available in plug and socket styles in 14, 24, 36, and 50 position sizes. ■ Sockets available with industry-standard bail latch feature for positive locking/unlocking without tools, for applications such as SCSI-1 and Centronics. ■ #4-40 threaded board mounting holes provide means to secure and ground connector to board. ■ UL Recognized - File E170218. MATERIALS Insulator: Blue UL94V-0 rated glass-filled polyester Contact: Phosphor bronze Contact Plating: Select gold over nickel in mating area as indicated; tin-lead on solder tails Shell: Steel ELECTRICAL ENVIRONMENTAL Shell Plating: Nickel Operating Temperature: -55°C to +105°C Withstanding Voltage: Contact Rating: Contact Resistance: Insulation Resistance: 1000 VAC RMS @ sea level 5 Amps 30 milliohms maximum 1000 Megohms minimum Right-Angle Miniature Ribbon connectors provide I/O directly from printed circuit boards, where the mating face of the connector is perpendicular to the board. It is well-suited to front-panel I/O on plug-in cards, rear-I/O from system/peripheral motherboards, etc. See page 6-51 for accessories such as dust covers, bent bail latches and mounting screws that make the use of Cinch Miniature Ribbon connectors even more cost-effective in board-mount applications. Call Toll Free: 1 (800) 323-9612 6-46 .085 in. (2.16mm) Density Miniature Ribbon Right-Angle Solder Tail Metal Shell Dimensions A Size 14 24 36 50 in 1.720 2.146 2.661 3.260 B mm 43.70 54.50 67.60 82.80 in 1.417 1.842 2.352 2.947 C mm 35.99 46.79 59.74 74.85 in 0.992 1.417 1.925 2.520 D mm 25.20 36.00 48.90 64.00 in 1.008 1.436 1.943 2.538 mm 25.60 36.00 49.35 64.00 Plug Socket Ordering Information, Right-Angle Solder Tail Plug, 4-40 Board Mount Size 36 50 Flash 57-LRP36-F 57-LRP50-F 15Au/Ni 57-LRP36-15 57-LRP50-15 30Au/Ni 57-LRP36-30 57-LRP50-30 Socket, 4-40 Board Mount Bail Latch No Latches Latch Size 14 24 36 50 14 24 36 50 Flash 57-LRS14-F 57-LRS24-F 57-LRS36-F 57-LRS50-F 57-LRS14-BF 57-LRS24-BF 57-LRS36-BF† 57-LRS50-BF 15Au/Ni 57-LRS14-15 57-LRS24-15 57-LRS36-15 57-LRS50-15 57-LRS14-B15 57-LRS24-B15 57-LRS36-B15† 57-LRS50-B15 30Au/Ni 57-LRS14-30 57-LRS24-30 57-LRS36-30 57-LRS50-30 57-LRS14-B30 57-LRS24-B30 57-LRS36-B30† 57-LRS50-B30 † IEEE 1284-B 6-47 Call Toll Free: 1 (800) 323-9612 Filtered Vertical-Mount Solder Tail and Male/Female Adapter .085 in. (2.16mm) Density Miniature Ribbon ■ ■ Insulator: Gray UL94V-0 rated glass-filled polyester Contact: Copper alloy Contact Plating: 30µin. select gold over 50µin. select nickel standard; tin-lead on solder tails Mounting Hardware Plating: Tin-lead Operating Temperature: -50°C to +105°C Shock: 50G Peak, per EIA Std. RS364, TP27, Condition A Vibration: 3 cycles @ 10-55Hz in each of 3 axes per EIA Std. 364, TP28, Condition A Moisture Resistance: Per EIA Std. RS364, TP31, Condition B, with Step 7B excluded ELECTRICAL MATERIALS ■ ■ ■ ■ Low-pass (single-pole, capacitive) filtered contacts reduce inbound and outbound conducted EMI standard capacitance values of 50pF through 1,200pF. Saves space by incorporating required filter functions directly into footprint of I/O connector. Available as straight Solder Tail plug for solder termination to printed circuit board (nominal thickness through .093") and as plug/socket adapter, in 50-position size. All-plastic design reduces cost. All plugs lock with InstaLatch passive latch feature for automatic latching. Adapters available with InstaLatches, with Bail Latches, or with no latches on socket side. Available with through holes, #4-40 holes, #6-32 holes, or M3 holes for mounting/latching. ENVIRONMENTAL FEATURES ■ Voltage Rating: Contact Rating: RF Current Rating: Leakage Current: Voltage Surge: Contact Resistance: Insulation Resistance: Dissipation Factor: 500VDC @ sea level 3 Amps 0.3 Amps 10mA maximum per contact when subjected to 1000 VAC test voltage, applied over 30 seconds and held for 60 seconds per FCC Part 68.5 Withstands 1,500V peak longitudinal voltage surge with 10µsec. risetime, 160µsec. decay 6 milliohms maximum, per EIA Std. RS364, TP6 5000 Megohms minimum 5% maximum @ 25°C, 1kHz and 1 VAC RMS maximum MECHANICAL Insertion Loss: Capacitance @ 25°C, 1kHz, 1 VAC RMS max. 50pF+15% 100pF+15% 220pF+15% 470pF+15% 820pF+15% 1,000pF+15% 1,200pF+15% Insertion Loss, min. (dB, @ 25°C, @ 50 ohm, no load, per MIL-STD-220) 10MHz 30MHz 50MHz 70MHz 100MHz 500MHz 1GHz 2 14 11 3 14 11 4 7 12 14 11 5 11 14 20 14 11 3 3 16 20 20 14 11 3 3 16 20 20 14 11 3 3 16 20 20 14 11 Durability: 200 mating/unmating cycles Mating / Unmating Forces: Mating Force (max.) with InstaLatches Size Lb. Kg 50 32 14.52 Unmating Force (min.) without InstaLatches Lb. Kg 7 3.18 Call Toll Free: 1 (800) 323-9612 6-48 .085 in. (2.16mm) Density Miniature Ribbon Filtered Vertical-Mount Solder Tail and Male/Female Adapter Filtered Vertical-Mount Solder Tail Plug Vertical-mount Filtered Miniature Ribbon plugs provide filtered I/O directly from printed circuit boards, where the mating face of the connector is in a plane parallel to that of the board. Filtering keeps conducted EMI from passing between the system board and I/O cable. The connector’s filter must be grounded to the system at the mounting holes, via either top flange or through the lower standoff to a pad on the component side of the printed circuit board. See page 6-51 for accessories such as dust covers and mounting screws that make the use of Cinch Filtered Miniature Ribbon connectors even more cost-effective in board-mount applications. Threaded Boardlock Through or threader hole Ordering Information, Filtered Vertical-Mount Solder Tail Plug, 50 Position Capacitance 50pF±15% 100pF±15% 220pF±15% 470pF±15% 820pF±15% 1,000pF±15% 1,200pF±15% 50pF±15% 100pF±15% 220pF±15% 470pF±15% 820pF±15% 1,000pF±15% 1,200pF±15% .144 Hole CF97-50PB-TH CF97-50PC-TH CF97-50PD-TH CF97-50PE-TH CF97-50PF-TH CF97-50PH-TH CF97-50PJ-TH - #4-40 Hole CF97-50PB-4T CF97-50PC-4T CF97-50PD-4T CF97-50PE-4T CF97-50PF-4T CF97-50PH-4T CF97-50PJ-4T CF97-50PB-4B CF97-50PC-4B CF97-50PD-4B CF97-50PE-4B CF97-50PF-4B CF97-50PH-4B CF97-50PJ-4B 6-49 #6-32 Hole CF97-50PB-6T CF97-50PC-6T CF97-50PD-6T CF97-50PE-6T CF97-50PF-6T CF97-50PH-6T CF97-50PJ-6T CF97-50PB-6B CF97-50PC-6B CF97-50PD-6B CF97-50PE-6B CF97-50PF-6B CF97-50PH-6B CF97-50PJ-6B M3 -0.5 Hole CF97-50PB-3T CF97-50PC-3T CF97-50PD-3T CF97-50PE-3T CF97-50PF-3T CF97-50PH-3T CF97-50PJ-3T CF97-50PB-3B CF97-50PC-3B CF97-50PD-3B CF97-50PE-3B CF97-50PF-3B CF97-50PH-3B CF97-50PJ-3B Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Filtered Vertical-Mount Solder Tail and Male/Female Adapter Filtered Panel Mount Feedthrough Adapter Filtered Ribbon Panel Mount Adapters provide filtered I/O in systems where internal cabling carries signals to the system panel. By filtering right at the panel, EMI that could otherwise be generated over the length of the internal cable is prevented. The use of a plug/socket adapter also yields a benefit in serviceability. Should it ever be necessary to replace the filter, an adapter can be readily replaced without replacing a bulky, more expensive cable assembly. The adapter must be grounded to the system panel through the mounting hardware, which extends to both plug and socket flanges; thus, the adapter may be mounted with either side to the panel. Adapters are also available without filter capacitors. Often referred to as “connector savers”, these devices are most useful as “throw away” intermediate interconnects in applications where numerous mating/unmating cycles are required. See page 6-51 for accessories such as bent bail latches, dust covers, and mounting screws that make the use of Cinch Miniature Ribbon Filtered Adapters even more cost-effective in panel mount-applications. Socket with Bail latches 6 Socket with InstaLatches Socket without latches Ordering Information, Filtered Adapter, 50 position Capacitance None (Connector Saver) 50pF±15% 100pF±15% 220pF±15% 470pF±15% 820pF±15% 1,000pF±15% 1,200pF±15% None (Connector Saver) 50pF±15% 100pF±15% 220pF±15% 470pF±15% 820pF±15% 1,000pF±15% 1,200pF±15% None (Connector Saver) 50pF±15% 100pF±15% 220pF±15% 470pF±15% 820pF±15% 1,000pF±15% 1,200pF±15% #4-40 Hole CF97-50AA-4T CF97-50AB-4T CF97-50AC-4T CF97-50AD-4T CF97-50AE-4T CF97-50AF-4T CF97-50AH-4T CF97-50AJ-4T CF97-50AA-4TI CF97-50AB-4TI CF97-50AC-4TI CF97-50AD-4TI CF97-50AE-4TI CF97-50AF-4TI CF97-50AH-4TI CF97-50AJ-4TI CF97-50AA-4TB CF97-50AB-4TB CF97-50AC-4TB CF97-50AD-4TB CF97-50AE-4TB CF97-50AF-4TB CF97-50AH-4TB CF97-50AJ-4TB Call Toll Free: 1 (800) 323-9612 #6-32 Hole CF97-50AA-6T CF97-50AB-6T CF97-50AC-6T CF97-50AD-6T CF97-50AE-6T CF97-50AF-6T CF97-50AH-6T CF97-50AJ-6T CF97-50AA-6TI CF97-50AB-6TI CF97-50AC-6TI CF97-50AD-6TI CF97-50AE-6TI CF97-50AF-6TI CF97-50AH-6TI CF97-50AJ-6TI CF97-50AA-6TB CF97-50AB-6TB CF97-50AC-6TB CF97-50AD-6TB CF97-50AE-6TB CF97-50AF-6TB CF97-50AH-6TB CF97-50AJ-6TB 6-50 M3 -0.5 Hole CF97-50AA-3T CF97-50AB-3T CF97-50AC-3T CF97-50AD-3T CF97-50AE-3T CF97-50AF-3T CF97-50AH-3T CF97-50AJ-3T CF97-50AA-3TI CF97-50AB-3TI CF97-50AC-3TI CF97-50AD-3TI CF97-50AE-3TI CF97-50AF-3TI CF97-50AH-3TI CF97-50AJ-3TI CF97-50AA-3TB CF97-50AB-3TB CF97-50AC-3TB CF97-50AD-3TB CF97-50AE-3TB CF97-50AF-3TB CF97-50AH-3TB CF97-50AJ-3TB .085 in. (2.16mm) Density Miniature Ribbon Accessories The following accessories are available to make your application using Cinch Miniature Ribbon and SUPERIBBON products as complete and cost-effective as possible. Dust Covers for all Metal Shell and All-Plastic Miniature Ribbon Connectors Dust covers may be added to Miniature Ribbon or SUPERIBBON assemblies to protect the mating area from damage or contamination when the connector is left unmated. They can be useful for protection from handling damage during assembly, or can be left on the connector for protection of unused system I/O ports. Compliant-pin Miniature Ribbon products come with special seating fixtures that must be used to install the connectors onto the printed circuit board. These may be replaced after insertion; however, with standard dust covers to maintain the standard color code, if so desired. Material: UL94V-0 rated polyethelene (blue for plug covers; red for socket covers) Ordering Information, Dust Covers Size 14 24 36 50 64 Plug Cover 57-1001 57-1003 57-1005 57-1008 57-1009 Socket Cover 57-1002 57-1004 57-1006 57-1022 57-1010 Bent Bail Latch for End-Entry Applications Standard Bail Latches will not lock under a plug cable in a typical end-entry application. This latch, which is bent at a 90° angle, may be used to replace a standard latch in this situation. Material: Stainless Steel Ordering Information, Bent Bail Latch Part No. 57-BL-90 Mounting Screws and Related Hardware Many Cinch Miniature Ribbon and SUPERIBBON products include all the hardware required for the most common application for the product; however, these alternatives may be desirable to better fit product to a specific use. Part No. Description Typical Applications 4-40UNC2AX11/32 #4-40 x .343 Pan Head Screw • SUPERIBBON to mate with female screwlock • PC Mount connector to PCB (secured from rear) 4-40UNC2AX17/32 #4-40 x .525 Pan Head Screw • SUPERIBBON to threaded panel 4-40UNC2AX5/8 #4-40 x .625 Fillister Head Screw • Metal Shell Running Cable (included on 4-40UNC2AX3/4 #4-40 x .750 Pan Head Screw • SUPERIBBON Running Cable (included on standard end-entry metal shell products) standard end-entry SUPERIBBON products) • SUPERIBBON to front-panel mounted SUPERIBBON held by panel clips 4-40UNC2AX7/8 #4-40 x .875 • Miscellaneous 4-40X1/4SPCR Hex Spacer, #4-40 Internal Thread x .250 • Female Screwlock 6-51 Call Toll Free: 1 (800) 323-9612 6 .085 in. (2.16mm) Density Miniature Ribbon Accessories Wire Restraints for Panel-Mount SUPERIBBON™ All-Plastic Connectors Wire restraints provide added security to terminated wires, preventing radial pullout. They are intended for use on panel mounted connectors where hoods are not required (wire restraints cannot be applied simultaneously with hoods), and snap on after connector termination. Material: Gray UL94V-0 rated polyester. Ordering Information, SUPERIBBON Wire Restraints (Two restraints required per connector) Size 14 24 36 50 64 Plug 97-WR-P14 97-WR-P24 97-WR-P36 97-WR-P50 97-WR-P64 Socket 97-WR-S14 97-WR-S24 97-WR-S36 97-WR-S50 97-WR-S64 Wire Restraints for Panel-Mount Miniature Ribbon Metal Shell Connectors Metal Shell Wire Restraints serve the same purpose as their SUPERIBBON counterparts, but are for IDC terminated metal shell connectors. These onepiece restraints snap in place around the termination area after assembly. Material: Blue UL94V-0 rated polyester. Ordering Information, Miniature Ribbon Wire Restraints (One restraint required per connector) Size 36 50 Plug or Socket 77-WR-36 77-WR-50 Panel Mounting Clips for All-Plastic Miniature Ribbon Connectors These clips slip into each end of a modified panel cutout, and allow all-plastic Miniature Ribbon connectors to be snapped into place and securely frontmounted to the panel with no additional hardware. Threaded holes are not required in the panel, and connectors can be loaded without needing access to the rear of the panel. Material: Steel Finish: Tin-cadmium/clear chromate 6 Ordering Information, Panel Mounting Clips B (Two clips required per connector) Dimensions Chassis Thickness .062" (1.57mm) .093" (2.36mm) .125" (3.18mm) Panel Clip Part Number 97-MC-062 97-MC-093 97-MC-125 Size 14 24 36 50 64 Call Toll Free: 1 (800) 323-9612 B in 1.417 1.842 2.352 2.947 3.542 mm 35.99 46.79 59.74 74.85 89.97 K in 1.060 1.485 1.995 2.590 3.185 6-52 mm 26.92 37.72 50.67 65.79 80.90 K .085 in. (2.16mm) Density Miniature Ribbon Accessories Wire Restraint with Integral Panel Clip This accessory for All-Plastic Miniature Ribbon products combines the Wire Restraint and Panel Mounting Clip into one molded device. Available only for 50 position size connectors, it provides a significant material and labor cost savings compared to alternate mounting methods. Material: Gray UL94V-0 rated polyester. Ordering Information, Wire Restraint with Integral Panel Clip (Two required per connector) Chassis Thickness .062" (1.57mm) .093" (2.36mm) Panel Clip Part Number 97-WRC-062 97-WRC-093 Hoods for SUPERIBBON Connectors 180° (Top-Entry) Hoods can be used with panel-mount All-Plastic SUPERIBBON connectors to provide strain relief and protection of the wire terminations. The two-piece snap-on assembly has adjustable tabs that allow effective strain relief on a wide range of cable sizes. 90°/270° (End-Entry) Hoods are for replacement on End-Entry SUPERIBBON connectors. They are available for all sizes, as well as for the pointed-nose 50 position size. Note: End-Entry Hoods cannot be added to panel-mount connectors because the finished assembly would not have the end-entry cable grip. See pages 6-10 thru 6-13 for complete end-entry connectors. Material: Gray UL94V-0 rated polyester. Ordering Information, Hoods for All-Plastic Miniature Ribbon Square Nose Pointed Nose Size 14 24 36 50 64 50 180° (Top-Entry) 97-14-180 97-24-180 97-36-180 97-50-180 97-64-180 - 6 90°/270° (End-Entry) 97-14-90 97-24-90 97-36-90 97-50-90 97-64-90 97-50-90P 6-53 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Application Tools A full range of tooling is available to make the use of Cinch Miniature Ribbon and SUPERIBBON™ products as cost-effective as possible. From hand repair tools to the high production rate Auto-ClinchTM termination tool, Cinch has the tool to fit your needs. Auto-Clinch Model 200S Termination Tool Auto-Clinch is a semi-automatic Connector Termination Machine that terminates IDC connectors pair-by-pair. The basic machine comes equipped ready to terminate 50-position end-entry Miniature Ribbon or SUPERIBBON connectors, which it can do in approximately 1.5 minutes. The Auto-Clinch is pneumatically powered and requires a min. 60psi air supply. It is electrically controlled, and requires a 117V, 60Hz Single Phase electrical circuit (5 Amps). Weight: 120 lbs. (54.48kg.), Dimensions: 25.5" (64.77cm.) wide; 20" (50.8cm) deep; 9" (22.86cm) high. Note: These specifications may change with the addition of certain options. Order Part No. AC-371 Several options are available that make the Auto-Clinch a versatile application tool: • Remote Visual Color Display shows wire color codes. It can be used to train new operators or to assist the operator in terminating non-standard wire sequences. Part No. ACO-482 • The Selective Programmer allows the operator to set the machine to skip over positions that are not to be terminated, thus speeding up the termination process. Part No. ACO-495 • The End-Entry Cable Clamp closer automatically closes the cable clamp on end-entry SUPERIBBON or SuperShield connectors as they are terminated. Part No. ACO-374 A power assist for this device is also available. Part No. ACO-405 • The Top-Entry Adapter dresses the wires during termination such that they are properly aligned for exit through a Top-Entry hood. Part No. ACO-218 NOTE: Auto-ClinchTM cannot be equipped with both Cable Clamp Closer and Top-Entry Adapter simultaneously. • Insertion Blades are included for terminating solid wire. For replacement, order Part No. ACB-443 To terminate stranded wire, order stranded-wire blades, Part No. ACB-872 • Nests for Panel Mount and Top-Entry Ribbon Connectors, and All Plastic SUPERIBBON connectors allow the use of Auto-Clinch to terminate other IDC Ribbon Connectors: For All-Plastic IDC Connectors 6 For Metal-Shell IDC Connectors Connector Size End-Entry Top-Entry End-Entry 14 ACEN-850 ACTN-568 24 ACEN-851 ACTN-569 36 ACEN-852 ACTN-797 50 ACEN-853 ACTN-798 ACMN-484 64 ACEN-570 ACTN-799 * For Bail-Latch plugs with hood where hood forms rear of connector body, i.e., For overmold kits, use panel mount/top-entry plug nests. Panel Mount/Top-Entry Sockets Plugs ACMN-231 ACMN-229 ACMN-228 ACMN-203 ACMN-527 ACMN-858 77-32500. AutoClinch is a trademark of Cinch Connector Division of Labinal Components & Systems, Inc. Call Toll Free: 1 (800) 323-9612 6-54 Top-Entry Plug With Hood* ACMN-232 ACMN-230 ACMN-227 ACMN-526 - .085 in. (2.16mm) Density Miniature Ribbon Application Tools Certi-Clinch™ Portable Termination Tool Certi-Clinch is a portable, manually operated tool that terminates Cinch allplastic and metal shell Miniature Ribbon connectors with discrete-wire IDC contacts. It is designed for field use assembling cables on-site, yet is efficient enough to fit well into lower-volume factory assembly operations. Its 10.5 lb. (4.77Kg) weight and versatile configuration make it readily portable for field use, and allow temporary use with virtually no setup time to handle peak demands in factory environments. A leather case is available for carrying Certi-Clinch onto a job site or for storing Certi-Clinch in the factory when not being used. Certi-Clinch measures 6" (15.24cm) wide x 13" (33.02cm) long x 6.5" (16.5cm) high. Ordering Information, Certi-Clinch Model SCT-330 SCT-335 SCT-360 SCT-342 SCT-343 SCT-645 SCT-038 SCT-649 Description Certi-Clinch Tool with 25-pair nest, for Solid Wire Certi-Clinch Tool with 32-pair nest, for Solid Wire Certi-Clinch Tool with 25-pair nest, for Stranded Wire Kit to convert 25-pair tool to 32-pair operation Kit to convert 32-pair tool to 25-pair operation Insertion Blades to convert 25-pair tool to Stranded Wire Insertion Blades to convert 32-pair tool to Stranded Wire Carrying Case for all Certi-Clinch Tools Handi-Clinch™ Hand Termination Tool This hand-operated tool terminates wires individually to Cinch SUPERIBBON™ and metal shell Miniature Ribbon IDC connectors. Its integral nest holds the connector in place during use. Part No. HCTT-539 Versa-Clinch™ Multi-Function Hand Tool This versatile tool performs four basic functions in applying Cinch SUPERIBBON and metal shell Miniature Ribbon products: • • • • Terminate individual wires to the IDC contact Unlatch the hood for removal on end-entry SUPERIBBON products Open and close the cable clamp on SUPERIBBON and SuperShield Unlock InstaLatches to unmate connectors Part No. VCTT-361 6-55 6 Call Toll Free: 1 (800) 323-9612 .085 in. (2.16mm) Density Miniature Ribbon Application Tools Termination Repair Pliers These plier type tools allow you to rework misterminated cable assemblies and/or perform specialized termination operations. They terminate wires individually into Cinch IDC contacts. Repair Pliers for Standard Termination: Part No. SRT-345 Repair Pliers for Half-Tap (Daisy-Chaining) allows you to terminate one wire to multiple contacts to short contacts together, or even to two separate connectors to make back/ back connections, etc. Part No. HT-560 InstaLatch™ Unlatching Tool While InstaLatches may be unlocked with something as simple as a center punch or ballpoint pen, this tool provides a “hooked” end that allows you to unlock InstaLatches even in tight areas. Part No. UT-304 Crimping Tools for Overmold Kit Ferrules Two model tools are available to crimp ferrules onto overmold kits: • Pneumatically powered bench-top press, which is portable so it can be placed in storage when not required. Part No. FCT-551 • Hand-operated crimping tool, satisfactory for lower-volume applications. Part No. FCT-552 Both tools use the same crimp dies. Select the crimp die(s) below for the particular ferrule being used (ferrules shown on page 6-22). Crimp Die Part No. CD08 CD09 CD10 Crimp Ferrule Part No. CF57 CF60 CF64 6 Call Toll Free: 1 (800) 323-9612 6-56 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cinch Connectivity Solutions: 97-12500-91PDA 77-72500 4-40-THMB-1 97-12500-91PD 97-22500-93PA 57-60500-WW2A 303R 304R 333R 41C 4-40UNC2AX3/4 50-12H-20 50-48SN-9 50-50SN-1 50-6H-20 77-12500 77-22500 77-22500A 77-72500-270 77-72500-271 77-72500A 77-82500 77-82500-270 77-82500-271 77-82500A 97-12500-01 97-12500-01A 9712500-11 97-12500-11A 97-12500-90 97-12500-91 97-12500-91PA 97-12640-01 97-12640-01A 97-12640-11 9712640-90 97-12640-91 97-22500-01 97-22500-01A 97-22500-11 97-22500-12 97-22500-90 97-22500-91 9722500-91A 97-22500-91PDA 97-22500-93 97-22500-93P 97-22500-93PD 97-22640-01 97-22640-01A 97-2264002A 97-22640-11 97-22640-90 97-22640-91 97-22640-91A 97-50-180 97-50-90 97-64-180 97-64-90 97-WR-P50 97-WR-P64 97-WR-S50 MDC-8P13 S-324-CCT SD-LB-125 SD-WC15 SD-WC25 SD-WC37 SD-WC9 SSDWC15 SSD-WC25 SSD-WC37 SSD-WC9 M24308/2-1Z M24308/2-4 CIET-20-HD 57-60500-WW2 97-12500-91P 97-22500-91P 4-40UNC2AX5/8 77-9250P1 77-9250S3 77-9250S3A 77-9250S4 77-9250S4A SD-2537-SB SD915-SB TE-H9P M24308/3-3Z M24308/1-1Z M24308/1-2Z M24308/2-4Z S-202-CCT-THR M24308/4-313F M24308/4-315F M24308/4-324Z M24308/4-326Z M24308/4-435F M24308/4-435Z M24308/4-437F
DEMA9S 价格&库存
很抱歉,暂时无法提供与“DEMA9S”相匹配的价格&库存,您可以联系我们找货
