191-025-223R001
191-025-223R001
    NORCOMP
    25 位 D-Sub 插座,母形插口 连接器, 通孔 压配式
191-025-223R001 数据手册
DESCRIPTION: Vertical Mount Female Low Profile/Plastic Back Press Fit Dimensions (mm) Size A B C 09 30.81 24.99 16.33 15 39.20 33.30 24.70 25 53.05 47.04 38.40 37 69.40 63.50 54.80 Material: Insulator: Contact: Shell: Nylon 6T, UL94V-0, 260°C Process Temp, Black Phosphor Bronze Nickel Plated Steel Electrical: Current Rating: Contact Resistance: Insulation Resistance: Working Voltage: Operating Temperature: 5 AMPS 20 mOhms Max. 1000 MOhms Min. 250V -55° C TO +125° C 191-YYY-223RYYY 1.42 2.77 Series Position 009 015 025 037 Gender 2 = Female Termination 2 = Press Fit Shell Plating 3 = Nickel Hardware Options 00 = No Hardware 55 = 4-40 Insert 56 = 4-40 Insert with Board Locks 57 = 4-40 Standoff with Board Locks 59 = 4-40 Standoff Plating Options 1 = Gold Flash mating area, Tin plated tails 2 = 30 " Gold mating area, Tin plated tails View A 2.84 ∅3.3 x 2 ∅1.05 ±0.02 Recommended PCB Layout RoHS COMPLIANT THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: Pam Jenkins DATE: 9/15/2003 Tolerance X. .X .XX ±0.38 ±0.25 ±0.13 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 191-YYY-223RYYY 7 DESCRIPTION: Hardware Options RoHS COMPLIANT THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: Pam Jenkins DATE: 9/15/2003 Tolerance X. .X .XX ±0.38 ±0.25 ±0.13 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 191-YYY-223RYYY 7
191-025-223R001 价格&库存
很抱歉,暂时无法提供与“191-025-223R001”相匹配的价格&库存,您可以联系我们找货
