DCH-B-003
DCH-B-003
    CINCH
    CONN HOOD DSUB 25POS MTL PLAST
DCH-B-003 数据手册
Cinch Connectors » Accessories – Backshells – D*H Series » Print Page 1 of 3 - Cinch Connectors - http://www.cinch.com - Accessories – Backshells – D*H Series Features [1] | Part Numbers [2] | Dimensions [3] Features Backshells have two-piece construction and are frequently used where appearance is a major factor. • RFI/EMI shielding capability is also an option: ◦ Plastic Backshells: No shielding. ◦ Metallized Plastic: Economical method of shielding. ◦ Diecast Backshells: Maximum shielding. • Standard two-piece construction available in plastic, metallized plastic, or diecast zinc versions with 180° straight cable entry. • Fits standard metal shell D-subminiature plugs and sockets as well as HTD Series 1.5 D-subs. • Included in all backshells: ◦ Hardware: 4-40 screws, hex nuts, 4-40 screw mounting bracket. ◦ Grommets: To accommodate most cable sizes. Grommets also function as strain reliefs. • Backshells are individually bagged. • Note that slide locks may not be used with these backshells. • Optional thumbscrew for backshell must be ordered separately if required. Materials 4-40 screws, hex nuts, mounting bracket: Steel with zinc plating and clear chromate coating. Standard Backshells • Plastic Backshells: ABS (black), hardware – steel with zinc plating, grommets – polyphenylene, (black). • Metallized Plastic Backshells: ABS with nickel over copper plating, hardware – steel with zinc plating, grommets – PVC (black). • Diecast Backshells: Diecast zinc, grommets – PVC (black). back to top [4] Part Numbers Ordering Information D*H Two-Piece Backshells (see below for RoHS parts) Fits Standard Shell Size Density Cable Entry Style Plastic E 9 Straight (180°) Cable Dia. (in) Metallized Plastic Cable Dia. (in) DPH-E-001 [5] .210-.320 DCH-E-001 [5] .210-.350 .210-.320 DCH-A-001 [5] .210-.350 A 15 Straight (180°) DPH-A-001 [5] B 25 Straight (180°) DPH-B-001 [5] .230-.450 DCH-B-001 [5] .230-.450 C 37 Straight (180°) DPH-C-001 [5] .350-.650 DCH-C-001 [5] .350-.640 D 50 Straight (180°) N/A .350-.650 DCH-D-001 [5] .350-.640 Ordering Information D*H Two-Piece Backshells (see below for RoHS parts) http://www.cinch.com/products/d-subminiature/accessories-backshells-dh-series/printpage/ 12/14/2012 Cinch Connectors » Accessories – Backshells – D*H Series » Print Page 2 of 3 Fits Standard Shell Size Density Cable Entry Style Diecast Metal Cable Dia. (in) E 9 Straight (180°) DMH-E-001 [5] .210-.320 A 15 Straight (180°) DMH-A-001 [5] .210-.320 B 25 Straight (180°) DMH-B-001 [5] .230-.450 C 37 Straight (180°) DMH-C-001 [5] .350-.650 D 50 Straight (180°) DMH-D-001 [5] .350-.640 Ordering Information for RoHS D*H Two-Piece Backshells Cable Dia. Cable Entry Shell Size B Fits. Std. Style Dens Straight 9 (180°) Straight 15 (180°) Straight 25 (180°) C Straight (180°) E A 37 Plastic DPH-E-003 [5] DPH-A-003 [5] DPH-B-003 [5] Metallized Plastic (in) .210-.320 DCH-E-003 [5] Diecast Metal .210-.320 (in) . DMH-A-003 [5] .210-.350 [5] .210-.320 .230-.450 DCH-B-003 [5] .230-.450 . [5] DCH-C-003 Met. Plast. Drw. [6] back to top (in) Cable Dia. .210-320 DCH-A-003 N/A Plastic Drw. PDF Cable dia. .350-640 DMH-C-003 [5] .350-.650 Diecast Drw. [7] [8] [4] Dimensions Straight (180deg.) Plastic & Metalized Plastic Dimensions Shell Size A B C D E F in in mm in mm in mm in mm in mm in E 1.225 31.12 1.547 39.29 0.640 16.26 0.645 16.38 0.400 10.16 0.984 24.99 A B C D 1.540 39.12 1.516 38.51 0.640 16.26 0.645 16.38 0.400 10.16 1.312 33.32 2.090 53.09 1.655 42.04 0.710 18.03 0.645 16.38 0.522 13.26 1.857 47.17 2.730 69.34 1.830 46.48 0.906 23.01 0.645 16.38 0.725 18.42 2.500 63.50 2.645 67.18 1.855 41.12 0.940 23.88 0.750 19.05 0.725 18.42 2.406 61.11 EMI/RFI Shielded Diecast Backshells Dimensions Shell Size in E A B C D A B C D E F in mm in mm in mm in mm in mm in 1.225 31.12 1.465 37.21 0.620 15.75 0.620 15.75 0.400 10.16 0.984 24.99 1.540 39.12 1.600 40.64 0.620 15.75 0.620 15.75 0.400 10.16 1.312 33.32 2.090 53.09 1.570 39.88 0.690 17.53 0.620 15.75 0.525 13.34 1.857 47.17 2.730 69.34 1.810 45.97 0.862 21.89 0.620 15.75 0.725 18.42 2.500 63.50 2.624 66.65 1.800 45.72 0.862 21.89 0.730 18.54 0.725 18.42 2.406 61.11 Click image for larger view. Click image for larger view. [9] http://www.cinch.com/products/d-subminiature/accessories-backshells-dh-series/printpage/ 12/14/2012 Cinch Connectors » Accessories – Backshells – D*H Series » Print Page 3 of 3 [10] Article printed from Cinch Connectors: http://www.cinch.com URL to article: http://www.cinch.com/products/d-subminiature/accessories-backshells-dhseries URLs in this post: [1] Features: #features [2] Part Numbers: #parts [3] Dimensions: #dimensions [4] back to top: #top [5] DPH-E-001: http://www.cinch.comjavascript:viewPartNumInfo( [6] Plastic Drw.: http://www.cinch.com/pdfs/1195164201-DPH-X-003.PDF [7] Met. Plast. Drw.: http://www.cinch.com/pdfs/1195164537-DCH-X-003.PDF [8] Diecast Drw.: http://www.cinch.com/pdfs/1195164560-DMH-X-003.PDF [9] Image: http://www.cinch.com/images/dsubmin/dh2.gif [10] Image: http://www.cinch.com/images/dsubmin/dh.gif Copyright © 2010 Cinch Connectors. All rights reserved. http://www.cinch.com/products/d-subminiature/accessories-backshells-dh-series/printpage/ 12/14/2012
DCH-B-003 价格&库存
很抱歉,暂时无法提供与“DCH-B-003”相匹配的价格&库存,您可以联系我们找货
