GCHDLP26F26F
GCHDLP26F26F
    NORCOMP
    GCHDLP26F26F
GCHDLP26F26F 数据手册
DESCRIPTION: 26-PIN FEMALE / FEMALE HIGH DENSITY GENDER CHANGER SPECIFICATION: INSULATOR: PBT, UL 94 V-0 CONTACT: GOLD PLATED BRASS SHELL: TIN PLATED STEEL CURRENT RATING: 3 AMP DIELECTRIC STRENGTH: 1,000VAC FOR 1 MINUTE INSULATION RESISTANCE: 1,000 MOHMS MIN @500 VDC TEMPERATURE: -55° C - +105° C NOTE: 9 LABEL: SIDE 1: SIDE 2: 1 18 10 26 19 YELLOW COLOR WITH BLACK CHARACTERS MINI GENDER CHANGER U.S.A. PATENT 5199906 4.80±0.10 5.20±0.25 5.80±0.10 4.00±0.25 4.75 6.00±0.25 MINI GENDER CHANGER UNC #4-40 HEXSCREW (INTERNAL & EXTERNAL THREADS) 5.80±0.10 39.51±0.25 3.96±0.05 33.28±0.15 26-PIN FEMALE 26-PIN FEMALE 1 2 3 1 2 3 7.90±0.20 24.60±0.20 12.65±0.25 5.00±0.10 9 1 18 25 26 SHELL 10 26 19 2.29±0.05 RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 25 26 SHELL UNC #4-40 HEXNUT (INTERNAL THREADS) PIN OUT UNITS = mm DRAWN: C. SMITH DATE: 10/15/2007 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 1 GCHDLP26F26F 2
GCHDLP26F26F 价格&库存
很抱歉,暂时无法提供与“GCHDLP26F26F”相匹配的价格&库存,您可以联系我们找货
