FH35C-13S-0.3SHW(99)
    HRS(广濑)
    13 Position FPC Connector Contacts, Top and Bottom 0.012" (0.30mm) Surface Mount, Right Angle
FH35C-13S-0.3SHW(99) 数据手册
Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. HR S DR AW IN G FO R RE FE RE NC E Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. HR S DR AW IN G FO R RE FE RE NC E Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. HR S DR AW IN G FO R RE FE RE NC E Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. HR S DR AW IN G FO R RE FE RE NC E Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. HR S DR AW IN G FO R RE FE RE NC E Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. HR S DR AW IN G FO R RE FE RE NC E
1. 物料型号:文档中提到了多种型号,例如FH35C-9S-0.3SHW(99)、FH35C-11S-0.3SHW(99)等,这些型号可能代表不同的配置或特性。
2. 器件简介:文档由广濑电机株式会社(HIROSE ELECTRIC CO., LTD.)在2022年10月1日版权所有,提到了连接器的高可靠性,特别是在汽车设备/装置中的应用。
3. 引脚分配:文档中提到了不同数量的接触点(Contact No.),例如9、11、13等,以及与之相关的尺寸和布局。
4. 参数特性:提供了详细的尺寸参数,例如接触点的宽度、高度、间距等,以及推荐的PCB安装图案和FPC(Flexible Printed Circuit)配置。
5. 功能详解:文档中包含了连接器的操作说明,例如如何锁定(Lock)、如何插入FPC、如何检查FPC插入以及如何进行FPC布线。
6. 应用信息:强调了在设计用于汽车设备的连接器时,需要考虑的可靠性和精细操作。
7. 封装信息:提供了连接器的尺寸和包装信息,例如卷轴尺寸、带头和尾带的尺寸等。
FH35C-13S-0.3SHW(99) 价格&库存
很抱歉,暂时无法提供与“FH35C-13S-0.3SHW(99)”相匹配的价格&库存,您可以联系我们找货
  • 1+15.82310
库存:14
  • 1+20.827601+2.51240
  • 10+17.0493010+2.05660
  • 100+14.69360100+1.77250
  • 500+12.85110500+1.55020
  • 1000+10.996901000+1.32660
  • 2500+10.658702500+1.28580
  • 5000+10.075605000+1.21540
库存:831
