FH23-61S-0.3SHAW(05)
    HRS(广濑)
    SMD,P=0.3mm
    CONN FPC BOTTOM 61POS 0.30MM R/A
FH23-61S-0.3SHAW(05) 数据手册
0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors FH 23 Series ●Staggered termination configuration. Only 1.25 mm above the board. Leadless type Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Completely enclosed bottom surface Lead type 1.25mm ■Features 1. FPC low insertion force and high holding force Hirose Electric's unique low insertion force (LIF) design (patents pending) improves the Flexible Printed Circuit (FPC) holding force after insertion. 2. Temporary hold of FPC There is no need to hold the FPC after insertion in the connector. The connector will hold it in correct position, allowing closing of the actuator. 3. Easy board mounting The surface mounted termination of the contacts is staggered on 0.6 mm centers, positioned on front and back of the connector. Bottom of the connector is completely insulated, allowing conductive traces on PCB to run under the connector. When the actuator is opened 4. Proven Flip-lock Actuator assures easy and reliable operation Rotating actuator permits easy insertion and reliable connection with the FPC. Tactile sensation confirms complete mechanical locking of the actuator and the electrical connection. 5. Variations to suit different mounting areas Available with lead and leadless type of terminations (for opposing FPC insertion side). 6. Designed for placement with automatic equipment Temporary hold of FPC Flat top surface allows pick-up with vacuum nozzles. Packaged in embossed tape, on reel. One reel contains 2,500 pieces. 7. Accepts 0.2mm thick FPC 8. Variety of contact positions Available with 15,17,21,23,25,27,31,33,37,39,45,51,61and 71 pos. 9. Halogen Free The connector does not use chlorine and bromine exceeding standard limits. *Defined in accordance with IEC61249-2-21 *Br 900ppm or lower, Cl 900ppm or lower, Br + Cl 1,500ppm or lower When the actuator is closed 2013.11w 1 FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■Product Specifications Operating temperature range -55 ç to +85ç (Note 1) Operating humidity range 30V AC Relative humidity 90% max. (No condensation) Current rating 0.3A Ratings Voltage rating Recommended FPC Thickness: = 0.2±0.03mm Gold plated Item Specification Conditions 1. Insulation resistance 50 M ohms min. 2. Withstanding voltage No flashover or insulation breakdown 3. Contact resistance 100 m ohms max. *Including FPC/FFC conductor resistance Contact resistance: 100 m ohms max. 4. Durability 4. (insertion / withdrawal) No damage, cracks, or parts dislocation. Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Storage temperature range -10ç to +50ç (Note 2) Storage humidity range Relative humidity 90% max. (No condensation) 100 V DC 90 V AC/one minute 1 mA AC 10 cycles 5. Vibration No electrical discontinuity of 1 μs or more. Contact resistance: 100 m ohms max. No damage, cracks, or parts dislocation. Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 10 cycles, 3 axis. 6. Shock No electrical discontinuity of 1 μs or more. Contact resistance: 100 m ohms max. No damage, cracks, or parts dislocation. Acceleration of 981 m/s 2 , 6ms duration, sine half-wave waveform, 3 cycles, 3 axis. 7. Humidity (Steady state) Contact resistance: 100 m ohms max. Insulation resistance: 50 M ohms min. No damage, cracks, or parts dislocation. 96 hours at 40°C and humidity of 90% to 95% 8. Temperature cycle Contact resistance: 100 m ohms max. Insulation resistance: 50 M ohms min. No damage, cracks, or parts dislocation. Temperature:-55ç/+15ç to +35ç/+85ç/+15ç to +35ç Time: 30/ 2 to 3 / 30 / 2 to 3 (Minutes) 5 cycles 9. Resistance to soldering heat No deformation of components affecting performance. Reflow: At the recommended temperature profile Manual soldering: 350 ç±5 ç for 5 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term ”storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non-conducting condition of installed connectors in storage, shipment or during transportation. ■Materials Part Material Finish Insulator LCP Color: Beige Actuator LCP Color: Black Contacts Phosphor bronze Gold plated Remarks UL94V-0 --------------- ■Ordering information FH 23 - 39S - 0.3 SHW (05) 1 2 3 1 Series name : FH 2 Series No : 23 3 Number of contacts : 15 to 71 4 Contact pitch: 0.3mm 5 Terminal type SHW: SMT horizontal mounting type, lead type termination. SHAW: SMT horizontal mounting type, lead-less type termination. 2 4 5 6 6 Plating specifications : (05) : Gold plated (All contact positions except 51 contacts) (06) : Gold plated (51 contacts) FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■Connector Dimensions (Lead Type termination) A 0.3 B 1.7 (0.15) 1.25(Including contact terminal leads) 2.45 0.6 0.6 Number of contacts indicator (0.12) C (2.84) Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ** 0.05MAX. 0.05MAX. E 0.1MAX. 0.55 (D: FPC insertion area dimensions) 1 4.15 0.5 0.1MAX. 2 1 2 Notes 1 The coplanarity of each terminal lead is within 0.1. 2 The contact terminal lead position indicates the dimension from the E surface, the bottom surface of the insulator body. 3 Any discoloration of the plastic compound will NOT AFFECT form, fit or function of the connector. 4 Packaged on tape and reel only. Check packaging specification. Lead Type Unit: mm Part Number CL No. Number of Contacts A B C D FH23-15S-0.3SHW(05) 586-1317-0-05 FH23-17S-0.3SHW(05) 586-1300-7-05 15 7 3.6 4.2 4.83 17 7.6 4.2 4.8 5.43 FH23-21S-0.3SHW(05) FH23-23S-0.3SHW(05) 586-1314-1-05 21 8.8 5.4 6 6.63 586-1324-5-05 23 9.4 6 6.6 7.23 FH23-25S-0.3SHW(05) 586-1322-0-05 25 10 6.6 7.2 7.83 FH23-27S-0.3SHW(05) 586-1308-9-05 27 10.6 7.2 7.8 8.43 FH23-31S-0.3SHW(05) 586-1302-2-05 31 11.8 8.4 9 9.63 FH23-33S-0.3SHW(05) 586-1304-8-05 33 12.4 9 9.6 10.23 FH23-37S-0.3SHW(05) 586-1335-1-05 37 13.6 10.2 10.8 11.43 FH23-39S-0.3SHW(05) 586-1306-3-05 39 14.2 10.8 11.4 12.03 FH23-45S-0.3SHW(05) 586-1318-2-05 45 16 12.6 13.2 13.83 FH23-51S-0.3SHW(06) 586-1312-6-06 51 17.8 14.4 15 15.63 FH23-61S-0.3SHW(05) 586-1310-0-05 61 20.8 17.4 18 18.63 FH23-71S-0.3SHW(05) 586-1320-4-05 71 23.8 20.4 21 21.63 Note1: Embossed tape reel packaging(2,500 pieces/reel) Order by number of reels. Note2: The specification of (06) is applied to number of 51. Refer to ordering information. 3 FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■Connector Dimensions Diagram (Leadless Type termination) A 0.3 1.7 B (0.15) 1.25 (Including contact terminal leads) 2.45 0.6 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ** 0.6 Number of contacts indicator (0.12) (2.84) C 0.05MAX. 0.1MAX. (D: FPC insertion area dimensions) 1 0.05MAX. E 0.55 0.1MAX. 4.15 2 1 2 Notes 1 The coplanarity of each terminal lead is within 0.1. 2 The contact terminal lead position indicates the dimension from the E surface, the bottom surface of the insulator body. 3 Any discoloration of the plastic compound will NOT AFFECT form, fit or function of the connector. 4 Packaged on tape and reel only. Check packaging specification. Leadless Type Part Number Unit: mm CL No. Number of Contacts A B C D FH23-15S-0.3SHAW(05) 586-1316-7-05 FH23-17S-0.3SHAW(05) 586-1301-0-05 15 7 3.6 4.2 4.83 17 7.6 4.2 4.8 5.43 FH23-21S-0.3SHAW(05) FH23-23S-0.3SHAW(05) 586-1315-4-05 21 8.8 5.4 6 6.63 586-1325-8-05 23 9.4 6 6.6 7.23 FH23-25S-0.3SHAW(05) 586-1323-2-05 25 10 6.6 7.2 7.83 FH23-27S-0.3SHAW(05) 586-1309-1-05 27 10.6 7.2 7.8 8.43 FH23-31S-0.3SHAW(05) 586-1303-5-05 31 11.8 8.4 9 9.63 FH23-33S-0.3SHAW(05) 586-1305-0-05 33 12.4 9 9.6 10.23 FH23-39S-0.3SHAW(05) 586-1307-6-05 39 14.2 10.8 11.4 12.03 FH23-45S-0.3SHAW(05) 586-1319-5-05 45 16 12.6 13.2 13.83 FH23-51S-0.3SHAW(06) 586-1313-9-06 51 17.8 14.4 15 15.63 FH23-61S-0.3SHAW(05) 586-1311-3-05 61 20.8 17.4 18 18.63 FH23-71S-0.3SHAW(05) 586-1321-7-05 71 23.8 20.4 21 21.63 Note1: Embossed tape reel packaging(2,500 pieces/reel) Order by number of reels. Note2: The specification of (06) is applied to number of 51. Refer to ordering information. 4 FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■Recommended PCB Land and Metal Mask Dimensions (Lead Type) (5.2) 3.45±0.05 (0.1) 0.3±0.05 (Land) 0.25±0.05 (Metal mask) 0.3±0.05 1.25±0.05 (5.4) 0.7±0.05 B±0.05 0.6±0.05 0.25±0.05 (Metal mask) C±0.05 Lead Type Unit: mm Number of Contacts B FH23-15S-0.3SHW(05) 586-1317-0-05 Part Number CL No. 15 3.6 4.2 4.8 FH23-33S-0.3SHW(05) 586-1304-8-05 33 9 FH23-17S-0.3SHW(05) 586-1300-7-05 17 4.2 4.8 5.4 FH23-37S-0.3SHW(05) 586-1335-1-05 37 10.2 10.8 11.4 FH23-21S-0.3SHW(05) 586-1314-1-05 21 5.4 6.6 FH23-39S-0.3SHW(05) 586-1306-3-05 39 10.8 11.4 12 FH23-23S-0.3SHW(05) 586-1324-5-05 23 6.6 7.2 FH23-45S-0.3SHW(05) 586-1318-2-05 45 12.6 13.2 13.8 FH23-25S-0.3SHW(05) 586-1322-0-05 25 6.6 7.2 7.8 FH23-51S-0.3SHW(06) 586-1312-6-06 51 14.4 15 15.6 FH23-27S-0.3SHW(05) 586-1308-9-05 27 7.2 7.8 8.4 FH23-61S-0.3SHW(05) 586-1310-0-05 61 17.4 18 18.6 FH23-31S-0.3SHW(05) 586-1302-2-05 31 8.4 FH23-71S-0.3SHW(05) 586-1320-4-05 71 20.4 21 21.6 Number of Contacts B 6 C 6 9 G 9.6 Part Number CL No. C G 9.6 10.2 ■Recommended Land and Metal Mask Dimensions (Leadless Type) ( 0.1 ) 0.3±0.05(Land) 0.6±0.05 0.25±0.05(Metal mask) (4.6) 0.3±0.05 1.25±0.05 2.9±0.05 0.65±0.05 B±0.05 (4.8) Recommended metal mask thickness: t = 0.1 mm 0.3±0.05(Land) 0.6±0.05 (0.1) Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.3±0.05 (Land) (0.1) Recommended metal mask thickness: t = 0.1 mm 0.6±0.05 0.25±0.05(Metal mask) C±0.05 Leadless Type Part Number Unit: mm CL No. Number of Contacts B C G Part Number CL No. Number of Contacts B 9 C G FH23-15S-0.3SHAW(05) 586-1316-7-05 15 3.6 4.2 4.8 FH23-33S-0.3SHAW(05) 586-1305-0-05 33 FH23-17S-0.3SHAW(05) 586-1301-0-05 17 4.2 4.8 5.4 FH23-39S-0.3SHAW(05) 586-1307-6-05 39 10.8 11.4 12 FH23-21S-0.3SHAW(05) 586-1315-4-05 21 5.4 6.6 FH23-45S-0.3SHAW(05) 586-1319-5-05 45 12.6 13.2 13.8 FH23-23S-0.3SHAW(05) 586-1325-8-05 23 6.6 7.2 FH23-51S-0.3SHAW(06) 586-1313-9-06 51 14.4 15 15.6 FH23-25S-0.3SHAW(05) 586-1323-2-05 25 6.6 7.2 7.8 FH23-61S-0.3SHAW(05) 586-1311-3-05 61 17.4 18 18.6 FH23-27S-0.3SHAW(05) 586-1309-1-05 27 7.2 7.8 8.4 FH23-71S-0.3SHAW(05) 586-1321-7-05 71 20.4 21 21.6 FH23-31S-0.3SHAW(05) 586-1303-5-05 31 8.4 6 6 9 9.6 10.2 9.6 5 FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■Recommended FPC Dimensions G±0.05 C±0.03 0.3±0.07 1 0.3 +0.04 -0.03 ( 0.1 ) 0.2±0.03 (0.07) stiffener (0.5) (0.2) Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. +0.04 -0.03 (2) 1.1 ±0.15 0.3 ±0.15 ( 0.2 ) 0.4 2.8 ±0.15 3.5 ±0.3 (Area with removed covering layer film) 1.3 ±0.15 0.6 ±0.02 2R0 .2 0.3 ±0.07 (0.05) (0.1 between conductors) (0.2 conductor width) B±0.03 0.6±0.07 2 0.3±0.02 T 0.6±0.02 6 +0.04 - 0.03 1 0.3 2 Dimension T must be 0.5mm minimum. also permitted when drawing plated leads. FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■FH23 Series FPC Construction (Recommended Specifications) 1. Using Single-sided FPC Material Name Covering film layer. Material Polyimide 1 mil thick. Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cover adhesive Thickness (μm) (25) (25) Surface treatment Nickel under plated 1 to 5μm / Gold plated 0.2μm Copper foil Cu Base adhesive Heat-hardened adhesive 25 Base film Polyimide 1 mil thick 25 Reinforcement material adhesive Heat-hardened adhesive 30 Stiffener 1oz Polyimide 3 mil thick Total 3 35 75 193 2. Using Double-sided FPC Material Material Name Covering layer film Polyimide 1 mil thick Thickness (μm) (25) (25) Cover adhesive Surface treatment Nickel under plated 1 to 5μm / Gold plated 0.2μm Through-hole copper Cu Copper foil Cu Base adhesive Heat-hardened adhesive 18 Base film Polyimide 1 mil thick 25 Base adhesive Heat-hardened adhesive 18 Copper foil Cu Cover adhesive Heat-hardened adhesive 25 Covering layer film Polyimide 1 mil thick 25 Reinforcement material adhesive Heat-hardened adhesive 25 Stiffener Polyimide 3 15 1/2oz 1/2oz 1 mil thick Total 18 (18) 25 197 Note : Recommended specification for FPC 0.2±0.03 mm thick. 3. Precautions 1. This specification is a recommendation for the construction of the FH23 Series FPC (t=0.2±0.03). 2. For details about the construction, please contact the FPC manufacturers. 7 FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■Packaging Specification ●Embossed Carrier Tape Dimensions ●Embossed Carrier Tape Dimensions (5.1) (0.5) Ø1. 5 Flat surface for placement with Automatic equipment (2.45) 1.5 +0.1 0 Unreeling direction Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (1.7) (0.3) (0.85) (5.1) Unreeling direction H±0.3 J±0.1 (L) Flat surface for placement with Automatic equipment (Ø1 3) ●Reel Dimensions (0.5) (2.45) (M) K±0.1 (0.3) (N) K±0.1 (L) 2±0.15 12±0.1 (1.7) 1.7 +0.15 0 (0.85) (M) (N) Ø1 .5 + 0 0 .1 12±0.1 H±0.3 2±0.15 1.75±0.1 4±0.1 4±0.1 1.75±0.1 (Tape width of 32 mm min.) +0 .1 0 (Tape width of 24 mm max.) (Ø80) (Ø380) (Q : INSIDE) (R : OUTSIDE) Leader (400 mm min.) Section with connectors Trailer Embossed carrier tape 10 Empty components min. Part Number CL No. Number of Contacts H 586-1317-0-05 586-1300-7-05 586-1314-1-05 586-1324-5-05 586-1322-0-05 586-1308-9-05 586-1302-2-05 586-1304-8-05 586-1335-1-05 586-1306-3-05 586-1318-2-05 586-1312-6-06 586-1310-0-05 586-1320-4-05 15 17 21 23 25 27 31 33 37 39 45 51 61 71 16 16 16 24 24 24 24 24 24 24 24 32 32 44 Part Number CL No. Number of Contacts H FH23-15S-0.3SHAW(05) FH23-17S-0.3SHAW(05) FH23-21S-0.3SHAW(05) FH23-23S-0.3SHAW(05) FH23-25S-0.3SHAW(05) FH23-27S-0.3SHAW(05) FH23-31S-0.3SHAW(05) FH23-33S-0.3SHAW(05) FH23-39S-0.3SHAW(05) FH23-45S-0.3SHAW(05) FH23-51S-0.3SHAW(06) FH23-61S-0.3SHAW(05) FH23-71S-0.3SHAW(05) 586-1316-7-05 586-1301-0-05 586-1315-4-05 586-1325-8-05 586-1323-2-05 586-1309-1-05 586-1303-5-05 586-1305-0-05 586-1307-6-05 586-1319-5-05 586-1313-9-06 586-1311-3-05 586-1321-7-05 15 17 21 23 25 27 31 33 39 45 51 61 71 16 16 16 24 24 24 24 24 24 24 32 32 44 FH23-15S-0.3SHW(05) FH23-17S-0.3SHW(05) FH23-21S-0.3SHW(05) FH23-23S-0.3SHW(05) FH23-25S-0.3SHW(05) FH23-27S-0.3SHW(05) FH23-31S-0.3SHW(05) FH23-33S-0.3SHW(05) FH23-37S-0.3SHW(05) FH23-39S-0.3SHW(05) FH23-45S-0.3SHW(05) FH23-51S-0.3SHW(06) FH23-61S-0.3SHW(05) FH23-71S-0.3SHW(05) 8 Top cover tape 10 Empty components min. J -----------28.4 28.4 40.4 J ----------28.4 28.4 40.4 K L M N Q Unit: mm R 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 20.2 7.3 7.9 9.1 9.7 10.3 10.9 12.1 12.7 13.9 14.5 16.3 18.1 21.1 24.1 5.1 5.7 6.9 7.5 8.1 8.7 9.9 10.5 11.7 12.3 14.1 15.9 18.9 21.9 4.5 5.1 6.3 6.9 7.5 8.1 9.3 9.9 11.1 11.7 13.5 15.3 18.3 21.3 17.4 17.4 17.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 45.4 21.4 21.4 21.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 49.4 K L M N Q R 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 20.2 7.3 7.9 9.1 9.7 10.3 10.9 12.1 12.7 14.5 16.3 18.1 21.1 24.1 5.1 5.7 6.9 7.5 8.1 8.7 9.9 10.5 12.3 14.1 15.9 18.9 21.9 4.5 5.1 6.3 6.9 7.5 8.1 9.3 9.9 11.7 13.5 15.3 18.3 21.3 17.4 17.4 17.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 45.4 21.4 21.4 21.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 49.4 FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■Recommended Temperature Profile Max. 250ç 250 HRS test condition Solder method Environment Solder composition Temperature 230ç 200 200ç Test board 150 150ç Land dimensions (ç) 100 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Metal mask 50 25ç (60 sec.) 90 sec. to 120 sec. (60 sec.) 0 Start Preheating Time (Seconds) Soldering :Reflow, IR/hot air :Room air :Paste, 96.5%Sn/3.0%Ag/0.5%Cu (Senju Metal Industry, Co., Ltd.’s Part Number: M705-221-CM5-3210.5) :Glass epoxy 45mm∞100mm∞1.6mm thick : Lead type 0.3mm∞1.25mm, 0.3mm∞0.7mm Leadless type 0.3mm∞1.25mm, 0.3mm∞0.65mm : Lead type 0.25mm∞1.25mm∞0.1mm thick 0.25mm∞0.7mm∞0.1mm thick Leadless type 0.25mm∞1.25mm∞0.1mm thick 0.25mm∞0.65mm∞0.1mm thick In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/thickness. Consult tour solder paste and equipment manufacturer for specific recommendations. 9 FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■Connector Operating Instructions, precautions and recommendations Operation 1.FPC Termination procedure. Connector installed on the board. 1) Lift up the actuator. Use thumb or index finger. Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2) Fully insert the FPC in the connector parallel to mounting surface, with the exposed conductive traces facing down. FPC conductor surface (Bottom side) photo 1 3) Rotate down the actuator until firmly closed. NOTE: The FPC must be fully inserted in the connector. If not fully inserted, the actuator will not close properly. Should this be the case, lift up the actuator (per Step 2 below) and repeat the process (starting with Step 1 above) 4) For connectors with multiple contacts, such as 61 and 71 pos. rotate down the actuator pushing at both ends. 2.FPC Removal 1) Lift up the actuator. 2) Carefully remove the FPC. 10 photo 2 photo 3 FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors ■Connector Operating Instructions, precautions and recommendations Precautions Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1) Do not apply excessive force or use any type of tool to operate the actuator. 2) The connector will assure reliable performance when the actuator is open to 90° maximum Do not exceed this angle, as this may cause permanent damage to the connector. 3) Properly insert the FPC at the positioning part of the connector. Locking the FPC while it is partially inserted, may cause lock damage, disconnection of the FPC, or continuity fault. 90ç C FP lot ns rtio e ins 4) Do not apply force in the upward direction (as illustrated). Do not bend the FPC too close to the actuator. 5) When inserting the FPC, do not forcefully rub against the bottom surface of the connector insertion entrance. Doing so will result in the contacts and FPC making strong contact and may cause deformation of the contacts, peeling of the FPC conductor, and other problems. 11 Jun.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH23 Series●0.3mm Contact Pitch, 1.25mm above the board, Flexible Printed Circuit Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. Headquarters 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : 1-805-522-7958 Fax : 1-805-522-3217 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. North California Office 20400 Stevens Creek Blvd., Ste 250, Cupertino, CA 95014 Phone : 1-408-253-9640 Fax : 1-408-253-9641 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : 1-734-542-9963 Fax : 1-734-542-9964 http://www.hiroseusa.com GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : 49-711-4560-02-1 Fax : 49-711-4560-02-299 http://www.hirose.de THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : 31-20-6557460 Fax : 31-20-6557469 http://www.hiroseeurope.com UK: HIROSE ELECTRIC EUROPE B.V. UK BRANCH First Floor, St Andrews House, Caldecotte Lake Business Park, Milton Keynes MK7 8LE Phone : 44-1908-369060 Fax : 44-1908-369078 http://www.hirose.co.uk CHINA: HIROSE ELECTRIC CO., LTD. BEIJING REPRESENTATIVE OFFICE A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, Chao Yang District, Beijing, 100025 Phone : 86-10-5165-9332 Fax : 86-10-5908-1381 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1501-02, Cross Tower Building, 318 Fuzhou Road, Huang Pu District, Shanghai 200001 Phone : 86-21-6391-3355 Fax : 86-21-6335-0767 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC CO., LTD. SHENZHEN OFFICE Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre 5002, ShenNanDong Road, ShenZhen City, Guangdong Province, 518008 Phone : 86-755-8207-0851 Fax : 86-755-8207-0873 http://www.hirose-china.com.cn HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Unit 1102 A&B, Energy Plaza, 92 Granville Road, Tsim Sha Tsui East, Kowloon Phone : 852-2803-5338 Fax : 852-2591-6560 http://www.hirose-hongkong.com.hk TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : 886-2-2555-7377 Fax : 886-2-2555-7350 http://www.hirose-taiwan.com.tw SINGAPORE: HIROSE ELECTRIC CO., LTD. 10 Anson Road #26-16 International Plaza 079903 Phone : 65-6324-6113 Fax : 65-6324-6123 http://www.hirose-singapore.com.sg KOREA: HIROSE KOREA CO., LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, Kyunggi-Do 429-450 Phone : 82-31-496-7000,7124 Fax : 82-31-496-7100 http://www.hirose.co.kr ® 12 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The contents of this catalog are current as of date of 11/2013. Contents are subject to change without notice for the purpose of improvements.
FH23-61S-0.3SHAW(05) 价格&库存
很抱歉,暂时无法提供与“FH23-61S-0.3SHAW(05)”相匹配的价格&库存,您可以联系我们找货
