SMBJ6.8A(CA) THRU SMBJ68A(CA) SMB
Surface mount transient voltage suppressor power 600 watts
Stand-Off Voltage: 6.8V~68V
Pinning
1.Cathode
2.Anode
FEATURES
1
For surface mounted applications in order tooptimize board space.
Low profile package.
2
Unipolar
Glass passivated junction.
Low inductance.
Bipolar
Plastic package has Underwriters Laboratory Flammability.
DO-214AA/SMB
MECHANICAL DATA
Case: DO-214A A /SMB
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 0.1g / 0.0034oz
Maximum Ratings and Electrical characteristics
Ratings at 25 ambient temperature unless o °C therwise specified.
Parameter
Symbol
Value
Unit
PPPM
600
W
IFSM
(UNI)
100
A
IPPM
see Table 1
A
Contact
VESD1
±30
Air
VESD2
±30
Cj
390
pF
RθJA
100
°C/W
TJ,TSTG
-65 to +150
°C
Peak Pulse Power Dissipation on TA=25°C (Note 1,2,5, Fig1)
Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed
on Rated Load, (JEDEC Method) (Note 3,Fig4).
Peak Pulse Current on 10/1000 us waveform (Note 1) Fig 3
ESD Voltage per IEC6100-4-2
kV
Typical Junction Capacitance at VR=4V, f=1MHz
Typical Thermal Resistance Junction to Ambient(Note 2)
Operating Junction Temperature and Storage Temperature
Range
NOTES:
1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2.
2. Mounted on 5mm2 copper pads to each terminal.
3. Peak Forward Surge Current : 8.3ms single half sine-wave Superimposed on rated load (JEDEC method).
4. Peak pulse power waveform is 10/1000μS.
www.yfwdiode.com
1/4
Dongguan YFW Electronics Co, Ltd.
Type
Breakdown
Voltage
Marking
VRMW
VBR @ IT
Min
Max
Test
Reverse
Current Leakage
IT
Max.
Clamp
Voltage
IR@VRWM VC@IPP
Peak
Pulse
Current
IPP
Uni
Bi
Uni
Bi
V
V
V
mA
μA
V
A
SMBJ6V8A
SMBJ6V8CA
6V8A
6V8CA
5.8
6.45
7.14
10
1000
10.5
58.1
SMBJ7V5A
SMBJ7V5CA
7V5A
7V5CA
6.4
7.13
7.88
10
500
11.3
54
SMBJ8V2A
SMBJ8V2CA
8V2A
8V2CA
7.02
7.79
8.61
10
200
12.1
50.4
SMBJ9V1A
SMBJ9V1CA
9V1A
9V1CA
7.78
8.65
9.55
1
50
13.4
45.5
SMBJ10A
SMBJ10CA
10A
10CA
8.55
9.5
10.5
1
10
14.5
42.1
SMBJ11A
SMBJ11CA
11A
11CA
9.4
10.5
11.6
1
5
15.6
39.1
SMBJ12A
SMBJ12CA
12A
12CA
10.2
11.4
12.6
1
5
16.7
36.5
SMBJ13A
SMBJ13CA
13A
13CA
11.1
12.4
13.7
1
1
18.2
33.5
SMBJ15A
SMBJ15CA
15A
15CA
12.8
14.3
15.8
1
1
21.2
28.8
SMBJ16A
SMBJ16CA
16A
16CA
13.6
15.2
16.8
1
1
22.5
27.1
SMBJ18A
SMBJ18CA
18A
18CA
15.3
17.1
18.9
1
1
25.5
24.2
SMBJ20A
SMBJ20CA
20A
20CA
17.1
19
21
1
1
27.7
22
SMBJ22A
SMBJ22CA
22A
22CA
18.8
20.9
23.1
1
1
30.6
19.9
SMBJ24A
SMBJ24CA
24A
24CA
20.5
22.8
25.2
1
1
33.2
18.4
SMBJ27A
SMBJ27CA
27A
27CA
23.1
25.7
28.4
1
1
37.5
16.3
SMBJ30A
SMBJ30CA
30A
30CA
25.6
28.5
31.5
1
1
41.4
14.7
SMBJ33A
SMBJ33CA
33A
33CA
28.2
31.4
34.7
1
1
45.7
13.3
SMBJ36A
SMBJ36CA
36A
36CA
30.8
34.2
37.8
1
1
49.9
12.2
SMBJ39A
SMBJ39CA
39A
39CA
33.3
37.1
41
1
1
53.9
11.3
SMBJ43A
SMBJ43CA
43A
43CA
36.8
40.9
45.2
1
1
59.3
10.3
SMBJ47A
SMBJ47CA
47A
47CA
40.2
44.7
49.4
1
1
64.8
9.4
SMBJ51A
SMBJ51CA
51A
51CA
43.6
48.5
53.6
1
1
70.1
8.7
SMBJ56A
SMBJ56CA
56A
56CA
47.8
53.2
58.8
1
1
77
7.9
SMBJ58A
SMBJ58CA
58A
58CA
52.78
55.1
60.9
1
1
79.8
7.7
SMBJ62A
SMBJ62CA
62A
62CA
53
58.9
65.1
1
1
85
7.2
SMBJ68A
SMBJ68CA
68A
68CA
58.1
64.6
71.4
1
1
92
6.6
www.yfwdiode.com
2/4
Fig.2 Forward Current Derating Curve
PEAK PULSE POWER(PPP)OR CURRENT(Ipp)
DERATINGIN PERCENTAGE%
P PPM ,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
100
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
10
1.0
0.1
0.1
10
1
100
1000
10000
100
80
60
40
I ppm ,Peak Pulse Current (%)
I FSM ,PEAK FORWARD SURGE CURRENT,
AMPERES
T A =25°C
100
Peak Value
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
I ppm
80
Half Value-I pp /2
60
10/1000usec Waveform as Defined bye R.E.A.
40
2.0
3.0
4.0
T,TIME,ms
www.yfwdiode.com
100
125
150
175
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Pulse Waveform
t f =10usec
75
T A ,AMBIENT TEMPERATURE,°C
td,PULSE WIDTH ,us
120
50
120
100
80
60
40
T J =T J max
8.3ms Single Half Sinepwave
JEDEC Method
10
100
Number of Cycles at 60Hz
3/4
DO-214AA SMB
Package Outline
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
UNIT
mm
mil
VM
A
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
E1
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
160
130
The recommended mounting pad size
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
Summary of Packing Options
Package
DO-214AA SMB
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
3000
EIA-481-1
4/4
很抱歉,暂时无法提供与“SMBJ6V8CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28595
- 100+0.22466
- 600+0.19392
- 1200+0.19101
- 国内价格
- 1+0.34430
- 200+0.22110
- 1500+0.19250
- 3000+0.17050
- 国内价格
- 10+0.35500
- 100+0.28448
- 300+0.24927
- 3000+0.22270
- 6000+0.20153
- 9000+0.19095
