APXK2R5ARA331ME61G
APXK2R5ARA331ME61G
    NCC(贵弥功)
    DIP
    铝聚合物电容器 DIP 330µF ±20% 2.5V Ф5.00mm 16mΩ
APXK2R5ARA331ME61G 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS PXK TM NPCAP Surface Mount - Series ・Super low ESR, impedance and high heat resistance have been obtained by using conductive polymer as electrolyte. ・Rated voltage range : 2.5 to 16Vdc, Capacitance range : 100 to 560µF ・Suitable for DC-DC converters, voltage regulators and decoupling applications used to computer motherboards etc. ・RoHS Compliant ・Halogen Free PXK Downsized PXE P36 ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Surge Voltage Leakage Current Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance -55 to +105℃ 2.5 to 16Vdc ±20% (M) Rated voltage×1.15V Shall not exceed values shown in STANDARD RATINGS. (at 20℃, 120Hz) (at 105℃) (at 20℃ after 2 minutes) 0.12 max. (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.15 Z(-55℃)/Z(+20℃)≦1.25 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours (F46 : 1,000 hours) at 105℃. Appearance No significant damage Capacitance change ≦±20% of the initial value DF (tanδ) ≦150% of the initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to the DC rated voltage at 60℃, 90 to 95% RH for 1,000 hours (F46 : 500hours). Appearance No significant damage Capacitance change ≦±20% of the initial value DF (tanδ) ≦150% of the initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105℃ for 30 seconds through a protective resistor(R=1kΩ) and discharge for 5 minutes 30 seconds. Appearance No significant damage Capacitance change ≦±20% of the initial value DF (tanδ) ≦150% of the initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value 0.5% per 1,000 hours maximum (Confidence level 60% at 105℃) Bias Humidity Surge Voltage Failure Rate *Note : If any doubt arises, measure the leakage current after following voltage treatment. Voltage treatment : DC rated voltage are applied to the capacitors for 120 minutes at 105℃. ◆DIMENSIONS [mm] EX) 2.5V330µF Code : A P C±0.2 W B±0.2 φD±0.5 ●Terminal ◆MARKING 0.3max. L±0.3 (Note) Size Code E61 F46 F61 φD 5 6.3 6.3 L 5.8 4.5 5.8 A 5.3 6.6 6.6 B 5.3 6.6 6.6 C 5.9 7.2 7.2 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 P 1.4 1.9 1.9 K89A 330 2.5V A±0.2 Note : L+0.1/-0.2 for F46 ◆PART NUMBERING SYSTEM 1 2 3 4 A PXK 5 6 7 8 9 10 A RA 11 12 13 14 M 15 16 17 18 G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 330µF:331, 560µF:561) Taping code Terminal code Voltage code (ex. 2.5V:2R5, 6.3V:6R3) Series code Category Please refer to "Product code guide (conductive polymer type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 30 CAT. No. E1001N CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS TM NPCAP Surface Mount PXKSeries - ◆STANDARD RATINGS WV (Vdc) 2.5 4 6.3 16 Cap (µF) 220 330 330 560 180 220 390 150 180 220 330 100 Size code Leakage current (µA max./after 2min.) F46 E61 F46 F61 F46 E61 F61 F46 E61 F46 F61 F61 300 412 700 700 360 440 780 472 567 700 1,040 320 ESR Rated ripple current (mΩ max./20℃, 100k to 300kHz) (mArms/105℃, 100kHz) 19 16 16 16 19 17 17 19 17 18 17 24 2,780 3,500 3,500 3,500 2,780 3,390 3,390 2,780 3,390 3,200 3,390 2,490 Part No. APXK2R5ARA221MF46G APXK2R5ARA331ME61G APXK2R5ARA331MF46G APXK2R5ARA561MF61G APXK4R0ARA181MF46G APXK4R0ARA221ME61G APXK4R0ARA391MF61G APXK6R3ARA151MF46G APXK6R3ARA181ME61G APXK6R3ARA221MF46G APXK6R3ARA331MF61G APXK160ARA101MF61G Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 31 CAT. No. E1001N
APXK2R5ARA331ME61G
物料型号:NPCAP TM-PXK系列
器件简介:该系列固态铝电解电容器使用导电聚合物作为电解质,具有超低的等效串联电阻(ESR)、阻抗和高耐热性。适用于计算机主板等使用的DC-DC转换器、电压调节器和去耦应用。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性: - 工作温度范围:-55°C至+105°C - 额定电压范围:2.5至16V直流 - 电容公差:±20%(M),在20°C、120Hz时 - 冲击电压:额定电压的1.15倍(在105°C时) - 漏电流:在20°C下2分钟后不超过标准额定值 - 耗散因子(tan δ):最大0.12(在20°C、120Hz时) - 低温特性:在100kHz时,-25°C时的阻抗与+20°C时的阻抗比不超过1.15,-55°C时不超过1.25 - 耐久性:在105°C下施加额定电压2000小时后,电容变化不超过初始值的+20%,耗散因子不超过初始指定值的150%,ESR不低于初始指定值的150%
功能详解:文档中没有提供详细的功能解释。
应用信息:适用于DC-DC转换器、电压调节器和去耦应用。
封装信息:提供了不同尺寸代码的封装尺寸,例如E61、F46和F61,包括直径(D)、长度(L)、宽度(W)等。
APXK2R5ARA331ME61G 价格&库存
很抱歉,暂时无法提供与“APXK2R5ARA331ME61G”相匹配的价格&库存,您可以联系我们找货
