RFS-16V102MJ7#5
RFS-16V102MJ7#5
    ELNA(伊娜)
    DIP
    CAP ALUM 1000UF 20% 16V RADIAL
RFS-16V102MJ7#5 数据手册
RFS RFS MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS FOR AUDIO MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS FOR AUDIO ® ® SILMIC series Silk fiber using audio purpose capacitor ELNA developed new raw material for the separate paper which use a silk fibers. Therefore, this capacitor can give you high grade sound for your audio design. Due to the silk fiber's pliability, the capacitor makes a dream of the high quality sound. For examples ; To relieve the music's vibration energy. To decrease the peak feeling sound at high compass and rough quality sound at middle compass. To increase massive sound at low compass. For bipolar capacitors, consult with us. ● ● ● ● Marking color : White print on a brown sleeve ● ● Miniature High Grade Capacitors for Audio(SILMICⅠ Ⅰ) ● ● GREEN CAP All lead wires oxygen-free copper for extremely low distortion. (Third high frequency distortion 10kHz,0.1A,-120dB or less) "SILMIC II" mark on sleeve. For Audio For higher grade RFS For higher grade ROS For higher grade ROA ROB Specifications Item Performance ー40 to +85 ±20 Less than 0.01CV or 3 whichever is larger (after 5 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V) Category temperature range (℃) Tolerance at rated capacitance (%) Leakage current (µA) 6.3 0.20 Rated voltage (V) tanδ (max.) Tangent of loss angle (tanδ) 10 0.17 16 0.13 35 0.10 50 0.08 63 0.08 100 0.08 0.02 is added to every 1000µF increase over 1000µF (20℃,120Hz) Test time Leakage current Percentage of capacitance change Tangent of the loss angle Endurance (85℃) (Applied ripple current) 1000 hours (with the polarity inverted every 250 hours) The initial specified value or less Within ±20% of initial value 150% or less of the initial specified value Test time : 1000 hours. Other have same as endurance. Voltage application treatment : According to JIS C5101 -1 JIS C5101-1, -4 1998 (IEC 60384-1 1992, -4 1985) Shelf life (85℃) Applicable standards Outline Drawing Unit : mm Vent (except φ5) Sleeve φd±0.05 copper wire (tinned) Coefficient of Frequency for Rated Ripple Current Rated voltage (V) 15min. L+α max. 5 2.0 0.6 6.3 2.5 0.6 8 3.5 0.6 10 5.0 0.6 12.5 5.0 0.6 16 7.5 0.8 50・60 120 1k 10k 100k 0.8 0.8 0.8 0.8 0.8 1 1 1 1 1 1.1 1.5 1.2 1.6 1.2 1.2 1.7 1.3 1.9 1.3 1.2 1.7 1.3 1.9 1.3 Part numbering system (example : 25V100µF) 18 7.5 0.8 RFS 2.0 (φ10,16L or less : 1.5) 1.5 α 50 to 100 5 min. Frequency (Hz) CV (µF×WV) All CV value ≤1000 1000< ≤1000 1000< 25 to 35 F±0.5 φD+0.5max. 6.3 to 16 φD F φd 25 0.10 (20℃,120Hz) (20℃) ̶ Series code 25 V Rated voltage symbol 101 M Rated capacitance Capacitance symbol tolerance symbol H4 #5 ̶ Casing symbol Taping (Forming) symbol Case symbol Standard Ratings Rated voltage (V) Rated capacitance (µF) Item Case 6.3 φD×L (mm) 10 16 25 35 50 63 100 Rated ripple Rated ripple Rated ripple Rated ripple Rated ripple Rated ripple Rated ripple Rated ripple Case Case Case Case Case Case Case current current current current current current current current (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) 2.2 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 3.3 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 4.7 10 22 33 47 100 220 330 470 1000 2200 3300 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 5×11 5×11 6.3×11 8×11.5 10×12.5 10×16 10×20 12.5×20 ̶ ̶ ̶ 55 65 80 135 240 290 390 710 ̶ ̶ 5×11 5×11 6.3×11 5×11 6.3×11 8×11.5 10×16 10×20 12.5×20 16×25 16×35.5 18×40 50 65 70 75 85 145 260 350 455 835 1500 1980 ̶ ̶ 5×11 35 5×11 6.3×11 5×11 6.3×11 55 70 70 90 5×11 6.3×11 5×11 6.3×11 5×11 6.3×11 20 23 25 30 35 40 5×11 6.3×11 25 30 5×11 22 5×11 30 8×11.5 40 5×11 6.3×11 35 40 10×12.5 60 75 10×16 95 10×20 155 5×11 25 5×11 30 5×11 6.3×11 5×11 6.3×11 35 60 60 80 5×11 6.3×11 35 55 8×11.5 75 8×11.5 95 10×12.5 130 10×16 140 8×11.5 8×11.5 120 10×12.5 140 10×16 175 10×20 190 12.5×20 220 8×11.5 125 8×11.5 140 10×12.5 170 10×16 210 10×20 225 12.5×25 285 10×12.5 10×20 12.5×20 12.5×25 16×31.5 18×40 ̶ 215 385 545 710 1315 2150 ̶ 10×16 12.5×20 12.5×25 16×25 16×35.5 ̶ ̶ 270 505 675 940 1575 ̶ ̶ 10×20 12.5×25 16×25 16×31.5 18×35.5 ̶ ̶ 295 550 785 1030 1690 ̶ ̶ 12.5×20 16×25 16×31.5 16×35.5 18×40 ̶ ̶ 380 720 965 1210 1985 ̶ ̶ 12.5×25 16×31.5 16×35.5 18×35.5 ̶ ̶ ̶ 415 785 1010 1295 ̶ ̶ ̶ 16×25 18×40 ̶ ̶ ̶ ̶ ̶ 485 930 ̶ ̶ ̶ ̶ ̶ (Note) Rated ripple current : 85℃, 120Hz NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 169 CAT.No.2015/2016E FOR AUDIO ALUMINUM Casing Casing Casing Casing Case Case Case Case φD×L (mm) Symbol φD×L (mm) Symbol φD×L (mm) Symbol φD×L (mm) Symbol 5×11 E3 10×12.5 H3 16×31.5 J7 12.5×20 Ⅰ5 6.3×11 F3 10×16 H4 16×35.5 J8 12.5×25 Ⅰ6 8×11.5 G3 10×20 H5 18×35.5 K8 16×25 J6 18×40 K9
RFS-16V102MJ7#5
物料型号:SILMIC系列
器件简介:使用丝纤维作为原料的电容器,可提供高品质音效,适用于音频设计。
引脚分配:文档中未明确提及引脚分配
参数特性: - 漏电流:在+20°C和120Hz条件下,小于0.01CV或3μA(取较大者)。 - 损耗角正切值(tand):根据额定电压不同,tand值在0.08至0.20之间。 - 耐久性测试:在85°C下进行1000小时测试,电容变化在初始值的20%以内,损耗角正切值不超过初始值的150%。
功能详解: - 减少音乐振动能量。 - 降低高频峰值感和中频粗糙音质。 - 增加低频的厚重感。
应用信息:适用于音频设备,特别是需要高品质音效的场合。
封装信息:提供了不同尺寸的封装,包括直径和长度的详细图纸。
RFS-16V102MJ7#5 价格&库存
很抱歉,暂时无法提供与“RFS-16V102MJ7#5”相匹配的价格&库存,您可以联系我们找货
