LAO-50V682MS47PX#B
LAO-50V682MS47PX#B
    ELNAAMERICA
    DIP
    CAP ALUM 6800UF 20% 50V SNAP
LAO-50V682MS47PX#B 数据手册
LAO LAO LARGE CAPACITANCE ALUMINUM ELECTROLYTIC LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS FOR AUDIO CAPACITORS FOR AUDIO ® ® ● ● For Audio GREEN CAP Power Supply Smoothing Use,Standard Capacitors for Audio Best suited as power supply filters for sound quality priority audio equipment. Printed circuit board terminal snap-in type. For audio LAO LA5 Marking color : Gold print on a black sleeve Specifications Performance ー40 to +85 ±20 Less than 0.03CV or 5mA whichever is smaller (after 5 minutes) C : Rated capacitance (µF), V : Rated voltage (V) Item Category temperature range (℃) Tolerance at rated capacitance (%) Leakage current (µA) Rated voltage (V) tanδ (max.) Tangent of loss angle (tanδ) Characteristics at high and low temperature 16 0.40 25 0.40 (20℃,120Hz) (20℃) 50 to 100 0.30 35 0.35 (20℃,120Hz) Rated voltage (V) Impedance ratio Z−25℃/Z+20℃ Z−40℃/Z+20℃ (max.) 16 to 35 4 15 50 to 100 3 10 (120Hz) Endurance (85℃) (Applied ripple current) 1000 hours The initial specified value or less Within ±20% of initial value 150% or less of the initial specified value Test time Leakage current Percentage of capacitance change Tangent of the loss angle Test time : 1000 hours. Other have same as endurance. Voltage application treatment : According to JIS C5101 -1 JIS C5101-1, -4 1998 (IEC 60384-1 1992, -4 1985) Shelf life (85℃) Applicable standards Outline Drawing Unit : mm Printed circuit board snap-in type (Series LAO) Frequency (Hz) Rated voltage (V) 0.9 4.7 5.4 φD+1max. 1 0. 4.0±0.5 1k 10k 20k 0.95 0.95 1 1 1.10 1.16 1.15 1.30 1.15 1.33 ± 10 10 Vent 120 Part numbering system (example : 63V6800µF) LAO L+2max. 50 0.9±0.1 Thickness : 0.8t 1.5±0.1 Markings kings 16 to 50 63 to 100 Lug terminal details 2−φ2 Sleeve Coefficient of Frequency for Rated Ripple Current Position of PC board holes (‒)Negative terminal indicated by cross notching 2.1 (For 4.0±0.5) ̶ Series code 63 Rated voltage symbol V 682 M Rated capacitance Capacitance symbol tolerance symbol S57 PX # Casing symbol B Optional symbol FOR AUDIO ALUMINUM CAT.No.2015/2016E 176 NOTE : ‌Design, Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. LARGE CAPACITANCE ALUMINUM ELECTROLYTIC LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS FOR AUDIO CAPACITORS FOR AUDIO ® Standard Ratings 16 Rated voltage (V) 25 35 50 63 LAO LAO 80 100 Rated ripple Rated ripple Rated ripple Rated ripple Rated ripple Rated ripple Rated ripple Rated Rated Rated Rated Rated Rated Rated Item capacitance current current current current current current current capacitance capacitance capacitance capacitance capacitance capacitance Case Casing φD×L (mm) symbol (µF) (Arms) (µF) (Arms) (µF) (Arms) (µF) (Arms) (µF) (Arms) (µF) (Arms) (µF) (Arms) 22×20 S21 3300 1.2 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 22×25 S22 4700 1.5 2200 1.0 1500 0.8 1000 0.8 680 0.7 ̶ ̶ ̶ ̶ 22×30 S23 ̶ 3300 1.3 2200 1.3 1500 1.1 1000 0.9 680 0.7 ̶ ̶ 22×35 S24 2.0 4700 1.7 3300 1.7 ̶ ̶ 1500 1.2 1000 1.0 680 0.8 22×40 S25 ̶ ̶ ̶ 22×45 S26 10000 2.7 22×50 S27 ̶ ̶ 25×25 S32 ̶ 3300 1.7 25×30 S33 6800 2.5 4700 2.1 25×35 S34 10000 3.2 25×40 S35 ̶ ̶ 25×45 S36 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 25×50 S37 ̶ ̶ 10000 3.0 6800 2.6 4700 2.4 3300 2.0 2200 2.0 1500 1.8 30×25 S42 6800 2.6 4700 2.2 3300 2.3 2200 1.9 1500 1.6 1000 1.3 680 1.1 30×30 S43 10000 3.3 6800 2.7 4700 2.8 3300 2.4 2200 1.9 1500 1.6 1000 1.4 30×35 S44 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 30×40 S45 ̶ ̶ 10000 3.1 2.7 4700 2.4 3300 2.1 2200 2.1 1500 1.8 30×45 S46 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 30×50 S47 ̶ ̶ ̶ ̶ 10000 3.4 6800 3.1 4700 2.6 3300 2.2 2200 1.8 35×25 S52 10000 3.4 6800 2.8 4700 2.9 3300 2.4 2200 2.0 1500 1.7 1000 1.5 35×30 S53 ̶ ̶ 10000 3.1 6800 2.7 4700 2.5 3300 2.1 2200 2.1 1500 1.8 35×35 S54 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 35×40 S55 ̶ ̶ ̶ ̶ 10000 3.5 6800 3.1 4700 2.6 3300 2.2 2200 1.8 35×45 S56 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 35×50 S57 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 6800 3.3 4700 2.7 ̶ ̶ ̶ 6800 ̶ ̶ 6800 ̶ ̶ 6800 ̶ 2.2 ̶ ̶ 2.7 ̶ 2200 1.5 ̶ ̶ ̶ ̶ ̶ 2.3 ̶ ̶ 2200 1.6 ̶ ̶ ̶ ̶ ̶ 3300 2.0 ̶ ̶ 1500 1.3 1000 1.2 2200 1.7 1500 1.4 1000 1.2 680 1.0 ̶ ̶ 3300 2.2 2200 1.8 1500 1.5 1000 1.2 680 1.1 ̶ 4700 ̶ ̶ 4700 ̶ ̶ 6800 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 2.8 3300 2.3 2200 1.9 1500 1.6 1000 1.4 (Note) Rated ripple current : 85℃, 120Hz. FOR AUDIO ALUMINUM NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 177 CAT.No.2015/2016E
LAO-50V682MS47PX#B 价格&库存
很抱歉,暂时无法提供与“LAO-50V682MS47PX#B”相匹配的价格&库存,您可以联系我们找货
