82340195
    CROUZET(高诺斯)
    MOTOR SYNC AC 0.16W 230V 600RPM
82340195 数据手册
02/11/2015 www.crouzet.com Starting/running torque 2.5 mNm 0.16 watts Part number 82340195 Constant speed dependent on supply frequency Direction of rotation controlled by long-life mechanical anti-return Permanent magnet rotor with 5 pole pairs Toughened shaft turning on two moulded polyamide bearings UL, CSA (class B) Part numbers 82 340 195 Type Type Direction of rotation Voltages/Frequencies 0.16 watts 82 340 0 Anti-clockwise 230 V 50 hz Specifications General characteristics Base speed of motor (rpm) Absorbed power (W) Usable Power (W) Starting/running torque (mNm) Stall torque (mNm) 600 3 0,16 2,5 3,3 Temperature rise (o C) Ambient temperature (°C) 55 Maximum inertial load that can be moved (g.cm2 ) 4,6 Number of offload starts 106 10 Max. reverse rotation angle (o ) Insulation resistance (MΩ) 360 Breakdown voltage (V-50 Hz) Weight (g) Wires length mm (approximately) Protection rating -5 →+60 75 x 103 1800 - 1 s 110 250 IP30 Dimensions (mm) 82 340 0 No Legend 3 fixing holes ØM2 at 120 ° on r=19.5 max. depth 2.4 mm Product adaptations Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Different voltages available Pinion on output shaft Special cable lengths Special connectors Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
82340195 价格&库存
很抱歉,暂时无法提供与“82340195”相匹配的价格&库存,您可以联系我们找货
    • 1+859.05570
    库存:2
