12V DC Motor 251rpm w/Encoder (SKU: FIT0186)
Contents
1 Introduction
2 Specification
3 Encoder Diagram
4 Encoder Sample Code
Introduction
This is a Gear Motor w/Encoder, model No.GB37Y3530-12V-251R. It is a powerful 12V motor with a
43.7:1 metal gearbox and an integrated quadrature encoder that provides a resolution of 64 counts
per revolution of the motor shaft, which corresponds to 2797 counts per revolution of the gearbox’s
output shaft. These units have a 0.61" long, 6 mm-diameter D- shaped output shaft. This motor is
intended for use at 12V, though the motor can begin rotating at voltages as low as 1V. The face
plate has six mounting holes evenly spaced around the outer edge threaded for M3 screws. These
mounting holes form a regular hexagon and the centers of neighboring holes are 15.5 mm apart.
This motor is an ideal option for your mobile robot project.
Warning: Do not screw too far into the mounting holes as the screws can hit the gears. Manufacturer
recommends screwing no further than 3mm (1/8") into the screw hole.
Specification
Gear ratio: 43.8:1
No-load speed: 251 + 10% RPM
No-load current: 350 mA
Start Voltage: 1.0 V
Stall Torque: 18 Kg.com
Stall Current: 7 A
Insulation resistance: 20 M Ω
EncoderOperating Voltage: 5 V
Encoder type: Hall
Encoder Resolution: 16CPR(motor shaft)/700CPR(gearbox shaft)
Weight: 205g
Encoder Diagram
====Diagram for UNO====
====Interrupt Port with Different Board====
Notcie:attachInterrupt()
For example,with UNO board, you want to use interrupt port 0(int.0). You should connect digital pin 2
with the board. So, the following code is only used in UNO and Mega2560. If you want to use
Leonardo or Romeo, you should change digital pin 3 instead of digital pin 2.
See the link for detail http://arduino.cc/en/Reference/AttachInterrupt
Encoder Sample Code
//The sample code for driving one way motor encoder
const byte encoder0pinA = 2;//A pin -> the interrupt pin 0
const byte encoder0pinB = 4;//B pin -> the digital pin 4
byte encoder0PinALast;
int duration;//the number of the pulses
boolean Direction;//the rotation direction
void setup()
Serial.begin(57600);//Initialize the serial port
EncoderInit();//Initialize the module
void loop()
Serial.print("Pulse:");
Serial.println(duration);
duration = 0;
delay(100);
void EncoderInit()
Direction = true;//default -> Forward
pinMode(encoder0pinB,INPUT);
attachInterrupt(0, wheelSpeed, CHANGE);
void wheelSpeed()
int Lstate = digitalRead(encoder0pinA);
if((encoder0PinALast == LOW) && Lstate==HIGH)
int val = digitalRead(encoder0pinB);
if(val == LOW && Direction)
Direction = false; //Reverse
else if(val == HIGH && !Direction)
Direction = true;
//Forward
encoder0PinALast = Lstate;
if(!Direction)
else
duration++;
duration--;
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“FIT0186”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+219.434291+28.53250
