ROB-09065
ROB-09065
    SPARKFUNELECTRONICS
    SERVO - GENERIC (SUB-MICRO SIZE)
ROB-09065 数据手册
4 3 1 2 1.2500 [31,75] .9100 [23,114] D mount .1570 [3,988] .1838 [4,668] .1170 [2,972] .0800 [2,032] (mount) .0600 [1,524] C SCALE 2.000 R.3855 [9,792] B 1.1420 [29,007] .5920 [15,037] C SCALE 4.000 .4620 [11,735] .7000 [17,78] .1550 [3,937] Features Voltage: 4.8-6.0 Volts Torque: 16.6/20.8 oz-in. (4.8/6.0V) Speed: 0.15/0.10 sec/60° (4.8/6.0V) Rotation: ~160° Single Top Ball Bearing Nylon Gears 3-Pole Ferrite Motor .1700 [4,318] .7620 [19,355] MATERIAL: Plastic + Metal Here is a simple, low-cost, high quality servo for all your mechatronic needs. This servo is very similar in size and specifications to the Hitec HS-55. This little guy is able to take in 6 volts and deliver 20.8 oz-in. of maximum torque at 0.10 sec/60° This small servo comes with a standard 3 pin power and control cable. A NOTES: 4 B Includes 1x Micro Servo 1x Single Arm Micro Horn 1x Double Arm Micro Horn 1x Four Point Micro Horn 1x Circle Micro Horn 2x 2x8mm Phillips Screw 1.1340 [28,804] This servo is rated for 180° rotation, but in actuality it only hits ~160° .1690 [4,293] D DESCRIPTION: DRAWN BY: .1690 [4,293] DATE: Paul Smith 16 July 2013 CAD APLICATION: Creo Parametric 2.0 3 2 Servo - Small MODEL NAME: https://www.sparkfun.com/products/9065 ROB-09065 A PAGE SIZE C 22 x 17 INCH SCALE: variable UNITS: inch [mm] VER: SHEET 1 / 1 1.0 1
ROB-09065
1. 物料型号:9g A0090,ROB-09065 2. 器件简介: - 描述:Micro Servo,一个小型伺服电机,适用于各种机电一体化需求。 - 特色:低成本,高质量,与Hitec HS-55类似。 3. 引脚分配:标准的3引脚电源和控制电缆。 4. 参数特性: - 电压:4.8-6.0伏特 - 扭矩:4.8伏特时16.6盎司英寸,6.0伏特时20.8盎司英寸 - 速度:4.8伏特时0.15秒/60度,6.0伏特时0.10秒/60度 - 旋转角度:约160度(额定180度) 5. 功能详解: - 包含单顶球轴承,尼龙齿轮,3极铁氧体电机。 - 包含1个单臂微型号角,1个双臂微型号角,1个四点微型号角,1个圆形微型号角。 - 包含2个2x8毫米十字螺丝。 6. 应用信息: - 适用于需要精确控制角度的场合。 - 由于其小型尺寸和高性价比,适合用于小型机器人或模型飞机。 7. 封装信息:塑料+金属伺服电机,尺寸较小。
ROB-09065 价格&库存
很抱歉,暂时无法提供与“ROB-09065”相匹配的价格&库存,您可以联系我们找货
