Single direction synchronous geared motors
➜ 0.5 Nm
3 Watts
Mechanical strength : 0.5 Nm
Constant speed, dependent on supply frequency
Wide range of speeds available
Direction of rotation controlled by long-life mechanical
anti-return device
■ Permanent magnet rotor
Specifications
Type
Voltage / Frequency
Output
Ratios (i)
speed
72 rpm
10
60 rpm
12
48 rpm
24 rpm
30
18 rpm
40
15 rpm
48
14.4 rpm
50
12 rpm
60
9 rpm
80
7.2 rpm
100
6 rpm
120
4.8 rpm
150
3.6 rpm
200
3 rpm
240
2.4 rpm
300
1.2 rpm
600
0.80 rpm
750
0.60 rpm
1200
0.40 rpm
1800
0.30 rpm
2400
0.24 rpm
3000
0.12 rpm
6000
6.00 rph
7200
4.80 rph
9000
3.60 rph
12000
3.00 rph
14400
1.20 rph
36000
0.60 rph
72000
1/10 rph
432000
1/240 rph
864000
General characteristics
Motor
Gearbox
Maximum permitted torque
from gearmotor under
continuous conditions for 1
millions turns of the
gearmotor Nm
Axial load (static) daN
Radial load (static) daN
Absorbed power (W)
Motor output (W)
Maximum temperature rise
(oC)
Ambient temperature (oC)
Weight (g)
Wires length mm
(approximately)
Protection rating
3 Watts
3 Watts
3 Watts
3 Watts
82 344 0
115 V 60 Hz
Counter-clockwise
82 344 0
115 V 60 Hz
Clockwise
82 344 0
220 V 60 Hz
Counter-clockwise
82 344 0
220 V 60 Hz
Clockwise
82 344 0A20072MB
82 344 0A20060MB
82 344 0A20048MB
82 344 0A20024MB
82 344 0A20018MB
82 344 0A20015MB
82 344 0A214.4MB
82 344 0A20012MB
82 344 0A20009MB
82 344 0A207.2MB
82 344 0A20006MB
82 344 0A204.8MB
82 344 0A203.6MB
82 344 0A20003MB
82 344 0A202.4MB
82 344 0A201.2MB
82 344 0A200.8MB
82 344 0A200.6MB
82 344 0A200.4MB
82 344 0A200.3MB
82 344 0A20.24MB
82 344 0A20.12HB
82 344 0A20006HB
82 344 0A204.8HB
82 344 0A203.6HB
82 344 0A20003HB
82 344 0A201.2HB
82 344 0A200.6HB
82 344 0A200.1HB
82 344 0A20.05HB
82 344 0A10072MB
82 344 0A10060MB
82 344 0A10048MB
82 344 0A10024MB
82 344 0A10018MB
82 344 0A10015MB
82 344 0A114.4MB
82 344 0A10012MB
82 344 0A10009MB
82 344 0A107.2MB
82 344 0A10006MB
82 344 0A104.8MB
82 344 0A103.6MB
82 344 0A10003MB
82 344 0A102.4MB
82 344 0A101.2MB
82 344 0A100.8MB
82 344 0A100.6MB
82 344 0A100.4MB
82 344 0A100.3MB
82 344 0A10.24MB
82 344 0A10.12HB
82 344 0A10006HB
82 344 0A104.8HB
82 344 0A103.6HB
82 344 0A10003HB
82 344 0A101.2HB
82 344 0A100.6HB
82 344 0A100.1HB
82 344 0A10.05HB
82 344 0J20072MB
82 344 0J20060MB
82 344 0J20048MB
82 344 0J20024MB
82 344 0J20018MB
82 344 0J20015MB
82 344 0J214.4MB
82 344 0J20012MB
82 344 0J20009MB
82 344 0J207.2MB
82 344 0J20006MB
82 344 0J204.8MB
82 344 0J203.6MB
82 344 0J20003MB
82 344 0J202.4MB
82 344 0J201.2MB
82 344 0J200.8MB
82 344 0J200.6MB
82 344 0J200.4MB
82 344 0J200.3MB
82 344 0J20.24MB
82 344 0J20.12HB
82 344 0J20006HB
82 344 0J204.8HB
82 344 0J203.6HB
82 344 0J20003HB
82 344 0J201.2HB
82 344 0J200.6HB
82 344 0J200.1HB
82 344 0J20.05HB
82 344 0J10072MB
82 344 0J10060MB
82 344 0J10048MB
82 344 0J10024MB
82 344 0J10018MB
82 344 0J10015MB
82 344 0J114.4MB
82 344 0J10012MB
82 344 0J10009MB
82 344 0J107.2MB
82 344 0J10006MB
82 344 0J104.8MB
82 344 0J103.6MB
82 344 0J10003MB
82 344 0J102.4MB
82 344 0J101.2MB
82 344 0J100.8MB
82 344 0J100.6MB
82 344 0J100.4MB
82 344 0J100.3MB
82 344 0J10.24MB
82 344 0J10.12HB
82 344 0J10006HB
82 344 0J104.8HB
82 344 0J103.6HB
82 344 0J10003HB
82 344 0J101.2HB
82 344 0J100.6HB
82 344 0J100.1HB
82 344 0J10.05HB
82 340 0
81 021 0
0.5
82 340 0
81 021 0
0.5
82 340 0
81 021 0
0.5
82 340 0
81 021 0
0.5
1
8
3
0.16
55
1
8
3
0.16
55
1
8
3
0.16
55
1
8
3
0.16
55
-5 ➞ +60
160
250
-5 ➞ +60
160
250
-5 ➞ +60
160
250
-5 ➞ +60
160
250
IP40
IP40
IP40
IP40
Products and specifications subject to change without notice.
Order/Technical Support - Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com
4/84
Products adaptations, available on request
Special supply voltages
Special lead lengths
Special connectors
Special output shafts
Special gearbox ratios
Special gear material
Special output bearings
Special mounting plate
Curves
Graph of torque versus speed 82 344 0
mN.m
500
400
300
200
150
100
80
60
40
30
2
3 4 56
10 15
30
60
B RPM
Dimensions
82 344 0
2
3
1
4
B 2 fixing holes Ø 3.2
C (pushed-in shaft)
D 3.5 across flat
E Fixing clip
4
Options
Shaft 79 200 967
Shaft 79 200 779
Shaft 70 999 421 SP1295-10
1
B (pushed-in shaft ← )
B Across flat
Other information
The speed of a motor powered by a 60 Hz supply is 20 % higher than that of a motor powered by a 50 Hz supply.
4/85
很抱歉,暂时无法提供与“823440A10006HB”相匹配的价格&库存,您可以联系我们找货
