Dcmind Brush motor
Data sheet
Series
89 810 008
89 810
71.4 maxi
2 x M3 at 180°, depth 5 mm and 32mm diameter
2 x holes of 2,75 mm diameter, at 120°, depth 5 mm and 32mm diameter
General characteristics
Motor characteristics at (1)
24 Vdc
At no load - A
Speed
Current
Life (2)
At max efficiency - B
Speed
Torque (4)
Power output
Current
Efficiency
Life (2)
At nominal load - C
Speed
Torque (4)
Power output
Current
Efficiency
Life (2)
Others
Starting torque
Starting current
Max. output power
Winding parameters (1)
Torque constant
rpm
A
h
4 000
0,11
10 000
+-10%
rpm
mNm
W
3 300
30
10
0,6
72
5 000
+-10%
+-10%
mNm
W
A
h
2 920
50
15
1
64
4 000
mNm
A
W
190
3,3
rpm
10 000
50
0,8
17
0,0463
3
1
75
11
2
8
3
340
35
A
h
rpm
mNm
ms
ms
mNm/rpm
mNm
mNm/krpm
gcm²
°/W
mNm
g
dBA
V / Krpm
Resistance
Inductance
Start voltage
Current demagnetization
(magnets at 150 ° C)
Ohms
mH
Volts
A
56
0,056
5,88
7,3
6
0,9
14
+-10%
+-10%
+-10%
+-10%
Generic parameters
Motor for direct current supply
Output shaft with ball bearings
(20mm from front face)
Max. Radial force
Max. axial force(5)
CEI60068-2-1/2
Temperature range
Storage temperature
(1min 2mA 50Hz) CEI60335
Dielectric
CEI60085
Motor insulation
Enameled wire insulation
CEI60068-2-58
Salt spray
CEI60529
Degree of protection
EMC
CEI61000-4-2
Electrostatic Discharge
CEI61000-4-4
Electrical fast transsient / burst test
CEI61000-4-5
Surge test
Radiated emission
Approvals
Designed in accordance with UL
2002/95/CE
ROHS
EC
Designed for medical machines using the standard
Motor parameters (1)
Allowed speed
Rated torque
Electrical time constant
Mechanical time constant
Factor torque / speed
Dry friction
Viscous friction
Rotor inertia
Thermal Resistance
Stator poles
Collector blades
Cogging torque
Weight (g)
Noise level
mNm/A
Volts/(rad/s)
Constant electromotive force
max
100
70
-30 / 70
-40 / 100
500
E (120°C)
F (155°C)
2
65
N
N
°C
°C
Vdc
class
class
severity
IP
3
3
2
B
level
level
level
class
1004
EN60601-1
Values without tolerences, are average production values.
(1) Cold motor, 20 ° C ambient temperature
(2) Continuous cycle, one direction
(3) Continuously rated torque, zero radial and axial loads
(4) Max torque for continuous operation at 20 ° C, decrease this value for higher ambient temperature
(5) Pinion or pulley fitting are done at the Crouzet factory, before final assembly.
3,5
4 000
3
80
60
2 500
2
2 000
1,5
1 500
1
1 000
0,5
500
0,1
0,15
0,2
Torque (Nm)
B (max efficiency)
Power (W)
2,5
3 000
Performance / Motor curves (1)
70
Current (A)
Speed (rpm)
3 500
25
50
15
40
10
30
10
0,1
0,15
0,2
Voltage supply
Efficiency (%)
4 500
24
Vdc
Output data
A
B
C
Speed
rpm
4 000
3 300
2 920
Torque (4)
mNm
50
190
Current
A
0,1
0,6
1,0
3,3
Power output
W
10
15
Efficiency
72
64
D
Torque (Nm)
C (nominal)
Specifications subject to change without notice. Updated february 29, 2012.
Crouzet Automatismes
2 rue du Docteur Abel BP59
26902 Valence CEDEX 9 France
www.crouzet.com
Series 89 810
Curves
很抱歉,暂时无法提供与“89810008”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1875.016921+242.54421
