89830011
    CROUZET(高诺斯)
    MOTORDC89830012V3600RPM
89830011 数据手册
Dcmind Brush motor Data sheet Series 89 830 011 89 830 3,7 103 maxi 4 x M5 at 90°, depth 10mm and 40 mm diameter 4 x holes diam 3.65 at 90°, depth 8mm and 48 mm diameter 4 x M5 at 90°, depth 7mm and 40 mm diameter General characteristics 12 Vdc Motor characteristics at (1) At no load - A Speed Current EMC (55022) Life (2) At max efficiency - B Speed Torque (4) Power output Current Efficiency EMC (55022) Life (2) At nominal load - C Speed Torque (4) Power output Current Efficiency EMC (55022) Life (2) Others Starting torque Starting current Max. output power Winding parameters (1) Torque constant rpm A class h 3 830 0,52 B 20 000 +-10% rpm mNm +-10% h 3 340 90 31,479 3,5 75 B 10 000 rpm mNm W A % class h 2 850 180 54 6,5 69 B 5 000 +-10% mNm A 703 24,0 70 W A % class W mNm/A Volts/(rad/s) Constant electromotive force V / Krpm Resistance Inductance Start voltage Current demagnetization (magnets at 150 ° C) Ohms mH Volts A 30,1 0,030 3,15 0,5 0,38 0,6 120 +-10% +-10% +-10% +-10% Generic parameters Motor for direct current supply Output shaft with ball bearings (20mm from front face) Max. Radial force Max. axial force(5) CEI60068-2-1/2 Temperature range Storage temperature (1min 2mA 50Hz) CEI60335 Dielectric CEI60085 Motor insulation Enameled wire insulation CEI60068-2-58 Salt spray CEI60529 Degree of protection EMC CEI61000-4-2 Electrostatic Discharge CEI61000-4-4 Electrical fast transsient / burst test CEI61000-4-5 Surge test Radiated emission 150 100 -30 / 70 -40 / 100 500 E (120°C) F (155°C) 2 65 N N °C °C Vdc class class severity IP 3 3 2 B level level level class Motor parameters (1) Allowed speed Rated torque Electrical time constant Mechanical time constant Factor torque / speed Dry friction Viscous friction Rotor inertia Thermal Resistance Stator poles Collector blades Cogging torque Weight (g) Noise level 10 000 max 180 0,8 21 0,18367 7 1,5 380 4 2 12 9 1 200 35 rpm mNm ms ms mNm/rpm mNm mNm/krpm gcm² °/W mNm g dBA Approvals Designed in accordance with UL 2002/95/CE ROHS EC Designed for medical machines using the standard 1004 EN60601-1 Values without tolerences, are average production values. (1) Cold motor, 20 ° C ambient temperature (2) Continuous cycle, one direction (3) Continuously rated torque, zero radial and axial loads (4) Max torque for continuous operation at 20 ° C, decrease this value for higher ambient temperature (5) Pinion or pulley fitting are done at the Crouzet factory, before final assembly. 3 000 80 80 25 70 70 60 60 50 50 40 40 30 30 20 20 10 10 20 2 500 15 2 000 1 500 10 1 000 5 500 0 0 0 0,2 0,4 0,6 0,8 0 0,2 0,4 0,6 0,8 12 Vdc Output data A B C D Speed rpm 3 830 3 340 2 850 0 Torque (4) mNm 0 90 180 703 Current A 0,5 3,5 6,5 24,0 Power output W - 31 54 - Efficiency % - 75 69 - Torque (Nm) Torque (Nm) B (max efficiency) 0 0 Performance / Motor curves (1) Voltage supply Efficiency (%) Speed (rpm) 3 500 30 Power (W) 4 000 Current (A) 4 500 C (nominal) Specifications subject to change without notice. Updated february 29, 2012. Crouzet Automatismes 2 rue du Docteur Abel BP59 26902 Valence CEDEX 9 France www.crouzet.com Series 89 830 Curves
89830011 价格&库存
很抱歉,暂时无法提供与“89830011”相匹配的价格&库存,您可以联系我们找货
