02/11/2015
www.crouzet.com
Starting/running torque from 30 and 37.5 mN.m 3.5 Watts Part number 82520014
Constant speed, dependent on supply frequency
Direction of rotation controlled by dephasing capacitor
Sintered bearing lubricated for life
Silent operation
UL, CSA (classe B)
Part numbers
82 520 014
Type
Type
Voltages/Frequencies
3.5 Watts
82 520 0
230-240 V 50 Hz
Specifications
Base speed of motor (rpm)
Absorbed power (W)
Usable Power (W)
Starting/running torque (mNm)
Stall torque (mNm)
250
3,5
0,98
37,5
42
Temperature rise (o C)
Ambient temperature (°C)
55
Maximum inertial load that can be moved (g.cm2 )
Number of offload starts
Insulation resistance (MΩ)
33
Breakdown voltage (V-50 Hz)
Weight (g)
Wires length mm (approximately)
Protection rating
-10+75
75x103
1800 -1 sec.
210
250
IP40
Accessories
μF
Capacitors motor 82 520 0
Condensateur
V AC
Code
230-240 V - 50 Hz
0,1 ± 10 %
500
26 231 941
115 V 60 Hz
0,33 ± 10 %
240
26 231 801
24 V - 50 Hz
8,2 ± 10 %
63
26 231 711
Dimensions (mm)
82 520 0
Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
02/11/2015
No
www.crouzet.com
Legend
2 oblong fixing holes 3.5 wide
Connections
In parallel
Motors 82 520 0 - 82 520 4
No
Legend
SA : Clockwise
SI : Anti-clockwise
Product adaptations
Different voltages available
Pinion on output shaft
Special output shafts
Special supply voltages
Special cable lengths
Special output bearings
Special mounting plate
Special connectors
很抱歉,暂时无法提供与“82520014”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+857.00072
- 5+769.89284
- 10+708.30141
