80140511
80140511
    CROUZET(高诺斯)
    MOTOR55WEFFETSHALLS(5000RPM
80140511 数据手册
02/11/2015 www.crouzet.com 57 square - 225 mNm continuous with Hall effect sensors 60 W nominal at 24 V and 3000 rpm Part number 80140511 High power motors (up to 95 W continuous at 24 VDC) Suitable for voltages between 6 and 75 VDC Ideal for applications where the control electronics have to be off centre due to the high ambient temperature Temperature probe built into the motor Part numbers 80140511 Type Type References 60 W nominal at 24 V and 3000 rpm 801405 Without option Specifications General characteristics Max. speed (rpm) Torque peak in (mNm) Maximum continuous torque (mNm) 10000 475* 215** Motor constant (mNm/W1/2) Electrical time constant (ms) Mechanical time constant (ms) Energy losses at peak torque (W) Torque/speed factor - zero impedance (mNm/ (rad/s) ) 57 Rotor inertia (gcm2) Thermal resistance (°C/W) 50 Max. coil temperature (oC) Integrated temperature sensor Number of phases Number of poles Ambient operating temperature (°C) Dielectric strength at 500 V DC (MΩ) Service life (h) Output ball bearing Weight (g) Length (mm) Protection index 120 2 1,7 77 2,9 5,7 Yes 3 (delta config) 4 -40 →70 1000 20000 Yes 900 73 IP54 Comments Standard winding Phase-to-phase resistance (Ω) Voltage at peak torque (V) Current at peak torque (A) Torque constant (mNm/A) Back EMF constant (V/ (rad/s) ) Back EMF constant (V/Krpm) Inductance (mH) 1,03 ±12,5 % 8,9 8,7 54,8 ±10 % 0,0548 5,7 ±10 % 2,1 ±30 % Dimensions (mm) 801405 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 No www.crouzet.com Legend 4 holes M5 over Ø 40 mm - depth of thread : 4.5 mm - depth of hole 6.6 mm D : Ø6 - 0.010 - 0.020 mm L : 73.2 mm max. Curves Power/Power supply No Legend Nominal power Supply voltage Speeds (rpm) Connections Forward No Legend Winding Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Connections Reverse No Legend Winding Connections Part number 801405 Hall effect : Voltage range : 4.5 24 VDC Max. current : 20 mA Type of output : NPN open collector Not protected against connection errors Connections Part number 801405 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Hall effect : Voltage range : 4.5 24 VDC Max. current : 20 mA Type of output : NPN open collector Not protected against connection errors Other information For other standard windings visit www.crouzet.com Precautions for use Not protected against connection errors Product adaptations Special shafts Lead length A single cable instead of two C12 connector built in 200, 500, 1000 points/revolution encoder Shorter motor Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Crouzet: 80140511
80140511 价格&库存
很抱歉,暂时无法提供与“80140511”相匹配的价格&库存,您可以联系我们找货
