Memory Metal Actuator - NM70R (2P)
SKU: FIT0258
INTRODUCTION
Shape Memory metals that were developed by NASA for the space industry, and have been used for increasing applications
down on earth.For example,there have been limited studies on using these materials in robotics. They make it possible to create
very light robots.
Tiny, silent, and lightweight at just 4.2 grams, NanoMuscle Rotary shape memory alloy actuators provide 60°of rotation using a
linear NM70-Super memory metal actuator encapsulated in a body with a spring-loaded, cam-action rotary output. The
NanoMuscle Rotary actuators come in two different versions: the 2-pin NM70R-2P, and the 6-pin NM70R-6P. The -2P actuator
‘bounces’ between limit stops when connected to a power source, and the -6P provides greater control, with access to end limit
sensors, and can be driven by the MADv5 (sold separately). Operating voltages are ~3-9V. Refer to the Downloads page for
additional details.
APPLICATIONS
o
o
Automotive
Bi-directional grill louver mechanism
Fuel tank door release mechanism
o
o
o
o
o
o
o
o
o
o
Trunk, glove compartment release mechanism
Consumer
Memory card ejector
Electronic latch release
Security doors and locks
Biometric sensor assist
Hobby/Miscellaneous
Grasping device
Undersea Core Sampling Robot
Point Of Use sale items
Latch release for ROVs
Pneumatic actuator replacement
SPECIFICATION
Operating voltages: 3-9v
Rotation up to 60 degrees in either direction
2 pin version gives you direct on/off control
Simply apply 3-6V at 350mA and the rotary will turn
Size: 50x10x15mm (1.97x0.39x0.59")
Weight: 4.2g
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“FIT0258”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+91.363821+11.87982
