Mo
Advanced Miniature Motion
RS-70-CE 1131 Rotary Actuator
System Includes
• Bidirectional
o
60 rotary
actuator
overstrain/abuse
protection
• End-stop indicator
• Position feedback (for
optional position control)
• Built-in
Benefits
• Silent
operation
size
• Integrated direct-drive
design
• No gearbox or clutch
required
• Miniature
Applications
• Moving
eyes for dolls and
plush toys
• Lip-sync for moving mouths
• Creature animation and
articulation
• Controlled movement of
latches and levers
The best way to evaluate
NanoMuscle actuators is by
purchasing our Toy
Development Kit. Order
yours today!
Contact Information:
NanoMuscle, Inc.
2545 West 10th St.
Suite A
Antioch, CA 94509
Office: 925-776-4700
Sales: 925-776-4726
Fax: 925-755-9572
www.NanoMuscle.com
sales@nanomuscle.com
1101131 Rev B
The NanoMuscle RS-70-CE 1131 is a
bidirectional rotary motion actuator that
rotates up to 60 to provide smooth, silent
movement in a miniature package. It is a
complete motion solution. Unlike regular
motors, the actuator is an integrated design
for direct drive. There is no gearbox or
clutch necessary, which saves cost, reduces
space required, and simplifies product
design.
o
With a minimum of external components,
the actuator can provide a simple rotate,
hold, and return motion. Position and speed
control can be obtained by using the pulse
width modulated (PWM) output available
on virtually all inexpensive 4-bit or
8-bit speech ICs, LCD controllers, and
other general-purpose microprocessors.
Please refer to the RS series actuator user
guide for more details.
External Dimensions
Performance
Torque: A unique feature of the
NanoMuscle rotary actuator is that it provides constant torque of 12.2 g-cm in both
directions, for a full range of smooth
motion.
Speed: A full, clockwise 0!"! 60º rotation
with 3.0V applied takes a minimum of
300 ms, while the counter-clockwise
(60!"! 0º return) requires no power applied
and takes a minimum of 600 ms. Faster
rotate speeds are possible with higher
voltage applied. Speed control and/or
symmetry of motion can be achieved via
software running on an inexpensive
microprocessor as mentioned above.
Electrical Specifications
!# Operating voltage range: 2.5 – 6.4V
!# Nominal voltage range: 4.5 – 6.0V
!# Hold current for full-rated torque:
68 mA (@4.5V), 52 mA (@6.0V)
# Battery life: performing a continuous
test using alkaline batteries, holding
the shaft at full-rated torque and
moving to a new position every 4
seconds
- 3 AA cells will last 18.8 hours
- 2 AA cells will last 12.5 hours
- 3 AAA cells will last 9 hours
The lower limit of battery life is when the
battery voltage drops to 2.5V.
This is a preliminary engineering release. The information contained herein is believed to be correct at time of printing, but the company
reserves the right to change any specification without prior notice. The intellectual property described in this data sheet is covered by
很抱歉,暂时无法提供与“FIT0257”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+87.907851+11.42774
