HR-3UWX
HR-3UWX
    FDK
    BATT NIMH 1.2V AA 2.4AH
HR-3UWX 数据手册
Cell Type HR-3UWX Specifications Type : Nickel-Metal Hydride Battery Size : AA Consumer Type Typical 2500mAh Minimum 2400mAh Capacity 1) 14.50 mm Nominal Voltage 1.2V Charging Current x Time 50.4 mm Ambient Temp. 2500mA × 1.1h Fast Charge 2) Charge Fast Charge 2) Condition 0°C - 40°C Discharge Condition 0°C - 50°C Less than Storage 90days Condition Less than 1year -20°C - 40°C -20°C - 30°C Internal Impedance 3) (after discharge to E.V.=1.0V) Approx. 25mΩ(at 1000Hz) Weight 4) Approx.30g Size 4) :(Diameter) x (Height) Dimensions (with tube) D 14.50 mm H 50.4 mm 14.5(D) x 50.4(H) mm 1)Single cell capacity under the following condition. Charge : 250mA×16h, Discharge : 500mA(E.V.=1.0V) at 20°C 2)Use recommended charging system. 3)After a few charge and discharge cycles under the above 1) condition. 4)With tube. Typical Characteristics Charge Discharge 1.6 1.8 0°C 25°C 40°C 1.6 1.5 1.4 1.3 Charge : 2500mA (-DV=10mV) Ambient Temp. : 0°C,25°C,40°C 1.2 Charge : 2500 mA (-DV=10mV) Rest : 1h Discharge : 500mA,2500mA,5000mA (E.V.=1.0V) Ambient Temp. : 25°C 1.5 Cell Voltage (V) Cell Voltage (V) 1.7 1.4 1.3 1.2 1.1 500mA 2500mA 1.0 1.1 1.0 5000mA 0.9 0 10 20 30 40 50 60 Charge Time (min) 70 80 0 500 1000 1500 2000 2500 Discharge Capacity (mAh) 2012/11
HR-3UWX 价格&库存
很抱歉,暂时无法提供与“HR-3UWX”相匹配的价格&库存,您可以联系我们找货
