HR-AUC
HR-AUC
    FDK
    BATT NIMH 1.2V A 1900MAH
HR-AUC 数据手册
Cell Type HR-AUC Specifications Type : Nickel-Metal Hydride Battery Size : A Typical 2100mAh Minimum 1900mAh Capacity 1) 17.0 mm Nominal Voltage 1.2V Charging Current x Time 50.0 mm Fast Charge 2) 2100 mA x about 1.1h Charge Fast Charge 2) Condition 0°C - 40°C Discharge Condition 0°C - 50°C Less than 30days -20°C - 50°C Storage Less than Condition 90days -20°C - 40°C Less than 1year -20°C - 30°C Ambient Temp. Internal Impedance 3) (after discharge to E.V.=1.0V) About 20mΩ(at 1000Hz) Weight 4) About 40 g Size 4) :(Diameter) x (Height) Dimensions (with tube) D 17.0 mm H 50.0 mm 17.0(D) x 50.0(H) mm 1)Single cell capacity under the following condition. Charge : 210mA×16h, Discharge : 420mA(E.V.=1.0V) at 20°C 2)Use recommended charging system. 3)After a few charge and discharge cycles under the above 1) condition. 4)With tube. Typical Characteristics Discharge 1.8 1.6 1.7 1.5 0°C 20°C 1.6 Cell Voltage (V) Cell Voltage (V) Charge 1.5 40°C 1.4 1.3 1.2 Charge : 2100mA (-∆V=10mV) Ambient Temp. : 0°C,20°C,40°C 1.1 Charge : 210mA x 16h Rest : 1h Discharge : 420mA, 2100mA, 4200mA (E.V.=1.0V) Ambient Temp. : 20°C 1.4 420mA 1.3 1.2 1.1 2100mA 4200mA 1.0 1.0 0 10 20 30 40 50 60 Charge Time (min) 70 80 0.9 0 500 1000 1500 2000 Discharge Capacity (mAh) 2500
HR-AUC 价格&库存
很抱歉,暂时无法提供与“HR-AUC”相匹配的价格&库存,您可以联系我们找货
