DFR0208
DFR0208
    DFROBOT
    LITHIUMBATTERYCHARGER
DFR0208 数据手册
    Lithium Battery Charger SKU: DFR0208 INTRODUCTION If you need to charge LiPo batteries, this simple charger will do just that, and do it fast! The Lithium Battery Charger can charge 3.7V LiPo battery at a rate of 500mA per hour. It is designed to charge single-cell Li-Ion or Li-Polymer batteries. Check the datasheet below to see if it will work with your battery. The board incorporates a charging circuit, status LED, connector for your battery (JST-type used in the batteries we carry), and a micro-USB connector. Four small mounting holes allows this charger to be easily embedded into a project. SPECIFICATION     o o   Programmable Charge Current:Up to 1000mA Constant-Current/Constant-Voltage Types of battery:Single-cell Li-Ion or Li-Polymer batteries Interface Charge from Micro USB JST-type or terminal connect to battey With ON/OFF switch,3 status LEDs Accuracy:1.5% @ Preset 4.2V Charge Voltage   C/10 Charge Termination  Size:3.2x2.7x1cm(1.26"x1.06"x0.39") Operating Ambient Temperature:-40Ԩ~85Ԩ SHIPPING LIST  Lithium Battery Charge x1 Powered By DFRobot © 2008-2016
DFR0208 价格&库存
很抱歉,暂时无法提供与“DFR0208”相匹配的价格&库存,您可以联系我们找货
DFR0208
    • 1+106.090611+13.14528
    库存:8
    DFR0208
    • 1+105.214801+13.03680
    库存:21
