U280-W01-QC3
U280-W01-QC3
    TRIPPLITE
    1-PORTUSBWALLCHARGERWITHQUI
U280-W01-QC3 数据手册
1-Port USB Wall Charger with Quick Charge 3.0 Technology MODEL NUMBER: U280-W01-QC3 Highlights ● Quick Charge 3.0 Class A 5/9/12V technology ● Built-in auto-sensing technology for non-Quick Charge devices ● Protects against overheating, overcurrent and overcharging ● Compact design fits into backpacks, purses and laptop bags ● Works with any NEMA 1-15R, 515R or 5-15/20R AC outlet Package Includes Fast charger with auto-sensing Quick Charge 3.0 USB-A port charges a single mobile device at a time. Smartphones, tablets and other devices compliant with Quick Charge 3.0 charge up to 4x faster than conventional USB devices. Description The U280-W01-QC3 1-Port USB Wall Charger lets you quickly and safely charge a USB-powered mobile device. Recommended for smartphones, tablets, digital cameras, MP3 players and other USB devices, this wall/travel charger features one QC 3.0 Quick Charge port for rapid charging of QC 3.0-compliant devices—up to four times faster than normal USB charging. The USB-A port features built-in auto-sensing technology that detects the connected device and automatically adjusts to the appropriate power level up to 5V 2.4A, perfect for fast-charging tablets and ereaders. A front LED indicates successful charging. To charge your USB device, simply connect the unit to a NEMA 1-15R, 5-15R or 5-15/20R AC outlet, and connect your device to the available USB port. The unit protects against overheating, overcurrent and overcharging—in fact, it stops charging as soon as your devices’ batteries are at full capacity. Compactly designed for easy carrying in a backpack, purse, suitcase or laptop bag, the U280-W01-QC3 comes with international plug adapters for Europe, Australia and the United Kingdom, so you can use it almost anywhere. The NEMA 1-15P plug folds into the unit to protect it and other items in your bag from damage. Features Charges a Mobile Device at Quick Charge 3.0 Speeds ● Recommended for smartphones, tablets, digital cameras, MP3 players and other USB devices ● Quick Charge 3.0 Class A 5/9/12V technology 1/3 ● U280-W01-QC3 1-Port USB Wall Charger with Quick Charge 3.0 Technology ● (3) International plug adapters (EU, AU, U.K.) ● Quick Start Guide ● QC 3.0-compliant devices charge up to 4x faster than conventional USB charging ● Auto-sensing USB port detects non-Quick Charge device and adjusts to proper power level up to 5V, 2.4A ● Protects against overheating, overcurrent and overcharging ● LED indicates successful charging Convenient Charging Almost Anywhere ● Compact design fits into backpacks, purses and laptop bags ● Works with any NEMA 1-15R, 5-15R or 5-15/20R AC outlet ● European, Australian and U.K. plug adapters included for international power outlets Specifications OVERVIEW UPC Code 037332197405 Product Type Wall Charger Charging Form Factor Direct Plug-In Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC; 240V AC Input Plug Type NEMA 1-15P (NON-POLARIZED) OUTPUT Overload Protection Yes CHARGING Number of Charging Ports 1 Total Charging Amps 3A Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports Details 3.6V~6.5V/3A, 6.5V~9V/2A, 9V~12V/1.5A Charging Ports / Amps 3A / 2A / 1.5A Charging Method Detail Quick Charge 3.0 PHYSICAL Color White Shipping Dimensions (hwd / in.) 1.90 x 4.40 x 6.20 Shipping Dimensions (hwd / cm) 4.83 x 11.18 x 15.75 2/3 Shipping Weight (lbs.) 0.50 Shipping Weight (kg) 0.23 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 176 F (-20 to 80 C) Relative Humidity 5% to 90% RH, Non-Condensing CONNECTIONS Number of Ports 1 Side A - Connector 1 NEMA 1-15P (NON-POLARIZED) Side B - Connector 1 USB A (FEMALE) FEATURES & SPECIFICATIONS Quick Charge Compliant 3.0 Overcurrent Protection Yes Overvoltage Protection Yes GaN Technology No WARRANTY Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U280-W01-QC3 价格&库存
很抱歉,暂时无法提供与“U280-W01-QC3”相匹配的价格&库存,您可以联系我们找货
