U280-005-ST
U280-005-ST
    TRIPPLITE
    5-PORTUSBCHARGINGSTATIONWITH
U280-005-ST 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5-Port USB Charging Station with Built-In Device Storage, 12V 4A (48W) USB Charger Output MODEL NUMBER: U280-005-ST Highlights ● 5V, 2.4A per port for charging battery-intensive devices ● All five ports support USB Battery Charging (BC) specification v1.2 ● 7 adjustable storage brackets for organizing devices ● Storage compartment neatly organizes your cabling ● External dual-voltage power supply with NEMA 1-15P plug ● Protects against overheating, overcurrent and overcharging Package Includes Charges and organizes up to 5 electronic devices at the same time. Storage compartment neatly organizes your excess cabling to reduce clutter when charging, and stores it out of the way when not in use. Recommended for quick-charging and storing tablets, smartphones and other mobile devices. Description Whether you’re at home or in the office, Tripp Lite’s U280-005-ST 5-Port USB Charging Station provides enough ports and power to keep your devices at 100% capacity. No more peering behind furniture to find an available outlet or unplugging one device to charge another. You can charge up to five tablets, smartphones and other devices at the same time. The U280-005-ST doesn’t require a computer, so you can take it anywhere AC power is available. The U280-005-ST features five USB-A ports, each capable of delivering up to 5V, 2.4A, which is enough for charging even battery-intensive devices like the Apple® iPad®. In addition, this charging station doubles as a storage unit by providing space to neatly organize cabling while your devices charge. When not in use, cables can be stored in the compartment and kept out of the way. The included adjustable brackets accommodate the number and size of the devices being charged. To charge your USB devices, simply connect the five-foot power cord’s NEMA 1-15P plug to an AC power outlet, and connect your devices to the available USB ports. The unit protects against overheating, overcurrent and overcharging—in fact, it stops charging as soon as your devices’ batteries are at full capacity. Also, each port complies with USB Battery Charging (BC) specification v1.2. The brackets and power supply store conveniently in the charging station when not in use. Features Charges Up to 5 Devices at the Same TimeRecommended for charging tablets, smartphones and other devices at home or workFunctions anywhere AC power is available—no computer required Provides Plenty of Juice for ChargingDelivers up to 5V, 2.4A per port—enough for charging batteryintensive devices like the Apple iPadProtects against overheating, overcurrent and overchargingComplies with USB Battery Charging (BC) specification v1.2 Efficiently Stores Your Cables / Devices Too7 adjustable brackets provide space to neatly organize devices as they chargeConvenient storage compartment lets you neatly organize your cabling while your devices chargeWhen not in use, cables can be stored in the compartment and kept out of the way Easy to UseExternal dual-voltage power supply with C8 power inlet and detachable C7 to 1-15P 5 ft. cordNo computer required 1/4 ● U280-005-ST 5-Port USB Charging Station ● (7) Storage brackets ● External power supply (Input: 100–240V, 50/60 Hz, 1.5A; Output: 12V, 4A) ● C7 to NEMA 1-15P power cord, 5 ft. ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332199584 Product Type Charging Station Charging Form Factor Charging Hub Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC; 230V AC Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Plug Type NEMA 1-15P (NON-POLARIZED) OUTPUT Overload Protection Yes POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.5A External Power Supply Output Specs (V / A) 12V / 4A External Power Supply Cord Length (m.) 1 AC Adapter Input: 100-240V, 50/60Hz, 1.5A; Output: 12V, 4A DC Barrel Plug OD: 5.5 x 2.5 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 12.7 Power Consumption Detail 12.7W (Operating) 0.23W (Standby) USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power) CHARGING Number of Charging Ports 5 Total Charging Amps 4A Total Charging Watts 48 Charging Method USB Charging Port Type (5) USB A (FEMALE) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Ports Details USB-A: 12V/4A Charging Ports / Amps (5) 2.4A Charging Method Detail 5V - 1.5A (7W) PHYSICAL Color Black Material of Construction Polycarbonate Shipping Dimensions (hwd / in.) 2.70 x 6.00 x 10.10 Shipping Dimensions (hwd / cm) 6.86 x 15.24 x 25.65 Shipping Weight (lbs.) 2.05 Shipping Weight (kg) 0.93 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2 x 16.8 x 12.4 Unit Packaging Type Box Unit Weight (lbs.) 1.3 Unit Weight (kg) 0.59 ENVIRONMENTAL Operating Temperature Range 41 to 95 F (5 to 35 C) Storage Temperature Range -4 to 122 F (-20 to 50 C) Relative Humidity 20% to 80% RH, Non-Condensing CONNECTIONS Number of Ports 5 Side A - Connector 1 NEMA 1-15P (NON-POLARIZED) Side B - Connector 1 (5) USB A (FEMALE) FEATURES & SPECIFICATIONS IP68 Rated No Overcurrent Protection Yes Overvoltage Protection Yes GaN Technology No IP20 Rated No STANDARDS & COMPLIANCE External Power Supply Certifications CCC; FCC; GS; PSE; RoHS; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U280-005-ST 价格&库存
很抱歉,暂时无法提供与“U280-005-ST”相匹配的价格&库存,您可以联系我们找货
U280-005-ST
  • 1+784.537071+101.14197
