U280-004-OTG
U280-004-OTG
    TRIPPLITE
    Battery Charger Cell phone 5V 1A, 2A
U280-004-OTG 数据手册
4-Port USB Charging Station with OTG Hub - 5V 6A / 30W USB Charger Output MODEL NUMBER: U280-004-OTG Highlights ● Charge up to 4 tablets, phones, or other mobile devices ● Features two 5V, 2A ports and two 5V, 1A ports ● Doubles as a USB OTG Hub; connect up to four USB devices (flash drive, mouse, keyboard, etc.) to your OTG compatible tablet or phone ● All four ports are USB Battery Charging (BC) specification v1.2 compliant. Supports iPad; iPhone; Samsung Galaxy (Tab, Phone, and Note); Microsoft Surface; etc. ● Sleek, compact design keeps charging area neat and clutter free ● Input: 100-240V, 50/60Hz, 1.0A / Output: 5V 6A Package Includes Description Tired of searching for wall outlets or swapping out one device to charge another? Tripp Lite's U280-004- ● U280-004-OTG ● Micro-USB OTG Cable - 2.6-ft. ● C7 to NEMA 1-15P Power Cord - 3.9-ft. ● Quick Start Guide OTG Charging hub with OTG is the solution, featuring four ports for charging tablets, phones, or other mobile devices, all at the same time. It provides a single location to charge multiple devices, and its sleek, compact design keeps your charging area neat and clutter free. It features two 5V, 2A ports and two 5V, 1A ports, providing up to 6A for charging the connected devices. Furthermore, it comes with an internal power supply, eliminating the need to fumble around with bulky power adapters. When not being used for charging, it doubles as a USB OTG hub. Simply connect your OTG compatible tablet or phone to the dedicated port on the hub, and then connect up to four USB devices (flash drive, mouse, keyboard, etc.). You can now use those devices on your tablet or phone. So whether you're at home or in the office, our Charging Hub with OTG provides an ideal solution for charging your devices or expanding the functionality of your OTG compatible tablet or phone. Input: 100-240V, 50/60Hz, 1.0A / Output: 5V 6A Features ● Features four ports for charging tablets, phones, or other mobile devices in a single location ● Includes two 5V, 2A ports and two 5V, 1A ports ● Doubles as a USB OTG Hub when not being used for charging; connect up to four USB devices (flash drive, mouse, keyboard, etc.) to your OTG compatible tablet or phone ● All four ports are USB Battery Charging (BC) specification v1.2 compliant. Supports iPad; iPhone; Samsung Galaxy (Tab, Phone, and Note); Microsoft Surface; and more ● Sleek, compact design keeps charging area neat and clutter free ● Features Over-Temperature and Over-Current detection and protection ● Internal power supply eliminates the need to fumble around with bulky power adapters ● Input: 100-240V, 50/60Hz, 1.0A / Output: 5V 6A ● P059-006 (EU) and P061-006 (UK) power cords (sold separately) available for international use 1/3 Specifications OVERVIEW UPC Code 037332182937 Product Type Plug in Charger Charging Form Factor Charging Hub Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC; 230V AC Plug Type C7 to NEMA 1-15P Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Input Plug Type NEMA 1-15P (NON-POLARIZED) Input Current 120V (0.8A) / 230V (0.4A) OUTPUT Output Capacity 5V 6A Overload Protection Yes POWER Power Consumption (Watts) 37.7 Power Consumption Detail 37.7W (Operating) 0.07W (Standby) USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power) CHARGING Number of Charging Ports 4 Total Charging Amps 6A Total Charging Watts 30 Charging Method USB Charging Port Type (4) USB A (FEMALE) Charging Ports / Amps (2) 1A; (2) 2A Charging Method Detail 5V - 1.5A (7W) PHYSICAL 2/3 Color White Material of Construction Polycarbonate Shipping Dimensions (hwd / in.) 2.20 x 9.50 x 6.00 Shipping Dimensions (hwd / cm) 5.59 x 24.13 x 15.24 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 Unit Dimensions (hwd / in.) 1.200 x 4.100 x 3.900 Unit Dimensions (hwd / cm) 3.05 x 10.414 x 9.91 Unit Packaging Type Box Unit Weight (lbs.) 0.45 Unit Weight (kg) 0.20 ENVIRONMENTAL Operating Temperature Range 41 to 95 F (5 to 35 C) Storage Temperature Range -4 to 122 F (-20 to 50 C) Relative Humidity 20% to 80% RH, Non-Condensing CONNECTIONS Number of Ports 5 Side A - Connector 1 NEMA 1-15P (NON-POLARIZED) Side A - Connector 2 USB A (FEMALE) Side B - Connector 1 (4) USB A (FEMALE) FEATURES & SPECIFICATIONS Overcurrent Protection Yes Overvoltage Protection Yes GaN Technology No WARRANTY Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U280-004-OTG 价格&库存
很抱歉,暂时无法提供与“U280-004-OTG”相匹配的价格&库存,您可以联系我们找货
