1000 Eaton Boulevard
Cleveland, OH 44122
United States
4-Port USB-C Charger, 72W, 1x USB-C PD Port
(60W) and 3x USB-A Auto-sensing ports
MODEL NUMBER: U280-004-WS3C1
Highlights
USB-A auto-sensing ports each
support up to 5V, 2.4A for
charging
USB-C port supports up to 20V,
3A for charging
Internal dual-voltage power
supply with NEMA 1-15P plug
Protects against overheating,
overcurrent and overcharging
No computer required
System Requirements
The U280-004-WS3C1 includes
a C7 to 1-15P power cord for
use in 120V applications. An
applicable 230V power cord can
be purchased separately for use
in 230V applications.
Package Includes
Charges up to 4 electronic devices at the same time via USB connection. Recommended for charging
mobile devices ranging from smartphones and tablets to larger power consumers, such as MacBooks and
Chromebook Pixels.
Description
Whether you’re at home or in the office, Tripp Lite’s U280-004-WS3C1 4-Port USB Charging Station
provides enough ports and power to keep your devices at 100% capacity. No more peering behind
furniture to find an available outlet or unplugging one device to charge another. You can charge up to four
tablets, cell phones, laptops and other devices at the same time. The U280-004-WS3C1 doesn’t require a
computer, so you can take it anywhere AC power is available.
The U280-004-WS3C1 features three auto-sensing USB-A ports, each capable of delivering up to 5V,
2.4A, which is enough for charging cell phones, tablets and other mobile devices. Each USB-A port
senses the connected device and automatically adjusts the required power level accordingly. A USB-C
port supports power output up to 20V, 3A for charging more battery-intensive USB power delivery devices,
such as a MacBook®, MacBook Pro® or Chromebook Pixel™.
To charge your USB devices, simply connect the detachable four-foot power cord’s NEMA 1-15P plug to
an AC power outlet, and connect your devices to the available USB ports. The unit protects against
overheating, overcurrent and overcharging—in fact, it stops charging as soon as your devices’ batteries
are at full capacity.
USB Type-C™ and USB-C™ are trademarks of USB Implementers Forum
Features
Charges Up to 4 Devices at the Same Time
● Recommended for charging tablets, cell phones, laptops and other devices at home or office
Functions anywhere AC power is available—no computer required
Provides Plenty of Juice for Charging
● USB-A auto-sensing ports each support up to 5V, 2.4A for charging
Senses connected USB-A devices and automatically adjusts required power level
USB-C port supports up to 20V, 3A for charging more battery-intensive devices, such as laptops
Protects against overheating, overcurrent and overcharging
1/4
Charging Station
C7 to NEMA 1-15P power cord,
4 ft.
Quick Start Guide
Cleveland, OH 44122
United States
Easy to Use
● Internal dual-voltage power supply with NEMA 1-15P plug and detachable 4 ft. cord
Specifications
OVERVIEW
UPC Code
037332196507
Product Type
Plug in Charger
Charging Form Factor
Charging Hub
Device Compatibility
Phone; Tablet; Amazon Kindle
INPUT
Nominal Input Voltage(s) Supported
120V AC; 230V AC
Input Connection Type
IEC C7
Plug Type
C7 to NEMA 1-5P
Voltage Compatibility (VAC)
100; 110; 120; 125; 127; 200; 208; 220; 230; 240
Input Frequency
50/60Hz
Input Plug Type
NEMA 1-15P (NON-POLARIZED)
Input Current
5V (2.4A) / 20V (3A)
OUTPUT
Overload Protection
Yes
POWER
Power Consumption (Watts)
72
USB Power Delivery (PD) Charging
Support
Yes
Specification
3.0
CHARGING
Number of Charging Ports
4
Total Charging Amps
5.4A
Total Charging Watts
72
Charging Method
USB
Charging Port Type
(3) USB A (FEMALE); USB C (FEMALE)
Charging Ports Details
USB-C: 20V 3A (60W), PD 3.0USB-A: 5V 2.4A (12W)
2/4
Cleveland, OH 44122
United States
Charging Ports / Amps
(3) 2.4A; (1) 3A / 2A / 1.5A
Overcharge Protection
Yes
PHYSICAL
Color
Black
Material of Construction
Polycarbonate
Shipping Dimensions (hwd / in.)
1.60 x 6.40 x 5.10
Shipping Dimensions (hwd / cm)
4.06 x 16.26 x 12.95
Shipping Weight (lbs.)
0.80
Shipping Weight (kg)
0.36
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
9.1 x 7.6 x 2.8
Unit Weight (lbs.)
0.49
Unit Weight (kg)
0.22
ENVIRONMENTAL
Operating Temperature Range
32°F to 104°F / 0°C to 40°C
Storage Temperature Range
-4°F to 176°F / -20°C to 80°C
Relative Humidity
5% to 90% RH, NON-CONDENSING
CONNECTIONS
Number of Ports
4
Side A - Connector 1
Side B - Connector 1
(3) USB A (FEMALE)
Side B - Connector 2
USB C (FEMALE)
FEATURES & SPECIFICATIONS
Over Current Protection
Yes
Overcurrent Protection
Yes
Overvoltage Protection
Yes
GaN Technology
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed
Product Compliance
RoHS; CE (Europe); EAC (Belarus, Kazakhstan, Russia); REACH; WEEE; FCC (USA)
WARRANTY & SUPPORT
3/4
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“U280-004-WS3C1”相匹配的价格&库存,您可以联系我们找货
