1000 Eaton Boulevard
Cleveland, OH 44122
United States
16-Port USB Charging Station with Syncing,
230V, 5V 40A (200W) USB Charger Output, 2U
Rack-Mount
MODEL NUMBER: U280-016-RMINT
Highlights
Maximum charge output of 2.4A
per USB port
Supports USB 2.0 data transfer
rates up to 480 Mbps
Syncs any USB device using its
compatible software
Enables future software
upgrades to support newer
devices
Mounts in 2U of EIA-standard
19 in. rack
System Requirements
Tablet, smartphone or other
smart device with USB port
Computer with available USB
port (if syncing)
Package Includes
2U rack-mountable USB charger with integrated hub charges and syncs up to 16 tablets, smartphones
and other mobile devices. Recommended for schools, offices and other environments where multiple USB
devices are used.
Features
Charges Up to 16 Tablets, Smartphones and Other USB Devices
● Recommended for schools, offices and other environments where multiple USB devices are used
Compatible devices include iPad, iPod, iPhone and Android tablets and smartphones
Provides up to 5V, 2.4A (12W) of charging power to each port
LED indicators signal ports in use
Backward compatible with previous USB generations
Supports data transfer rates up to 480 Mbps
Also Syncs Devices via Connected Computer
● Syncs USB devices using its compatible software, such as iTunes or Apple Configurator
Included USB cable connects USB-B port and computer's USB-A port
Mini-USB Firmware Port
● Enables future software upgrades to support newer devices
Easy Installation and Connection
● Mounts in 2U of EIA-standard 19 in. rack using included hardware
Also installs on level surface using included rubber feet
Conveniently configures for professional, educational or personal installation
10-ft. (3.05 m) BS 1363 to C13 and CEE 7/7 to C13 power cords included
Durable steel housing
1/4
U280-016-RMINT 16-Port USB
Charging Station
BS 1363 (U.K.) to C13 power
cord, 10 ft.
CEE 7/7 (Schuko) to C13 power
cord, 10 ft.
USB 2.0 A/B cable, 6 ft.
(4) Rubber mounting feet
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
TAA-Compliant
● Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332193544
Product Type
Multi-Device Charger
Charging Form Factor
Rack Mount
Functions
Charge; Sync
Device Compatibility
Tablet; Phone
Technology
USB 2.0 (High Speed)
Device Slots
16
INPUT
Nominal Input Voltage(s) Supported
230V AC
Input Connection Type
IEC320-C14
Voltage Compatibility (VAC)
230
Input Frequency
50 / 60 Hz
Input Plug Type
C14
Input Cord Length (ft.)
10
Input Cord Length (m)
3.05
Input Current
2.5A
POWER
Power Consumption (Watts)
56
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (16x USB Charging, 1x Sync)
CHARGING
Number of Charging Ports
16
Total Charging Amps
40A
Total Charging Watts
200
Charging Method
USB
Charging Port Type
USB A (FEMALE)
2/4
Cleveland, OH 44122
United States
Charging Ports Details
Pass through
Charging Ports / Amps
(16) 2.4A
Overcharge Protection
Yes
Charging Amps per Port
2.4A
PHYSICAL
Color
Black
Material of Construction
Steel
Shipping Dimensions (hwd / in.)
7.80 x 16.70 x 19.00
Shipping Dimensions (hwd / cm)
19.81 x 42.42 x 48.26
Shipping Weight (lbs.)
15.90
Shipping Weight (kg)
7.21
Unit Dimensions (hwd / in.)
3.410 x 17.300 x 11.880
Unit Dimensions (hwd / mm)
86.7 x 440 x 301.7
Unit Packaging Type
Box
Unit Weight (lbs.)
10.1
Unit Weight (kg)
4.58
Number of Shelves
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
5 to 122 F (-15 to 50 C)
Relative Humidity
5% to 95% RH, Non-Condensing
BTUs
191.1 BTU/Hr (Full load)
CONNECTIONS
Number of Ports
16
Side A - Connector 1
(16) USB A (FEMALE)
Side A - Connector 2
USB B (FEMALE)
Side A - Connector 3
MICRO-USB B (FEMALE)
Side B - Connector 1
IEC-320-C14
FEATURES & SPECIFICATIONS
Cord Management
No
Antimicrobial
No
Driver Required
No
EMI/RFI Line Noise Protection
Yes
3/4
Cleveland, OH 44122
United States
Locking
No
IP68 Rated
No
Built-In Circuit Breaker
Yes
Overcurrent Protection
Yes
Flow-Through Ventilation
Yes
UV Sterilization
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA-C22.2 No. 60950-1 (Canada); IEC 60950-1; NOM (Mexico); UL 60950-1
Product Compliance
RoHS; REACH; FCC Part 15 Class B (USA); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
CATEGORY PAGE FILTERS (Y/N ONLY)
External Receptacle
No
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“U280-016-RMINT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4261.370991+552.35482
