U280-032-RMINT
U280-032-RMINT
    TRIPPLITE
    32-PORTUSBCHARGINGSTATIONWIT
U280-032-RMINT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 32-Port USB Charging Station with Syncing, 230V, 5V 80A (400W) USB Charger Output, 2U Rack-Mount MODEL NUMBER: U280-032-RMINT Highlights ● Maximum charge output of 2.4A per USB port ● Supports USB 2.0 data transfer rates up to 480 Mbps ● Syncs any USB device using its compatible software ● Enables future software upgrades to support newer devices ● Mounts in 2U of EIA-standard 19 in. rack System Requirements ● Tablet, smartphone or other smart device with USB port ● Computer with available USB port (if syncing) Package Includes 2U rack-mountable USB charger with integrated hub charges and syncs up to 32 tablets, smartphones and other mobile devices. Recommended for schools, offices and other environments where multiple USB devices are used. Features Charges Up to 32 Tablets, Smartphones and Other USB Devices ● Recommended for schools, offices and other environments where multiple USB devices are used ● Compatible devices include iPad, iPod, iPhone and Android tablets and smartphones ● Provides up to 5V, 2.4A (12W) of charging power to each port ● LED indicators signal ports in use ● Backward compatible with previous USB generations ● Supports data transfer rates up to 480 Mbps Also Syncs Devices via Connected Computer ● Syncs USB devices using its compatible software, such as iTunes or Apple Configurator ● Included USB cable connects USB-B port and computer's USB-A port Mini-USB Firmware Port ● Enables future software upgrades to support newer devices Easy Installation and Connection ● Mounts in 2U of EIA-standard 19 in. rack using included hardware ● Also installs on level surface using included rubber feet ● Conveniently configures for professional, educational or personal installation ● 10-ft. (3.05 m) BS 1363 to C13 and CEE 7/7 to C13 power cords included ● Durable steel housing 1/4 ● U280-032-RMINT 32-Port USB Charging Station ● BS 1363 (U.K.) to C13 power cord, 10 ft. ● CEE 7/7 (Schuko) to C13 power cord, 10 ft. ● USB 2.0 A/B cable, 6 ft. ● (4) Rubber mounting feet ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States TAA-Compliant ● Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332193537 Product Type Multi-Device Charger Charging Form Factor Rack Mount Functions Charge; Sync Device Compatibility Tablet; Phone Technology USB 2.0 (High Speed) Device Slots 32 INPUT Nominal Input Voltage(s) Supported 230V AC Input Connection Type IEC320-C14 Voltage Compatibility (VAC) 230 Input Frequency 50 / 60 Hz Input Plug Type C14 Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 Input Current 5A POWER Power Consumption (Watts) 112 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (32x USB Charging, 1x Sync) CHARGING Number of Charging Ports 32 Total Charging Amps 80A Total Charging Watts 400 Charging Method USB Charging Port Type USB A (FEMALE) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Ports Details Pass through Charging Ports / Amps (32) 2.4A Overcharge Protection Yes Charging Amps per Port 2.4A PHYSICAL Color Black Material of Construction Steel Shipping Dimensions (hwd / in.) 7.90 x 16.90 x 19.80 Shipping Dimensions (hwd / cm) 20.07 x 42.93 x 50.29 Shipping Weight (lbs.) 18.40 Shipping Weight (kg) 8.35 Unit Dimensions (hwd / in.) 3.410 x 17.300 x 11.880 Unit Dimensions (hwd / mm) 86.7 x 440 x 301.7 Unit Packaging Type Box Unit Weight (lbs.) 13.1 Unit Weight (kg) 5.94 Number of Shelves 0 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Relative Humidity 5% to 95% RH, Non-Condensing AC Mode Efficiency Rating (100% Load) 74.57 BTUs 382.2 BTU/Hr (Full load) CONNECTIONS Number of Ports 32 Side A - Connector 1 (32) USB A (FEMALE) Side A - Connector 2 USB B (FEMALE) Side A - Connector 3 (2) MICRO-USB B (FEMALE) Side B - Connector 1 IEC-320-C14 FEATURES & SPECIFICATIONS Cord Management No Antimicrobial No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Driver Required No EMI/RFI Line Noise Protection Yes Locking No IP68 Rated No Built-In Circuit Breaker Yes Overcurrent Protection Yes Flow-Through Ventilation Yes UV Sterilization No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); IEC 60950-1; NOM (Mexico); UL 60950-1 Product Compliance RoHS; REACH; FCC Part 15 Class B (USA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty CATEGORY PAGE FILTERS (Y/N ONLY) External Receptacle No © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U280-032-RMINT 价格&库存
很抱歉,暂时无法提供与“U280-032-RMINT”相匹配的价格&库存,您可以联系我们找货
