CSC16USB
CSC16USB
    TRIPPLITE
    16-PORTUSBCHARGINGSTATIONCAB
CSC16USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 16-Device USB Charging Station Cabinet with Sync for iPad and Android Tablets, Wall-Mount and Cart Options, Black Highlights ● Fast 2.4A USB charging and syncing for 16 tablets ● Secures devices in locking, vented steel cabinet with cart option ● Protective shelf with removable dividers and cord management ● Supports mounting to wall, desk, table, counter or floor ● Ships fully assembled for quick, easy installation MODEL NUMBER: CSC16USB Package Includes Locking steel cabinet provides 2.4A USB charging, syncing, secure storage and cord management for up to 16 tablets and other devices. Recommended for education, office, commercial, retail, industrial and healthcare environments. Features Fast Charging ● 16 USB ports provide fastest charging supported by each device, up to 2.4A per port ● Recommended for iPad, Android, Surface and Kindle tablets ● Also charges mobile phones and other USB devices ● Fits tablets with cases (up to 16.5 x 10.5 x 1.5 in. with cord) ● 10-ft. (3.05 m) AC input cord with NEMA 5-15P plug reaches distant outlets Convenient Syncing ● USB uplink port connects to host computer for wired syncing ● Supports wireless syncing and simultaneous syncing/charging (up to 1.5A per port during wired syncing) Comprehensive Protection ● Sturdy steel construction and powder-coated finish promote long-term durability ● Doors lock with included keys to help prevent device theft, damage or tampering ● 3-point locking mechanism latches doors at top, middle and bottom ● Built-in hasp and user-supplied padlock can replace or supplement built-in lock ● Rear ports accommodate user-supplied bicycle cable or chain lock ● Flow-through ventilation helps prevent devices from overheating ● Protective shelf specially coated to avoid device scratches and scuffs ● Cord access ports with rubber grommets protect against abrasions ● Solid top work surface helps avoid accidental drips and spills that could damage devices 1/4 ● CSC16USB 16-Device USB Charging Station Cabinet, Black ● (2) Keys ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Clutter-Reducing Organization ● USB ports and charging cords store out of sight ● Shelf includes charging cord access ports for each device ● Toolless trim panel permits quick access to cords Flexible Configuration ● Ships fully assembled for quick, easy installation ● Supports mounting to wall, desk, table, counter or floor ● Split front doors open 180 degrees for improved device and service access ● Removable dividers accommodate thicker devices like battery chargers ● Firmware upgrade port for future updates ● Converts to mobile cart with optional CSHANDLEKIT2 (sold separately) Specifications OVERVIEW UPC Code 037332194640 Product Type Multi-Device Charger Charging Form Factor Stationary Cabinet Functions Charge; Secure; Sync Device Compatibility Tablet Device Slots 16 INPUT Nominal Input Voltage(s) Supported 120V AC Voltage Compatibility (VAC) 110; 120 Input Frequency 50 / 60 Hz (auto-select) Input Plug Type NEMA 5-15P Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 POWER Power Consumption (Watts) 56 CHARGING Number of Charging Ports 16 Total Charging Amps 40A Total Charging Watts 200 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports Details Pass through Charging Ports / Amps (16) 2.4A Overcharge Protection Yes Charging Amps per Port 2.4A PHYSICAL Color Black Material of Construction Steel Charging Station Form Factor Stationary Cabinet Shipping Dimensions (hwd / in.) 24.53 x 23.62 x 33.66 Shipping Dimensions (hwd / cm) 62.31 x 59.99 x 85.50 Shipping Weight (lbs.) 112.00 Shipping Weight (kg) 50.80 Slot Dimensions (hwd / in.) 10.6 x 1.5 x 15.4 Slot Dimensions (hwd / mm) 268.1 x 38.2 x 390.5 Unit Dimensions (hwd / in.) 18.800 x 30.330 x 20.200 Unit Dimensions (hwd / cm) 47.75 x 77.04 x 54.86 Unit Weight (lbs.) 84.66 Unit Weight (kg) 38.40 Number of Shelves 1 FEATURES & SPECIFICATIONS Cord Management Yes Antimicrobial No EMI/RFI Line Noise Protection Yes Locking Yes Lock Type Key IP68 Rated No Built-In Circuit Breaker Yes Overcurrent Protection Yes Flow-Through Ventilation Yes UV Sterilization No IP20 Rated No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL 60950-1 Product Compliance RoHS; CE (Europe); EIA/ECA-310-E; REACH; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty CATEGORY PAGE FILTERS (Y/N ONLY) External Receptacle No © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
CSC16USB 价格&库存
很抱歉,暂时无法提供与“CSC16USB”相匹配的价格&库存,您可以联系我们找货
CSC16USB
    • 1+10448.335021+1351.43281
