CS48USB
CS48USB
    TRIPPLITE
    Battery Charger Notebook 2.4A
CS48USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Multi-Device Charging Station, 48 USB Ports, iPad and Android Tablets, Black MODEL NUMBER: CS48USB Highlights ● Fast 2.4A USB charging, syncing and storage for 48 devices ● Locking steel cabinet with flowthrough ventilation ● Adjustable device dividers and integrated cord management ● Ships fully assembled and mounts to wall, desk, table or floor ● Detachable 10-ft. (3.05 m) power cord Package Includes Locking steel cabinet provides 2.4A USB charging, syncing, secure storage and cord management for up to 48 tablets and other USB devices. Recommended for education, office, commercial, retail, industrial and healthcare environments. Features Fast Charging ● 48 USB ports provide fastest charging supported by each device, up to 2.4A per port ● Recommended for iPad®, Android™, Surface™ and Kindle™ tablets ● Also charges mobile phones and other USB devices ● Detachable 10-ft. (3.05 m) AC input cord with NEMA 5-15P plug Convenient Syncing ● USB sync uplink port connects to host computer for wired syncing ● Compatible with wireless syncing ● Supports simultaneous syncing and charging (up to 1.5A per port during wired syncing) Comprehensive Protection ● Sturdy steel construction and powder-coated finish promote long-term durability ● Doors lock with included keys to help prevent device theft, damage or tampering ● Flow-through ventilation helps prevent devices from overheating ● Coated shelves shield devices from scratches and scuffs Flexible Configuration ● Ships fully assembled ● Supports mounting to wall, desk, table, counter or floor ● Door opens 180 degrees for improved device and service access ● Removable dividers accommodate thicker devices ● Firmware upgrade port for future updates 1/4 ● CS48USB 48-Device USB Charging Station Cabinet, Black ● Detachable 10-ft. (3.05 m) AC input cord w/NEMA 5-15P plug ● (2) Keys ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Converts to mobile cart with optional CSHANDLEKIT accessory (sold separately) Specifications OVERVIEW UPC Code 037332185433 Product Type Multi-Device Charger Charging Form Factor Stationary Cabinet Functions Charge; Secure; Sync Device Compatibility Tablet; Phone Device Slots 48 INPUT Nominal Input Voltage(s) Supported 120V AC; 230V AC Voltage Compatibility (VAC) 110-240 Input Frequency 50 / 60 Hz (auto-select) Input Plug Type NEMA 5-15P Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 POWER Power Consumption (Watts) 224 CHARGING Number of Charging Ports 48 Total Charging Amps 120A Total Charging Watts 600 Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports Details Pass through Charging Ports / Amps (48) 2.4A Overcharge Protection Yes Charging Amps per Port 2.4A PHYSICAL Color Black Material of Construction Steel 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Station Form Factor Stationary Cabinet Shipping Dimensions (hwd / in.) 41.02 x 28.35 x 26.38 Shipping Dimensions (hwd / cm) 104.19 x 72.01 x 67.01 Shipping Weight (lbs.) 183.00 Shipping Weight (kg) 83.01 Slot Dimensions - Bottom (hwd / in.) 8.0 x 0,8 x 13,9 Slot Dimensions - Bottom (hwd / mm) 204 x 20,1 x 353.8 Slot Dimensions - Middle (hwd / in.) 8.0 x 0,8 x 13,9 Slot Dimensions - Middle (hwd / mm) 204 x 20,1 x 353.8 Slot Dimensions - Top (hwd / in.) 8.1 x 0,8 x 13,9 Slot Dimensions - Top (hwd / mm) 206 x 20,1 x 353.8 Unit Dimensions (hwd / in.) 35.630 x 23.620 x 21.570 Unit Dimensions (hwd / cm) 90.42 x 59.9 x 54.86 Unit Weight (lbs.) 150 Unit Weight (kg) 68.04 Number of Shelves 3 FEATURES & SPECIFICATIONS Cord Management Yes Antimicrobial No EMI/RFI Line Noise Protection Yes Locking Yes Lock Type Key IP68 Rated No Built-In Circuit Breaker Yes Overcurrent Protection Yes Flow-Through Ventilation Yes UV Sterilization No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL 60950-1 Product Compliance RoHS; CE (Europe); EIA/ECA-310-E; REACH; FCC Part 15 Class B (USA) WARRANTY & SUPPORT 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 2-year limited warranty CATEGORY PAGE FILTERS (Y/N ONLY) External Receptacle No © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
CS48USB 价格&库存
很抱歉,暂时无法提供与“CS48USB”相匹配的价格&库存,您可以联系我们找货
