BVW122250003N
BVW122250003N
    SLPOWER
    BATTERY CHG UNIV 12VDC @ 2.25A
BVW122250003N 数据手册
BVW Lead Acid Fast Chargers Features • • • • • • • • • • • • 100-240 VAC In Case IEC 320 Automatic Fast/Float Function LED Indicators Charges Lead Acid Batteries Optimizes Battery Life Meets Safety Agency Requirements Complies with EMI-RFI Regulations Impact Resistant Polycarbonate Enclosure Private Label Marking Available 3 Year Warranty Modified and Custom Designs Also Available Ault Model Battery Voltage DC Output Amps Switchover Amps Fast Charge Volts DC Float Charge Volts DC Maximum Watts BVW-06380-0003A BVW-12225-0003A BVW-24125-0003A 6 12 24 3.80 2.25 1.25 0.205 0.165 0.120 7.35 14.70 29.40 6.90 13.80 27.60 28 33 37 Input • Voltage • Line Frequency • Current • Protection • Configuration Electrical • Topology • Dielectric Withstand • Leakage Current • • • • EMI CE MTBF Protection Safety Approvals • Agency Listings 100-250 VAC -10%, +6% 47 - 63 Hz 0.80A - 0.35A (Lower current with higher voltage) Internal primary current fuse Inrush limiting In Case IEC320 with ground Switching - DC battery charger 3000 VAC, 4243 VDC primarysecondary 1500 VAC, 2150 VDC primaryground 500 DC secondary-ground Less than 0.5mA change typical Complies with EMC Directives CE Compliant 100,000 calculated hours Foldback overcurrent. Short circuit protection CSA223; NRTL/C (ANSI/UL1310); TUV TO EN60065 LED Indicators • Indicator #1 (Green) • Indicator #2 Amber) Environment • Operating Temperature • Storage Temperature • Relative Humidity • Altitude • Cooling Mechanical • Case Dimensions • • Case Material Weight • Cords and Connectors On (unit energized) Off (unit de-energized) On (battery discharged) Off (battery charged 5° to 40° C with no derating -30° to +85° C 5% to 95% non-condensing 0-10,000 feet Convectional - non vented case LP7 - Desktop 5.08 L x 3.05 W x 1.59 H (in) 129 L x 77 W x 40 H (mm) Black 94V0 polycarbonate 13 ounces, 370 grams (excluding cord) 6 ft., 2 conductor, 18 AWG, Ault #3 connector. Other connectors are also available. THREE YEAR WARRANTY Ault Incorporated, 7105 Northland Terrace, Minneapolis, MN 55428 Contact Ault Inc. for all your custom design requirements. Phone: 763.592.1900 • Fax 763.592.1911
BVW122250003N 价格&库存
很抱歉,暂时无法提供与“BVW122250003N”相匹配的价格&库存,您可以联系我们找货
