3287
3287
    ADAFRUIT
    CONN ADAPT BNC PLUG TO UHF JACK
3287 数据手册
3 x AA Battery Holder with On/Off Switch, JST, and Belt Clip PRODUCT ID: 3287 Description This battery holder connects 3 AA batteries together in series for powering all kinds of projects. We spec'd these out because the box is compact, and 3 AA's add up to about 3.3-4.5V, a very similar range to Lithium Ion/polymer (Li-Ion) batteries, plus it has a nifty on-off switch. That makes them ideal for use with 3.3V projects that have a 2-pin JST connector meant for one of our Li-Ion/Poly batteries. (Of course, you can't recharge them like Li-Ion/Polys, so don't try to plug this into one of our Li-Ion/Poly charger boards!). It also features an ergonomic belt clip for taking your power on the go! Fits any standard AA battery. When using rechargeable NiMH the output voltage will range from about 3.7V with charged batteries to 2.7V at the end of life with a nominal voltage of 3.6V. When using alkalines, the output will range from 4.5V with new batteries to 3.3V at the end of life with a nominal voltage of about 4.5V. The polarity matches that of our 2-pin JST cable and Li-Ion/Poly batteries. Uses a genuine JST connector so it wont 'catch and tear' in JST connectors. Technical Details Cable Length: 6" long, terminated with a genuine JST-PH 2 pin connector Product Dimensions: 78.0mm x 49.0mm x 29.0mm / 3.1" x 1.9" x 1.1" Product Weight: 32.6g / 1.1oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3287”相匹配的价格&库存,您可以联系我们找货
