Waterproof 3xAA Battery Holder with On/Off
Switch
PRODUCT ID: 771
DESCRIPTION
Keep your power source safe and toasty in these waterproof 3xAA battery holders.
They're just like classic switched battery holders, but designed for survival! The
case has a rubber gasket around the edge of the case (its black and hard to see in
the photos but it is there) and attaches together with 4 machine screws. What we
like about this design is that the hexnuts are captive in one side and you can
assemble/disassemble as many times as you need. There's a potted power switch
and a rubber-boot on-off switch (press to turn on/off). Use with any alkaline or
rechargeable batteries for about 4.5V output.
Would work great with our waterproof DC power plugs (just use heatshrink to
waterproof the solder connections)
The power cable wires are not polarity marked, use any multimeter to verify the
polarity during use.
We also have a 2xAA version when you need a smaller & lighter box
http://www.adafruit.com/product/771
11/12/2015
Technical Details
Weight: 36 grams
2" (2.5" with machine screw ears) x 3" x.8" (50mm (63mm with machine screw ears) x 77mm x
6" (150mm) long power cable
很抱歉,暂时无法提供与“771”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+74.50920
- 200+29.73240
- 500+28.73880
- 1000+28.25280
- 国内价格 香港价格
- 1+37.555231+4.71132
