HR-AAUF2X5
HR-AAUF2X5
    FDK
    BATT PACK 12.0V AA 1500MAH NIMH
HR-AAUF2X5 数据手册
Standard Model HR-AAU Size : AA Data sheet Dimensions Capacity 14.2+0 −0.5 mm Nominal1) 1650 mAh Minimum1) 1500 mAh 1)Single cell capacity under the following condition. Charge : 150 mA × 16 hours, Discharge : 300 mA(E.V.=1.00 V) at 20 °C General Specifications +0 mm 50.0−1.0 Nominal Voltage 1.2 V End Voltage 1.00 V Charging Current x Time Ambient Temp. 1650 mA x about 1.1 hours Fast Charge 2) Charge Fast Charge 2) Condition3) 0 °C ~ +40 °C Discharge Recommended Condition3) 0 °C ~ +50 °C 45 % ~ 85 % Relative Humidity 4) 2)Use recommended charging system. 3)Charge or discharge on outside the recommended temperature range may generate the battery degradation. 4)No water condensation. Storage Conditions Dimensions (including tube) Diameter 14.2 +0/ -0.5 mm Less than 30 days -20 °C ~ +50 °C Height 50.0 +0/ -1.0 mm Ambient Temp. Less than 90 days -20 °C ~ +40 °C Less than 1 year -20 °C ~ +30 °C Approx. Weight (including tube) 27 g Approx. Internal Impedance at 1kHz 20゚C 5) 25 mΩ 5) After 3 cycles of charge and discharge under the conditions of 1), followed by the measurement 1~4 hours later. Nominal Charge Characteristics 1.8 6)No water condensation. Nominal Discharge Characteristics 1.6 Char Char 1.7 0゚C 1.5 25゚C 40゚C 1.4 1.3 1.2 Charge : 1500mA(-ΔV=10mV) Cell Voltage (V) Cell Voltage (V) 1.6 1.5 45 % ~ 85 % Relative Humidity 6) Charge : 1500mA (-ΔV=10mV) Ambient Temp. : 25゚C Rest : 3hours Discharge : 1500mA (E.V.=1.00V) Ambient Temp. : 0, 25, 40゚C 1.4 40゚C 25゚C 0゚C 1.3 1.2 1.1 Ambient Temp. : 0, 25, 40゚C 1.0 1.1 1.0 0.9 lifespan are affected by 0 200 conditions. 400 600 0.0・Battery 0.2performance 0.4 and 0.6 0.8 greatly 1.0 1.2usage and temperature ・Test results vary depending on individual batteries. Charge Time (hours) 800 1000 1200 1400 1600 Discharge Capacity (mAh) ・Single cell performance and lifespan are greatly affected by usage and temperature conditions. ・Test results vary depending on individual cells. ・Each values included in this material are intended to describe performance. They are not guaranteed. ZKH
HR-AAUF2X5 价格&库存
很抱歉,暂时无法提供与“HR-AAUF2X5”相匹配的价格&库存,您可以联系我们找货
