HR-4/5AUL5X2
HR-4/5AUL5X2
    FDK
    BATT PACK 12.0V 4/5A NIMH
HR-4/5AUL5X2 数据手册
Standard Model HR-4/5AU Size : 4/5A Data sheet Dimensions Capacity Nominal1) 2150 mAh Minimum1) 1950 mAh 1)Single cell capacity under the following condition. Charge : 195 mA × 16 h, Discharge : 390 mA(E.V.=1.00 V) at 20 °C +0 mm 17.0−1.0 General Specifications +0 mm 43.0−2.0 Nominal Voltage 1.2 V End Voltage 1.00 V Charging Current x Time Ambient Temp. 2150 mA x about 1.1 hours Fast Charge 2) Charge Fast Charge 2) Condition3) 0 °C ~ +40 °C Discharge Recommended Condition3) 0 °C ~ +50 °C 45 % ~ 85 % Relative Humidity 4) 2)Use recommended charging system. 3)Charge or discharge on outside the recommended temperature range may generate the battery degradation. 4)No water condensation. Storage Conditions Dimensions (including tube) Diameter 17.0 +0/ -1.0 mm Less than 30 days -20 °C ~ +50 °C Height 43.0 +0/ -2.0 mm Ambient Temp. Less than 90 days -20 °C ~ +40 °C Less than 1 year -20 °C ~ +30 °C Approx. Weight (including tube) 33 g Approx. Internal Impedance at 1kHz 20゚C 5) 25 mΩ 5) After 3 cycles of charge and discharge under the conditions of 1), followed by the measurement 1~4 hours later. Nominal Charge Characteristics 1.8 6)No water condensation. Nominal Discharge Characteristics 1.6 Char Char 1.7 0゚C 25゚C 1.5 40゚C 1.4 1.3 1.2 Charge : 1950mA(-ΔV=10mV) Charge :1950mA (-ΔV=10mV) Ambient Temp. : 25゚C Rest : 3hours Discharge :1950mA (E.V.=1.00V) Ambient Temp. : 0, 25, 40゚C 1.4 40゚C 25゚C 0゚C 1.3 1.2 1.1 Ambient Temp. : 0, 25, 40゚C 1.0 1.1 1.0 Cell Voltage (V) Cell Voltage (V) 1.6 1.5 45 % ~ 85 % Relative Humidity 6) 0.9 lifespan are affected by conditions. 0 400 800 0.0・Battery 0.2performance 0.4 and 0.6 0.8 greatly 1.0 1.2usage and temperature ・Test results vary depending on individual batteries. Charge Time (hours) 1200 1600 2000 2400 Discharge Capacity (mAh) ・Single cell performance and lifespan are greatly affected by usage and temperature conditions. ・Test results vary depending on individual cells. ・Each values included in this material are intended to describe performance. They are not guaranteed. ZKH
HR-4/5AUL5X2 价格&库存
很抱歉,暂时无法提供与“HR-4/5AUL5X2”相匹配的价格&库存,您可以联系我们找货
