HR-4/3AU(4.0AH)F10
HR-4/3AU(4.0AH)F10
    FDK
    BATT PACK 12.0V 4/3A NIMH
HR-4/3AU(4.0AH)F10 数据手册
Standard Model HR-4/3AU Size : 4/3A Data sheet Dimensions Capacity Nominal1) 4000 mAh Minimum1) 3600 mAh 1)Single cell capacity under the following condition. Charge : 360 mA × 16 hours, Discharge : 720 mA(E.V.=1.00 V) at 20 °C +0 mm 17.0−1.0 General Specifications +0 mm 67.5−2.0 Nominal Voltage 1.2 V End Voltage 1.00 V Charging Current x Time Ambient Temp. 3000 mA x about 1.4 hours Fast Charge 2) Charge Fast Charge 2) Condition3) 0 °C ~ +40 °C Discharge Recommended Condition3) 0 °C ~ +50 °C 45 % ~ 85 % Relative Humidity 4) 2)Use recommended charging system. 3)Charge or discharge on outside the recommended temperature range may generate the battery degradation. 4)No water condensation. Storage Conditions Dimensions (including tube) Diameter 17.0 +0/ -1.0 mm Less than 30 days -20 °C ~ +50 °C Height 67.5 +0/ -2.0 mm Ambient Temp. Less than 90 days -20 °C ~ +40 °C Less than 1 year -20 °C ~ +30 °C Approx. Weight (including tube) 53 g Approx. Internal Impedance at 1kHz 20゚C 5) 20 mΩ 5) After 3 cycles of charge and discharge under the conditions of 1), followed by the measurement 1~4 hours later. Nominal Charge Characteristics 6)No water condensation. Nominal Discharge Characteristics 1.8 1.6 Char 1.7 Char 0゚C 25゚C 1.5 40゚C Cell Voltage (V) Cell Voltage (V) 1.6 1.5 1.4 1.3 1.2 1.1 1.0 Charge : 3000mA(-ΔV=10mV) Ambient Temp. : 0, 25, 40゚C 45 % ~ 85 % Relative Humidity 6) Charge : 3000mA (-ΔV=10mV) Ambient Temp. : 25゚C Rest : 3hours Discharge : 3600mA (E.V.=1.00V) Ambient Temp. : 0, 25, 40゚C 1.4 40゚C Charge Time (hours) 0゚C 1.2 1.1 1.0 0.9 and lifespan greatly affected by usage and temperature 0.0・Battery 0.2 performance 0.4 0.6 0.8 are1.0 1.2 1.4 0 500 conditions. 1000 1500 ・Test results vary depending on individual batteries. 25゚C 1.3 2000 2500 3000 3500 4000 Discharge Capacity (mAh) ・Single cell performance and lifespan are greatly affected by usage and temperature conditions. ・Test results vary depending on individual cells. ・Each values included in this material are intended to describe performance. They are not guaranteed. ZKH
HR-4/3AU(4.0AH)F10 价格&库存
很抱歉,暂时无法提供与“HR-4/3AU(4.0AH)F10”相匹配的价格&库存,您可以联系我们找货
