EPA060050-S/T-SZ
EPA060050-S/T-SZ
    CUIDEVICES
    AC/AC WALL MOUNT ADAPTER 6V 3W
EPA060050-S/T-SZ 数据手册
Part No: EPA060050-S/T-SZ Date: 5/11/2007 Unit: mm Description: linear power supply Page No: 1 of 7 Specifications Output voltage Rated input voltage Primary rated voltage Primary exciting current Secondary rated voltage & current Temperature rise of primary winding (full load) Insulation resistance HI-POT test Safety standards RoHS compliant No load power consumption Efficiency Test conditions Adapter color Phone: 800.275.4899 6 V ac at 500 mA 120 V ac 120 V ac 60 Hz 5 W 30 mA rms max. no load voltage (max.) 7.5 V ref full load voltage (500 mA) 6 V ±5% 70°C max. using resistance method >= 100 M Ohm at 500 V dc from input to output for 1 min. 1240 V ac at 2 mA from input to output for 1 sec. 1600 V ac at 2 mA from primary to secondary winding for 1 sec. 1600 V ac at 2 mA from primary winding to core for 1 sec. 1600 V ac at 2 mA from secondary winding to core for 1 sec. 750 V ac at 2 mA UL/cUL yes 0.5 W max. Energy Star Compliant - Efficiency Level IV Ambient temp 40°C ±2°C Humidity 90-95% 96 hours at Full Load Rated voltage 8 hours at full load Case black Cord black Fax: 503.612.2383 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Part No: EPA060050-S/T-SZ Date: 5/11/2007 Unit: mm Description: linear power supply Page No: 2 of 7 Label E140898 88Y3 IV 34.3+0/-0.2 FOR VERTICAL OR FLOOR MOUNT USE ONLY EFFICIENCY LEVEL 1.6 MIN AC ADAPTOR CLASS 2 TRANSFORMER INPUT: AC 120V 60Hz 5W OUTPUT : A C 6V 500mA P/N:EPA060050-S/T-SZ Adhesive tape: 3m #44 tape 18 width Thickness: 0.2mm Material: PVC Polyester Color: black on silver base Remarks: YYWW X YY=production year WW=production week X=production location RoHS MODEL : 35A-6-500 EIA 363 YYWW X MADE IN CHINA 24.4+0/-0.2 Phone: 800.275.4899 Fax: 503.612.2383 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Date: 5/11/2007 Part No: EPA060050-S/T-SZ Unit: mm Description: linear power supply Page No: 3 of 7 Mechanical Drawing Tolerance: ±1 Weight Phone: 800.275.4899 Fax: 503.612.2383 www.cui.com 180 g 20050 SW 112th Ave. Tualatin, OR 97062 Part No: EPA060050-S/T-SZ Date: 5/11/2007 Unit: mm Description: linear power supply Page No: 4 of 7 DC Cord Phone: 800.275.4899 Fax: 503.612.2383 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Part No: EPA060050-S/T-SZ Date: 5/11/2007 Unit: mm Description: linear power supply Page No: 5 of 7 Circuit Diagrams Test Diagram Phone: 800.275.4899 Fax: 503.612.2383 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Part No: EPA060050-S/T-SZ Date: 5/11/2007 Unit: mm Description: linear power supply Page No: 6 of 7 Individual Packaging Tolerance: ±1 Phone: 800.275.4899 Fax: 503.612.2383 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Part No: EPA060050-S/T-SZ Date: 5/11/2007 Unit: mm Description: linear power supply Page No: 7 of 7 Packaging Tolerance: +7/-0 Phone: 800.275.4899 Fax: 503.612.2383 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062
EPA060050-S/T-SZ
1. 物料型号: EPA060050-S/T-SZ 2. 器件简介: 这是一个线性电源,符合Energy Star的效率等级IV,并且是RoHS合规的。 3. 引脚分配: 文档中未提供具体的引脚分配信息。 4. 参数特性: - 输出电压: 6V AC 在500mA时 - 额定输入电压: 120V AC - 初级额定电压: 120V AC 60Hz 5W - 初级额定电流: 最大30mA RMS - 次级空载电压(最大): 7.5V - 次级满载电压(500mA): 6V ±5% - 初级绕组温度升高(满载): 最大70°C - 绝缘电阻: ≥100MΩ 在500V DC HI-POT测试下 - 安全标准: UL/cUL 5. 功能详解: - 无负载功耗: 最大0.5W - 效率: 符合Energy Star效率等级IV - 测试条件: 环境温度40°C ±2°C,湿度90-95%,96小时满载测试 6. 应用信息: 文档中未提供具体的应用信息。 7. 封装信息: - 重量: 180g - 尺寸公差: ±1mm - 标签: 使用3M #44胶带,18mm宽,0.2mm厚,材料为PVC聚酯,颜色为黑色底银色字 - 备注: YYWW X 表示生产年份、周和地点
EPA060050-S/T-SZ 价格&库存
很抱歉,暂时无法提供与“EPA060050-S/T-SZ”相匹配的价格&库存,您可以联系我们找货
